Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 16375Likes
post #11941 of 17733 Old 05-28-2019, 06:33 AM
Tom Bley's Avatar
Quoted: 916 Post(s)
Liked: 892
My RS-2000 hasn't had any of the vertical stripes thankfully, so far. I still have slow start up times though, about 2.20 minutes. It did get down to about 1.25 minutes after the 2.01 firmware update but, then seemed to go back to the 2 minute mark. I actually switch the input on my Yamaha RX-A1080 and then the D-ILA logo seems to appear. I did put in my new spare bulb and am running with it now for about 4 hours.
At least it looks like the projectors are built solid and also ready for laser.
http://cine4home.de/exklusiver-tear-...bWgzHAob7HY2DI
Tom Bley is online now
post #11942 of 17733 Old 05-28-2019, 07:03 AM
tommarra's Avatar
Quoted: 625 Post(s)
Liked: 373
Originally Posted by woofer View Post
Sorry, but the whole N/NX series is a joke!!
How do you make that inference? There are hundreds if not thousands who are not on AVS and are perfectly happy with their projector.
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #11943 of 17733 Old 05-28-2019, 07:07 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6662 Post(s)
Liked: 6647
Originally Posted by tommarra View Post
Can I ask how is the audio calibration he does different from running ARC on my Anthem? Is he able to create some form of custom EQ and calibration that ARC cannot do?
Mine was done with Chad B. It is far beyond that, with audio calibration you are looking at around 8 hours of him being there working. I do not know all the ins and outs, I know each speaker is tuned and tested individually.
Jacob92175 likes this.
Cleveland Plasma is online now
post #11944 of 17733 Old 05-28-2019, 07:08 AM
dlinsley's Avatar
Quoted: 547 Post(s)
Liked: 438
Unless there was a running change in the hardware, it definitely feels like v2.0x firmware related. I had 120 hours on my original RS3000, using v1.17 and 1.19 (I think, whatever they publicly made available) without issue.
I only just ended up with a replacement - which reproduced this issue after only 5 hours total lamp time - as my lamp wouldn't strike and when I went to put in my replacement the connector was lose and couldn't connect. The connector has a flange and is behind another piece of plastic and so pulls tight against that to let the connector disconnect but the retaining clip (I'm guessing) had come loose and so was free to push back and never could reconnect.
dlinsley is offline
post #11945 of 17733 Old 05-28-2019, 07:13 AM
Davidian1's Avatar
Quoted: 23 Post(s)
Liked: 5
Concerning my red and yellow bars and ghosting my Canadian JVC rep did not indicate there was any immediate fix and needs to see the machine to possibly duplicate the issue. I think I'll wait before sending it in since he doesn't know what will cause it or how to exactly fix it. I would suggest there's no real fix yet unless there's a 2.06. But I'm having the bars and input 2 not working
Davidian1 is offline
post #11946 of 17733 Old 05-28-2019, 07:13 AM
Frohlich's Avatar
Quoted: 2054 Post(s)
Liked: 2261
Not sure your statement makes sense. if there are issues being reported on AVS by multiple members than there are inherent issues for all JVC owners. Just because they don't post on AVS doesn't mean their units are not working or working, it just means they don't post on AVS. IE if "X" percent of all units are having issues than that applies across the board for all owners all over the world. I would say there is enough evidence on this thread that these projectors have issues...there is plenty of documentation that this should not be a point of discussion..it is a fact. Whether those will all be resolved with future firmware updates remains to be seen. The power of this community is sharing information and helping JVC make a better product going forward.
woofer, loggeo, MaxTemp and 1 others like this.
Frohlich is online now
post #11947 of 17733 Old 05-28-2019, 07:17 AM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 200
Spare Bulb Storage
I got notification of shipment today, barely 2 weeks after I mailed in the form. I don't think there is an issue storing the bulb in its packaging in the attic but wanted to make sure if extreme temps are an issue (attics in Texas can get pretty hot in the summer)
gravi is online now
post #11948 of 17733 Old 05-28-2019, 07:48 AM
bwillcox's Avatar
Quoted: 928 Post(s)
Liked: 535
Hmm, unlikely that it gets as hot in your attic as it does in the projector when turned on.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is online now
post #11949 of 17733 Old 05-28-2019, 07:55 AM
tigerhonaker's Avatar
Quoted: 628 Post(s)
Liked: 626
Thumbs down
Old Today, 08:17 AM
gravi
gravi's Avatar
Spare Bulb Storage
Just as a Heads-Up i (Suggest) not storing that extra Lamp-Assembly in your attic in Texas.
I live in Franklin, TN. and even here in mid-summer it can and does reach plus 100-degrees.
And the temperature in the attic is way-way higher than the outside that's for sure.
Anyway, years and years ago I use to store different things in the attic and below is what actually took place.
