Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 360 - AVS Forum | Home Theater Discussions And Reviews
 13264Likes
post #10771 of 13985 Old 04-30-2019, 07:14 PM
SoonerDoc's Avatar
Quoted: 55 Post(s)
Originally Posted by davidahn View Post
Just to clarify your setup, the NX7 is plugged into the main HDMI/ARC/4K HDR output? Does your HDMI cable have directionality? Some have a source end and a display end.
You might have hit on it. The HDMI cable is a 30 ft run with directionality. Maybe that is it. Going to try a nondirectional long cable I have.
If this is the issue, why is everything but the directv boxes working?
SoonerDoc is offline
post #10772 of 13985 Old 04-30-2019, 07:28 PM
SoonerDoc's Avatar
Quoted: 55 Post(s)
Nope. Nondirectional HDMI cable has same issue.
post #10773 of 13985 Old 04-30-2019, 07:38 PM
markmon1's Avatar
Quoted: 4634 Post(s)
Liked: 2942
Ran into another issue that at least tangentially involves the NX7.
Have Pioneer Elite VSX-LX503 that is a couple months old. Have Xbox one x, ps4, apple tv and panny UB820 connected to the back HDMI ports. Also have 2 DirecTV boxes connected via HDMI to the back ports. Was feeding a JVC RS57 front projector via HDMI from the pioneer receiver. All cables are new and certified 4K. Everything working perfectly.
Replaced my RS57 with the NX7. Just a matter of taking down old projector, mounting new projector and plugging in HDMI cable. Or so I thought.
Everything working fine EXCEPT no sound from EITHER DirecTV boxes. Picture is fine but no sound. Tested the DTV boxes with same cables on another TV. Good picture and sound. Tried every single input on the back of the receiver with both DTV boxes with same result...good picture, no sound. Everything else (apple tv, ps4, panny player and xbox) all have normal picture and sound from every HDMI port on the back. No sound from either DTV box from ANY of the back HDMI ports. If I take the HDMI running from the pioneer receiver out of the NX7 and plug it into any other HDTV including the RS57, automatically get sound from all the theater speakers. Plug it back into the NX7, no sound.
Interestingly when the cable from the receiver is plugged into any other HDTV and there is sound, the receiver says it is getting 5.1 DD from the DTV boxes. When it is plugged into the NX7 and there is no sound the receiver says it is getting ANALOG signal.
Finally hooked up a couple of optical cables and got sound via optical and picture via hdmi.
Obviously there is something in the NX7 that is preventing the receiver from receiving the digital audio signal from the DirecTV boxes. Can't figure it out.
Your post is interesting, but your conclusion is flawed. The NX7 is a display only device and has no sound capabilities. It is up to your receiver to handle this situation. The problem is in your receiver in how it is detecting the projector and its capabilities, most likely.
Does the behavior change if you force the output to 1080p from the DTV devices or in the receiver?
Edit: also I'd poke around the DTV inputs and make sure all ARC (audio return channel) features are turned off. Projectors don't support this feature.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #10774 of 13985 Old 04-30-2019, 08:28 PM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
Too bad that didn't work.
30' is a pretty long run; maybe try testing with a shorter cable to see if the length is prohibiting the HDCP handshake between the AVR and the NX7. Different chipsets might have different tolerances for long runs.
Does your 30' cable have ferrite cores? If not, Monoprice sells just ferrite cores. No guarantee that will fix it, but I always prefer overkill at every link in the signal chain. It only takes one weak link to make the whole setup fail. That's why I went with 48 Gbps rather than 18 Gbps cables.
JVC DLA-NX9 / 156" 2.4:1 CIH Seymour AT screen / Marantz AV7704 11.2 / Yamaha MX-A5000 11-ch amp
HTPC MadVR RTX 2080 / 24TB PMS Server (direct UHD rips)
Adam A8X monitor LCR / RBH A-610 x 8 / Kef Ci160ER x 4 / HSU ULS-15
Secondary: Samsung UN82MU8000 / Marantz NR1607 AVR / Kef Q150 + Minx Min 10 / SVS SB-2000
davidahn is offline
post #10775 of 13985 Old 04-30-2019, 08:45 PM
Liked: 9
Originally Posted by coxy2416 View Post
But the DI on my N7 is not working as designed. It is, most of the time, but this clamping down is something else happening. I am very happy with the DI function, when it works. Apart from the yellowing that is [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG] But hopefully that specific issue is fw fixable.
Is this happening on HDR and SDR material?
