Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 381 - AVS Forum | Home Theater Discussions And Reviews
 12353Likes
post #11401 of 12844 Old 05-14-2019, 02:38 AM
locutus2k's Avatar
Quoted: 236 Post(s)
Liked: 75
Originally Posted by edub90 View Post
I did add 2 ticks but the Oppo still had a hint better sharpness. Still really close though.
Oppo and Cambridge players have a sharper image than Panasonic and they also have more "pop" in contrast. Panasonic have a "sweeter" image, overall well balanced with nice colours but less "pop" than Oppo or Cambridge (in my experience, Cambridge a bit more than Oppo). I have all 3 players and have done extensive tests on N9 and LG Oled TV. On the oled tv we're not talking big differences but with the Jvc projector they are more evident.
locutus2k is online now
post #11402 of 12844 Old 05-14-2019, 04:25 AM
docrog's Avatar
Quoted: 1028 Post(s)
Liked: 344
Originally Posted by Steve Goff View Post
Nope, can’t be done. The projector has to scale to 4K to address all of the pixels on the imaging chips.
Well, here's the interesting thing about 3D source material. If you set your player to force output at 4K (for example, using either my Oppo 103D BR player or Panasonic UB820 UHD player), it will only play the 3D content in 2D. You have to change output to "native resolution" (3D output at 1080p) in order to achieve 3D on the JVC. Do you have any explanation why a UHD capable player will send native 2D 1080p/UHD content as UHD to the PJ for 1 to 1 UHD mapping, but the same player can't internally up-convert 1080p 3D content to that same UHD format?
docrog is online now
post #11403 of 12844 Old 05-14-2019, 06:03 AM
markmon1's Avatar
Quoted: 4419 Post(s)
Liked: 2768
Originally Posted by fatallerror View Post
What would be the sacrifice using an AT screen with this projector?
AT screens have to have holes to let the sound through. I guess if you're sitting far enough back there's no difference. But if you're sitting close enough to really cash in on 4K benefits, those holes have to take away some small amount of detail.
I don't think any display device can receive 4K 3d signal.
Brandon B likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #11404 of 12844 Old 05-14-2019, 06:39 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6308 Post(s)
Liked: 6311
Hi, yes the bulb is identical to the eshift models from last 3 years.
So if you have a spare bulb and are updating, keep it
Originally Posted by davidahn View Post
Have not finalized, but have a prelim design. It was based on the PJ sitting in the box; now with the Chief mount, the hush box will be built around the mounted PJ.
If you are building the box around the projector and mount, you would not need the mount anymore right?
Cleveland Plasma is offline
post #11405 of 12844 Old 05-14-2019, 06:56 AM
cxwingav's Avatar
Quoted: 20 Post(s)
Originally Posted by markmon1 View Post
135" can be plenty brightly lit by an NX series projector. You can probably go a little bigger. Also, if your room is only 13.5 feet wide but 9.5 feet tall, you probably can get away with a higher screen and not sacrificing the quality hit it takes to go AT.
Something else to consider, since your wall is so tall. You could put a center channel centered directly above and below your screen which would center the sound on the middle of your screen and still avoid being AT.
Are you sure? A 135" wide screen will be 76" tall (16/9). Sitting 12" away you'll get an offset of 19" between the two center channels, which will cause comb filtering in the 0.8 to 2kHz region, so you have to run a delay line, and a different EQ on each. Also there is no phantom imaging vertically, you receive the sound with the same ITD. What you'll get is a reinforcement of perceived loudness due to precedence effect.
cxwingav is offline
post #11406 of 12844 Old 05-14-2019, 06:58 AM
Mike Garrett's Avatar
Quoted: 11652 Post(s)
Liked: 9213
Originally Posted by Waikis View Post
Does anyone know whether the new pjs are still using the same bulb?
I know that the housing would be different, but is it still 265w ushio?
Yes, same bulb as previous generation. Just different housing was required for the new projector design.
Mike Garrett is offline
post #11407 of 12844 Old 05-14-2019, 07:08 AM
baronzemo78's Avatar
Dumb question. I have heard that since these projectors are so heavy that they can sway if people walk on the floor above the mount.
