Official Sony VPL-VW695ES Owners Thread - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 370Likes
post #511 of 807 Old 04-24-2019, 06:57 PM
markmon1's Avatar
Quoted: 6571 Post(s)
Liked: 4723
Originally Posted by DAK View Post
Comparison between Grayhawk and StudioTek 130:
Hopefully this thread won't devolve into Grayhawk vs. StudioTek nonsense
Craig Peer likes this.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #512 of 807 Old 04-25-2019, 09:46 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7508 Post(s)
Liked: 7539
Originally Posted by DLCPhoto View Post
My fear is that I'd get the RS2000, and have them announce it's successor in the fall which would fix that problem, leaving current owners high and dry. Remember the Gamma D scenario with the RSx00 series. Not exactly the same, but not that different either.
There is always something better coming right?
Cleveland Plasma is offline
post #513 of 807 Old 04-25-2019, 09:55 AM
DLCPhoto's Avatar
Quoted: 1838 Post(s)
Liked: 936
In general, that is true, and if you wait for everything to be perfect, or to have some new technology that's just around the corner, you'll never get anything.
But to me, this is a little different. It's a broken feature, not a missing feature. They have implemented a new Anamorphic mode to work correctly with the DCR lens for scope content, but failed to have this working properly for 16:9 and for 3D. It is something that from what I've been told, they *can* fix, but at least for now, have decided *not* to fix.
So I stand by my position, that if I bought one now, hoping that they would fix this, and then they come out with a slightly updated model that does, with this fix not being provided for the current generation, I would be quite upset. Since I'm not willing to take that risk, I am fine with waiting until they either fix it, or come out with a newer model that does address this broken feature.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #514 of 807 Old 04-25-2019, 09:57 AM
deepsneaker's Avatar
Quoted: 20 Post(s)
Originally Posted by TomWheeler View Post
Has anyone used the Panasonic 820 with their 695ES? Does the Panasonic 820 apply its tone mapping to streamed HDR content or does it only tone map UHD Blu-ray discs? I am quite pleased with the results that I am getting with HDR content from both streaming and UHD blu-ray sources on my Sony 695ES but I am wondering if the Panasonic 820 would afford even better HDR especially with streaming content.
Tom
I run this setup since a week and can confirm, that the HDR optimizer also works with Netflix. Unfortunately the Panny Netflix app sucks (slow, framerate seems to be fixed to 60fps) so I still mostly use my Apple TV 4k.
Is there any tweak to get movies on the A4k brighter without putting the Sony into high Lamp mode?
Netflix movies like „Bright“ look way to dark via the A4k...
Sent from iPhone via Tapatalk
deepsneaker is online now
post #515 of 807 Old 04-25-2019, 02:53 PM
TomWheeler's Avatar
Quoted: 191 Post(s)
Liked: 113
Thanks for responding. Yes, one of the reasons I have not bought the Panasonic 820 and continue to use my Panasonic 900 is the fact that all of the network applications on the Panasonic are very poor. I use the Apple 4K TV for nearly all of my streaming content. I have not tried the Netflix movie 'Bright", but I have tried other Netflix UHD 4K HDR content and none of it to date has been unacceptably dark. There are two suggestions that I can make to you regarding controlling the brightness of HDR on the 695ES. The first is to move the Contrast (HDR) slider to the left (lower values) which will brighten the image but at the expense of raising the black floor. Using the Contrast (HDR) slider judiciously may give you the image brightness that you wish. The other is to shift the 695ES HDR from Auto to HDR10 or to HDR Reference. Personally, I have not liked the results that I have gotten in either of those two positions compared to HDR Auto, but you may. I have a relatively small 16:9 screen 92 in. wide which is probably why I get a quite bright picture with the 695ES with streaming HDR content. Finally, don't forget to set your Apple 4K TV to Match Frame Rate and Match Resolution in Settings>Video.