Hopefully you get it all sorted out but it sounds exactly like what I was experiencing..
I am also experiencing this exact thing, although I get a yellow pumping after a bright to dark scene. I've sent videos to JVC,
https://drive.google.com/drive/folde...OB?usp=sharing
Haalik123 is offline
post #10776 of 13985 Old 04-30-2019, 08:54 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6392 Post(s)
Liked: 6392
Originally Posted by GregCh View Post
For what it is worth, shipping location and bulb availability seem to be the key factors for time it takes to receive a bulb.
I sent in my paperwork on February 8th. I sent it certified USPS mail and watched the tracking. It took nearly 4 weeks for my form to reach JVC in NJ from Durango. Pretty ridiculous. Anyway I just got my free bulb yesterday April 29th. That makes 11 & 1/2 weeks. I wasn't in a rush as I won't need to use the new bulb for awhile but it is good to have a free spare. Thanks JVC.
Snail mail can drive you mad sometimes, I think it was 20 items that we dropped off at a USPS office. One week later no update, had to call office I dropped off at. They said we never dropped them off. I said they had to be there somewhere just sitting, 2 hours later all but 3 tracked....on those three that never tracked, they said I never dropped them off so I could not file a claim.
Cleveland Plasma is online now
post #10777 of 13985 Old 04-30-2019, 09:09 PM
Quoted: 128 Post(s)
Liked: 36
The yellowing issue seems to be there in every unit when the DI is on ? For me it’s very evident with the subtitles turning mildly yellow. In my case, while using the shield, it’s only evident while watching the subtitles and does not seem to be visible in the scenes but the minute I go back to the main menu, there is a yellow tint on the entire image. No yellowing however in Auto 1 mode.
abinav555 is offline
post #10778 of 13985 Old 04-30-2019, 09:14 PM
NapsterNZ's Avatar
Any details for N5 vs N7 for contrast and black levels floating around that i have missed?
NapsterNZ is offline
post #10779 of 13985 Old 04-30-2019, 09:39 PM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Originally Posted by locutus2k View Post
What firmware version do you have? Do you had low latency and/or motion enhance enabled? It seems there is a bug related to low latency/motion enhance when an high contrast image suddenly appear on screen.
I'm on firmware 2.01, i was using CMD on high.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #10780 of 13985 Old 04-30-2019, 10:29 PM
Quoted: 128 Post(s)
Liked: 36
Originally Posted by abinav555 View Post
Thanks David. I just found out that I do have good cables that support bt.2020. Problem seems to be the receiver (Marantz 7702) which has only 4K and no HDR support. Will be replacing it in two days.
On the other hand, this has been eating me for a while now. Dark scenes(full HD) are extremely dark when watching with the Shield, looks like it’s losing a lot of highlights. Using the rs2000. I just watched the 3rd episode of Game of Thrones S08 and the dark scenes are extremely dark. I know the episode was intentionally shot that way but something seems off.
Post your PJ color profile selections menus.
Also the info tab when the content is running.
Will post it when i go through the content again. But if i remember right, color profile is bt.709 at 6500k. Iris at auto 2 clamped at -2.
Content info was 4k 59.xx p 8 bit.
1080 24p when played through 1080p setting.
These are the settings
ID:	2560892   Click image for larger version
ID:	2560894   Click image for larger version
post #10781 of 13985 Old 04-30-2019, 11:07 PM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
If it’s HDR content try using BT2020 color profile. There is no yellowing in that profile
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #10782 of 13985 Old 05-01-2019, 12:04 AM
Quoted: 166 Post(s)
Liked: 94
My dealer called me today to tell me my NX7 and Stewart StudioTek 130 scope screen have arrived
I’m in Australia. Another forum member received there projector this week too.
At my request the dealer will check the projector for me before it is installed. Here is a list I’ve sent to check. Have I missed anything?
Ensure no purple bar on the picture
e.g. https://photos.smugmug.com/JVC-RS200...HOTO%201-L.jpg
Ensure no blue bars on the picture
e.g. https://www.avsforum.com/forum/attac...0&d=1555936711
Ensure no green border around the edges of the picture e.g. https://uploads.tapatalk-cdn.com/201...19b6298f14.jpg
Ensure no blue bars when viewing end of movie credits e.g. Aquaman https://postimg.cc/z3pgK5tz
Ensure no purple ring on the picture
e.g. https://www.avsforum.com/forum/attac...0&d=1550175431
Ensure no loud IRIS noise when DI is in use
Check version of Firmware installed? Latest is 2.05
Once the projector has warmed up for an hour or so, check for convergence - From viewing distance the grid should be white and sharp
Dandlj is offline
post #10783 of 13985 Old 05-01-2019, 12:22 AM
KarlKlammer's Avatar
Quoted: 250 Post(s)
Liked: 243
I would let him check uniformity of every primary color, secondary color, black and white with iris open and closed.
