Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 16444Likes
post #10711 of 17821 Old 04-29-2019, 12:54 PM
davidahn's Avatar
Quoted: 97 Post(s)
Liked: 59
Bingo
Originally Posted by Th601 View Post
Hey David I’m looking for an hdmi cable from my devices to my processor. For instance a Panasonic UB820>Marantz 8805. Would these work? https://www.monoprice.com/product?p_id=31229 I don’t have a Nx9. I do have a Nx7 on preorder though. This is the only cable I see on the site that has 48Gbps. It doesn’t say 60P, 4:4:4 either.
You got it. That's the exact one I got, it comes in only 1.5 and 3 ft lengths for now.
JVC DLA-NX9 / 156" 2.4:1 CIH Seymour AT screen / Marantz AV7704 11.2 / Yamaha MX-A5000 11-ch amp
HTPC MadVR RTX 2080 / 24TB PMS Server (direct UHD rips)
Adam A8X monitor LCR / RBH A-610 x 8 / Kef Ci160ER x 4 / HSU ULS-15
Secondary: Samsung UN82MU8000 / Marantz NR1607 AVR / Kef Q150 + Minx Min 10 / SVS SB-2000
davidahn is offline
post #10712 of 17821 Old 04-29-2019, 01:02 PM
davidahn's Avatar
Quoted: 97 Post(s)
Liked: 59
Originally Posted by Dave T View Post
Ok, and thanks for trying to help. I'm just looking at specific times. I want to know if what I'm experiencing is typical or if there might be a manufacturing defect in my projector. Sure, the slow startup isn't the end of the world if it otherwise works fine. But 3 minutes is excessive. I'm hoping a future firmware update will fix it. And the 17 seconds before my screen lowers is a problem. It's the kind of thing that will confuse other family members who want to use the projector but rarely do. You press the power button on the remote and nothing happens for so long that I will be getting called before they realize that it did come up after all.
Haha no worries, just came across a bit rude; I'm sure you were just hyper focused on finding a resolution. I'll time it when I get home on Friday night, to the logo and to displaying image.
I agree 3 minutes is a long time, especially if everyone else is getting under a minute. (Ignorance is bliss... I bet you're a LOT angrier on finding out others' times.) But even at one minute, your wife/kids will start mashing buttons; 2 seconds is the limit of most people's patience. If you're using a 12V trigger to lower the screen, maybe your AVR or AV Pre-Pro could lower the screen instead of the PJ?
davidahn is offline
post #10713 of 17821 Old 04-29-2019, 01:22 PM
davidahn's Avatar
Quoted: 97 Post(s)
Liked: 59
Originally Posted by tommarra View Post
This was discussed a few post earlier and in its own dedicated post: The culprit in most cases is Contrast and Motion Enhance. The fix is as follows:
1. Turn down contrast to zero (i think the default is 7 on these PJs)
2. Turn off motion enhance, turn on low latency - this is really the key fix.
Agreed; on my NX9 the contrast default is 0, so I didn't turn that down.
The other setting that might be even more problematic than contrast is sharpness (sharpening or edge enhancement). On the NX series "sharpness" is called MPC (Multiple Pixel Control); I recommend turning that down to 0 (or 1 if that's the lowest) to reduce film grain/sensor noise.
I'll have to track down motion enhance on my PJ and check that out. My film grain noise is a LOT better after removing MPC but still objectionable. (I realize it's normal to have film grain, but it's still excessive and "sparkly".)
tommarra likes this.
davidahn is offline
post #10714 of 17821 Old 04-29-2019, 01:29 PM
davidahn's Avatar
Quoted: 97 Post(s)
Liked: 59
Originally Posted by mattztt View Post
From time to time I'm seeing an unusual artifact in content - the brighter portions of the scene have "static" in them like a television with the tuner set to an unused frequency. I've seen it in the UHD of La La Land and the Blu-ray of Unbreakable (both played on a Panasonic UHD-9000) and a streaming episode of The Walking Dead (YouTube TV/Chromecast) so its present in a variety of sources and content types. I did not notice it last night during Game of Thrones (granted, there was little brightly lit content) nor during a YouTube stream of the Falcon Heavy rocket launch from a couple weeks ago (lots of bright content).
Is this a common artifact? Does it have a name? Any thoughts on the possible cause?
As edub90 stated, it has indeed been discussed before. I believe the consensus to date is it's artificially enhanced film grain (whether native to film or added in post to digitally shot footage) by sharpness (edge enhancement). I only really fired up my NX9 this past weekend, so I hadn't seen it myself. I noticed it in certain bright scenes with large areas of the same color, with pretty active movement in the noise like static. And most of the time, no such noise. I turned down my MPC to the minimum setting (0 or 1?), contrast was already at 0 so I left it. It reduced it, but it's still there.