Tom
TomWheeler is offline
post #516 of 807 Old 04-26-2019, 10:19 PM
Quoted: 82 Post(s)
Liked: 67
Does anyone have the newest version of the Sony Projector Calibration Pro software available?
azkino is offline
post #517 of 807 Old 05-03-2019, 11:20 AM
Chad B's Avatar
Quoted: 708 Post(s)
Liked: 1623
Sony 695ES technical evaluation
Thanks to a patient new owner and Cleveland AV owner Chris Majoros, I was able to spend a couple weeks with the Sony VPL-VW695ES in my theater room, projecting on to a 119” 16x9 Da-Lite High Power 2.8 gain screen.
Out of the box and calibration notes:
The 695ES comes out of the box in the Cinema Film 1 picture mode, which has some modest enhancements engaged. The resulting image with ordinary 1080P streaming content showed some promise, with a very bright, punchy, and sharp quality. However, depth was shortened, and there seemed to be somewhat odd behavior around and just above black. Some colors were impressive, though skin tones lacked natural ruddiness.
Sure enough, test patterns revealed some strange behavior around black. With default brightness and white balance bias settings and all enhancements turned off, blacker than black levels were actually brighter than slightly above black levels, which were totally crushed. This “inside out” black behavior, while not common, has been seen in a few other SXRD projectors. Interestingly, though it was there early on (before 80 hours), it disappeared after additional break in. Regardless, it can be eliminated through calibration, and in the end the 695ES came out of black gracefully.
Fan noise was very quiet in low lamp power, and while switching to high did make it more noticeable, even then it was unobtrusive. Uniformity, tested by observing full white and gray fields, was fair. The right side of the screen had a slight greenish tinge at white, 50% gray, and 15% dark gray. At and around 15%, odd contouring was slightly visible as well. Fortunately, these anomalies were never noticed with images or content. Black uniformity was perfect, with no bright corners or other issues.
The 695ES had outstanding, razor sharp focus over most of the screen, though it softened close to the sides. Upscaling of 1080P content was excellent, and Sony’s Reality Creation did a nice job of slightly sharpening the image without hardening. Input lag, measured with a 1080P signal, was normally 139ms but improved to 37 with the low latency setting engaged.
The dynamic iris control was generally useful, making fades to black richer and improving punch in some scenes. However, it darkened already very dark scenes and did not help the perceived contrast in those extreme cases. This seems to be a departure from previous SXRDs, which electronically boosted the brightness of levels just above black to compensate for the mechanically closed iris, thereby increasing contrast while maintaining overall brightness.
The full field on/off contrast ratio, measured with the meter facing the lens to maximize dynamic range, was 22,462:1 as calibrated in SDR mode with the dynamic iris disengaged and the fixed iris at the calibrated setting of 38. With the fixed iris at max brightness, the contrast decreased to 16,641:1, but with it set to minimum brightness it increased to 23,887:1. Engaging the dynamic iris would dramatically multiply these numbers. Measured with a 10% size, 25% APL window to simulate actual content, the contrast was very close to 3,200:1 with iris set to max brightness regardless of the dynamic setting. With iris set to the calibrated 38 brightness level, it measured 2,901:1 with the dynamic set to off, 3,055: with it at limited, and 3,751:1 at full. Finally, with the iris at minimum brightness, it was 2,594:1 with dynamic off, 2,845:1 at limited, and 3,676:1 at full. The modified ANSI contrast, a torture test measured at only one point of a 4x4 checkerboard, was not influenced by the dynamic setting and came in at 287:1 at maximum iris brightness and 237:1 at minimum. These are excellent results, and provided they hold up over time (older SXRD models have been known to loose contrast over time) means that Sony and JVC now share best contrast honors.