Anything that was in a box the Constant-HEAT deteriorated and the box simply turned Brittle and when Touched broke into shreds instantly.
Don't do it .............
Terry
tigerhonaker is offline
post #11950 of 17733 Old 05-28-2019, 07:55 AM
Tom Bley's Avatar
Quoted: 916 Post(s)
Liked: 892
That was my thought as well but, why does it have to be in the attic? It's such a small box I would just put it on the shelf in a closet unless he's really strapped for storage space.
post #11951 of 17733 Old 05-28-2019, 08:18 AM
leo9000's Avatar
Quoted: 32 Post(s)
I've had the same issue, but so far has only occurred while watching movies on AppleTV. I contacted JVC and they had me send an email to their projector tech department. We'll see what they say. While this issue was occurring the resolution display box that appears in the upper right corner was also shaking.
leo9000 is offline
post #11952 of 17733 Old 05-28-2019, 08:23 AM
Drem's Avatar
Quoted: 148 Post(s)
Liked: 127
Do we have users in the EU with the vertical lines issues? Considering we have different voltage output over here. Just a long shot. Also do you get the issue even with fiber optic hdmi cabling?
Skickat från min VKY-L29 via Tapatalk
Drem is offline
post #11953 of 17733 Old 05-28-2019, 08:24 AM
mikela's Avatar
Quoted: 444 Post(s)
Liked: 634
Thermal cycling is often used as a means of accelerating the life time of a part or material in reliability engineering studies. Putting it in your attic would be very similar to this.
mikela is online now
post #11954 of 17733 Old 05-28-2019, 08:41 AM
Gates's Avatar
Quoted: 313 Post(s)
Liked: 153
Would the RS1000 be a massive upgrade over my RS400?
JVC DLA-RS1000, 120″ EluneVision Reference Studio AudioWeave 2.35:1 CinemaScope screen, Marantz AV8802a Pre/Pro, Anthem MCA 525, Anthem MCA 225, Anthem PVA-4, Paradigm CI Elite E80-R ceiling speakers x4, Paradigm Prestige 95F, Paradigm Prestige 15B x4, Paradigm Prestige 55C, Paradigm Signature Sub 1, Panasonic UDP820 UHD player, OPPO 203 UHD player, Richard Gray 1200c Custom power conditioner, AC Infinity AIRCOM X4.
Gates is offline
post #11955 of 17733 Old 05-28-2019, 08:53 AM
KarlKlammer's Avatar
Quoted: 263 Post(s)
Liked: 257
I still hope that my unit won't be affected.
Just yesterday a NX9 owner sent me a picture as evidence. Some days prior I was told there are three known cases. So that makes it four in my country.
Projection: JVC DLA-NX9
VP/Calibration: Lumagen Radiance Pro, LightSpace CMS, x-rite i1 Pro 2, x-rite i1 Display 3
KarlKlammer is offline
post #11956 of 17733 Old 05-28-2019, 09:00 AM
locutus2k's Avatar
Quoted: 252 Post(s)
Liked: 87
Originally Posted by leo9000 View Post
I've had the same issue and, but so far has only occurred while watching movies on AppleTV. I contacted JVC and they had me send an email to their projector tech department. We'll see what they say. While this issue was occurring the resolution display box that appears in the upper right corner was also shaking.
Listen guys, i've been there and, yes, my OSD was "shaking" too. This is NOT hardware fault is a firmware bug. I've had the very same issues, Jvc japan look at the video i've sent by email (my dealer sent) and they say: firmware update. After 2.05 install issue is gone. Now i have the "blue vertical bars" tough but that's a whole different thing.
I'm in Europe and i have the blue vertical bars bug. I now other european owners who experienced this bug, too. I'm on fiber optic hdmi cabling. The issue has NOTHING to do with voltage, sources or cables. Is a bug and can happen also with nothing attached and projector under a voltage conditioner.
locutus2k is offline
post #11957 of 17733 Old 05-28-2019, 09:03 AM
leo9000's Avatar
Quoted: 32 Post(s)
Thanks locutus2k. Hopefully they will email me firmware 2.05 It is not available on the website to download yet.
leo9000 is offline
post #11958 of 17733 Old 05-28-2019, 09:09 AM
Craig Peer's Avatar
Quoted: 6955 Post(s)
Liked: 8221
Considering the improvements in HDR, and the native 4K, I'd say it would be a big improvement. " Massive " is hard to define !
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #11959 of 17733 Old 05-28-2019, 09:10 AM
Gates's Avatar
Quoted: 313 Post(s)
Liked: 153
Thanks Craig!
Gates is offline
post #11960 of 17733 Old 05-28-2019, 09:24 AM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 200
Contrast and black level about the same. Big leap in clarity, sharpness, image noise/calmness. And of course, the auto tone mapping.
