Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 355 - AVS Forum | Home Theater Discussions And Reviews
 14103Likes
post #10621 of 15188 Old 04-27-2019, 08:12 PM
Mike Garrett's Avatar
Quoted: 12028 Post(s)
Liked: 9548
Originally Posted by pjones View Post
Similar phenomenon has been reported by several of us over the past couple of weeks in this thread. JVC replaced mine because of it, see my report here, with photos from others above. My replacement unit is still working well with a solid week of usage now.
I suspect the next firmware update will solve this problem.
Todd G. likes this.
Mike Garrett is online now
post #10622 of 15188 Old 04-27-2019, 08:16 PM
Liked: 9548
Originally Posted by slots1 View Post
I also think my NX9 out of the box is amazing
Only thing my 53 X 121 inch screen, does fit my 16 X 9 at 13.5 feet
When I switch to 2.35 video i zoom out to full max.
I have a 3 inch open border around the whole screen.
Can only move projector back another 6 inches.
So either new screen or anamorphic lens??
My sony es600 had no problem filling the screen
It would have to be a horizontal expansion lens. The vertical compression lens will not give you a larger image. Other option would be a conversion lens, but 4K conversion lens is as expensive as a high end A-lens.
post #10623 of 15188 Old 04-27-2019, 08:19 PM
Liked: 9548
Thank you!
I still have to go about setting up my RS600 for UHD/4K.
I'd bought a cable that purportedly was the "right one" and tested for longer distance transmission, but when I tried setting up my UHD player I was getting all sorts of sync problems. It was frustrating enough for me to give up at the time (especially as re-wiring for UHD is a significant undertaking in my set up, hence I don't want to f$ck around rewiring through ceilings and walls only to have introduced glitchiness in to my system).
More than half the cables out there that are reported by the manufacturer to work, do not.
post #10624 of 15188 Old 04-27-2019, 08:23 PM
Liked: 9548
Originally Posted by desray2k View Post
To NX7 owners, what is the optimum Lamp IRIS setting you have set to date which you find most satisfying for SDR (Rec709) color profile?
Is it -5 or -10 or perhaps any other figures?
This question can't be answered. What is optimal for others would not apply to you, unless they had the same room, same size screen, same fabric in screen, same aspect ratio, same throw and prefered the same brightness as you.
desray2k and Jacob92175 like this.
post #10625 of 15188 Old 04-27-2019, 08:37 PM
dsm1212's Avatar
Quoted: 36 Post(s)
Originally Posted by locutus2k View Post
I had an issue similar to yours in my N9. Service did a firmware upgrade to version 2.05 that fixed it (and no you can't do it by yourself is a service operation). I'm having different issues right now, not sure if this is a software or hardware issue.
Interesting. I thought that we could do firmware updates? Maybe you mean 2.0.5 isn't available yet and service is required to get it?? Mine came with 2.0.4 but only 2.0.1 seems to be available on the jvc site for download.
steve
dsm1212 is offline
post #10626 of 15188 Old 04-27-2019, 08:43 PM
dsm1212's Avatar
Quoted: 36 Post(s)
Usually when I start my system with a logitech remote I using the roku activity. Something is happening that maybe 50% of the time the AVR shows no signal input from the roku. I have to unplug and replug an HDMI cable to get it connected. I've replaced everything recently (AVR, cables, PJ) except the roku so I'm not sure if I have a compatibility issue or a timing problem on startup. Is there a recommendation for JVC startup order you folks can suggest? I seem to recall I did something like this for my sony projector but it was so long ago I can't remember. I think I added delay in the startup but I can't recall where. I've tried pj first and pj last but it makes no difference.
steve
dsm1212 is offline
post #10627 of 15188 Old 04-27-2019, 09:22 PM
R Harkness's Avatar
Quoted: 2756 Post(s)
Liked: 2675
Thanks Mike.
I bought my cable quite a while back when everyone was testing UHD cables. I was headed for the Celerity cable which seemed to be the popular one, when at the last minute info arose that the Celerity wasn't as reliable and in fact the RUIPRO had been tested as actually working for 50 foot lengths. So I switched to the RUIPRO. But, things were still glitchy. Gotta figure that out.
Has any new long-length cable (e.g. 50 feet) come to the forefront that seems to work reliably?
R Harkness is offline
post #10628 of 15188 Old 04-27-2019, 10:32 PM
bathes2051's Avatar
Quoted: 56 Post(s)
Liked: 30
Originally Posted by davidahn View Post
It seems to be using high lamp mode, as any HDR material makes the fan kick into high.
Does this mean that the Low Lamp setting only applies to SDR, and that HDR always uses High Lamp (like 3D mode on previous pjs)?
bathes2051 is offline
post #10629 of 15188 Old 04-27-2019, 10:57 PM
bathes2051's Avatar
Quoted: 56 Post(s)
Liked: 30
Originally Posted by Nicoff View Post
Has anybody here used the PXLDRIVE device to avoid having to replace an older passive HDMI cable? I have a 30 feet run and would like to avoid having to run new cables.
The mention of the PXLDRIVE in this review is actually what made me jump in.