While the 695ES will automatically pick up an HDR signal and apply a specific gamma and some other corrections for it, bypassing that and instead calibrating a separate manually engaged HDR mode will allow the use of custom gamma curves and a more precise calibration in general. With that in mind, Reference was tailored for HDR, and Cinema Film 1 was calibrated for normal Blu Ray and HD content. It is easy to switch back and forth between the modes, but it would significantly help usability if Sony allowed more calibration flexibility in this regard.
The before calibration measurements revealed a somewhat cooler white balance than the indicated 6500K; gamma showed compression of mid to bright levels, which explains the lack of depth noted out of the box. The slightly pale skin tones are also hinted at in the pre calibration measurements, though full purity color shades are actually a bit over saturated. After using Sony’s Projector Calibration Pro software to straighten gamma and grayscale tracking, the after calibration measurements are very good, with no particularly weak points. It should be noted that the grayscale and gamma tracking would not have been as good without the use of Sony’s calibration software and instead only relying on the 695ES’s own calibration adjustments.
Custom gamma curves were generated and imported for HDR use. Measured performance of HDR mode after calibration was generally very good, though color saturation was somewhat limited and the skin tone simulation patches leaned toward yellow. Brightness levels were a little high with low levels, a factor of the 695ES’s less than perfect native gamma tracking and the custom curve’s inability to correct for such. A meter multiplier of 1.29 was used for the HDR measurements, so reported nit levels should be divided by this.
After calibration:
Watching the same 1080P streaming shows as before showed very detailed textures. However, there were times when pans and motion were distracting both here and with HDR, regardless of the input signal frame rate and with True Cinema engaged or not. Contrast was rich in normal to bright scenes, with lots of pop. There was excellent color depth and shadow detail, and skin tone rendition was rich and satisfying.
UHD HDR Blu Rays had impressive pop and detail, and the image was pleasing overall. Occasionally a very slight bias toward yellow could be discerned in skin tones, and the general color presentation leaned toward the polite and pale side of natural. My wife, a less technical enthusiast who generally likes Sony displays, felt the HDR image was more washed out than expected. While I do not disagree, that was in comparison to unfair (LG OLEDs) and very stiff (high level JVC projectors) competition. Regardless, while there is room for improvement in the 695ES’s HDR image, there is no doubt it is still among the best in it’s class.
A more direct comparison with the JVC RS2000 will be posted and linked here soon.
ID:	2561952   Click image for larger version
ID:	2561954   Click image for larger version
Name:	CP Sony VPL-VW695ES HDR-page-001.jpg
ID:	2561956   Click image for larger version
Name:	CP Sony VPL-VW695ES HDR-page-002.jpg
ID:	2561958   Click image for larger version
Name:	CP Sony VPL-VW695ES HDR-page-003.jpg
Name:	CP Sony VPL-VW695ES HDR-page-004.jpg
ID:	2561962   Click image for larger version
Name:	Cleveland Plasma Sony VPL-VW695ES SDR-page-001.jpg
ID:	2561964   Click image for larger version
Name:	Cleveland Plasma Sony VPL-VW695ES SDR-page-002.jpg
ID:	2561966   Click image for larger version
Name:	Cleveland Plasma Sony VPL-VW695ES SDR-page-003.jpg
ID:	2561968   Click image for larger version
Name:	Cleveland Plasma Sony VPL-VW695ES SDR-page-004.jpg
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS540, JVC RS3000, Sony VPL-VW695ES
Copied settings measured, Review archive
Chad B is online now
post #518 of 807 Old 05-04-2019, 07:46 AM
Kensmith48's Avatar
Quoted: 134 Post(s)
Liked: 39
Chad B, I scheduled an appointment with you last Feb/March for your Michigan tour. Look forward to you straightening out my 695. I also scheduled my Sony A9F.
Chad B and jh901 like this.
Kensmith48 is offline
post #519 of 807 Old 05-18-2019, 03:54 PM
m0j0's Avatar
Quoted: 1317 Post(s)
Liked: 1985
Only had the 695es for a few days now but I am really enjoying this projector! Curious if there are any specific configuration threads or if anyone can share their preferred settings that I could try out. Thanks!
