Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 204 - AVS Forum | Home Theater Discussions And Reviews
 13327Likes
post #6091 of 14131 Old 02-18-2019, 06:35 PM
ScottieBoysName's Avatar
Quoted: 1123 Post(s)
Liked: 305
Originally Posted by Javs View Post
No, I have not seen the new JVC's but I can tell you in depth how MadVR works, and once you understand that it is measuring literally every frame and adapting to each instance, there is no amount of 'static' metadata tone mapping that will even approach it.
Right now, the JVC looks to be applying a set 'curve' for each film you put in. We used to have 1 or 2 custom curves in total and pick the best one based on metadata, now the JVC will read metadata and update is own settings on a film by film basis. it can do this with probably millions of combinations since it uses 3 sliders to do it. But they are static, ONE curve per film is possible, thats it.
But what if the Metadata is wrong - I can tell you over 70% of the metadata IS wrong.
What if the title has a 1200 nit pixel for a millisecond and thus its metadata reflects that, but 99% of the film is around 600 nits peak? The JVC will be tone mapping to 1200 nits and the whole image will be darker than it ideally should be.
MadVR will know this and as it reads and measures the peak of every single frame, it can adapt extremely quickly within 1 frame even if you have it set that way, it can also detect scene changes, there is a whole host of algorithms which juggle and decide when to change the curve for a set event.
In fact one of the most recent things we are doing is having MadVR throw away the top 1% measured peaks, the image suddenly becomes exceptionally vibrant just by doing this. Thats one trick.
Lumagen I think is working on this too so should eventually be playing the same game if not already, but the MadVR development has been crazy in depth and rapid on this for months now, its extremely good. It is pretty much indistinguishable from full blown Dolby Vision now. But it will work for every title you put through it.
I have a extra PC laying around. My understanding is MadVR takes quite the graphics card to run though.
ScottieBoysName is offline
post #6092 of 14131 Old 02-18-2019, 06:47 PM
ChldsPlay's Avatar
Quoted: 1115 Post(s)
Liked: 630
Picked up my NX7 today. Made my order maybe 3 weeks ago.
I picked it up directly from the distributor, so it didn't even get to the dealer. While I was there, I happened to see a form showing the dealer costs on these units. If I could get those prices, I may have been tempted to get the NX9.
Probably won't get it up and running for a day or two. I did get my shelf installed today, but still have a fabric panel to modify, and I am hoping that might happen soon. Just a little less worry putting that back up before the projector meets its home.
Dandlj likes this.
The Hodor Theater - Now with Atmos
Projector - JVC D-ILA NX7/Panasonic PT-AE8000U; Receiver - Yamaha Adventage A3050
LCR speakers - JTR Noesis 228 HT (3); Surr./Back - Klipsch Pro Cinema KPT-8000M (4)
Atmos In-ceiling - Niles DS8HD (4); Subs - Passive JTR Captivator Pro (2)
ChldsPlay is offline
post #6093 of 14131 Old 02-18-2019, 06:49 PM
markmon1's Avatar
Quoted: 4654 Post(s)
Liked: 2950
Originally Posted by ScottieBoysName View Post
Can you see that? That green border?
Around the picture? Can’t you just zoom that image until it fills your screen and let the screen bezel handle the rest?
markmon1 is offline
post #6094 of 14131 Old 02-18-2019, 06:50 PM
markmon1's Avatar
Liked: 2950
I had to move red up one. That helped MOST of the panel. Moving it up one helped 75% of the screen, made the upper right corner/zone off by one though.
Would you consider that a win?
It’s a win if you can’t see any convergence problems from your seating in ny opinion.
markmon1 is offline
post #6095 of 14131 Old 02-18-2019, 07:01 PM
Javs's Avatar
Quoted: 6791 Post(s)
Liked: 6418
Originally Posted by rak306 View Post
Ok. I get that MadVR has dynamic tone maping. But how about if you compare the JVC’s auto tone mapping to MadVR without the dynamic feature. In other words, does JVC do a good job (e.g. keeping accurate colors/saturations when reducing video levels that are beyond the displays peak output).
Yeah sure, I guess. Accuracy is a strange word when talking about HDR though.
Madvr can also select a tone mapping (target nits) curve in the same way the JVC does on a case by case basis, this is different to its rolling dynamic tone mapping. At that point one could probably make the two look very similar. I know I was able to get madvr in the past look almost identical to curves.
There are still heaps of things going on with HDR and MadVR. Development has been in depth for 6-9 Months+ and dynamic is only in the past couple Months.
I'm sure the JVC does a pretty darn good job. I don't think you would need to use custom curves at all with it based on what I'm hearing. That's an achievement for sure. There are no other projectors out there right now doing anything similar.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #6096 of 14131 Old 02-18-2019, 07:04 PM
Javs's Avatar
Liked: 6418
Originally Posted by docrog View Post
Sorry, for any confusion..... I wasn't asking for further comparison of JVC static tone mapping of HDR10 versus MadVR dynamic mapping. I was hoping for a comparison of MadVR versus SDR BT2020 (no tone mapping) for UHD Blu Ray source material.
