Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 216 - AVS Forum | Home Theater Discussions And Reviews
 13280Likes
post #6451 of 14022 Old 02-22-2019, 08:57 AM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
Originally Posted by smitty View Post
I use that exact same cable and it has worked flawlessly for 4K content.
Reddig likes this.
mattztt is offline
post #6452 of 14022 Old 02-22-2019, 09:11 AM
jszei's Avatar
Quoted: 28 Post(s)
Liked: 30
My NX-5 arrived today. What's the recommended mount for it?
Surround Theater: Panasonic DP-UB820-> Yamaha CX-A5200-> Emotiva amps-> Paradigm Persona 9H, JL Fathom v2, JVC NX-5
Two channel: Custom Audio Linux Server (sCLK-EX modified motherboard, Mutec REF 10)->AL NUC NA->Holo Spring L3 DAC ->Audio Research LS28->Benchmark AHB2 ->Paradigm Persona 9H Analog: VPI Prime (Ortofon Quintet Black)-> Simaudio Neo 310LP
jszei is offline
post #6453 of 14022 Old 02-22-2019, 09:20 AM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
Chief RPMA-281
coxy2416 likes this.
mattztt is offline
post #6454 of 14022 Old 02-22-2019, 09:22 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3464 Post(s)
Liked: 1621
Originally Posted by ChldsPlay View Post
They're 25'.
Awwww....for a 25'er, why tap out a fellow member at such a price point?
I have used, do use this source repeatedly and I have NEVER had a failure to get 18 gb [email protected] 4:4:4 HDR10 to pass'
https://www.amazon.com/dp/B06XS3CNRS/
Name:	Cable Matters HDMI.jpg
PioManiac, ChldsPlay and Reddig like this.
MississippiMan is offline
post #6455 of 14022 Old 02-22-2019, 09:24 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6395 Post(s)
Liked: 6394
They're 25'.
You have any shorter known Premium certified cables around the house, try that out real quick if your devises or projector are easy to get to and move around........
mikela and Reddig like this.
Cleveland Plasma is offline
post #6456 of 14022 Old 02-22-2019, 09:26 AM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Originally Posted by Mike Garrett View Post
It always takes a while to get the official release. Same thing with Sony and Epson. You will see new models released with new firmware from all three and yet it will take a month or so, before it shows up officially. Should see something early to mid March.
Hopefully with the fix the the Yellow DI :-)
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #6457 of 14022 Old 02-22-2019, 09:26 AM
jszei's Avatar
Quoted: 28 Post(s)
Liked: 30
Chief RPMA-281
jszei is offline
post #6458 of 14022 Old 02-22-2019, 09:27 AM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Originally Posted by mavromatis View Post
I had similar issues and it was all my cable... try plugging directly to the projector with a shorter hdmi cable. If it works, then you’ve ruled out the projector. My issue was cable length 25’ for hdr was borderline... surprisingly a $23 hdmi 2.0 repeater solves my issue. I even tried an hdbaset extender using a shielded cat6 and that was causing the banding issues with hdr content.
I use Amazon Basics 25ft. It is a very well built cable and have no issues with 18gpps connection. All for just $13
No need to spend any more money than you absolutely have to.
https://www.amazon.com/dp/B014I8TC4E..._7edCCbS4T86KV
If it doesnt work you can always return it and get one of those "premium certified cables"
tommarra is offline
post #6459 of 14022 Old 02-22-2019, 09:28 AM
mavromatis's Avatar
Quoted: 88 Post(s)
Liked: 51
Originally Posted by claw View Post
I had one of those in 25 foot length and it did not support 4K60. Even 4K24 would have HDMI sync drop outs. Replaced it with a Blue Jeans Series 1.
I actually installed a BJS1 cable 25' and it didn't sync for me either... not sure what the issue was, but I also had ran a cat6 shielded 30' and wanted to get the projector up and running so I bought a HDBaseT that stated full HDMI 2.0 spec support -- while it worked, I was getting that gradient banding issue with HDR. Returned that POS and replaced it with this little HDMI 2.0 repeater before I was going to go Fiber and I was amazed that it worked!
mavromatis is offline
post #6460 of 14022 Old 02-22-2019, 09:40 AM
Kevin Snyder's Avatar
Quoted: 38 Post(s)
Liked: 33
i don't have it yet, unfortunately.