Update: Coming from a UHD60 and black levels on this thing are really blowing me away right now, as well as HDR color gamut and contrast. This really is a great projector!
Archibald1 likes this.
m0j0 is offline
post #520 of 807 Old 05-18-2019, 07:07 PM
Aztar35's Avatar
Quoted: 2969 Post(s)
Liked: 1698
Now all you need to do is pair it with my favorite subwoofer, the Monolith 15.
Aztar35 is offline
post #521 of 807 Old 05-18-2019, 07:14 PM
m0j0's Avatar
Liked: 1985
Actually, I have a Monolith 15, as well as multiple Monolith 10's!
m0j0 is offline
post #522 of 807 Old 05-18-2019, 07:16 PM
Aztar35's Avatar
Liked: 1698
Then you've arrived.
Aztar35 is offline
post #523 of 807 Old 05-18-2019, 07:34 PM
m0j0's Avatar
Liked: 1985
Man, it's definitely starting to feel that way! I have the audio part locked down and now the video is rocking too! Living the dream finally!
Aztar35 and Archibald1 like this.
m0j0 is offline
post #524 of 807 Old 05-18-2019, 07:46 PM
Mike Garrett's Avatar
Quoted: 13799 Post(s)
Liked: 11452
Have you compared the specs to the SB4000? SB4000 is only $200 more, but has smaller cabinet, 200 more watts RMS, Slightly smaller but much better driver and beefier built driver and much beefier built box. Even though the driver and box are smaller, the SB4000 is 25% heavier. The Monolith has a 15" driver with 25mm of Xmax. The SB4000 has 13.5" driver, but it has 52mm of xmax. The SB4000 can move close to twice as much air, due to the more than double xmax.
DoctorCyclops and Aztar35 like this.
Mike Garrett is offline
post #525 of 807 Old 05-18-2019, 10:45 PM
Aztar35's Avatar
Liked: 1698
No, I haven't yet. But nice!!! So... my post to Mojo was kind of an inside joke. But it seems he didn't know from the THX Monolith thread that we both had those same subs.
I have an SVS PC that I like too. All subs I'm using are ported, but I'll be sure check out the SVS sealed 4000.
Aztar35 is offline
post #526 of 807 Old 05-19-2019, 05:46 AM
m0j0's Avatar
Liked: 1985
I got the Monolith 15 when it was on sale for a little over 1k, so the price/performance is what made the difference for me. However, I also have an SVS SB2000 and can only imagine what the SB4000 can do.
@Aztar35 , sorry I didn't get the joke man! Hard to keep up with all the different threads sometimes...
Aztar35 likes this.
m0j0 is offline
post #527 of 807 Old 05-19-2019, 06:39 AM
Liked: 11452
Available in ported also, but a little more money. :With subs you have to look at driver size, excursion and wattage.
Aztar35 likes this.
post #528 of 807 Old 05-21-2019, 06:22 AM
m0j0's Avatar
Liked: 1985
So, quick question. I have been watching some 4K UHD movies on the 695ES and playing around with Dynamic Contrast. I liked the lamp set to High and the Dynamic Contrast set to Medium, with the Iris at Full and 94 brightness. Are there any downsides to using the Dynamic Contrast at either a low or medium setting?
m0j0 is offline
post #529 of 807 Old 05-21-2019, 03:50 PM
PBonn's Avatar
Quoted: 42 Post(s)
Liked: 30
I use the test screens on Sony UHDs to evaluate the impact of contrast changes. You can tell what black and white levels you may be crushing.