SDR BT2020 is tone mapping. That's also what the Panasonic if and Oppo does. Along with Lumagen I believe.
When you use madvr tone mapping it actually needs your display to be in gamma 2.2 mode.
seanbryan likes this.
Javs is offline
post #6097 of 14131 Old 02-18-2019, 07:09 PM
Liked: 305
Of course! That’s what I’m doin now. From everyone I’ve talked to though they’ve indicated that’s not normal.
Gonna run a few more tests in the morning to see what’s what.
post #6098 of 14131 Old 02-18-2019, 07:22 PM
mavromatis's Avatar
Quoted: 88 Post(s)
Liked: 51
So if you use madvr tone mapping we need to use gamma 2.2 instead of 2.4?
mavromatis is offline
post #6099 of 14131 Old 02-18-2019, 07:22 PM
Mike Garrett's Avatar
Quoted: 11825 Post(s)
Liked: 9357
I’m out and about right now. Be home later tonight. In showing the grid, that’s the whole panel regardless - right?
This is on my ST130 screen. Iris is Auto2. Throw is about 13 feet 3 inches.
High or low lamp?
Is this without DCR lens?
Manual iris setting.
Added
If you are in low lamp and have not closed the iris down, you are running about 35FL for SDR. Your black floor is pretty high.
Mike Garrett is online now
post #6100 of 14131 Old 02-18-2019, 07:28 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6409 Post(s)
Liked: 6404
Originally Posted by stumlad View Post
So how far along has JVC come to pre-orders being fulfilled/delivered? We at the 50/75% mark yet? Obviously it would be a guess for most other than dealers.
Probably not....There are some dealer/distributors who have not received any.
Cleveland Plasma is online now
post #6101 of 14131 Old 02-18-2019, 07:42 PM
Liked: 305
Originally Posted by Mike Garrett View Post
High or low lamp?
Added
I’ll run through all that and get back to you.
You think that might be it? I have never adjusted the manual iris at all. Seems like from what I was reading most people left it alone.
post #6102 of 14131 Old 02-18-2019, 07:43 PM
Javs's Avatar
Liked: 6418
You have to tell madvr which gamma you are using. But the tone mapping algorithms are based on a 2.2 working space so it's best to use that.
You could set it to 2.4 in the on the pj and madvr but it will probably not look different.
Javs is offline
post #6103 of 14131 Old 02-18-2019, 07:44 PM
grendelrt's Avatar
Quoted: 557 Post(s)
Liked: 293
I thought that gamma 2.2 was only if you were using a 3d lut and not pixel shaders?
grendelrt is offline
post #6104 of 14131 Old 02-18-2019, 07:47 PM
docrog's Avatar
Quoted: 1060 Post(s)
Liked: 361
Thanks for your input. I meant that there was no further utilization of the auto tone mapping feature within the JVC since it occurs external to the PJ. What I'm trying to ascertain is whether contrast & black levels are appreciably improved with the MadVR tone mapping HDR10 versus SDR BT2020 tone mapped external to the PJ.
docrog is offline
post #6105 of 14131 Old 02-18-2019, 08:06 PM
Liked: 9357
For SDR, pretty much everyone adjusts the manual iris to set the light output.
post #6106 of 14131 Old 02-18-2019, 08:29 PM
Liked: 305
I’m getting it mixed up then. For HDR they set Auto and go. For SDR you’re right. Manual Iris is adjusted.
post #6107 of 14131 Old 02-18-2019, 08:33 PM
markmon1's Avatar
Liked: 2950
Let's agree that it's not normal. But if your unit is good otherwise, then who cares? Also, I bet more people have those types of things and just don't know because they're properly zoomed to their screen bezel
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6108 of 14131 Old 02-18-2019, 08:34 PM
markmon1's Avatar
Liked: 2950
This is what I do, FYI. 2.4 in projector, 2.4 in madVR. I just never thought to try 2.2 on both. I'm happy with how it looks.
RapalloAV likes this.
markmon1 is offline
post #6109 of 14131 Old 02-18-2019, 08:35 PM
Craig Mecak's Avatar
Quoted: 319 Post(s)
Liked: 248
If madvr is as good as it is, then JVC should license it and incorporate it into their future projector models. Sounds like a match made in heaven.
Enter in screen size, screen material, screen gain, nits level, and madvr would dynamically optimise the HDR picture in real time.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is offline
post #6110 of 14131 Old 02-18-2019, 08:35 PM
markmon1's Avatar
Liked: 2950
I think most people turn on the projector and go. The dynamic iris handles contrast.
markmon1 is offline
post #6111 of 14131 Old 02-18-2019, 08:41 PM
Liked: 305
I can totally get down with this, but I’d argue that we’re all on this forum due “good otherwise” not being....good enough.