Almost seems like a hardware issue, but it's so intermittent. I wonder if it's a firmware issue, or a panel issue where it freaks out with a certain kind of signal?
davidahn is offline
post #10715 of 17821 Old 04-29-2019, 01:57 PM
Liked: 9
Is anyone else having problems with JVC on exchanges for defective units? My installer started to troubleshoot this over a month ago and has spoken with them directly three times, It will be difficult to uninstall the projector and replace it, I certainly don't want the extra cost. Feels unnecessary.
Haalik123 is offline
post #10716 of 17821 Old 04-29-2019, 02:29 PM
davidahn's Avatar
Quoted: 97 Post(s)
Liked: 59
[QUOTE=Th601;57972178]Hey David I’m looking for an hdmi cable from my devices to my processor. For instance a Panasonic UB820>Marantz 8805. Would these work? https://www.monoprice.com/product?p_id=31229 I don’t have a Nx9. I do have a Nx7 on preorder though. This is the only cable I see on the site that has 48Gbps. It doesn’t say 60P, 4:4:4 either./QUOTE]
Forgot to address your question about 4K/60p 4:4:4 HDR. Scroll to the table at the bottom of this page: http://community.cedia.net/blogs/dav...tes-for-4k-hdr
For 4K/60p/12 bit 4:4:4 HDR, you need 24.06 Gbps and a link speed of 24-48 Gbps, which is easily handled by this cable. And it handles 8K/60p only at 4:2:0 at up to 10 bits, not at 4:2:2 or 4:4:4.
The balun I was recommending, using HDbaseT, does NOT support 10- or 12-bit 4K/60p HDR. But it DOES support 24p and 30p at 10- and 12-bits, which is virtually all the material I watch (film, NTSC TV).
davidahn is offline
post #10717 of 17821 Old 04-29-2019, 03:12 PM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
I keep getting the intermittent, way to much clamping down of the DI on my N7. It seems more frequent now. I mentioned this before, but I use Auto2 and aperture at 0. Usually works well, I see the DI clamp just a little bit in darker scenes. This is perfect for my setup. But then, all of a sudden, it clamps down to what seems like maybe -8 or -9, making the picture way to dark, and the text gets dim eller greyish. This happens more frequent, now maybe every other time I use the projector. At first I though this was triggered by something, switching between SDR/HDR maybe, or some procedure when starting or shutting down the projector. But today I saw it triggered during a movie. To get it back to normal Auto-mode, I had to restart the projector. Then played the same scene. All was back to normal, but then a few min later, occured again.
I have tried reflashing firmware, factory reset, changing auto and manual aperture modes. All possible changes of settings. No go. SDR/HDR makes no difference. Using Auto1 or Auto2, no difference. Not sure what to think. I have contacted the distributor / dealer, lets see what they say. Since it is intermittent I am more worried something is wrong with the DI om my unit. Maybe I'll wait for the next firmware and see if it fixes things..
Tom Bley likes this.
Drem is offline
post #10718 of 17821 Old 04-29-2019, 03:33 PM
mattztt's Avatar
Quoted: 368 Post(s)
Liked: 364
Originally Posted by jbarteli View Post
Do you mean this:
Spoiler!
Possibly, but it's hard to tell from those photos. They look a little bit like "mosquito noise"; an artifact that appears on the edges of objects. What I see is a persistent moving static effect on large areas of lighter content, like say the sky or a white suit.
I'll experiment with a few of the settings suggested and see if can capture a representative photo/video.
mattztt is offline
post #10719 of 17821 Old 04-29-2019, 03:46 PM
tommarra's Avatar
Quoted: 628 Post(s)
Liked: 373
Really try turning off motion enhance. That should fix it.
See this thread JVC NX series HDR image artifact?
https://r.tapatalk.com/shareLink?sha...2&share_type=t
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #10720 of 17821 Old 04-29-2019, 04:06 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6668 Post(s)
Liked: 6658
RS1000 and RS3000 have been readily available. If you have a RS2000 that may take a little longer then expected. Installing a projector is pretty easy unless you have a weird setup, I would have installed it and replaced it when the new one came in.
Cleveland Plasma is online now
post #10721 of 17821 Old 04-29-2019, 05:37 PM
satfam's Avatar
Quoted: 75 Post(s)
Liked: 64
I just timed the start up of my RS 2000, V2.01 and it took 40 seconds to show the DILA logo.
