Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 380 - AVS Forum | Home Theater Discussions And Reviews
 13332Likes
post #11371 of 14146 Old 05-13-2019, 10:38 AM
dsm1212's Avatar
Quoted: 36 Post(s)
Originally Posted by smitty View Post
https://www.monoprice.com/product?p_id=21568
Many also use the Ruipro Fiber HDMI cable that is available on amazon.
At current pricing I would probably get the RUIPRO too, but there was a bizarre pile of coupons at one point on these cables below. A friend of mine had used one so I ordered them. One of the four coupons was BOGO so I got two 50ft for $62 total which is crazy cheap, but they have worked great so far.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
steve
dsm1212 is offline
post #11372 of 14146 Old 05-13-2019, 10:39 AM
edub90's Avatar
Quoted: 39 Post(s)
Liked: 5
What gamma settings are you guys using? I had mine on Cinema 1 but noticed it’s lacking contrast and adds some grain to low light scenes. Cinema 2 is too dark and everybody looks sun tanned. Should I use 2.2 or 2.4?
edub90 is offline
post #11373 of 14146 Old 05-13-2019, 11:08 AM
jeahrens's Avatar
Quoted: 1814 Post(s)
Liked: 1136
For SDR I'm using 2.4. HDR I'm using HDR PQ.
jeahrens is online now
post #11374 of 14146 Old 05-13-2019, 11:38 AM
Quoted: 1802 Post(s)
Liked: 1117
Does anyone know what gamma THX is using?
It is just labeled as THX but is it 2.2, 2.3, 2.4?
Just wondering how it will be effected by a gamma autocal.
GregCh is offline
post #11375 of 14146 Old 05-13-2019, 01:15 PM
N8DOGG's Avatar
Quoted: 1299 Post(s)
Liked: 1529
Originally Posted by jh901 View Post
Anyone can do light control. It's light treatment that separates the special experiences from the relatively common.
Not sure what you mean.
N8DOGG is offline
post #11376 of 14146 Old 05-13-2019, 01:49 PM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
Not Silent
Originally Posted by Colozeus View Post
I have privately asked a few of you that have experience with the rs3000 and everyone has said the DI was silent. It also sounds like the 1000/2000 has a silent DI mechanism, but that's a different lens and possibly a different DI mechanism they are using.
No wonder no one can get their projectors! You're approaching double digits on the replacement PJ count.
My NX9 DI is NOT silent, but neither is its fan in high lamp mode. It's may change some when I mount it in its final ceiling location yet (I first want to add cross bracing before mounting), but it is as far back as it's going to be, so ceiling mounting will only involve an elevation and orientation change (it's currently on a table, so closer to ear level).
I will do some A/B with DI on and off. Frankly, before I turned on the DI I was plenty happy with black levels; didn't know it was off until I looked in the menu. I'm perfectly pleased with my NX9 with its DI noise. This is not a deal breaker. The fan noise bothers me more, as it's louder and constant.
Either way, I will be building a hush box to solve both issues.
ultra 150 pilot likes this.
JVC DLA-NX9 / 156" 2.4:1 CIH Seymour AT screen / Marantz AV7704 11.2 / Yamaha MX-A5000 11-ch amp
HTPC MadVR RTX 2080 / 24TB PMS Server (direct UHD rips)
Adam A8X monitor LCR / RBH A-610 x 8 / Kef Ci160ER x 4 / HSU ULS-15
Secondary: Samsung UN82MU8000 / Marantz NR1607 AVR / Kef Q150 + Minx Min 10 / SVS SB-2000
davidahn is offline
post #11377 of 14146 Old 05-13-2019, 01:54 PM
edub90's Avatar
Quoted: 39 Post(s)
Liked: 5
Thanks for the response. You don’t find 2.4 too dark at any point?
edub90 is offline
post #11378 of 14146 Old 05-13-2019, 02:09 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6409 Post(s)
Liked: 6404
Cleveland Plasma is offline
post #11379 of 14146 Old 05-13-2019, 02:11 PM
jeahrens's Avatar
Liked: 1136
I haven't yet, but this unit is not calibrated. Honestly most content has been 4K, but the first Hobbit (2K) didn't feel crushed in Gollum's cave at 2.4.
post #11380 of 14146 Old 05-13-2019, 02:23 PM
jmeitz's Avatar
Quoted: 55 Post(s)
Originally Posted by jmonier View Post
Originally Posted by DVD MAN View Post
They did send me the latest firmware 2.05 I believe, but unfortunately it did not take care of the issue. JVC did what ever the could to accommodate me including offering a replacement. But I only ha the PJ for 3 days and decided to return it. I will purchase it in the future when all the issues are taken care off. I still have a perfectly working RS 500.
