Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 231 - AVS Forum | Home Theater Discussions And Reviews
 25270Likes
post #6901 of 28770 Old 02-27-2019, 02:18 PM
Willie's Avatar
Quoted: 250 Post(s)
Liked: 341
Timed my RS1000 time to logo today @40 seconds with v 1.19. I have no reason to go to 1.20 at this point.
Willie is offline
post #6902 of 28770 Old 02-27-2019, 02:20 PM
ChldsPlay's Avatar
Quoted: 1203 Post(s)
Liked: 704
So, will an IR 3D emitter work with these, or does it have to be an RF emitter?
The Hodor Theater - Now with Atmos
Projector - JVC D-ILA NX7; Receiver - Yamaha Adventage A3050
LCR speakers - JTR Noesis 228 HT (3); Surr./Back - Klipsch Pro Cinema KPT-8000M (4)
Atmos In-ceiling - Niles DS8HD (4); Subs - Passive JTR Captivator Pro (2)
ChldsPlay is offline
post #6903 of 28770 Old 02-27-2019, 02:21 PM
Cleveland Plasma's Avatar
Quoted: 7652 Post(s)
Liked: 7716
Originally Posted by OzHDHT View Post
Hard to say what the story with existing units will be, but lets hope not. This was actual JVC info from them to me just to clarify.
Yep enough for JVC to slow production right down again it seems..
Seems like units are flowing pretty good now, except for the NX9 / RS3000. In the USA anyway.......
Cleveland Plasma is offline
post #6904 of 28770 Old 02-27-2019, 02:24 PM
madshi's Avatar
Quoted: 2884 Post(s)
Liked: 4358
Originally Posted by markmon1 View Post
madVR works on the HTPC, the HTPC does not have an HDMI input that routes to direct show based players. So no, you cannot use madVR for anything that doesn't originate on the PC at this time.
Stay tuned...
madshi is offline
post #6905 of 28770 Old 02-27-2019, 02:28 PM
JohnnyWilkinson's Avatar
Quoted: 387 Post(s)
Liked: 260
Thumbs up
Originally Posted by madshi View Post
stay tuned...
JohnnyWilkinson is offline
post #6906 of 28770 Old 02-27-2019, 02:42 PM
ChldsPlay's Avatar
Liked: 704
post #6907 of 28770 Old 02-27-2019, 02:43 PM
DennisLJacob's Avatar
Quoted: 174 Post(s)
Liked: 96
RF emitter the model number eludes me. I just got my first pair of expand vision glasses. So I'm ready to try out 3D on the big screen.
DennisLJacob is offline
post #6908 of 28770 Old 02-27-2019, 03:52 PM
SirMaster's Avatar
Quoted: 1389 Post(s)
Liked: 1045
As far as I know, you can use both an IR or RF emitter.
See the NX7 manual:
http://www33.jvckenwood.com/pdfs/B5A-2809-01.pdf
Page 9 says you can use PK-EM1 (IR) or PK-EM2 (RF) emitters.
SirMaster is offline
post #6909 of 28770 Old 02-27-2019, 04:19 PM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 197
Originally Posted by DennisLJacob View Post
Back a few pages someone was asking about cleaning his lens. Everyone basically said leave it alon How would a "dust-off" pressure can air work? .
Do NOT use a pressure can on this or any other lens. they are waaay to strong. They are also blowing very cold air.
It most likely will not need cleaning unles you got your fingres on it. and small visible dust is going to be there no matter what.
If you must clean it do this:
Wash your hands thtorough with soap and water. or put on gloves. grease from your fingers will smudge or get picked up by the cleaning cloth.
Use a brand new micro-fibre cloth (or one that has just been washed) and gently brush from the center to the outside. Some cloths are better than others, the newer types feel "grippy" and soak up grease fast.
If there is still any grease on the lens then use a new single-pack wet cloth designed for cleaning coated eyeglasses, same deal middle to out (so you don't drag stuff from the out sides into the lens).
If there is still grease even after this (which there should not be unless you smeared it with popcorn grease), put a very small dot of plant-based, non perfumed, dish-washing liquid (not petroleum based) on a cloth and apply to lens, then wash off with a damp cloth then finally with a dry cloth. THIS SHOULD NOT BE NEEDED but is a last resort.