If he can take measurements then I would also let him check gamut coverages.
Projection: JVC DLA-NX9
VP/Calibration: Lumagen Radiance Pro, LightSpace CMS, x-rite i1 Pro 2, x-rite i1 Display 3
KarlKlammer is offline
post #10784 of 13985 Old 05-01-2019, 12:28 AM
Justin Morgan's Avatar
Quoted: 59 Post(s)
Liked: 32
Does anyone know if the Panasonic UB9000's exclusive "High Luminance Projector" (500-nit) mode offers any advantage versus the UB820's basic 350-nit mode for use with an NX-7?
I'm trying to decide between the UB820 and UB9000.
In case it matters, I'm using a 115" diagonal 1.0 gain screen, the projector will be mounted at 13 ft, and the main seating distance is 8.5 ft. My NX7 has arrived and is still in its box.
Thanks for any help!
JeffR1 likes this.
Sci-Fi Theater, a modest 13-ft x 18-ft home theater room with riser
PROJECTOR: JVC NX7 | SCREEN: 115" Elunevision Reference 4K 1.0 gain
RECEIVER: Denon X8500H 13.2 | SOURCES: TiVo Bolt, Xbox One X, Apple TV 4K
SUBS: 2 x SVS SB16-Ultra | L/C/R: 3 x JTR 228HT | SURROUNDS: 6 x JTR Single 8HT-lp
ATMOS: 4 x MartinLogan 8" ElectroMotion R | SEATS: Seatcraft Diamante
Justin Morgan is offline
post #10785 of 13985 Old 05-01-2019, 01:12 AM
markmon1's Avatar
Liked: 2942
This all seems a bit much for a dealer to check just to make sure a projector is ready for pick up. Most this can be checked by the customer once picked up.
I'd say check no purple, blue bars, no green bars. No purple ring, no super loud auto dynamic iris. Then that's about it. To be honest, focus and convergence will wander the first few days anyway and will settle in after.
Dandlj and Jacob92175 like this.
markmon1 is offline
post #10786 of 13985 Old 05-01-2019, 01:54 AM
locutus2k's Avatar
Quoted: 240 Post(s)
Liked: 79
Originally Posted by desray2k View Post
May I inquire whether it only happen to one particular source? Say Oppo player (since the second image depicted shows the typical Oppo wallpaper) only? Or it happens with different sources as well? Have you disable all forms of post processing features like CMD, latency mode etc?
It happen with all kind of sources and so far it happened with low latency on motion enhance low as well with everything off. It happens most of the times at cold boot, in 5-10 minutes. After the reboot it may not happen again for hours. It is absolutely random and not source or special functions related.
locutus2k is offline
post #10787 of 13985 Old 05-01-2019, 02:01 AM
desray2k's Avatar
Quoted: 467 Post(s)
Liked: 222
It happened to me twice when using nividia shield TV around 60hrs and now I’m at 264hrs and so far it never happen again (cross my fingers). It never happen on other sources.
An upgrade in recent firmware for the nvidia shield seems to solve it.
Oh yeah, I did change the HDMI cable to fibre optics but I doubt this I has any effect.
desray2k is offline
post #10788 of 13985 Old 05-01-2019, 02:23 AM
Quoted: 250 Post(s)
Liked: 243
Yes, it seems much. But from personal experience you can't be careful enough in the current situation. Don't forget, @Dandlj doesn't live in the US where you can easily get rid of a unit you are not satisfied with and find yourself at the mercy of a service that decides what's whithin specs and what's not.
IMDave and Dandlj like this.
post #10789 of 13985 Old 05-01-2019, 03:05 AM
locutus2k's Avatar
Quoted: 240 Post(s)
Liked: 79
I doubt it is source related: when it happen it stay even if you switch sources, even if you switch to hdmi2 input that has no cable attached. For sure there's something who triggers this thing but the point is: software or hardware related? If it's hardware it can happen anytime with no logic if it's software/firmware there's something who triggers it but i can't understand what.
post #10790 of 13985 Old 05-01-2019, 03:49 AM
Quoted: 166 Post(s)
Liked: 94
Correct. Anything that is found after it leaves the dealer has to be done through warranty.
