Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 382 - AVS Forum | Home Theater Discussions And Reviews
 13320Likes
post #11431 of 14094 Old 05-14-2019, 01:38 PM
Tom Bley's Avatar
Quoted: 909 Post(s)
Liked: 865
Originally Posted by Jeffg8 View Post
Same as the rs600 bulb? I just realized I still have a new bulb I was going to sell with an rs600 I no longer use, but if it works with the nx7, nx9....might be a factor if I decide to upgrade this fall.
Sent from my SM-G955U using Tapatalk
Same bulb, different housing.
raheaps likes this.
Tom Bley is offline
post #11432 of 14094 Old 05-14-2019, 01:41 PM
xenofin's Avatar
Just to inform people my N5 might also be one of the vertical stripes bug victim. Fw is 2.05 OOB.
However, a little different story how bug was shown. After 27 hrs in the middle of GoT, latest episode, while streaming from HBO app in Samsung S4 tablet green pixels started to show in picture and finally larger areas of greenish blocks corrupted the picture. I opened main menu and it started to show stripes, bluish and pink stripes in menu window and menu itself was also vibrating rapidly. No stripes in picture itself, only those green pixels.
Next I only changed iris from auto2 to manual which didn't help. Power cycle did help and rewatching problematic point in the episode did not show any corruption.
I have Ruipro 10m cable between N5 and Denon AVR-X4500H. Picture mode was in user mode, color profile SDR709 with custom gamma 2.3, brightness -3, iris auto 2, -9, low lamp. Info window showed 2160p,30fps and RGB 8bit. Upscaling in AVR was disabled.
This was first sign of any failure or bug. I think it was not the case of overheating or problem with the cable or in signal path. I had projector on for couple of hours before it happened. Day before it was on for much longer period of time.
Otherwise I am quite satisfied with this projector although it does not have the best convergence. Projector has also so many options that it takes a lot of work to get picture quality right for multiple sources I have. And I have not yet touched 3D.
7.1.4 Dolby Atmos system: Denon AVR-X4500H, Sony DA2400ES(for back Atmos speakers), 2xMonitor Audio Silver RS6, 2xRS1, 2xRadius 90, Radius 225, 4xDali Alteco C-1, BK XLS200, JVC N5BE with Ruipro 10m fibre HDMI cable, Grandview Fixed 4K Edge 100" (1.0), Panasonic DP-UB824, Sony BDP-S790, Topfield cable FHD box, old Sony FHD 46" TV, Denon DP-450USB, Logitech Harmony Hub + Samsung Galaxy S4 TAB, Asus RT-AC68U router
xenofin is offline
post #11433 of 14094 Old 05-14-2019, 01:51 PM
jeahrens's Avatar
Quoted: 1809 Post(s)
Liked: 1135
Same bulb, but new housing. I believe you still could remove the bulb from the current housing and place it in the new one.
jeahrens is offline
post #11434 of 14094 Old 05-14-2019, 02:11 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6405 Post(s)
Liked: 6399
Originally Posted by baronzemo78 View Post
Dumb question. I have heard that since these projectors are so heavy that they can sway if people walk on the floor above the mount.
I have a Chief mount and adjustable column in some 2x4s in the soffit. I used 3/8" bolts with: washers, lock washers and nuts. Is that solid enough to hold the projector and not have it move if people walk above it?
That is a very solid installation, and barring someone doing Jumping Jacks directly above that mount, you should be just fine"as is".
No dance parties either lol
Originally Posted by davidahn View Post
True. That was the original plan. Then I couldn't get anyone to build it, so I got the mount. Then I realized I needed a hush box once I heard the high lamp mode!
That makes sense now......Might be easier just to ditch the mount all together now...
Cleveland Plasma is offline
post #11435 of 14094 Old 05-14-2019, 05:26 PM
jbn008's Avatar
Quoted: 257 Post(s)
Liked: 124
That sounds very similar to what I've experience. i've been talking with JVC and they're sending me a replacement since it's still happening with the newer 2.05 software. I'm still not convinced that it's not just a software bug (and not related the hardware of specific units).
I noticed that you use a Denon receiver (as do I) and I'm curious if those that have experienced this issue are using a Denon or Marantz as well. If anything, at least we can rule that out.
jbn008 is offline
post #11436 of 14094 Old 05-14-2019, 05:45 PM
slots1's Avatar
Quoted: 67 Post(s)
Liked: 24
I have put very quiet fans to help and I am using the same enclosed, except for front and back of box open.
slots1 is offline
post #11437 of 14094 Old 05-14-2019, 06:01 PM
N8DOGG's Avatar
Quoted: 1298 Post(s)
Liked: 1529
Originally Posted by tommarra View Post
Have you tried Elunevision - their 1.0 gain for AT material is totally incorrect and they don’t give out samples. Their gain is closer to 0.8 - so make sure you are still able to do good HDR.