I have a Chief mount and adjustable column in some 2x4s in the soffit. I used 3/8" bolts with: washers, lock washers and nuts. Is that solid enough to hold the projector and not have it move if people walk above it?
baronzemo78 is offline
post #11408 of 12844 Old 05-14-2019, 07:21 AM
edub90's Avatar
Quoted: 39 Post(s)
Liked: 5
Thanks for the response. You don’t find 2.4 too dark at any point?
I haven't yet, but this unit is not calibrated. Honestly most content has been 4K, but the first Hobbit (2K) didn't feel crushed in Gollum's cave at 2.4.
Makes sense. I tried 2.4 last night and it was definitely better than Cinema 1 or 2. A little dark during low light scenes though.
Originally Posted by gravi View Post
I have found 2.3 to be ideal for SDR with all the JVC projectors I have had
Thanks for reply. I’ve set my projector to custom and tried 2.3 and that seems to be right in the sweet spot. Not too dark not too light and still gives the picture a night pop.
Interesting. For some reason I always thought it was the other way around. I thought the Panasonic had more detail but when I tested it, I was wrong. Is the Cambridge “pop” significantly more than the Oppo?
edub90 is offline
post #11409 of 12844 Old 05-14-2019, 07:25 AM
Liked: 9213
You can make this work for a single seat or even a single row, if the distance is the same from both center channel speakers. If you have two or more rows, I would never go with two center channel speakers, due to the mismatched distance. With that said, it should not be necessary.
post #11410 of 12844 Old 05-14-2019, 07:25 AM
fatallerror's Avatar
Quoted: 297 Post(s)
Liked: 156
Then I guess your screen is not AT, how far do you sit from the 135"? about 10ft/3m? If you are sitting closer than that and you have the center channel under the screen then the screen must be like 60cm/2ft from the floor so you need to look way up to the top of the screen, seems to me a weird angle. I can't find a pic of your setup but should be something like this without AT screen.
Maybe in reality it's not bad but the closer you sit the AT screen is more likely needed to keep the middle of the screen as close to your eye level as possible to avoid this looking up situation.
Any owner here with AT screen who's sitting relatively close?
fatallerror is offline
post #11411 of 12844 Old 05-14-2019, 07:27 AM
locutus2k's Avatar
Quoted: 236 Post(s)
Liked: 75
Not so much, is just a bit and you have to look for it.
post #11412 of 12844 Old 05-14-2019, 07:30 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 3398 Post(s)
Liked: 1599
That is a very solid installation, and barring someone doing Jumping Jacks directly above that mount, you should be just fine"as is".
MississippiMan is online now
post #11413 of 12844 Old 05-14-2019, 07:34 AM
Liked: 9213
The better AT screens take very little away and the improvement in speaker location, more than makes up for that in my opinion. Take a look at the 4K pixel size compared to the UF fabric. Same applies to Screen Excellence EN4K, NEO and Screen Acoustic V6.
Name:	Screen Shot 2019-05-14 at 9.28.06 AM.png
dlinsley and raheaps like this.
post #11414 of 12844 Old 05-14-2019, 07:41 AM
Liked: 9213
I sit 9' from a 9' wide AT screen.
post #11415 of 12844 Old 05-14-2019, 09:15 AM
davidahn's Avatar
Quoted: 96 Post(s)
Liked: 59
True. That was the original plan. Then I couldn't get anyone to build it, so I got the mount. Then I realized I needed a hush box once I heard the high lamp mode!
JVC DLA-NX9 / 156" 2.4:1 CIH Seymour AT screen / Marantz AV7704 11.2 / Yamaha MX-A5000 11-ch amp
HTPC MadVR RTX 2080 / 24TB PMS Server (direct UHD rips)
Adam A8X monitor LCR / RBH A-610 x 8 / Kef Ci160ER x 4 / HSU ULS-15
Secondary: Samsung UN82MU8000 / Marantz NR1607 AVR / Kef Q150 + Minx Min 10 / SVS SB-2000
davidahn is offline
post #11416 of 12844 Old 05-14-2019, 09:28 AM
JeffNebraska's Avatar
Quoted: 127 Post(s)
Liked: 27
I "only" have a Sony 350ES projector (4k, but SDR). However, an A/B comparison of the Oppo 203 v. Panasonic 820 yields the same results. The 820 is a smoother. more balanced image, but the Oppo has more pop and wow factor. The Oppo more frequently looks wrong, but it looks more incredible when it's right.
