LG HU85L 4K Ultra Short Throw Projector Announced. - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 157Likes
post #181 of 508 Old 05-13-2019, 11:59 PM
Quoted: 31 Post(s)
Liked: 9
Originally Posted by Gae80uk View Post
Looks great but if the price is confirmed around 5-6k, it will be an elite device for few elected ones :I
Is that a definite 5-6k on the price now then ? Just if it is i can rule that one out and then look at what the other alternatives are which at the moment stand at the new Xaomi mijija 4K 2019 version
danwel is offline
post #182 of 508 Old 05-14-2019, 04:09 AM
Quoted: 79 Post(s)
Liked: 60
It's not definite, this is based on some internal info gathered from few customers...still hope it will be cheaper but not so confident on that. I am considering the Vava 4K pj, which is the Xiaomi 4k version tweaked for the global market.
G.
Gae80uk is offline
post #183 of 508 Old 05-14-2019, 04:16 AM
Quoted: 31 Post(s)
Liked: 9
G.
To be honest I’m actually toying with buying the original non 4K one Chinese version as I want 3D and none of my sources will be actual 4K other than Xbox as I use Apple TV for plex and IPTV and non of those are actual 4K rips
drdoom2k likes this.
danwel is offline
post #184 of 508 Old 05-14-2019, 06:37 PM
Liked: 0
Originally Posted by niveknow View Post
The screen size is determined by the projector drawer pull out distance, but nothing tells me the height of the top of the projector to the bottom of the image until the dang thing is released and turned on.
So if you watch the video at
and believe the animations... the picture at 120" almost reaches the top of the projector. The 120" picture grows from the center of the display being casted at 90".
@ 90" Diagonal 16x9 we have 44" high and @ 120" Diagonal 16x9 we have 59" high. subtract the difference and divide by 2 to get the height difference on just the bottom and we have a height of 7.5" from the top of the projector. If you know where your screen is then you can put a little margin of error in place with the console.
Also, the image will be adjustable, just like the other UST models so theres margin there as well. I'd say I can adjust the image by 4" in either direction easy on the 1080p LED UST.
I happen to have a sound base I want to get rid off but could use for "decoration" if I needed it. Being that my screen is 30" from the ground and I have 7.5" from the top of the project and I bet the projector is about 4-5" tall/thick so I need a console of minimum height around 18-19" for maximum flexibility because I can add the sound base and I can go up to 21 inches or adjust the image from there for even more flexibility.
However, no one makes consoles this short so instead I will build a simple one or modify one with a solid wood top to add hinges where the top swings open with this hardware with these brackets so I can adjust the top as much as I want and have clearance for video.
Hope this helps. I'll be making my purchase very soon. Thanks to the guy who provided that video.
claywd is offline
post #185 of 508 Old 05-14-2019, 08:15 PM
Mikkle's Avatar
When it comes to dimensions I wouldn't trust anything in that marketing video. The projector and projected image are just 3D rendered.
Mikkle is offline
post #186 of 508 Old 05-17-2019, 11:08 AM
Liked: 0
So this projector maxes out at 120"? My screen is 125" would the image look bad if I forced those 5 more inches?
Casepb is offline
post #187 of 508 Old 05-18-2019, 08:52 PM
tambur123's Avatar
Quoted: 37 Post(s)
Liked: 5
I have an epson ls100 which according to specs maxes out at 130”. I used it for a while with a 135” inch screen without any problems. They were probably some minor image distortions at the edges, but I haven”t noticed anything. I’m willing to bet that will be the same with any UST projector.
tambur123 is online now
post #188 of 508 Old 05-23-2019, 03:09 AM
Derek J's Avatar
Liked: 1
I currently own an HU80ka lg cinabeam but I just wasnt to happy with the picture quality for 2500 lumens. Hopefully this projector will deliver a deeper picture quality.
Derek J is offline
post #189 of 508 Old 05-28-2019, 04:14 AM
Quoted: 79 Post(s)
Liked: 60
And I guess rumours were right...
Link below from a U.S. retailer with launch date end of Aug and retail price of $5.999...
https://www.*********************/HU...projector.html
Elite pricing/positioning...I am out :I
G.
Gae80uk is offline
post #190 of 508 Old 05-28-2019, 04:25 AM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
G.
Because no retailer posts a ridiculous price prior to launch and availability. Doesn't mean that's an accurate price. And that's most likely value electronics I'm guessing.
Sent from my SM-N960U1 using Tapatalk
dbpaddler is online now
post #191 of 508 Old 05-28-2019, 04:40 AM
Quoted: 79 Post(s)
Liked: 60
Really hope so...
Gae80uk is offline
post #192 of 508 Old 05-28-2019, 05:06 AM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
Really hope so...
Best buy does that consistently actually. So fingers crossed.
post #193 of 508 Old 05-28-2019, 02:03 PM
niveknow's Avatar
Quoted: 31 Post(s)
Getting impatient here waiting for this LG vs UHZ65UST. The impatience may just pushed me to the Mijia 4k and call it a day. =)
niveknow is offline
post #194 of 508 Old 05-28-2019, 04:36 PM
juic-E-juice's Avatar
Quoted: 26 Post(s)
Given what the rumors are, I’m fearful that we will all suffer sticker shock when these projectors FINALLY arrive. I would have already purchased the Mijia if its input lag wasn’t so atrocious, but I’m not holding my breath that these will be any better. InFocus seems to be hearing our cries, and they have a UST on the way as well. Hopefully they can merge their ultra low lag with their UST in time for launch. But anything above 3.5 grand and I’ve got a lot of high end traditional projectors that will compete for my dollars, especially after you factor in the additional cost of an ALR screen.
juic-E-juice is offline
post #195 of 508 Old 05-28-2019, 05:00 PM
Troy LaMont's Avatar
Quoted: 308 Post(s)
Liked: 283
Wired UK has an article dated from 5/4/19 here where the HU85L is listed at only $2,999 (guessing UK pounds) which would translate to about $3,800 US which is about where I was thinking this projector would fall!