Purple X is offline
post #6910 of 28770 Old 02-27-2019, 04:21 PM
Mike Garrett's Avatar
Quoted: 14054 Post(s)
Liked: 11733
I don't think they've actually stopped production as that wasn't said to me. It was portrayed as delivery delays, but linked back to the original unspecified issue from late last year issue.
Thanks for the clarification. I do know that production is ongoing, but yes it has been slow rollout.
Mike Garrett is offline
post #6911 of 28770 Old 02-27-2019, 04:26 PM
Liked: 11733
Yes, I believe it is backwards compatible.
post #6912 of 28770 Old 02-27-2019, 04:41 PM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 197
Auto-Tone mapping
So I've got 180 odd hours on the projector now and have pretty much got the settings bedded down now so I though I'd share.
Setting the Mapping level for Auto-Tone mapping raises both picture tone an dark tone; but it also seems to raise the black floor, which kills contrast and DI. Its not easy to get a manual setting that matches auto. So I played around quite a bit on how to counter that. I found best way is to reduce the brightness control as you increase the mapping level. For mapping level + 3 I use brightness -8.
This is not crushing blacks, contrast is back and DI is working as expected. You get auto-mapped HDR that works most all of the time. It is easy enough to change brightness if you do come across something that obviously crushes.
SDR performance is just suburb as is, I don't use DI with SDR. Set brightness -1.
I've viewed one HDR title so far that really tripped up auto-mapping and the required wildly weird manual settings to display correctly (Paddington 2 on itunes -8, 0 -7, ) I use brightness 0 for manual settings.
smitty, mattztt and Renerator like this.
Purple X is offline
post #6913 of 28770 Old 02-27-2019, 05:02 PM
Quoted: 6294 Post(s)
Liked: 2652
The manual says you can use either PK-EM1 (IR) or PK-EM2 (RF)
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #6914 of 28770 Old 02-27-2019, 05:06 PM
coderguy's Avatar
Quoted: 3022 Post(s)
Liked: 1604
Originally Posted by SOWK View Post
All the JVC are defective. Please send them to me, I'll dispose of them for you guys!
Helarios....
That's the Sci Fi version of how to say 'that was funny'...
Same here, I will even pay a recycling fee
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #6915 of 28770 Old 02-27-2019, 05:25 PM
blee0120's Avatar
Quoted: 1097 Post(s)
Liked: 792
See the NX7 manual:
That's great. Still got my ir emitter and 3d glass from the rs40 in 2010
blee0120 is offline
post #6916 of 28770 Old 02-27-2019, 05:41 PM
ultra 150 pilot's Avatar
Quoted: 291 Post(s)
Liked: 266
It works great, I’m using an emitter and glasses from an x30
ultra 150 pilot is offline
post #6917 of 28770 Old 02-27-2019, 05:45 PM
avsBuddy's Avatar
Quoted: 207 Post(s)
Liked: 124
How is it possible that we have same projector on same firmware but mine takes 2 whole minutes longer to get to logo?
avsBuddy is offline
post #6918 of 28770 Old 02-27-2019, 05:52 PM
deltagamma's Avatar
Liked: 25
Originally Posted by Jim Cutter View Post
Nice to see someone else in my neighborhood. I would love to see your RS3000 sometime. I have a RS2000 on order but haven't received it yet.
I'd love to show it to you sometime! Unfortunately, at the moment my theater isn't functional. This is a new theater that I'm building (in a house that I'm totally renovating) - there was an issue with the carpet install (wrong color) that I'm still trying to resolve with the carpet company. So right now the projector, speakers, chairs, and everything else is sitting on the floor in the master bedroom.
I had the RS3000 operating for only part of a day to make sure it was fully functional. For what I saw in that short amount of time, I thought the picture was quite excellent. Looks like it's going to be another 3 weeks or so before I'll be able to enjoy it! Pretty frustrating.
I'm really interested in what markmon1 had to say about using MadVR with the JVC projectors in this forum - I doubt I would have considered it otherwise. So now my next-gen HTPC will have to include that as well. I'll be thinking about this while I wait for the carpet to be resolved.
I'd also be interested in seeing your RS2000 when you get it set up.
rdf325 likes this.
deltagamma is offline
post #6919 of 28770 Old 02-27-2019, 05:54 PM
markmon1's Avatar
Quoted: 6841 Post(s)
Liked: 4965
You wanna bring the projector out to Hillsboro and do side-by-side with the RS4500?