Jeffnebraska
Reaching for the Next Level With a Sony 350ES and a 133" 2.35 AT Screen
JeffNebraska is offline
post #11417 of 12844 Old 05-14-2019, 10:10 AM
raheaps's Avatar
Quoted: 16 Post(s)
I second what Mike says. I’ve had AT screens on my theater for 12 years starting with the RS1 and now a RS2000. I sit 12 feet from a 154” scope Seymour XD screen. Outstanding picture no visible “holes” that I can see. Mike can get you pricing and samples of many varieties of screen material to evaluate in your environment.
raheaps is online now
post #11418 of 12844 Old 05-14-2019, 10:17 AM
dlinsley's Avatar
Quoted: 488 Post(s)
Liked: 376
Not particularly close, but 10ft from a 10ft wide 2.37:1 screen with the v6 material. It really is incredible, with your nose at the screen it looks solid and I can still make out the inter-pixel gaps - and that's through the Panamorph DCR lens that is shrinking the pixels to fit them all on the screen.
Mike Garrett likes this.
dlinsley is offline
post #11419 of 12844 Old 05-14-2019, 10:45 AM
Quoted: 297 Post(s)
Liked: 156
Thank you for the replies! So no noticeable loss with the right screen material with this projector from this distance
post #11420 of 12844 Old 05-14-2019, 11:31 AM
Todd G.'s Avatar
Quoted: 147 Post(s)
Liked: 353
I have significant wood blocking (3 1/2”) between two of the floor joists above and using 4” long 5/16” lag bolts into the blocking. Centerline of my Chief mount is nearly in the middle of the 16’ joint span between the support beams on either end of this spread and right under the main path into kitchen—a very busy route for sure. My extension is set at 15” to help minimize vertical shift, so any “sway” might be exaggerated somewhat. Still, I get minimal floor bounce and it’s difficult to see it on the screen...even when the heavy-footed people in our home are walking above.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #11421 of 12844 Old 05-14-2019, 11:42 AM
raheaps's Avatar
Quoted: 16 Post(s)
I can’t speak to non-AT high gain screens but yes, no noticeable loss. My room is 14.5’x 19’ with a 19.5’ throw from the RS2000 and Paladin DCR lens in a totally light controlled setting. I’ve looked at several samples of different material trying to find some improvement in clarity or brightness from the screen itself but nothing has jumped put. Perhaps if I sat closer I’d view things different. My key sanity check (my wife) keeps me from seeing more than is really there. If only something would come along in an AT screen with an improvement of 50% or more in gain without hot spotting, etc. Biggest improvement in my room is the RS2000. The tone mapping and flexibility to adjust the picture is terrific. And my RS2000 has less than 60 hours on it with only my adjustments and no professional calibration as yet.
fatallerror likes this.
post #11422 of 12844 Old 05-14-2019, 11:56 AM
Tom Bley's Avatar
Quoted: 908 Post(s)
Liked: 857
How do you get a 19.5' throw in a 19' room?
Tom Bley is offline
post #11423 of 12844 Old 05-14-2019, 12:06 PM
raheaps's Avatar
Quoted: 16 Post(s)
First, can’t you un-mush the Cubbies a little bit? They are playing good so far. (Cubs fan here.)
Second, the projector is not in the room. It’s in a temp controlled hush box that sits on the other side of the back wall of the room in the garage. I’m at 3300’ altitude so projector runs in high altitude mode and hush box helps with noise control. All four of my JVCs have used this box except I needed to do a little enlargement for the RS2000.