Paul
PBonn is offline
post #530 of 807 Old 05-21-2019, 05:27 PM
m0j0's Avatar
Liked: 1985
Paul
Thanks for the reply. I will give those a look.
m0j0 is offline
post #531 of 807 Old 06-03-2019, 09:18 AM
m0j0's Avatar
Liked: 1985
After spending more time with the 695ES, I can say one of my favorite things is the dynamic contrast and the reality creation capabilities with 4k material. I am amazed at how sharp the picture is with RC on and dynamic contrast set to high! I am really surprised by how good this projector is, since it doesn't seem to be getting a lot of press in comparison to the newer JVC units.
m0j0 is offline
post #532 of 807 Old 06-03-2019, 05:26 PM
Frohlich's Avatar
Quoted: 2113 Post(s)
Liked: 2405
AVS certainly has a huge JVC following but overall I am sure there are more Sony projector owners than Sony JVC projector owners. I am a heavy gamer and RC and low lag are a huge plus for my needs. I wouldn't mind trying a JVC either someday but for now the Sony ticks all the boxes for me and my needs.
Frohlich is online now
post #533 of 807 Old 06-03-2019, 08:32 PM
Aztar35's Avatar
Liked: 1698
Well, you guys don't have to prove anything. The 695 is one heck of a display. You know what, think of this: Sony makes many different displays, receivers, audio equipment, video equipment, and other things all the way down to their own batteries. Maybe some companies can make similar claims. But when the video content itself is displayed with that opening logo -- "SONY" how many manufacturers can make that claim?
Advantage --Sony.
m0j0 and Archibald1 like this.
Aztar35 is offline
post #534 of 807 Old 06-03-2019, 09:56 PM
Liked: 11452
The 695 is an excellent projector. These days the Sony and JVC are more alike than different.
m0j0, Franin and Archibald1 like this.
post #535 of 807 Old 06-05-2019, 05:10 PM
Squidjammer's Avatar
Quoted: 130 Post(s)
Liked: 41
Hi All,
If I calibrate one input for SDR and one input for HDR will the 695es automatically change inputs depending on the source? if so how long does it take to switch inputs? my current JVC takes exactly 9seconds to switch and I hear that the Sonys are much faster.
Many Thanks
Scott
Squidjammer is offline
post #536 of 807 Old 06-05-2019, 07:26 PM
m0j0's Avatar
Liked: 1985
Originally Posted by Squidjammer View Post
Hi All,
Many Thanks
Scott
I run all my components to the projector via my receiver, and switching between components is only a couple seconds. For each component, my blu ray player for example, I have calibrated Cinema Film 1 for 1080p sources and Cinema Film 2 for BT.2020 but not for HDR, as my player does tone mapping. For my Shield, I have a similar setup with Cinema Film 1 setup for 1080p content and Cinema Film 2 setup for HDR. Switching between these is very quick.
m0j0 is offline
post #537 of 807 Old 06-05-2019, 07:39 PM
Quoted: 130 Post(s)
Liked: 41
Thank m0j0, so for the shield does it automatically switch between Cinema Film 1 or Cinema Film 2 depending on whether SDR or HDR is being sent or do you have to change it manually?
post #538 of 807 Old 06-05-2019, 07:56 PM
m0j0's Avatar
Liked: 1985
It does not switch, I have to do it manually. It does detect and switch color space and changes Contrast to Contrast (HDR) if the source is HDR material, so you could use Cinema Film 1 or 2 for both HDR and non HDR and it would switch in that way. However, most people prefer to use Cinema Film 2 for setting up and calibrating for 4k / HDR material and Cinema Film 1 for 1080p Rec709 material I believe.
m0j0 is offline
post #539 of 807 Old 06-09-2019, 06:31 PM
sbquart's Avatar
Quoted: 204 Post(s)
Liked: 44
For HDMI Dynamic Range, are you guys using Limited or Enhanced? I’m using it with an Oppo 203.
sbquart is offline
post #540 of 807 Old 06-09-2019, 06:58 PM
m0j0's Avatar
Liked: 1985
I have HDMI Dynamic Range set to Auto.
I also found this info online:
https://www.sony.com/electronics/sup...icles/00013709
m0j0 is offline