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is online now
post #6920 of 28770 Old 02-27-2019, 05:58 PM
deltagamma's Avatar
Liked: 25
Yeah, that could be fun! I just got sick with a cold a few days ago, but once I get over that, I'd love to see your RS4500 in action - especially with MadVR.
post #6921 of 28770 Old 02-27-2019, 05:59 PM
mauricef's Avatar
Quoted: 47 Post(s)
Liked: 46
After a month of waiting I finally received my RS3000 replacement for my yellow blob infected unit. The new projector seems like a keeper. The focus and convergence are spot on, no iris noise, no bright corners, and it even seems a little brighter. It arrived with firmware 1.17 installed. An interesting note is that the serial number is only 30 units away from my original unit so maybe it is from the same lot. I thought I might get a unit with a newer build month. Maybe they are not shipping that may 3000s.
mauricef is offline
post #6922 of 28770 Old 02-27-2019, 06:01 PM
markmon1's Avatar
Liked: 4965
Sweet. Just let me know when you are interested. I dont work and am available 7 days a week after 3pm. If you wanted to build something for madvr for yourself I'd be happy to assist. @Jim Cutter is welcome to come if he is interested in the compare.
Jim Cutter likes this.
post #6923 of 28770 Old 02-27-2019, 06:11 PM
Jim Cutter's Avatar
Quoted: 205 Post(s)
Liked: 213
This would be neat to see since I wanted to see the RS4500 at markmon1's place too. To see it next to the RS3000 would be cool! I want to get some more info on the MadVR too. Let me know when you are both going to meet up as I would like to be there to if that's alright with both of you.
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #6924 of 28770 Old 02-27-2019, 06:14 PM
Jim Cutter's Avatar
Quoted: 205 Post(s)
Liked: 213
If we can do it on a weekend it would be better for traffic. I work Mon-Thur so I should be able to do it most weekends although I have to cover call once every 5 weeks.
post #6925 of 28770 Old 02-27-2019, 06:19 PM
deltagamma's Avatar
Liked: 25
My day typically starts at around 4pm as well...and if the sun is coming up, it's time for bed.
post #6926 of 28770 Old 02-27-2019, 06:24 PM
deltagamma's Avatar
Liked: 25
That would be great! I should be over my cold in a week or two.
post #6927 of 28770 Old 02-27-2019, 07:20 PM
ajax-jp's Avatar
Quoted: 57 Post(s)
Liked: 33
For those who have seen both, is the N9/RS3000 worth the extra $$ over the N7/RS2000?
Really would love to see all 3 units, calibrated by the same person compared side by side.
Speakers: Fronts: Triton One | Center: Supercenter XL | Surrounds: SuperSat 50 | Rear Surrounds: Invisa HTR 7000 | Atmos: 4x Invisa 650
Receiver: Anthem MRX 1120 | Electronics: XBOX One X, PS4 Pro, Roku Ultra, Chromecast Ultra | Power Management: Panamax M5400-PM
Projector: JVC DLA-NX9 | Screen: Screen Innovations Zero Edge Pro 135"
ajax-jp is offline
post #6928 of 28770 Old 02-27-2019, 07:30 PM
tommarra's Avatar
Quoted: 1023 Post(s)
Liked: 599
Can someone please help me convert light meter Lux or FC measurement into fL or Nits ... how do I use the light meter to set my lens aperture to get 16fL in SDR?
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 684S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Arcam AV40 + Monoprice Monolith 7x200 + Outlaw 7000x | Projector: JVC NX7 | Screen: 126 inch 16:9 Stewart Studiotek 130 G4 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #6929 of 28770 Old 02-27-2019, 07:36 PM
Quoted: 144 Post(s)
Liked: 96
Markmon when you say hillsboro are you talking Ohio
SSnarski is offline
post #6930 of 28770 Old 02-27-2019, 08:11 PM
blee0120's Avatar
Liked: 792
I was worried that they may drop it this year with the new design but we are lucky. My RS2000 should be at my door on Monday. Got lots of new 4k movies, plus got to rewatch majority of my 4k collection. Gonna be fun
Dandlj likes this.
blee0120 is offline
drift , Jvc , nx5 , nx7 , nx9 , pixel alignment , rs1000 , rs2000 , rs3000
