Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 378 - AVS Forum | Home Theater Discussions And Reviews
 16587Likes
post #11311 of 17938 Old 05-11-2019, 05:17 PM
Th601's Avatar
Quoted: 105 Post(s)
Liked: 31
Originally Posted by woofer View Post
Natellie,
Power on the PJ...wait 2-3min then hold down the "Power" button on the rear panel till the PJ goes into a controlled shutdown. Then try powering it on again as per normal BUT with ALL HDMI input cables unplugged.
Hey Woofer should that be normal shut down and start up sequence or just when you encounter an issue like this?
Th601 is offline
post #11312 of 17938 Old 05-11-2019, 05:17 PM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 201
Originally Posted by markmon1 View Post
I'd definitely get the iris set to 0 for HDR and then up the tone map slider as needed after.
Yes, that's what I did and it looks good. Some have suggested turning down the brightness control for the picture mode down a couple of notches to -3. What exactly does this accomplish? Lower the black floor? Appreciate your input.
gravi is online now
post #11313 of 17938 Old 05-11-2019, 05:18 PM
woofer's Avatar
Quoted: 1422 Post(s)
Liked: 2225
Only if you get a 'lockup" or such...
woofer is offline
post #11314 of 17938 Old 05-11-2019, 05:21 PM
Th601's Avatar
Quoted: 105 Post(s)
Liked: 31
Ok good deal. Thank you.
Th601 is offline
post #11315 of 17938 Old 05-11-2019, 05:22 PM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 201
Originally Posted by jpiddy View Post
Has anyone done a side by side comparison of any of the following settings? Or better yet, any actual testing @Javs .
Pana 820 -> SDRBT2020, with SDR settings on NX7
Pana 820 -> HDRBT2020, with HDR(PQ) auto tone mapping on NX7
Pano 820 -> HDRBT2020, with gamma 2.2 and Pana_PQ_BL color profile NX7
They all look absolutely fantastic to me. Switching settings takes long enough that I can’t seem to pick up on any major differences. Love to hear any thoughts. Cheers!
Many people favor the second option, which is what I am using. I agree it is very hard to do any comparisons and all three settings are similar. Not sure if anyone has done an objective comparison.
gravi is online now
post #11316 of 17938 Old 05-11-2019, 05:28 PM
cindernat's Avatar
Quoted: 58 Post(s)
Liked: 33
Thanks Woofer, I will remember that if it does it again.
Phew!
cindernat is online now
post #11317 of 17938 Old 05-11-2019, 05:32 PM
Th601's Avatar
Quoted: 105 Post(s)
Liked: 31
With the 2nd option the tone mapping in the player would be disabled and the tone mapping on the projector would be enabled correct?
Th601 is offline
post #11318 of 17938 Old 05-11-2019, 06:02 PM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 201
You actually set the player to "Basic Luminance Projector/LCD" which tone maps to a base 500 nits. Then the projector takes that signal and tone maps it further. You can control the mapping using either the "HDR Options" on the Panasonic or the tone map slider on the JVC, both should achieve pretty much the same results.
Th601 likes this.
gravi is online now
post #11319 of 17938 Old 05-11-2019, 06:07 PM
jbn008's Avatar
Quoted: 267 Post(s)
Liked: 131
Originally Posted by DVD MAN View Post
Yes I did.
Please do the following to update:
Uncompress the file.
Copy the UAB_*** folder to root directory of a USB stick (FAT32 format).
Plug into the USB port on back of the projector, while it is running.
Go to the Function Menu in the OSD to load the software.
Update software. It will take about 25 minutes. Lights blink slow then go to a faster rate. Projector will turn off.
Turn projector back on.
Perform factory reset from service menu. OK-left-right-OK-Back-OK will get you into the service menu.
I also did the factor reset and 15 hours later the blue bars popped back up. It seems to be completely random as i have 110 hours on the bulb, but the problem didn't manifest itself until about the 80 hour mark.
