Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 13264Likes
post #391 of 13987 Old 01-08-2019, 06:31 PM
Quoted: 1243 Post(s)
Liked: 973
Javs...
The 9900's I had here, and others I have seen posted around, they all seemed to have a real issue with the right hand side of the screen assuming shelf mounted. Left would be stellar, right would start drifting.
Same here, in a ceiling mount set up, my problem area was lower left, so a very consistent problem.
Javs likes this.
Bytehoven is offline
post #392 of 13987 Old 01-08-2019, 06:46 PM
alebonau's Avatar
Quoted: 1805 Post(s)
Liked: 1228
Originally Posted by BruceJK View Post
Here are my two units crossing paths for the first and only time:
my goodness ! it makes the previous gen JVC look like a TOY
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is online now
post #393 of 13987 Old 01-08-2019, 06:46 PM
BruceJK's Avatar
Quoted: 200 Post(s)
Liked: 366
Originally Posted by bobof View Post
Interesting. Can you capture a photo of what the JVC HDR stuff says it is seeing and doing with respect to the auto mapping controls at, say, 13m25 and 13m35 on that episode?
As far as I can tell the metadata update happens mid scene so it will be interesting to know if at that metadata change the changes are enough to trigger a change in map or not. It would be very clever indeed if it was waiting for a scene change to apply the new metadata, but a very good idea. But also perhaps if the algorithm is biased to maxFALL there is no update to the map at that point if as you say the maxFALL data is more sensible than maxCLL.
With a bit of searching I was able to find another scene in that same episode of Iron Fist (season 1 episode 3) that does trigger a perceptible luminance change though if you blink you'll miss it. It happens around the 16:30 mark where the max FALL jumps from 14 to 56 nits and it does cause a tone mapping change that resembles a DI pumping a little bit but it happens even if the DI is off. So there are circumstances where the fluctuating HDR10 metadata on the Apple TV will be visible though I don't want to overstate this. A lot of the flat panel TV's have tone mapping on HDR and ABL that causes luminance fluctuations that are worse than this.
ID:	2507968   Click image for larger version
Bruce K.
BruceJK is offline
post #394 of 13987 Old 01-08-2019, 06:46 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 3843 Post(s)
Liked: 6265
JVC RS3000/NX9
IN-DEPTH ANALYSIS AND EVALUATION | UNIT # 1
UPDATE #6 | QUICK BROWN FOX TEST PATTERN (FULL SET OF PHOTOS)
TOP LEFT:
TOP MIDDLE:
TOP RIGHT:
CENTRE LEFT:
CENTRE CENTRE:
CENTRE RIGHT:
BOTTOM LEFT:
BOTTOM MIDDLE:
BOTTOM RIGHT:
ARROW-AV is online now
post #395 of 13987 Old 01-08-2019, 06:55 PM
Liked: 973
Nigel, you are a mad man!
Thanks for your herculean effort.
You're gonna have nx9s in your dreams tonight instead of sheep.
Spizz, Dandlj and ARROW-AV like this.
post #396 of 13987 Old 01-08-2019, 07:06 PM
ddgdl's Avatar
Quoted: 329 Post(s)
Liked: 298
Originally Posted by Bytehoven View Post
Nigel, you are a mad man! [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
If you think the people on this board are going to let him sleep without taking contrast and ANSI measurements... 🙂
Spizz, Bytehoven and ARROW-AV like this.
ddgdl is offline
post #397 of 13987 Old 01-08-2019, 07:15 PM
DennisLJacob's Avatar
Quoted: 174 Post(s)
Liked: 96
Originally Posted by Javs View Post
See this is really interesting now...
CENTRE LEFT
CENTRE CENTRE
CENTER RIGHT
Notice anything?
Which is better
I think this is just down to sample variance rather than a larger underlying issue. As in, its a non-issue where the wide range of units is concerned.
As was said, no projector is perfect with this, I am satisfied that the left image is how its meant to look in the bigger picture of things.
Newbie question. Could this be the camera shutter speed capturing the video projection in mid-flight? Could that affect the photo result? Or is it possible the screen material isn't perfect and could have a surface difference in these locations? I know my tab tensioned screen is not perfectly flat. It has puckers. I don't mind since while viewing movies and TV programs, it doesn't make a huge difference. But it would make a difference in a static camera photo of running video.
DennisLJacob is offline
post #398 of 13987 Old 01-08-2019, 07:26 PM
Quoted: 174 Post(s)
Liked: 96
Hey are you guys letting these new "cold" projectors acclimate to your rooms before you plug them in? I know it is recommended with any high-end audio gear. Especially amps that heat up a lot. I believe at least 24 hours is recommended and more if you can wait that long. You could be creating humidity inside of those expensive projectors. If the boxes have been sitting in a cold warehouse or UPS truck, they could have quite varying climatic conditions. My two cents.
Thoughts?
Th601 likes this.
post #399 of 13987 Old 01-08-2019, 07:29 PM
ack_bk's Avatar
Quoted: 1334 Post(s)
Liked: 1467
If I am having problems sleeping I just repeat over and over to myself "The quick brown fox jumped over lazy dog".. And I'm out..