Tom Bley and dlinsley like this.
post #11424 of 12844 Old 05-14-2019, 12:12 PM
04rex's Avatar
Quoted: 320 Post(s)
Liked: 64
Hey guys, I might be having an issue with my XBox 1X and NX5. I just installed the JVC. I am running a brand new ruipro hdmi cable. When I go to the XBox main screen, it shows up fine but in 1080. Then I go to settings and switch it to 4k, but while it is doing that, it comes back and says there may be a problem displaying 4k.
So I choose 4k details, and everything is check marked except for Dolby Vision. It says it supports it all, but it is in 1080.
Then when I try to play a game, it just gets stuck on a black screen and doesn’t come back. I have to turn off the XBox to get it back working. What could be the problem?
Also, what should the color depth be at?
Thanks for any help.
04rex is offline
post #11425 of 12844 Old 05-14-2019, 12:44 PM
Tom Bley's Avatar
Quoted: 908 Post(s)
Liked: 857
Oh, nice! Even better than a hush box in the room.
I changed the Cubs logo last year after their meltdown at the end of the season. They didn't start this season well but, they are doing much better as of late.
Tom Bley is offline
post #11426 of 12844 Old 05-14-2019, 12:53 PM
tommarra's Avatar
Quoted: 559 Post(s)
Liked: 337
If you are in the market for AT screens don’t overlook Soundmax 4K AT screen from XYscreen.com
Image quality is fantastic. It does not perform as well with Audio as say the V6 (higher attenuation of highs ) but in terms of gain it is almost unity gain. IMO you can easily fix the treble attenuation through EQ - but you cannot do anything about low screen gain.
It is pretty fabulous - and has the highest gain of all the AT screens out there ... and it is dirt cheap so even if you don’t like it you won’t mind throwing it away and buying something like Seymour or V6
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #11427 of 12844 Old 05-14-2019, 12:56 PM
tommarra's Avatar
Quoted: 559 Post(s)
Liked: 337
Originally Posted by N8DOGG View Post
Ok, so it looks like I will be moving in the next few months and get to build a room from scratch.
13.5 x 20 x 9.5 ceilings (100% light controlled)... I will be getting a nx5 or nx7 (still undecided) but my screen size is still up in the air.
Screen will be a elunevision AT 4k 1.0 gain electric.
So, I can either go with a 120" or a 135". Im a bit worried the 135" wont be all that bright from 20 feel away. This will be a 16x9 screen as its my gaming room as well.
Im sure I should just go with the 135 and be done but I dont want a dim screen. Currently with a 108" and its plenty bright enough with my 1.1 elunevision 4k reference.
Any thoughts?
Have you tried Elunevision - their 1.0 gain for AT material is totally incorrect and they don’t give out samples. Their gain is closer to 0.8 - so make sure you are still able to do good HDR.
When I was buying my own AT screen - I was considering them but since they don’t give out samples to compare with V6 or Seymour I decided to not go for them
tommarra is offline
post #11428 of 12844 Old 05-14-2019, 01:09 PM
Liked: 9213
Pretty coarse weave. The weave looks close to XD.
post #11429 of 12844 Old 05-14-2019, 01:16 PM
Quoted: 297 Post(s)
Liked: 156
I'm European so not that many options here, basically Elite Screens, Screen Excellence and DreamScreen are the options here but I'm sure that one of them is good enough.
How does that hush box look like? How's the cooling? pic would help
post #11430 of 12844 Old 05-14-2019, 01:21 PM
Jeffg8's Avatar
Quoted: 144 Post(s)
Liked: 75
Same as the rs600 bulb? I just realized I still have a new bulb I was going to sell with an rs600 I no longer use, but if it works with the nx7, nx9....might be a factor if I decide to upgrade this fall.
Sent from my SM-G955U using Tapatalk
Dedicated Theater -Projector -Sony 385es-Screen-Stewart Firehawk 110" 1.78-Video-Panasonic UB-900, Direct Tv-Preamp-Anthem AVM-60-Amplifiers-MM8077, Proceed Amp 5-Sub-SVS-PB13 Ultra Speakers-B&W 803D, HTM1, Side and Rear Wall B&W (4), Ceiling B&W (4)
Xbox One -Panamax M5300-PM-Control 4 Ea-5,Pakedge Router
Jeffg8 is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