Maybe I’m just one of the lucky ones.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, JVC DLA-RS2000, Stewart Cima Neve 110", Tivo Bolt, PS-3, Apple 4K TV, GIK Acoustics treatments, Panasonic UB820
Gameroom: Denon AVR-X4500H, Emotiva 2-T1’s, C1, 2 B2’s, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR85X900F, PS4 Pro, Tivo Bolt,Oppo 203
satfam is offline
post #10722 of 17821 Old 04-29-2019, 05:57 PM
desray2k's Avatar
Quoted: 481 Post(s)
Liked: 229
Yes that’s about right.
desray2k is offline
post #10723 of 17821 Old 04-29-2019, 08:53 PM
Liked: 9
Originally Posted by Mike Garrett View Post
Did the free bulb come directly from JVC? I submitted my rebate about 3 weeks ago, received shipping notification today.
Yes, direct from JVC. 3 weeks is faster than expected turnaround time.
Sent my form in 6 weeks ago, Bulb arrived today.
post #10724 of 17821 Old 04-29-2019, 10:47 PM
tommarra's Avatar
Quoted: 628 Post(s)
Liked: 373
Spoiler!
@ARROW-AV you probably already noticed this, but I was playing some HDR content off my Nvidia shield (Chilling Adventures of Sabrina) on my NX7 when I noticed DI yellowing. I recalled you had said that for HDR DI shift is more of cyan / blue than Yellow - but I was getting yellow.
So I started playing around with color modes and found that for HDR content using anything other than BT2020 (DCI, HDR) results in Yellow DI. While using BT2020 profile the colors are maintained largely correct.
Could you or anyone else run this experiment and corroborate my findings.
I know that using BT2020 results in about 10% drop in light output ... But for someone looking to use DI - it might be worth using BT2020 vs HDR color profile.
DrMoz likes this.
tommarra is offline
post #10725 of 17821 Old 04-30-2019, 12:22 AM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
Anyone using DI with aperture at 0? If so, did your projector ever clamp down, to say and eqivalent of manual aperture -8, -9?
Drem is offline
post #10726 of 17821 Old 04-30-2019, 12:54 AM
RapalloAV's Avatar
Quoted: 2228 Post(s)
Liked: 773
Im using it at zero and its never done that.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild, plus new LED ceiling install Christmas 2018
RapalloAV is offline
post #10727 of 17821 Old 04-30-2019, 01:19 AM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
Thanks for the info. I am talking with my dealer, giving him as much info as I can. Which firmware are you on? And have you been on other firmwares also?
Drem is offline
post #10728 of 17821 Old 04-30-2019, 02:36 AM
coxy2416's Avatar
Quoted: 571 Post(s)
Liked: 341
Sounds like what I have experienced with the X790 and why I do not use the DI anymore. With the DI engaged on certain movies it would work flawlessly and on others I had a sense that it was clamping down more then it should making the scene to dim like you are experiencing. Unfortunately I believe this is just normal behaviour of the DI and not sure there is much you will be able to do to correct it.
When I first got my X790 I was pretty excited to have the DI and get those fantastic blacks but I came to realize there are certain trade offs to using the DI like the one you have mentioned. I spent way too many hours trying to figure out what was going on with the DI to try to get it to work but in the end was very glad I had the option of turning it off.
Some are ok with the DI and some are not, luckily for me the X790 has fantastic blacks without the DI and turning it off was the best thing I ever did.
coxy2416 is online now
post #10729 of 17821 Old 04-30-2019, 03:20 AM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
But the DI on my N7 is not working as designed. It is, most of the time, but this clamping down is something else happening. Like RapalloAV wrote above, he is at 0 aperture and it never clamped down like this. I am very happy with the DI function, when it works. Apart from the yellowing that is But hopefully that specific issue is fw fixable.
Drem is offline
post #10730 of 17821 Old 04-30-2019, 03:22 AM
coxy2416's Avatar
Quoted: 571 Post(s)
Liked: 341
But the DI on my N7 is not working as designed. It is, most of the time, but this clamping down is something else happening. I am very happy with the DI function, when it works. Apart from the yellowing that is [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG] But hopefully that specific issue is fw fixable.
Is this happening on HDR and SDR material?