Happy for those that are getting their shiny new toys. And man three new units have some girth! You don't want to drop one of the bad boys on your foot...
Spizz, smitty, Bytehoven and 1 others like this.
ack_bk is offline
post #400 of 13987 Old 01-08-2019, 08:11 PM
Jim Cutter's Avatar
Quoted: 173 Post(s)
Liked: 183
OMG!!! Are the RS2000/N7 and RS1000/N5 the same size as the RS3000/NX9??? That thing is huge!
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #401 of 13987 Old 01-08-2019, 08:19 PM
yankiy's Avatar
Quoted: 194 Post(s)
Liked: 203
I would love to hear some thoughts from the owners of the NX7's with regards to image uniformity, contrast, etc...
alebonau likes this.
JVC DLA-NX9 | Panasonic UB820 | Denon AVR-X6400H | Rotel RB 993 Amp | 135" 2:35:1 Elunevision Aurora NanoEdge Ambient Light Blocking Screen | Paradigm Monitor 11 v7, Monitor Center 3 v7, Monitor Surround 3 v7, CI Pro P65-R |
yankiy is offline
post #402 of 13987 Old 01-08-2019, 08:37 PM
lovingdvd's Avatar
Quoted: 3639 Post(s)
Liked: 810
Lumens measurements?
Originally Posted by ARROW-AV View Post
JVC RS3000/NX9
Nigel - Thanks for all the photos. Have you calibrated yet? If not, please do so before taking measurements. Also please let us know how well the JVC autocal software works. Can you please take the following lumens measurements when you have a chance?
1. Lamp high, iris wide open (0), BT2020 color filter NOT in place, @D65 : Measured lumens from short, mid, and long zoom. Zoom set for 16:9 picture.
2. Lamp high, iris wide open (0), BT2020 color filter NOT in place, @D65 : Measured lumens from short, mid, and long zoom. Zoom set for 2.40 picture, assuming you have a
scoped screen, if not please simulate the needed zoom and measure.
3. Lamp low, iris wide open (0), BT2020 color filter NOT in place, @D65 : Measured lumens from short, mid, and long zoom. Zoom set for 16:9 picture.
4. What % lumens drop when putting the BT2020 color filter in place?
lovingdvd is offline
post #403 of 13987 Old 01-08-2019, 08:39 PM
ddgdl's Avatar
Quoted: 329 Post(s)
Liked: 298
my goodness ! it makes the previous gen JVC look like a TOY [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
OMG!!! Are the RS2000/N7 and RS1000/N5 the same size as the RS3000/NX9??? That thing is huge! [IMG class=inlineimg]/forum/images/smilies/eek.gif[/IMG]
Re-read the label on the box- that IS the RS2000/N7!
ddgdl is offline
post #404 of 13987 Old 01-08-2019, 08:51 PM
703
703's Avatar
Quoted: 152 Post(s)
Liked: 49
Apart from test patterns, how is the picture compared to last years model given the lower contrast?
703 is offline
post #405 of 13987 Old 01-08-2019, 08:58 PM
Javs's Avatar
Quoted: 6791 Post(s)
Liked: 6418
You definitely shouldn't need to run Autocal out of the box... It should be close enough to spec, and only need a few clicks here and there in the CMS to be quite well measuring at D65...
alebonau and ARROW-AV like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #406 of 13987 Old 01-08-2019, 09:01 PM
Jim Cutter's Avatar
Quoted: 173 Post(s)
Liked: 183
Holy crap, it is!!! With all of the talk about the NX9 I just thought that's what it was. I looked at the picture but not close enough. That thing is a monster!!!!
post #407 of 13987 Old 01-08-2019, 09:13 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6265
post #408 of 13987 Old 01-08-2019, 09:39 PM
BruceJK's Avatar
Quoted: 200 Post(s)
Liked: 366
I received my NX7 late this afternoon and after a warm-up period I did some checking on the usual problem areas for a new projector:
1. Stuck Pixels - can't find a single one.
2. RGB Convergence - nearly perfect. There is a very slight convergence error in the blue channel on the far right hand side. You need to be within 2 feet of the screen to see it on a convergence test pattern. It's not visible on normal content at all.
3. Bright corners - there is a vague sense that the corners are a bit lighter than the centre after your eyes have adjusted to the darkness.
4. Overall on/off contrast seems comparable to my X750.
5. Build quality is high. The new chassis is solid.
Problems: so far only one. The dynamic iris skews the gamma so it looks like a solarized picture with blown highlights. This is most evident on SDR content but I see some of it on HDR as well. I believe 'woofer' had this issue on a preproduction NX9 and it was resolved through a firmware update. It's likely this fix was not ready for release at the time the first production machines were shipped. The native contrast is very good so I just disabled the dynamic iris for the time being.
Highlights: the HDR performance with auto tone mapping is really good. It's finally a plug and play solution without requiring custom curves and the need to manually switch curves based on content. There may be some limitations based on missing and/or incorrect metadata but I've gotten good results with all of the HDR10 streaming and UHD blu-rays I've tried so far. I don't have any HLG sources to evaluate that aspect.