"The cobbler's children have no shoes" sound familiar???
Kevin
Mike Garrett likes this.
Kevin Snyder is offline
post #6461 of 14022 Old 02-22-2019, 09:46 AM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
Given how many stories I've seen like yours it seems like 25' is just at the practical limit for effective transmission of 4K and variations in cable manufacture, source/sink device, bend radius, or RF environment appear to be enough to cause a failure. My run is just over 30 feet so I couldn't have used a 25' certified cable anyway, but I think I'd use fiber regardless for any run over 15-20' just for peace of mind. The cost is a rounding error compared to everything else in the room.
markmon1 and Reddig like this.
mattztt is offline
post #6462 of 14022 Old 02-22-2019, 09:47 AM
claw's Avatar
Quoted: 2215 Post(s)
Liked: 2070
I think you meant 4K60 4:2:2 HDR10. 4K60 4:4:4 is limited to 8-bit so not appropriate for HDR. 4K60 4:4:4 10-bit is not supported in HDMI 2.0 as it exceeds 18Gbps and no JVC projector will accept it.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Vertex/Linker/Integral
claw is offline
post #6463 of 14022 Old 02-22-2019, 09:52 AM
smitty's Avatar
Quoted: 748 Post(s)
Liked: 986
Because it's been tested along with lots of competing brands by some of the guru's around here and it, along with the Ruipro, were the only two cables that passed all tests for longer runs.
I agree that if you want to try find a cheaper cable that works, that's fine. And if a cheaper one doesn't work, you can always return it and try another. For me, if I'm buying a $5,000+ projector and have to deal with sync times, DI, tone mapping, changing metadata on HDR discs, calibration issues, issues with various streaming sources, and all the things that go into this hobby now with these complicated projectors, the last thing I want to be fiddling with and changing out over and over and playing guessing games with, is my HDMI cable. I want to eliminate as best I can one potentially problematic variable. But that's just me, and I fully understand why other people might want to try other alternatives, especially for the 25 feet distance.
mattztt likes this.
smitty is offline
post #6464 of 14022 Old 02-22-2019, 09:57 AM
coxy2416's Avatar
Quoted: 557 Post(s)
Liked: 327
I agree that if you want to try find a cheaper cable that works, that's fine. And if a cheaper one doesn't work, you can always return it and try another. For me, if I'm buying a $5,000+ projector and have to deal with sync times, DI, tone mapping, changing metadata on HDR discs, calibration issues, issues with various streaming sources, and all the things that go into this hobby now with these complicated projectors, the last thing I want to be fiddling with and changing out over and over and playing guessing games with, is my HDMI cable. I want to eliminate as best I can one potentially problematic variable. But that's just me, and I fully understand why other people might want to try other alternatives, especially for the 25 feet distance. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
I have a 50 foot monoprice fibre optic cable. There are 2 reason I bought it:
1) it works!
2) it is easy to snake through an in ceiling conduit
coxy2416 is offline
post #6465 of 14022 Old 02-22-2019, 10:01 AM
Mike Garrett's Avatar
Quoted: 11816 Post(s)
Liked: 9351
Kevin
tou·ché
Kevin Snyder likes this.
Mike Garrett is offline
post #6466 of 14022 Old 02-22-2019, 10:14 AM
JeffR1's Avatar
Quoted: 1054 Post(s)
Liked: 508
Originally Posted by yankiy View Post
Has anyone connected a PC to these projectors yet with native 4K output for regular windows desktop use? I connected my work laptop to my NX9. I really did expect to see an incredible image, but unless my laptop really sucks at sending 4K data to my projector, the text looked horrible. Not what I would have expected at all. I wonder if it's my screen material that may be causing the issue. I will take a picture of it this weekend. I have a grey 1.3 gain ambient light rejecting screen from Elunevision called Aurora. I also have the regular 1.0 white screen from them with no sparkling. Not sure if I should switch the screens. I do love the black level performance of the grey Aurora, but It leaves me wondering if I'm leaving anything on the table by using that screen.
Anyone using MadVR will have some sort of PC connected to their projector.