When I was buying my own AT screen - I was considering them but since they don’t give out samples to compare with V6 or Seymour I decided to not go for them
Im in Canada, Seymour is almost 3x the cost as I can get the elunevision for. So, its not even a consideration at this point.
There are not a ton of options for us Canucks.
I can get a 135" motorized elunevision for 45% off retail, so theres nothing that will come close to that price/performance for me that I can find.
N8DOGG is offline
post #11438 of 14094 Old 05-14-2019, 07:04 PM
ultra 150 pilot's Avatar
Quoted: 258 Post(s)
Liked: 234
I have over 200 hours on my nx5 and not a single glitch! Although I’m not using an hdmi pre pro or receiver.
The nx5 is connected to my oppo 205.
N8DOGG likes this.
ultra 150 pilot is offline
post #11439 of 14094 Old 05-14-2019, 07:15 PM
04rex's Avatar
Quoted: 322 Post(s)
Liked: 64
Hey guys, for the Chief RPA-281 mount, do I just get that or is the plate connector separate and in addition to that?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One, Apple TV, HTPC, Ben-Q W1070, 106" screen
04rex is offline
post #11440 of 14094 Old 05-14-2019, 07:18 PM
gravi's Avatar
Quoted: 354 Post(s)
Liked: 183
The RPA-281 includes the RPA mount as well as the JVC specific plate
gravi is offline
post #11441 of 14094 Old 05-14-2019, 07:25 PM
Quoted: 258 Post(s)
Liked: 234
I just got my plate for my nx5, not cheap but I’ve been using the same mount for 3 different pjs and many years
I will say that I found the screws that were provided with the plate seemed too short and made me feel uncomfortable with all that weight but a trip to the hardware store fixed that!
post #11442 of 14094 Old 05-14-2019, 07:29 PM
04rex's Avatar
Quoted: 322 Post(s)
Liked: 64
Perfect thank you. Do you know if it is centred for the projector? I have a mount right now that I don’t really trust because it is very hard to centre it to the projector so that it mounts straight. Right now it tilts down because the centre of gravity is off. Plus it just doesn’t seem strong enough.
Thanks for your help.
04rex is offline
post #11443 of 14094 Old 05-14-2019, 07:30 PM
04rex's Avatar
Quoted: 322 Post(s)
Liked: 64
Thank you for that. Would you be able to answer my centre of gravity question as well? It is greatly appreciated.
ultra 150 pilot likes this.
04rex is offline
post #11444 of 14094 Old 05-14-2019, 07:48 PM
leo9000's Avatar
Quoted: 32 Post(s)
Issue with Dolby Vision Discs
I received my NX5 this week and have been watching some 4K films on Apple TV and on my Oppo player. They all look amazing! Today I put in a Dolby Vision disc and the colors and image is distorted (see screen shot attached). Does anyone know what settings I have to adjust in the NX5 or in the Oppo to get the image to display correctly. I tried a couple of Dolby Vision discs and they all had the same problem. Thanks!
leo9000 is offline
post #11445 of 14094 Old 05-14-2019, 08:04 PM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
I would suggest you try XYscreens. IMO it’s much better because of higher gain
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #11446 of 14094 Old 05-14-2019, 08:28 PM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
I've found the RPA to be solid mount with good centering of the mass below the pivot points.
Todd G. likes this.
mattztt is offline
post #11447 of 14094 Old 05-14-2019, 08:49 PM
zombie10k's Avatar
Quoted: 5238 Post(s)
Liked: 5492
Is this an Oppo 203 or 205? If so, check Setup Menu -> HDR Setting -> HDR
you will see Auto, Forced, Off, Strip Metadata, Dolby Vision
Which setting is the default?
zombie10k is online now
post #11448 of 14094 Old 05-14-2019, 09:43 PM
markmon1's Avatar
Quoted: 4643 Post(s)
Liked: 2945
Originally Posted by cxwingav View Post
Are you sure? A 135" wide screen will be 76" tall (16/9). Sitting 12" away you'll get an offset of 19" between the two center channels, which will cause comb filtering in the 0.8 to 2kHz region, so you have to run a delay line, and a different EQ on each. Also there is no phantom imaging vertically, you receive the sound with the same ITD. What you'll get is a reinforcement of perceived loudness due to precedence effect.
Who said anything about 135" wide? I just saw '135"' or '120"' mentioned. Screen measurements always indicate diagonal.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #11449 of 14094 Old 05-14-2019, 09:47 PM
markmon1's Avatar
Liked: 2945
Originally Posted by fatallerror View Post
Then I guess your screen is not AT, how far do you sit from the 135"? about 10ft/3m? If you are sitting closer than that and you have the center channel under the screen then the screen must be like 60cm/2ft from the floor so you need to look way up to the top of the screen, seems to me a weird angle. I can't find a pic of your setup but should be something like this without AT screen.