Right?
post #6112 of 14131 Old 02-18-2019, 08:56 PM
DennisLJacob's Avatar
Quoted: 174 Post(s)
Liked: 96
So my new projector (RS3000) landed today. I'm letting it acclimate from the 20 degree outside temp to my house temps. So I need to make a few decisions before hanging the PJ. I have a couple questions that I hope someone can help me on.
Here are my system measurements. 16:9 AT drop down screen with top of screen height 8.5 inches down from the ceiling. I can raise it another inch maybe or lower it 4 or 5 inches if desired. The throw distance will be about 14.5 feet. Now for the PJ side. My current mount is set such that the lens center will be 10.5 from the ceiling or I can change the 3" down tube to a 6" down tube. The later would give a 13.5 inch drop from the ceiling.
So what would be the best setup for vertical Len shift positions? From reading posts, some have mentioned halos or barrel reflections and being at 100% of V shift might not be advised. The next question is about horizontal lens shift. Here I can get very close to being centered. Or I can move the ceiling mount to take it off of center if desired.
So those are the first two decisions and questions I'd like to get some feedback on. What are your recommendations?
aniv likes this.
DennisLJacob is offline
post #6113 of 14131 Old 02-18-2019, 09:11 PM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
I would just start with whatever is most simple for you or makes best use of the space (projector not hanging down too low) and only adjust from there if there is a problem. My vertical lens shift is at the maximum on my RS2000 and the picture looks fantastic. The people in this thread who have seen internal reflections have indicated that the problem is worse toward 0% lens shift. Some have hypothesized that using a lot of lens shift may cause uneven focus or other issues but others (like myself) see no detectible detrimental effects.
I would also start horizontally centered. That gives you the most vertical shift range and if there are any slight asymmetries they will tend to be less noticeable vertically than horizontally.
mattztt is offline
post #6114 of 14131 Old 02-18-2019, 09:54 PM
markmon1's Avatar
Liked: 2950
Right?
I kind of feel like we're all here to learn about our projectors and enjoy them. It's hard to enjoy your projector if you're obsessed with things that aren't that important
I'd stick to caring about problems that matter or impact the actual performance in a noticeable way.
davidahn and Mike Garrett like this.
markmon1 is offline
post #6115 of 14131 Old 02-18-2019, 09:57 PM
SirMaster's Avatar
Quoted: 390 Post(s)
Liked: 392
Except madVR only runs on Windows and through DirectX on a relatively powerful nVidia or AMD GPU. How would you put that in a projector? Even a console like a Playstation isn't allowed to use DirectX because it's completely controlled by Microsoft. Now if madVR was written to run on OpenGL then maybe we would have something.
SirMaster is offline
post #6116 of 14131 Old 02-18-2019, 09:58 PM
RapalloAV's Avatar
Quoted: 2205 Post(s)
Liked: 766
Im doing exactly the same as welll, 2.4 gamma on the NX9 and 2.4 gamma in madvr, it looks beautiful on SDR and HDR. All the shadow detail is there right down to 17 and 234 which was harder to achieve on the X9900.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #6117 of 14131 Old 02-18-2019, 10:03 PM
markmon1's Avatar
Liked: 2950
I don't think the issue is directx or licensing to microsoft. JVC would need a very power processor with capabilities similar to a GTX 1080ti I think. If JVC wanted to work with madshi and provided a proper hardware platform and dev kit, I'm sure he could make it happen. It wont.
markmon1 is offline
post #6118 of 14131 Old 02-18-2019, 10:08 PM
SirMaster's Avatar
Quoted: 390 Post(s)
Liked: 392
To not use DirectX madshi would have to completely rewrite madVR and how do you know he knows as much about OpenGL for instance? He’s heavily utilizing The DirectX framework to handle the complex processing.
I mean anything is technically possible, but yeah it would be quite a different functioning system and a rework of all the code to remove DirectX from the equation.
Also, if it was just for doing tone mapping you don’t really need anything near a 1080Ti. My laptop's 65W GTX 1060 max-q has no problems with the latest builds and dynamic tone-mapping with all the trade quality for performance options unchecked. Though of course it would be nice to have some of the other features built into a display as well.
post #6119 of 14131 Old 02-18-2019, 10:38 PM
Industry Insider
Liked: 6404
I think another key point wold be maximize what projectors can do as well.
post #6120 of 14131 Old 02-18-2019, 11:31 PM
Liked: 305
Right, but then again what we think is important is subjective also. I’m still using the crap outta my projector. Just want to make sure I’m not missing anything. I’m anal about little details.
Jvc , nx7 , nx9 , rs2000 , rs3000