Hopefully you get it all sorted out but it sounds exactly like what I was experiencing.
post #10731 of 17821 Old 04-30-2019, 03:40 AM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
It happens on both SDR and HDR material. I saw it once or twice in my first few hundred hours of usage. But I thought it was triggered by the switch between different modes etc. Yesterday it occurred 1 hour into a movie, just out of the blue. When it occurs, no matter what I play (HDR/SDR) or changes I make, it's there. Only a restart resets the Auto DI to defaults. And clamping from 0 to -8 makes a quite substatial impact in light output. Playing the same exakt scene where it triggered this yesterday, and it did not occur at the same instance. Totally random it seems.
Skickat från min VKY-L29 via Tapatalk
Drem is offline
post #10732 of 17821 Old 04-30-2019, 05:30 AM
Drem's Avatar
Quoted: 149 Post(s)
Liked: 127
Just got word from the distributor. He talked to the JVC technicians today and they said the new firmware will fix this issue. They didn't know an exact date, but in a few weeks most likely. He asked me if I was ok using the PJ without Auto until then.
Lets hope it does, and also fixes the yellowing at the same time.
Drem is offline
post #10733 of 17821 Old 04-30-2019, 06:50 AM
BondDonBond's Avatar
Quoted: 733 Post(s)
Liked: 660
Thanks @ARROW-AV ! That explains a lot because I was trying to figure out why I was not seeing the yellow but I am in manual for SDR and Auto2 BT2020 for HDR.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #10734 of 17821 Old 04-30-2019, 08:21 AM
smitty's Avatar
Quoted: 761 Post(s)
Liked: 1015
tommarra, if you put the "spoiler" tag around a lengthy post (like Arrow-AV's) when you're quoting it, it hides it and avoids cluttering the thread with a lengthy repeat of something that has already been posted. Saves a lot of space on what is becoming a very long thread.
smitty is offline
post #10735 of 17821 Old 04-30-2019, 08:25 AM
tommarra's Avatar
Quoted: 628 Post(s)
Liked: 373
Point taken. On the Tapatalk I didn't even realize this was an issue because the app itself hides the long quote and doesn't have option to add the spoiler tag.
Will be more mindful in future... also edited the post
tommarra is offline
post #10736 of 17821 Old 04-30-2019, 08:43 AM
mauricef's Avatar
Quoted: 47 Post(s)
Liked: 46
I think I encountered a variant of this problem on my RS3000. I was watch a SDR movie a couple of days ago an thought the image was very dim and had no pop. So I checked my aperture position and it was the same as I remembers. I switch to another source, I don't remember if it was HDR or not but when I returned back to the SDR movie all was normal again. It is like the aperture forgot where it should be.
I hope you are right that this will be fixed in a firmware update. I would hate to have to check this every time.
mauricef is offline
post #10737 of 17821 Old 04-30-2019, 10:08 AM
smitty's Avatar
Quoted: 761 Post(s)
Liked: 1015
No worries. I didn't know about Tapatalk. I'm too much of a Luddite to use that.
smitty is offline
post #10738 of 17821 Old 04-30-2019, 11:13 AM
Quoted: 40 Post(s)
Originally Posted by yankiy View Post
Try taking the contrast down to 5 as well. I’m playing with that. It’s growing on me. 🙂
Also I have figured out what I like for SDR content as well. I like using the BT.2020 color profile for SDR. Again, personal preference.
Attachment 2541180
Attachment 2541182
Attachment 2541186
Attachment 2541188
Attachment 2541190
Can you post the following situations and color profiles/settings used?
HDR and Non HDR from BD-820
Cable TV
Streaming Box (Apple tv or Shield HDR and Non HDR shield source material)
Thanks! This has been most helpful!
Video: Dedicated Light Controlled Room | JVC NX5 | 100" AT Silver Ticket 1.1 gain Screen
Audio: Sound Controlled Room | Denon X4500h running 5.1.4 | LR/Atmos - Pioneer SP-EFS73, Center - Pioneer SP-EC73, Rear/Atmos - Pioneer SP-EBS73-LR, Sub - SVS PC-2000
Sources: Nvidia Shield | Panasonic UB-820 | Gaming PC
smhunter1983 is offline
post #10739 of 17821 Old 04-30-2019, 11:14 AM
Mike Garrett's Avatar
Quoted: 12502 Post(s)
Liked: 10128
For those on the fence, last day that JVC is offering the free lamp.
Frohlich likes this.
Mike Garrett is online now
post #10740 of 17821 Old 04-30-2019, 11:43 AM
utee05's Avatar
Quoted: 72 Post(s)
Liked: 30
Yup I finally pulled the trigger on an nx5. I’m excited to join 4k in my projector.
davidahn and jeahrens like this.
utee05 is online now
Jvc , nx7 , nx9 , rs2000 , rs3000