Craig Peer likes this.
gravi is online now
post #11961 of 17733 Old 05-28-2019, 09:49 AM
tommarra's Avatar
Quoted: 625 Post(s)
Liked: 373
No. Unless you are very close to the screen and / your screen is huge.
Light output, contrast, etc are very similar. Dynamic tone mapping is a new feature, but can be easily fixed by clicking the Picture brightness setting under Gamma.
To me its not worth $3000 or so difference.
It would be a lateral upgade and not an upward upgrade.
IMO.
But if you are bothered by the eShift noise, then it would definitely be an upgrade.
markmon1 likes this.
post #11962 of 17733 Old 05-28-2019, 09:52 AM
Gates's Avatar
Quoted: 313 Post(s)
Liked: 153
IMO.
Wow, so you're saying my 4 or 5 year old projector is on par with the new RS1000?
Gates is offline
post #11963 of 17733 Old 05-28-2019, 09:58 AM
bwillcox's Avatar
Quoted: 928 Post(s)
Liked: 535
IMO.
For an alternative opinion, I find my NX7 to be significantly better than my x750, if for no other reason than the auto HDR switching and tone mapping with my Panasonic UB9000. I am very happy with the upgrade.
But as always, YMMV.
post #11964 of 17733 Old 05-28-2019, 10:12 AM
JMCecil's Avatar
Quoted: 326 Post(s)
Liked: 347
I'm leaning heavily towards the NX7, but I'm having a conundrum. I have a 22.5' x 18.5' x 10.2' room.
The room can pretty much do black out if I need too.
I want to go scope and I can do 150" or 180" or whatever the supported size around 180" is.
I'm have to choose between doing my HDMI/Power drop to support a 20' throw, needed to do 180"
Or, 16' throw which would restrict the size of the screen to the 150's with a very extreme zoom.
Obviously the brightness will be better at 16'. But I'm kind of doing this for size so I'd rather mount at 20'.
Big caveat ... I don't have experience with projectors and I live in the sticks so no access to places with projectors to look at.
Do you think I'll get sufficient brightness for good HDR pop at 180" from a 20' throw? I know it is subjective and you don't know me. Just general thoughts would be appreciated.
JMCecil is offline
post #11965 of 17733 Old 05-28-2019, 10:15 AM
tommarra's Avatar
Quoted: 625 Post(s)
Liked: 373
I am still trying to figure out apart from running ARC, double checking placement of speakers, levels at the main listening position, what else is there in audio calibration.
I dont know if there is a way to upload custom audio curve to my Anthem receiver.
Ultimately to decide whether to spend money on Audio calibration as well.
post #11966 of 17733 Old 05-28-2019, 10:17 AM
tommarra's Avatar
Quoted: 625 Post(s)
Liked: 373
What is your screen and screen gain? Without knowing that impossible to answer if you will get close to 100 nits for HDR or not.
You can always tonemap but you will crush some highlights.
post #11967 of 17733 Old 05-28-2019, 10:18 AM
Quoted: 4867 Post(s)
Liked: 1839
If you use SDR2020 on the UB9000, the x750 will have a better contrast ratio than the NX7 for watching HDR movies.
Jive Turkey likes this.
Dominic Chan is online now
post #11968 of 17733 Old 05-28-2019, 10:21 AM
tommarra's Avatar
Quoted: 625 Post(s)
Liked: 373
No that is not what I am saying. You asked if it would be a 'massive' upgrade.
IMO it would not be a 'massive' upgrade. It would for sure be an upgrade for reasons others have pointed out (auto tone mapping, native 4K, auto HDR mode switching)
But when you are really watching a movie on a well calibrated setup, the key difference is contrast, light output. On these two measure NX5 and 440 (X5900) are quite similar.
For me personally not worth the extra $2K - $3K you pay. If you were going to NX7 or NX9, I would certainly say that the upgrade would be 'massive'.
post #11969 of 17733 Old 05-28-2019, 10:22 AM
JMCecil's Avatar
Quoted: 326 Post(s)
Liked: 347
That is an excellent question. I don't have a screen picked, so I can choose a gain level to make up some brightness. This is one of those areas where my ignorance comes into play. According to the project calculator I'd need to go with a very high gain screen from 20' (1.6 or more) to get 100 nits. And I'm assuming that is an uncalibrated estimate which means another 20% loss or so. So I doubt I can get 100 nits on a 180" screen. Is the 100 nits the major driver for good perceived HDR then?
JMCecil is offline
post #11970 of 17733 Old 05-28-2019, 10:25 AM
Gates's Avatar
Quoted: 313 Post(s)
Liked: 153
Ah, gotcha. It's not the 440 I have but the 400. Thanks for the info!
tommarra likes this.
Gates is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