If you look at the white paper from their web site, they claim to have a much better design compared to other boosters (like the Gigabit Accelerator, I suppose) - loss detection, full re-clocking past EQ to remove both existing and EQ-induced jitter.
I have a cable that’s at the very end of their mentioned uncorrected passive 18 Gps support range (12 m/22 AWG), but it was listed by the manufacturer as supporting 10.2 Gbps (that was before HDMI 2.0 existed).
So according to the test report in the white paper, other accelerators wouldn’t help my cable, because it’s not lossy enough, so they would apply too much gain. A thinner cable would actually perform better when boosted.
Their solution claims to be one-size-fits-all.
They were announced at Cedia 2016 and their booster is THX-certified for cables, I guess that’s something (they list the THX certification tests in the white paper).
Anyway, I bought a PIXLDRIVE, and we’ll see.
I almost bought a Sony projector that only supported 10.2 Gbps, so if I only get that, it’s not the end of the world, and I still have other options.
The link to this product is under the video on YouTube.
post #10630 of 15188 Old 04-27-2019, 11:12 PM
bathes2051's Avatar
Quoted: 56 Post(s)
Liked: 30
Coincidence, I just mentioned the PIXLDRIVE booster, and the company that makes them also sells two kinds of cables:
- a hybrid fiber/copper design up to 50m (!)
- a bundle of cables and PIXLGEN (10 and 15m) that is “guaranteed” to support the future HDMI 2.1 8K/48Gbps standard by replacing the booster with the future version.
I have no idea what they’re worth, but they also have PDF documentation (along with a blog with more info), so perhaps it’s worth a look.
R Harkness likes this.
post #10631 of 15188 Old 04-27-2019, 11:31 PM
claw's Avatar
Quoted: 2273 Post(s)
Liked: 2111
Originally Posted by lastbeat View Post
I'm thinking of replacing my Sony 4k player with the Panny 820 everyone talks about here.
Can someone tell me, if there is no metadata on an HDR disc, does the Panasonic have something to at least rough out a better image? Is that what the optimizer does?
I'm still trying to figure out a good solution for when the NX7 can't auto tone map.
I can tell you what the UB820 outputs but can't tell you how it will look. With the UB820 set to HDR mode, the Optimizer turned ON, and HDR Display Type set to the 500 nit Projector setting:
Terminator 2 MaxDML=0, MaxCLL=0 and MaxFall=0
UB820 outputs MaxDML=500 MaxCLL=500 and MaxFall=0
Red Sparrow MaxDML=1000, MaxCLL=0 and MaxFall=0
Sicario MaxDML=4000, MaxCLL=0 and MaxFall=0
In each case the JVC will see 500 nit content.
I can't say for certain but I believe that:
UB820 will tone map Terminator 2 to 500 nits, assuming the content highlights reach 1000 nits.
UB820 will tone map Red Sparrow to 500 nits, assuming the content highlights reach 1000 nits.
UB820 will tone map Sicario to 500 nits, assuming the content highlights reach 4000 nits.
Clark Burk likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #10632 of 15188 Old 04-28-2019, 01:35 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 82
steve
They tell me that it was a "deeper" upgrade involving flash of the motherboard memory, not a simple firmware update. In fact, after the update all my settings were gone i've had to start all over again.
locutus2k is offline
post #10633 of 15188 Old 04-28-2019, 01:57 AM
Quoted: 128 Post(s)
Liked: 36
While using the ‘zoom’ function, i see a green line at the bottom and heavy purple fringing on the side. Is this normal ?
ID:	2559336   Click image for larger version
abinav555 is offline
post #10634 of 15188 Old 04-28-2019, 03:08 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 82
It seems that the random phenomenon of the blue/black vertical lines is an issue related to Low Latency/CMD/Motion enhance when vieving high contrast patterns like bright white letters appearing on a black background (end titles of a movie is the best example). With everything on OFF it doesn't happen but with Low Latency ON or Motion Enhance on low it does. Can someone confirm this?
And btw WHY one should use Low Latency to watch a movie? And Motion enhance in my setup doesn't seems to make some difference if switched off or low/high (apart for the random issue i've had).
post #10635 of 15188 Old 04-28-2019, 04:39 AM
Nexgen76's Avatar
Quoted: 739 Post(s)
Liked: 218
While watching Demo of The Art of Flight SDR i get this crap........Had to power cycle my projector to get rid of this crap..Wow..Cmon JVC.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #10636 of 15188 Old 04-28-2019, 04:59 AM
woofer's Avatar
Quoted: 1383 Post(s)
Liked: 2118
This is bordering on .... "Insane"
woofer is offline
post #10637 of 15188 Old 04-28-2019, 05:37 AM
Liked: 9548
Thanks Mike.
RUIPRO should work. What about your other HDMI cables?
post #10638 of 15188 Old 04-28-2019, 05:38 AM
Liked: 9548
Depends on how much light is needed for your setup. Most will run high lamp for HDR, but some people do run low lamp for HDR.
post #10639 of 15188 Old 04-28-2019, 06:01 AM
BdoUK's Avatar
Quoted: 42 Post(s)
Originally Posted by jbarteli View Post
Wow that expansive in the US?