I hope this is fixable thru a post 2.05 update
jbn008 is offline
post #11320 of 17938 Old 05-11-2019, 06:54 PM
markmon1's Avatar
Quoted: 5227 Post(s)
Liked: 3397
Originally Posted by Colozeus View Post
I bought one of the lux measurement meters everyone recommends here on amazon. What is the correct procedure to measure nits? Pull a full white background and place the sensor at the screen aimed towards the pj lens? Then convert lux to bits?
Thats my method.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #11321 of 17938 Old 05-11-2019, 10:29 PM
Quoted: 175 Post(s)
Liked: 98
Yes, high lamp on all JVCs I have owned has really loud noise, that's why I never use it
So what settings do you use to watch 4K but not 4K HDR (as HDR will kick the projector into high lamp)?
Dandlj is offline
post #11322 of 17938 Old 05-11-2019, 11:01 PM
Quoted: 1933 Post(s)
Liked: 1229
On the RS3000, if you use the THX picture mode, it defaults to a gamma of THX. You can't change it for this mode.
Does anyone know what gamma THX mode is using? If you run autocal to correct gamma with this setting will it screw up THX mode?
GregCh is online now
post #11323 of 17938 Old 05-11-2019, 11:15 PM
tommarra's Avatar
Quoted: 632 Post(s)
Liked: 376
Originally Posted by Manni01 View Post
@Jue Liang
I would leave CMD and motion enhance to off when watching movie content due to the artifacts they can cause. You can use CMD for fast TV sports if you like the difference.
Wondering what artifacts are you noticing with CMD on?
On my NX7 I have it on to Low and the image looks pretty good.
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #11324 of 17938 Old 05-11-2019, 11:22 PM
Quoted: 130 Post(s)
Liked: 41
What is the recommended temperature settings ? I read that 6500K is standard but I find 5500K a tad brighter and warmer, I like High Bright too but that puts a little bit of green tint to the image.
abinav555 is offline
post #11325 of 17938 Old 05-12-2019, 12:47 AM
KarlKlammer's Avatar
Quoted: 266 Post(s)
Liked: 257
Originally Posted by bobof View Post
Oh, you can't leave it at that... Do tell!
Nah, I can't do that. This model is so popular over here.
But there are only a handful of units in the wild in my country. And when I write about it, it will give conclusions on the owner.
bobof likes this.
Projection: JVC DLA-NX9
VP/Calibration: Lumagen Radiance Pro, LightSpace CMS, x-rite i1 Pro 2, x-rite i1 Display 3
KarlKlammer is offline
post #11326 of 17938 Old 05-12-2019, 02:40 AM
Manni01's Avatar
Quoted: 5439 Post(s)
Liked: 5639
Minor SOE and occasional minor posterization. But it's a taste thing. If you like the picture with CMD on low, have the picture with CMD on low.
It does help with motion on slow pans and with resolution on fast action, but I find motion with CMD off good enough to not add any SOE (which I really can't stand with films).
I do use CMD on low when I watch sports TV.
It's your PJ, use the settings that give you the best compromise to your eyes
tommarra likes this.
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is online now
post #11327 of 17938 Old 05-12-2019, 06:20 AM
markmon1's Avatar
Liked: 3397
Any player that tone maps HDR to tone mapped SDR will send 4K but not HDR. HTPC can do this as well (this is my only way of connecting).
HDR does not require the projector to be in high lamp. The HDR setting may be currently set to go to high lamp, but if you change that to low lamp, then it will stay that way instead.
High bright is basically an uncalibrated setting where color profiles are disabled. I think 6500k generally is what you want not 5500k but use whatever makes you happy even if its not accurate.
markmon1 is offline
post #11328 of 17938 Old 05-12-2019, 08:23 AM
tommarra's Avatar
Quoted: 632 Post(s)
Liked: 376
@Manni01 and @markmon1
You guys are MadVR experts - so a question for you:
For HDR tonemapping, in the Maximal Target Nits box, is there a guidance for what to use for projectors?
I tried using NeoXP's settings and set that to 10000, but the image was too dark. As i lower it the image keeps getting brighter, but i have not yet figured out what is an optimal point for it.