From what I understand, you also have to do a "Factory Reset" after installing 2.05 to fix the problem. If you asked for 2.05 specifically to fix the vertical lines, they should have told you this. Have you done this?
(I'm not positive that the "Factory Reset" in the regular menu will do it. It's possible that it has to be done from the Service Menu. Ask whoever sent you 2.05.)
Spoke with JVC engineers. No factory reset needed with 2.05. Just do normal firmware upgrade.
Yamaha Aventage 3070 * Emotiva xpa5
Polk LSIM 707, 706, 703, 702, Rci85 and 65
Stereo Integrity HT18 (2) * Inuke 6000dsp
Panasonic UB820 * JVC NX5 * Silver Ticket 120” thin bezel
jmeitz is offline
post #11381 of 14146 Old 05-13-2019, 02:24 PM
Waikis's Avatar
Quoted: 79 Post(s)
Liked: 41
Does anyone know whether the new pjs are still using the same bulb?
I know that the housing would be different, but is it still 265w ushio?
Waikis is offline
post #11382 of 14146 Old 05-13-2019, 02:35 PM
Liked: 1117
I found that keeping the room cooler significantly lowers the sound of the fan. Apparently the fan is set up to run at higher speed if the temperature rises. So if you keep the room cool you can actually get the fan to run at a slower speed that is a lot quieter.
davidahn likes this.
GregCh is offline
post #11383 of 14146 Old 05-13-2019, 02:44 PM
docrog's Avatar
Quoted: 1060 Post(s)
Liked: 361
Originally Posted by Mike Garrett View Post
The NX9 can only display 4K or E-shifted 8K. So everything sent to it will be up-converted to 4K or E-shift 8K, if you have E-shift turned on.
I believe that 1080p 3D source material will play in native format and not be up-converted to 4K.
docrog is offline
post #11384 of 14146 Old 05-13-2019, 03:46 PM
zombie10k's Avatar
Quoted: 5238 Post(s)
Liked: 5493
Hi, yes the bulb is identical to the eshift models from last 3 years.
Waikis likes this.
zombie10k is offline
post #11385 of 14146 Old 05-13-2019, 03:57 PM
jmonier's Avatar
Quoted: 186 Post(s)
Liked: 107
Well, this was specifically with regard to the vertical lines problem and the instructions that came with the 2.05 fix for that specific problem said to do a factory reset.
In any case there are 2 reports that it didn't fix the problem even after a factory reset.
DVD MAN likes this.
jmonier is online now
post #11386 of 14146 Old 05-13-2019, 04:02 PM
jmeitz's Avatar
Quoted: 55 Post(s)
Same reason for my 2.05 firmware, blue vertical lines.
jmeitz is offline
post #11387 of 14146 Old 05-13-2019, 04:23 PM
jmonier's Avatar
Quoted: 186 Post(s)
Liked: 107
So what are you saying? That you applied the 2.05 firmware without a factory reset and it fixed it? If so, how long have you gone without seeing the problem? (Sometimes I can go several days without seeing it, so I would have to go several weeks before I would say that the problem is fixed.)
There may actually be two different problems: 1) vertical lines with no picture visible; 2) blue or green vertical lines but with the picture still visible (which is the one that I see). Which one did you have?
There has been conflicting information posted quoting JVC sources, so it's hard to determine what is right. Certainly if one JVC source supplies the firmware with specific written instructions to do a factory reset and another says that the factory reset is not necessary, there's something wrong somewhere.
post #11388 of 14146 Old 05-13-2019, 04:31 PM
jmeitz's Avatar
Quoted: 55 Post(s)
Mine has source in background with blue vert. Not sure if it fixed my projector as I only use it about 2hrs Max a week. Just reporting what the jvc engineer emailed me.
jmeitz is offline
post #11389 of 14146 Old 05-13-2019, 04:56 PM
Nexgen76's Avatar
Quoted: 732 Post(s)
Liked: 218
I can confirm that i was advised by JVC to do factory reset.....I'm going on 15hrs no lines but that doesn't mean the problem is fixed.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is online now
post #11390 of 14146 Old 05-13-2019, 05:07 PM
markmon1's Avatar
Quoted: 4656 Post(s)
Liked: 2950
Originally Posted by N8DOGG View Post
Ok, so it looks like I will be moving in the next few months and get to build a room from scratch.