The fan is very quiet on low lamp and the noise level is acceptable to me on high lamp.
Overall, I'm very pleased with the performance of the NX7. The image is extremely sharp without the use of edge enhancement and appears very natural. Contrast levels are good and typical of what we expect from a JVC. The performance on 1080P SDR material is as good as the preceding models which were considered to be best in their class. I feel the new models are now best in their class for 4K HDR as well.
Bruce K.
BruceJK is offline
post #409 of 13987 Old 01-08-2019, 09:46 PM
ddgdl's Avatar
Quoted: 329 Post(s)
Liked: 298
Wonderful news on the RS2000 front- thank you!
ddgdl is offline
post #410 of 13987 Old 01-08-2019, 09:58 PM
703
703's Avatar
Quoted: 152 Post(s)
Liked: 49
Do you notice the occasional lamp flicker from time to time as seen in the last year(s) models?
703 is offline
post #411 of 13987 Old 01-08-2019, 10:12 PM
RapalloAV's Avatar
Quoted: 2203 Post(s)
Liked: 766
Motion Enhance = OFF
Mee too! Suffice to say I will not be sleeping tonight until after this is done. This just finishing up with QBF then these measurements next
Nigel do you also have an NX7 on hand?
It would be intersting to see if the "Fox" is any sharper without any e-shift in the light path...
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #412 of 13987 Old 01-08-2019, 10:16 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6265
It would be intersting to see if the "Fox"...
I will be evaluating a total of 5 UNITS of each and every of the NX9, N7, and N5... At the present time I have just received 1 number NX9. I should be receiving N7 and N5 very soon. I will be carrying out the same evaluations with each and every model
post #413 of 13987 Old 01-08-2019, 10:26 PM
Originally Posted by Mike Garrett View Post
Serial number of the first RS3000 shipped in US is 17340007. December build.
I was going to post my serial number, too, and realized that’s mine!
Loving the projector, like the others. Uncalibrated, but phenomenal picture across various sources on my Stewart Grayhawk RS. I can firmly state that if you are also considering moving up from an RS60, it is a decision you won’t regret! ....Okay, that might only be me with a seven year old projector...
John
JLLF is offline
post #414 of 13987 Old 01-08-2019, 10:36 PM
jmonier's Avatar
Quoted: 186 Post(s)
Liked: 107
Apparently JVC didn't want to have different cases for the NX5 and NX7 than for the NX9, so they sized it for the much bigger lens in the NX9. If you pick up each, though, you'll know which is which. The NX9 weighs almost 5 lbs (2 kg) more than the NX5/NX7.
All of them are heavy, though. Even the NX5/NX7 weighs almost 10 lbs more than previous models.
jmonier is online now
post #415 of 13987 Old 01-08-2019, 10:36 PM
Spizz's Avatar
Quoted: 450 Post(s)
Liked: 289
BruceJK- How is the upscaling for non 4K sources please? Is there any noise introduced in the image? How is the motion processing on it?
Spizz is online now
post #416 of 13987 Old 01-08-2019, 10:37 PM
Quoted: 262 Post(s)
Liked: 159
Originally Posted by SOWK View Post
do you guys listen to single frequency test tones to tell what a speaker sounds like?
Yes. And especially for my subwoofers.
wombats is offline
post #417 of 13987 Old 01-08-2019, 10:48 PM
Originally Posted by woofer View Post
Absolutely agree..
My opinion is it also adds to image noise..
I didn’t see any noise when I enabled 8K, but I noticed no real difference at 10 feet from my 110 inch screen. I flipped back and forth and would never be able to guess whether or not 8K was enabled if it were a blind test. Well... I guess if I were blind, I wouldn’t be able to tell anyway. Actually I might have because there is a very slight whine that comes from the projector when it is engaged. It isn’t really an issue, though.
In any event, I don’t see any reason I’ll ever enable 8K. But I didn’t buy the 3000 it for that, anyway. I just wanted the best brightness, contrast and lens.
John
JLLF is offline
post #418 of 13987 Old 01-08-2019, 11:11 PM
alebonau's Avatar
Liked: 1228
oh yeah.... these things are big ! not so obvious until a side by side was posted
there isnt much in it size difference n9 to n7/5 though like previous series pretty much share chasis. n9 just has a touch poking out front with the lens I see. but yeah the new series are the He-Man version compared to previous gen
Jim Cutter likes this.
post #419 of 13987 Old 01-08-2019, 11:13 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6392 Post(s)
Liked: 6392
Thats the way to do it, no unit variation.......what the size of the NX9 box in inches
Cleveland Plasma is online now
post #420 of 13987 Old 01-08-2019, 11:29 PM
markmon1's Avatar
Quoted: 4634 Post(s)
Liked: 2942
Does anyone care? It will probably be all but unusable... :-p
I care. If I cant use it in dynamic iris mode I'm out.
coxy2416 and wombats like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