Maybe in reality it's not bad but the closer you sit the AT screen is more likely needed to keep the middle of the screen as close to your eye level as possible to avoid this looking up situation.
Any owner here with AT screen who's sitting relatively close?
I sit 7 feet from a 135" screen. Screen is 4" from ceiling. Even on scope movies, I move the image to the top, not the bottom. This allows me to recline on my recliner, which points me more towards the ceiling.
markmon1 is offline
post #11450 of 14094 Old 05-14-2019, 11:09 PM
fatallerror's Avatar
Quoted: 297 Post(s)
Liked: 156
Wow that close, then you really can't have AT screen not just because of the weaves but also with low screen position your head might block the projection. It's all about personal preference, also sitting like that the higher position make sense
But good to know that there are many big AT screen owners here so this N series is bright enough for 130+ inch size.
fatallerror is offline
post #11451 of 14094 Old 05-15-2019, 12:18 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Since the Jvc has no Dolby Vision compatibility i think you may be using some sort of "forced" DV output that cause the issue. Just disable DV or put it on auto and it should be fine showing the hdr layer.
locutus2k is offline
post #11452 of 14094 Old 05-15-2019, 12:25 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
I'm convinced that series N has software issues. I'm also convinced that Jvc will iron out all those issues, eventually. The fact is that issues are so random and apparently not related to a specific enviroment tha is very hard to trace and reproduce. I've done extensive tests to find out what was causing the blue vertical bars and similar. I think that is something related to CMD and/or low latency setting. For some reason the low latency is on by default but apart from the fact that i can't see no use for normal movie viewing i'm pretty sure is the key factor or at least one of the key factors in causing the random issues. Since i have disabled all cmd options including low latency and motion enhance i've had zero issues.
post #11453 of 14094 Old 05-15-2019, 01:24 AM
xenofin's Avatar
If I remember correctly (I need to check this later) I have Motion Enhance set to low, CMD off and low latency off. However, I tried CMD setting 'low' during streaming but that was at the start of the episode, some 30-40 min earlier. I disabled it after noticing some artifacts (not green pixels). If glitch happens again I'll try the following in the order
1. change the input from HDMI1 to HDMI2 in projector. If no help then
2. disconnect HDMI cable from the projector
3. bypass AVR and connect source directly to projector
Hopefully I can check this way my AVR is not the culprit. I checked earlier that upscaling in AVR did not cause any detrimental effects on PQ but anyhow I disabled it when using projector.I use upscaling with my FullHD TV to get 1080p resolution (source 1080i or lower).
xenofin is offline
post #11454 of 14094 Old 05-15-2019, 02:05 AM
locutus2k's Avatar
Quoted: 242 Post(s)
Liked: 80
Your specific issue seems related to source and/or connections. IF we're talking of the well known issues changing input, disconnecting cables and/or bypass avr will not change anything. Anyway disable enahnce too in cmd and try again.
post #11455 of 14094 Old 05-15-2019, 06:14 AM
leo9000's Avatar
Quoted: 32 Post(s)
I have the 203. I'll check the settings when I'm home tonight. Before I got the NX5 I had the Epson 5040UB and it played the disc without any issues.
leo9000 is offline
post #11456 of 14094 Old 05-15-2019, 06:15 AM
leo9000's Avatar
Quoted: 32 Post(s)
Thanks! I'll try this when I get home tonight.
leo9000 is offline
post #11457 of 14094 Old 05-15-2019, 06:29 AM
jbn008's Avatar
Quoted: 257 Post(s)
Liked: 124
That's encouraging. Makes me think it might be more of a compatibility issue or something.
jbn008 is offline
post #11458 of 14094 Old 05-15-2019, 06:42 AM
jbn008's Avatar
Quoted: 257 Post(s)
Liked: 124
Unfortunately, I've had low latency and cmd turned off since I first powered up the projector and I've still been victim to the issue. I agree, I think it's a software issue so hopefully they'll get it worked out sooner than later. Btw, are you using a receiver for the HDMI switching? If so, what brand?
jbn008 is offline
post #11459 of 14094 Old 05-15-2019, 06:47 AM
Manni01's Avatar
Quoted: 5361 Post(s)
Liked: 5420
Low latency needs to be switched ON, not off, in order to disable all CMD processing. Motion enhanced should also be switched off.
Not sure if this is enough to prevent the issue from happening, but this is what you want if you want to prevent any unwanted processing.
JVC Autocal Software V11 Calibration for 2019 Models (Google)
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is online now
post #11460 of 14094 Old 05-15-2019, 06:48 AM
cxwingav's Avatar
Quoted: 20 Post(s)
Whatever the size, my comments still stand. I was asking "are you sure?" about your suggestion for two center speakers to have an educated discussion about the pros and cons of the approach. I didn't expect it to be shut down like that. Oh well, I will look elsewhere for friendly educational discussions...
Sent from my Pixel 3 using Tapatalk
cxwingav is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