13.5 x 20 x 9.5 ceilings (100% light controlled)... I will be getting a nx5 or nx7 (still undecided) but my screen size is still up in the air.
Screen will be a elunevision AT 4k 1.0 gain electric.
So, I can either go with a 120" or a 135". Im a bit worried the 135" wont be all that bright from 20 feel away. This will be a 16x9 screen as its my gaming room as well.
Im sure I should just go with the 135 and be done but I dont want a dim screen. Currently with a 108" and its plenty bright enough with my 1.1 elunevision 4k reference.
Any thoughts?
135" can be plenty brightly lit by an NX series projector. You can probably go a little bigger. Also, if your room is only 13.5 feet wide but 9.5 feet tall, you probably can get away with a higher screen and not sacrificing the quality hit it takes to go AT.
Something else to consider, since your wall is so tall. You could put a center channel centered directly above and below your screen which would center the sound on the middle of your screen and still avoid being AT.
N8DOGG likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #11391 of 14146 Old 05-13-2019, 05:41 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 253
Nope, can’t be done. The projector has to scale to 4K to address all of the pixels on the imaging chips.
seanbryan likes this.
Steve Goff
Steve Goff is offline
post #11392 of 14146 Old 05-13-2019, 06:04 PM
gravi's Avatar
Quoted: 354 Post(s)
Liked: 183
I have found 2.3 to be ideal for SDR with all the JVC projectors I have had
gravi is offline
post #11393 of 14146 Old 05-13-2019, 06:19 PM
04rex's Avatar
Quoted: 322 Post(s)
Liked: 64
Hey guys, I am wondering what the bolt size is to mount the NX5? I am using a Peerless mount. Thanks.
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One, Apple TV, HTPC, Ben-Q W1070, 106" screen
04rex is offline
post #11394 of 14146 Old 05-13-2019, 09:46 PM
N8DOGG's Avatar
Liked: 1529
I've been thinking of a bunch of different options. My current center is a custom JTR 210, so I'd either have to get Jeff to make me another one, or get something else... at this point with the money thats gonna be flying everywhere, the 4K CDN to build another center would suck... as would buying something new.
I'm willing to take a bit of a hit in brightness going with the AT but worry it will be too much of a hit and no stores locally have the JVC's up for Demos...
N8DOGG is offline
post #11395 of 14146 Old 05-13-2019, 11:57 PM
Quoted: 167 Post(s)
Liked: 94
When I watched GOT last night there were several scenes which were at night with flaming torches. The projector is behind me on the ceiling, however, I could see a strong beam of light from the projector coming over my seating position to the screen for the flaming torches. It was distracting watching the content seeing a beam of light go towards the screen.
I’ve not noticed it before when I was projecting onto a temporary screen, however now I’m projecting onto Stewart StudioTek 130 G3.
Scenes in daylight we’re fine.
Is this normal or do I need to adjust something?
Sorry for the noob question.
Dandlj is offline
post #11396 of 14146 Old 05-14-2019, 01:30 AM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
I'll have to check that out. My theater isn't completely done yet, so I've only turned on the A/C for one of my viewing sessions; I wasn't paying attention but next time I will. Thanks!
davidahn is offline
post #11397 of 14146 Old 05-14-2019, 01:58 AM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
I suggest a HEPA filter. Beams of light in a vacuum should be invisible, nearly invisible in air. You probably have particles of dust or haze.
seanbryan and Dandlj like this.
davidahn is offline
post #11398 of 14146 Old 05-14-2019, 01:59 AM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
Originally Posted by Cleveland Plasma View Post
Did you decide on a design?
Have not finalized, but have a prelim design. It was based on the PJ sitting in the box; now with the Chief mount, the hush box will be built around the mounted PJ.
davidahn is offline
post #11399 of 14146 Old 05-14-2019, 02:06 AM
fatallerror's Avatar
Quoted: 297 Post(s)
Liked: 156
What would be the sacrifice using an AT screen with this projector?
fatallerror is offline
post #11400 of 14146 Old 05-14-2019, 02:31 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Well, with 1080p 3D bluray i have a strange "issue". Sometimes (actually, very often) when the movie start there is blank space all around the image, something like a "direct video" mode with no upscaling. I use the zoom function, changin' to auto or native will fill the screen (i have set 2 memory banks for auto and zoom), at least "most" of the screen since in auto/native you have some lateral blank space that you have to zoom out.
Going back and forth from auto/native to zoom sometimes fixes the beahviour and i have the use of full panel even with 3D source and zoom mode.
Anyone experienced this?
locutus2k is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