You don't say how old you laptop is or what kind of video card it has, but generally you right click on the desk top and open "settings" for you video card.
There under "resolution" you can change the chroma subsampling, and resolution _ if available.
JeffR1 is offline
post #6467 of 14022 Old 02-22-2019, 10:24 AM
coxy2416's Avatar
Quoted: 557 Post(s)
Liked: 327
Originally Posted by gigq View Post
Originally Posted by coxy2416 View Post
On my X790 I always see issues with that Infinity War scene that you are referring to. If I set the DI to auto it always makes that scene way too dim. Now if I switch it to manual it will always looks good as the DI isn’t clamping down on that scene. I am using Javs custom curves.
Now you are saying you do not have that issue while using MadVR? And what projector are you using MadVR with at this moment and testing out that scene?
Correct, if setup with the proper nits value that the projector is outputting then MadVR handles scaling everything appropriately so I’m not having any issues with scenes like that. This is on my old projector I haven’t sold yet, a Sony 675ES.
Looks like I need to get myself an RTX 2060 so I can try out this MadVR. Too bad they are $500 in Canada!
coxy2416 is offline
post #6468 of 14022 Old 02-22-2019, 10:28 AM
PioManiac's Avatar
Quoted: 3172 Post(s)
Liked: 7742
^^^^^^^^^100% This for a 25' Run! ...and just $22!
Passes Billy Lynn's 4K/60 BT.2020 HDR 4:2:2 12 Bit torture test at 17.8Gbps (593MHz) (Oppo 203)
Regular 24p 4K/HDR/UHD's at 4:4:4 12Bit (13.4Gbps/ 445MHz) (Panasonic UB900)
Reddig and cindernat like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #6469 of 14022 Old 02-22-2019, 11:13 AM
Chris Kane's Avatar
Quoted: 37 Post(s)
Originally Posted by BondDonBond View Post
Have the same screen and projector. Center middle is the best. Mine is about 20" above middle of screen. Works great.
Chris Kane is offline
post #6470 of 14022 Old 02-22-2019, 12:36 PM
PioManiac's Avatar
Liked: 7742
Originally Posted by Willie View Post
I would check the 3050 specs. That receiver is old enough that it may not support full bandwidth 4K @18GB.
The screen shots I just posted above are routed through my RX-A3050, from almost 3 years ago
post #6471 of 14022 Old 02-22-2019, 12:50 PM
Erod's Avatar
Quoted: 1217 Post(s)
Liked: 739
How exactly do you tell how many gpps you are getting in your system?
All I can see is that I'm getting 12 bit.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: Jamo 626k4 in-wall mains, Jamo 631k4 bi/dipole surrounds, DefTech DI6.5R heights
Erod is offline
post #6472 of 14022 Old 02-22-2019, 12:54 PM
kennyz06's Avatar
Quoted: 29 Post(s)
Finally opened up the box and got my NX7 on the shelf last night.
I watched How to Train Your Dragon 2 (blu-ray) on it without changing any settings out of the box. I only adjusted the zoom/focus and position to fit my screen. No adjustments to convergence, brightness, etc. Oh wait, I did turn CMD off.
Initial impressions were that it's like I went from your standard theater (my Panasonic AE8000U) to a Dolby Cinema (a good one).
After the movie, I tried to watch a few short clips of 4K material, but ran into some problems.
When I played 4K files on my Zappiti One, ufortunately, I saw that the projector was being fed 1080p. Went through settings on the Zappiti and couldn't find anything. On the "TV System" setting, I had selected auto, but of the other selections, the highest it went to was 1080p, there was no 4K resolution listed.
Then I went to my Xbox One S, and it immediately said I had a 4K display and asked if I wanted to change the resolution. I clicked yes, and then the screen went blank and said no signal. I had to turn off my receiver (Yamaha A3050) and turn it back on to get a picture again - and that was the Xbox saying that the attempt didn't work. I checked the details screen, and it said my TV system was capable of 4K, but then said I wasn't able to do some other things. I went through some of the troubleshooting steps on the Xbox and got a few more of the items checked off, but most still said they wouldn't work. After this, I did get a 4K signal when watching Netflix, however, it was still not HDR. Zappiti is still just doing 1080p.