Is there a guidance for what to shoot for? I get ~80 nits on my screen in high lamp - if that helps.
post #11329 of 17938 Old 05-12-2019, 08:30 AM
Quoted: 229 Post(s)
Liked: 108
Go ask in the madvr player support thread. :-)
smitty likes this.
Colozeus is offline
post #11330 of 17938 Old 05-12-2019, 08:51 AM
tommarra's Avatar
Quoted: 632 Post(s)
Liked: 376
I specifically asked over here because it pertains to the NX7 as well - I am sure there are others who run MadVR and the new JVC projectors.
This way if another owner has a similar question then a quick search on this forum will answer the question.
Renerator likes this.
post #11331 of 17938 Old 05-12-2019, 09:04 AM
Manni01's Avatar
Liked: 5639
I'll post a guide when the next public madVR build is released. Everything is changing too quickly for now. I'll post my own settings in the madVR experimental thread soon (85nits at the moment), hopefully tonight. Off topic here.
Nexgen76 likes this.
post #11332 of 17938 Old 05-12-2019, 09:18 AM
tommarra's Avatar
Quoted: 632 Post(s)
Liked: 376
Thank you!
post #11333 of 17938 Old 05-12-2019, 11:56 AM
aka jfinnie
Quoted: 2640 Post(s)
Liked: 1738
I thought you were running much brighter than that?
bobof is offline
post #11334 of 17938 Old 05-12-2019, 12:53 PM
Manni01's Avatar
Liked: 5639
I used to but I'm experimenting with the DI and find that -8 is the soft spot to get rid of 90% of the DI artifacts (both yellowing and blooming) in my setup. I'm not 100% decided, but at the moment that's what I'm running.
I might go back to iris open, no DI and 120nits.
bobof likes this.
post #11335 of 17938 Old 05-12-2019, 01:01 PM
Chris F. V2's Avatar
Checking in again on my issue: 4K HDMI over CAT6 (or any other solution)
Running sources through my Marantz AV Pre. Initially tried Monoprice Blackbird to send signal over CAT6. Was ok on HD content with some lock issues. On 4K content, no signal whatsoever. I tested the same setup HD source/AV pre to 4K TV using the Blackbird and got a perfect picture. Seems the JVC is more sensitive. One poster suggested a $1000 box solution but trying to not throw money at the problem unless it's the only solution.
What is everyone else using to connect their projectors over long distances? Any help appreciated.
Chris F. V2 is offline
post #11336 of 17938 Old 05-12-2019, 01:43 PM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1015
https://www.monoprice.com/product?p_id=21568
Many also use the Ruipro Fiber HDMI cable that is available on amazon.
smitty is offline
post #11337 of 17938 Old 05-12-2019, 01:54 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6674 Post(s)
Liked: 6670
Cleveland Plasma is online now
post #11338 of 17938 Old 05-12-2019, 02:42 PM
aka jfinnie
Liked: 1738
You're lucky to be able to get that bright with the iris so closed... The constant battle we face between light and dark for HDR.
Manni01 likes this.
bobof is offline
post #11339 of 17938 Old 05-12-2019, 03:05 PM
Originally Posted by Cleveland Plasma View Post
Yep, I use the Ruipro, no issues
Thank you both!
More troubleshooting today isolated the issue to the Marantz AV7705. So frustrated. Going to reach out to Marantz and JVC tech support since the same path ways work fine if:
- I connect to my Sony 4k TV
- If I connect the sources directly to HDMI over CAT6.
Will order one of the Fiber HDMI's to see if it solves the problem.
post #11340 of 17938 Old 05-12-2019, 03:08 PM
jpiddy's Avatar
Liked: 3
What is the benefit to more nits on screen with open iris if it also raises the black floor? Brighter highlights, I assume, but at the cost of raised blacks and reduced contrast. It seems like a properly tone mapped source would benefit most from higher contrast. Seems like most calibrates/pros on the forum recommend open iris or max light output for HDR so I’m sure that I’m missing something.
jpiddy is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