Most of the better calibrators will spend 8-10 hours working on your projector. Pricing is very reasonable and well worth it IMO.
BdoUK is offline
post #10640 of 15188 Old 04-28-2019, 07:16 AM
Dave T's Avatar
Quoted: 70 Post(s)
How long does your projector take to turn on? I timed mine and it takes 3 minutes exactly, which seems crazy. Also, I have a trigger to lower my screen when the projector starts to draw power, and that takes 17 seconds, which is also annoying.
Dave T is offline
post #10641 of 15188 Old 04-28-2019, 07:19 AM
Quoted: 91 Post(s)
Liked: 115
My RS1000 takes 40 seconds or so, I start up using my Harmony remote and I place a 30 second delay before opening Kodi on my HTPC. The projector comes on 10-15 seconds after that so somewhere in the 40-45 second range.
dgrizzard is offline
post #10642 of 15188 Old 04-28-2019, 07:28 AM
Dave T's Avatar
Quoted: 70 Post(s)
Wow, that’s waaay faster than my RS2000! What firmware are you on? I upgraded mine to the latest. I wonder what else the difference could be. Are you using high lamp mode? I am.
Dave T is offline
post #10643 of 15188 Old 04-28-2019, 07:40 AM
Quoted: 91 Post(s)
Liked: 115
I haven't upgraded yet, plan to do so when I run my autocal, which I keep putting off. I am currently running 1.19. So I did a few tests, all of these are timed from hitting the on button until I see the blue screen (no content, HDMI handshake or anything), ended up being a little longer than I thought...
Low lamp - 54 seconds
(made sure to wait for the unit to go completely off/fans off in between testing)
High Lamp - 54 seconds
So for me, no difference in high or low lamp.
post #10644 of 15188 Old 04-28-2019, 07:41 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6517 Post(s)
Liked: 6490
Haven’t fully installed and gotten my NX9 set up yet, as I’m working way too many hours. But some random thoughts so far:
1. Flawless. So far absolutely no flaws. No blobs, purple fringes, nothing. Just beautiful. I wish I had time to watch some movies I’ve collected that I haven’t watched yet!
Oh yes, certainly a great projector for the price especially when you consider how good these are compared to the laser units....What was the first movie you watched?
antorsae likes this.
Cleveland Plasma is online now
post #10645 of 15188 Old 04-28-2019, 08:00 AM
Todd G.'s Avatar
Quoted: 162 Post(s)
Liked: 374
I'm a bit new to this, so let me preface this response by saying "if I understand this right..."
I think time spent often depends on how many calibrations a customer wants/needs and maybe just how much tinkering the customer wants to get things as close to perfect as possible (grayscale/color errors come to mind, but other factors may come into play). I believe the projector sample will play a part in this equation as well (whether beneficial or detrimental to the time required).
Still, four calibrations would be needed if a customer had a scope screen (SDR and HDR) but also wanted a calibration for 16:9 (masked) on the same screen (SDR and HDR again) and that could raise the amount of time needed to 8-ish hours with a good projector sample. Kris Deering calibrated my RS2000 this week and was here four hours for one SDR calibration and one HDR calibration on my 16:9 screen. All grayscale/color delta errors were less than 3, the threshold of perceptibility of such errors (many were less than 2). I think Kris had a good sample to work with in our projector.
Considering the financial commitment toward our projector and screen, I believe calibration was a worthwhile investment for us. YMMV.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #10646 of 15188 Old 04-28-2019, 08:02 AM
Todd G.'s Avatar
Quoted: 162 Post(s)
Liked: 374
But it’s gorgeous.
I saw the RS3000 (NX9) in action yesterday--very impressive. Enjoy yours!
Todd G. is offline
post #10647 of 15188 Old 04-28-2019, 08:06 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 82
What firmware version do you have? Do you had low latency and/or motion enhance enabled? It seems there is a bug related to low latency/motion enhance when an high contrast image suddenly appear on screen.
post #10648 of 15188 Old 04-28-2019, 08:20 AM
pjones's Avatar
With my first RS1000, the blue vertical stripes appeared even when CMD and Motion Enhance were off. I hadn't turned on Low Latency. Most frequently occurred with white-on-black content like end credits.
FWIW, both my original and replacement RS1000 showed having firmware version 2.04 (and take ~40 seconds from turning on to the "D-ILA" logo appearing).
pjones is offline
post #10649 of 15188 Old 04-28-2019, 12:36 PM
jmeitz's Avatar
Quoted: 55 Post(s)
Jeff from accucalav only took 3 hrs to do my NX5 and he is one of the best in the country.
Jacob92175 likes this.
jmeitz is offline
post #10650 of 15188 Old 04-28-2019, 12:52 PM
tommarra's Avatar
Quoted: 575 Post(s)
Liked: 346
It’s too dependent on room, screen size, gain, placement, lamp output ... that is why you need to calibrate or at least adjust some basic settings using a light meter to get 14-16 FL off your setup
desray2k and Todd G. like this.
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