I'm not sure if I'm just not having the settings right, or if there is something wrong with 1 or more of my devices (or cables - Monoprice redmere). Any settings on the JVC (or the other devices) I should look at as a possible culprit?
Here's the initial detail on the Xbox:
Edit: Also, I did try putting the lamp in high mode before shutting down for the night, and the fan was quite loud.
I had this same issue with mine on my Denon. I had to set the HDMI 4k settings to enhanced on my receiver. Fixed the issue for me!
kennyz06 is offline
post #6473 of 14022 Old 02-22-2019, 01:05 PM
kennyz06's Avatar
Quoted: 29 Post(s)
Got my NX7 last week and really been working on trying to adjust the picture, but I'm struggling. I probably dont know enough about what each setting does to really be using it correctly. Is there a consolidated list of recommended settings to really get the best performance out of this unit? The picture seems a bit dark sometimes when watching 4k discs.
Is there a recommendation on the low latency or CMD stuff? I like the picture to look smooth....
I have the aperture set to Auto 1 as well.
Thanks and sorry if it's a redundant question. This post has really exploded and gone so many directions.
Screen is 1.1 gain and room is completely light controlled, but we do like a little light when playing games or just watching regular TV. Love it blacked out for movies.
Pics of new room and NX7
Dandlj likes this.
kennyz06 is offline
post #6474 of 14022 Old 02-22-2019, 01:10 PM
smitty's Avatar
Quoted: 748 Post(s)
Liked: 986
Originally Posted by kennyz06 View Post
Nice theater! Really like those doors too.
Jim Cutter likes this.
smitty is offline
post #6475 of 14022 Old 02-22-2019, 01:17 PM
Quoted: 79 Post(s)
Liked: 82
If you are using auto tone mapping on a large screen you should probably bump up the mapping level until the picture is bright enough, I found setting mine to +3 and then increasing the contrast to 7 and the decreasing the brightness to -3 got me a decent picture with HDR, the contrast and mapping level got the picture bright enough and the -3 brightness got the black floor low enough to have a full fade to black with the DI engaged.
markmon1 likes this.
gigq is offline
post #6476 of 14022 Old 02-22-2019, 01:23 PM
703
703's Avatar
Quoted: 152 Post(s)
Liked: 49
I have the Amazon 25FT cable, it was artefacting at 4K60. Getting a premium certified mono priced cable solved the problem.
703 is offline
post #6477 of 14022 Old 02-22-2019, 02:27 PM
GPBURNS's Avatar
Quoted: 382 Post(s)
Liked: 687
Just got email from dealer (Canada) that couple N7's showed up out of blue - be shipping mine out on Monday 😁😁
Toe, coxy2416 and Dandlj like this.
15400 Watts of Atmos Seaton Power -Quad SubMersived - JVC N7
GPBURNS is online now
post #6478 of 14022 Old 02-22-2019, 02:41 PM
Toe
Toe's Avatar
Quoted: 2663 Post(s)
Liked: 3400
Congrats my friend! Curious to hear your thoughts once your up and running.
GPBURNS likes this.
Toe is offline
post #6479 of 14022 Old 02-22-2019, 03:27 PM
markmon1's Avatar
Quoted: 4639 Post(s)
Liked: 2943
Don’t get me wrong BR2049 has been my favorite movie to watch on the RS3000 because it just looks so damn good. I’m sure there are a few scenes I could pick out that show it strengths but I don’t think the JVC autotone mapping has any problems with that movie so only reason I mention the others.
Which version of blade runner 2049? I have the Sony version, which is mastered for a much brighter nit monitor than the USA WB version that most of you probably have. This has never looked good before the last two weeks version of madVR. It was definitely watchable before, but now it actually impresses as if I'm seeing HDR for the first time.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6480 of 14022 Old 02-22-2019, 03:34 PM
markmon1's Avatar
Liked: 2943
It's very likely your laptop sucks at sending a true 4K desktop.
Try the following things to clear up text as a starting point:
1) Go to display properties in the graphics card and set up 4k / 60 / RGB 8 bit. None of this yuv stuff.
2) Go to display settings in windows, and set dpi scaling to 100% not 150% not 225% etc. This will make the text small, but it will be non-scaled and should be crisp and sharp.
markmon1 is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