Hope is still alive! LOL
Name:	HU85L web uk web posting.png
Theater: Onkyo TX-NR807, Polk LSi15, Polk LSiC, Polk LSiF/X, Velodyne HGS12, Optoma HD80 on 100" Elite Aeon screen
Bedroom: Yamaha WXA50, Samsung Q6FN (2018), Martin Logan Motion LX16, Pro SW100P 10" sub
Gaming: Xbox One X, Samsung UH750 Quantum Dot 28" UHD monitor
Troy LaMont is offline
post #196 of 508 Old 05-28-2019, 05:11 PM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
Wouldn't it be listed with the £ sign and not $ if it were in pounds? Or is it common in the UK to interchange like that?
post #197 of 508 Old 05-29-2019, 07:48 AM
niveknow's Avatar
Quoted: 31 Post(s)
I'm with dbpaddler on the currency sign. It does infer USD which $2999 will keep me in the game for a wait. If it comes out at $3999, I'll be looking to see what the latest Mijia will be offering. I swear I think these vendors are playing the waiting game to see what their competitors do first from a pricing perspective.
Wesley Hester likes this.
niveknow is offline
post #198 of 508 Old 05-29-2019, 09:36 AM
Quoted: 308 Post(s)
Liked: 283
Looking at the remainder of the listings for products on that page they do have a mix of £ and $ so I'm not sure. 😮
But either way, that's a much better range than what we're hearing elsewhere.
Stay tuned.
post #199 of 508 Old 06-04-2019, 07:45 PM
ZAPH's Avatar
Quoted: 13 Post(s)
Liked: 7
One of the owners of Value Electronics out of Scarsdale, NY states on Blu-Ray's forums he'll have demo's August 24th. Believes the price to be $5,999.
BLURAYDOTCOM/showpost.php?p=16479091&postcount=21
ZAPH is offline
post #200 of 508 Old 06-05-2019, 04:30 PM
Quoted: 308 Post(s)
Liked: 283
Believing and knowing are two different things! LOL 😆😀
Looking through the posts and Robert states emphatically that "LG's new HU85LA is a native full 4K HDR chipset, it is not an e-shift chip. I confirmed this with LG's engineer in charge of projectors" which everyone knows is pure fallacy. He's a sales guy and it's 100% possible he may not have all the answers so the pricing he has may again be a placeholder!
ZAPH likes this.
post #201 of 508 Old 06-05-2019, 05:36 PM
JackB's Avatar
Quoted: 1460 Post(s)
Liked: 358
Could he be carefully using the word "e-shift" as in Epson and JVC?
Jack
JackB is offline
post #202 of 508 Old 06-06-2019, 10:03 AM
dbpaddler's Avatar
Quoted: 140 Post(s)
Liked: 84
Well my barber's father's son went to school with this guy that's the mailman for LG headquarters who said he delivered some marketing literature that had the MSRP on it and that it was $2999. He's pretty reliable, through rain, snow, sleet and the dark of night.
Troy LaMont and drdoom2k like this.
post #203 of 508 Old 06-06-2019, 10:30 AM
JackB's Avatar
Liked: 358
Now that's about the best source for a rumor that can be imagined. Classic!
dbpaddler likes this.
Jack
JackB is offline
post #204 of 508 Old 06-07-2019, 02:43 AM
Quoted: 64 Post(s)
That's an instant buy if it really is $3k to be honest (expecting that thing to outperform all other USTs in that price-range)!
drdoom2k is offline
post #205 of 508 Old 06-10-2019, 02:55 PM
Liked: 8
We don't use $ and £ interchangeably in the UK. $ is only used for dollars.
But in any case with electronic goods our prices tend to end up at roughly the same numerical number. A $3000 projector is likely to cost us £3000, this is because although $1 is worth less than £1 less we pay 20% VAT as well as often having a higher pre-tax price.
Troy LaMont likes this.
Mega_Maniac is offline
post #206 of 508 Old 06-11-2019, 11:35 AM
BenPlace's Avatar
Quoted: 97 Post(s)
Liked: 35
Where can I purchase the Xiaomi 4k UST laser projector and make sure its the 2019 model with native 4k?
I see a lot out there but none say if its the 2019 model or not.
Thanks in advance for any help.
Ben
BenPlace is online now
post #207 of 508 Old 06-11-2019, 05:28 PM
klas's Avatar
Quoted: 253 Post(s)
Liked: 83
Ben
Don't know... I am shopping around for 85" Sony TV. Have you seen any good deals? Perhaps last year model is cheaper.... Can't seem to figure out by looking through this thread.... All they seem to be talking about some LG but I don't care much for this brand.
Xiaomi Mija Mi Laser UST 1080P (International), Sharp 4k 65", LG 4k 43", Nvidia Shield
klas is offline
post #208 of 508 Old 06-11-2019, 07:12 PM
Quoted: 34 Post(s)
Troll Level: Weak AF
J Bone is online now
post #209 of 508 Old 06-12-2019, 06:17 AM
BenPlace's Avatar
Quoted: 97 Post(s)
Liked: 35
Thats odd, I could swear I was in the Xiaomi thread when I posted this. I apologize.
post #210 of 508 Old 06-12-2019, 01:43 PM
klas's Avatar
Quoted: 253 Post(s)
Liked: 83
haha, no worries, I figured you might be looking at the same two threads everyone else is looking who is interested in USTs
klas is offline