Dandlj is offline
post #10791 of 13985 Old 05-01-2019, 05:03 AM
Quoted: 128 Post(s)
Liked: 36
Where can I download v2.05 ? i’m currently at 2.01. I don’t have an ethernet connect to my projector.
post #10792 of 13985 Old 05-01-2019, 05:19 AM
desray2k's Avatar
Quoted: 467 Post(s)
Liked: 222
2.05 not going to be released in the public domain. However a new one addressing some teething issues related to the Iris will probably release soon.
tommarra likes this.
desray2k is offline
post #10793 of 13985 Old 05-01-2019, 05:39 AM
DLCPhoto's Avatar
Quoted: 1560 Post(s)
Liked: 693
Actually, the UB820's "Basic Luminance LCD & Projector" is the 500-nit mode, corresponding to the "High" luminance mode on the UB9000. The UB9000 also has the "Basic" luminance mode of 350 nits, which the UB820 doesn't have. Pretty poor use of terminology, obviously.
Theoretically, the 350 nit mode would be more appropriate to these JVC Projectors, but there are plenty of people using the 500 nit mode of the UB820 and like it just fine. Perhaps ask in the UB9000 thread, as only uB9000 owners would be in a position to make direct comparisons.
Whether that's worth doubling the price of an already somewhat expensive player is a subjective call.
Justin Morgan likes this.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #10794 of 13985 Old 05-01-2019, 06:26 AM
Wookii's Avatar
Quoted: 2860 Post(s)
Liked: 2048
Do you live a long way from the dealer? I think I'd be wanting to go there and check the issues myself to be honest, before taking it away with me.
markmon1 likes this.
Wookii is offline
post #10795 of 13985 Old 05-01-2019, 06:29 AM
markmon1's Avatar
Liked: 2942
Ya its same here in USA btw. We cant just return a projector. The difference is our dealers are helpful for exchange and we get advanced replacement not something sitting in a repair center. I think if you were concerned you should go to the dealer and check this stuff yourself not just have him do it all.
markmon1 is offline
post #10796 of 13985 Old 05-01-2019, 06:49 AM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
Actually i was using my nvidia shield also when it happen to me but i was using the new firmware from nvidia shield & that was last Sunday 28th of April unless nvidia has sent another update since that short period of time.
Nexgen76 is offline
post #10797 of 13985 Old 05-01-2019, 06:55 AM
DVD MAN's Avatar
Quoted: 227 Post(s)
Liked: 111
Has anyone received there pre order NX7 yet?
DVD MAN is offline
post #10798 of 13985 Old 05-01-2019, 06:58 AM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
Number of us but they are in short supply
post #10799 of 13985 Old 05-01-2019, 06:59 AM
Mike Garrett's Avatar
Quoted: 11812 Post(s)
Liked: 9349
100's of RS2000/NX7's have shipped in the US.
Mike Garrett is online now
post #10800 of 13985 Old 05-01-2019, 07:06 AM
BondDonBond's Avatar
Quoted: 644 Post(s)
Liked: 563
Soooo, Mr Deering calibrated my projector RS2000 yesterday. Let me start with this. That dude knows his stuff end of subject. People questioning his knowledge flat out do not know what they are talking about! He is worth every penny and trust me he is not cheap .
I will post some post calibration information later but let me sum up a few things.
1) It seemed to me that Kris was a little surprised at how good of a sample I got. He has done a few of these and he did comment that it was a real good one.
2) I followed a bunch of setting etc on here and let me say I had some things not correct. When I get back from traveling I am going to take a picture of all the settings so if I screw them up I can go back. Those setting were both on the RS2000, ATV and Panni 820 that needed adjustment.
3) I think I need to send it back because I only hit 98.76% of P3 color with 1.3 DE Errors. I want 100% ok just kidding. This thing tracked exceptional.
4) I thought uniformity was good but Kris showed me the right way to do it and made it even better. Concentrate on the center of screen and the rest should be ok. Also Focus, using a single pixel pattern to focus.
5) DCR Lens throws in some things that I need to bring up in that thread. Picture is great but it is throwing in some weird thing when I throw up a square pattern
6) Brightness does equate to good HDR! Actually he dialed back the brightness to get to 30FL and gave more contrast.
7) Know your calibrator. Be sure they know what they are talking about. Be in the same room as them and be sure to ask questions. You are paying for it.
Again thanks Kris and great job.
Home Theater: JVC NX7, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- 18" Velodyn Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Oppo 203, Panasonic 820, Apple TV, XBox One
BondDonBond is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
