Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 404 - AVS Forum | Home Theater Discussions And Reviews
 15133Likes
post #12091 of 16192 Old 05-30-2019, 05:43 AM
markmon1's Avatar
Quoted: 4994 Post(s)
Liked: 3253
Originally Posted by Drem View Post
Unfortunately I still have the DI closing down issue with 2.07. I will be contacting my dealer.
I find it odd that no one else has seen this issue. It feels like a software bug, like buffer memory/algoritm or something, but since no one else has it, Im not sure anymore.
This is what happens when the issue appears, usually 1-2 hours in. Sometime it has apperaed in a shorter period of time, and sometimes longer, but usually around the 1-hour mark. With a dark test scene, I bring the projector menu back and forth. DI almost completely closes. This is with manual aperture at 0. With the same test scene, in normal DI operation and manual aperture at 0, it closes just ever so little (as it should be with aperture at 0)
Video:
https://www.dropbox.com/s/9uow7qx1k3...24539.mp4?dl=0
I've had a very similar iris pumping problem on one of the previous e-shift projectors and was told the projector needed to be replaced under warranty. It was an intermittent problem and typically only happened after 45-60 min of watching and based on the type of content I was watching. My guess is that there are positional sensors in the iris that stop reading correctly. You should get your projector swapped.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #12092 of 16192 Old 05-30-2019, 05:52 AM
Josh Z's Avatar
Quoted: 4121 Post(s)
Liked: 3117
Originally Posted by locutus2k View Post
another thing i've noticed is that now when you shut down the projector the red light on front goes away after a while. To power the projector back you have to press any button on the remote (red light comes up) and then power on.
This seems like it could interfere with those who turn their entire home theater on as part of an automation program.
dgrizzard likes this.
Josh Z
Home Theater Writer/Editor, High-Def Digest
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #12093 of 16192 Old 05-30-2019, 05:55 AM
Drem's Avatar
Quoted: 138 Post(s)
Liked: 116
This is strange. Just to be clear: this happen when you set AUTO 1 or 2 or it happens also with auto disabled and iris set manual to 0? If the strong change happens in auto i think this is software related, otherwise there must be something that needs an hard reset.
Have you tried a factory reset from SERVICE menu? Not from the projector stanrdard menu but from the service menu. After the install of 2.07 i would consider an hard reset from service menu, you will loose your settings but if the behaviour is still there i would ask for a change.
Yes both AUTO1 and 2. No difference. Setting manual disables the DI so yes normal operation here and constant light output. I will try a service menu reset, I did on 2.05 but will try 2.07.
Drem is offline
post #12094 of 16192 Old 05-30-2019, 05:56 AM
Drem's Avatar
Quoted: 138 Post(s)
Liked: 116
Thanks for the input. I am awaiting a reply from the dealer.
Drem is offline
post #12095 of 16192 Old 05-30-2019, 05:58 AM
Manni01's Avatar
Quoted: 5402 Post(s)
Liked: 5572
I'm happy to report that 2.07 completely fix the "colour bug". Now you can choose 422 or 444 (or RGB) according to the input with no conversion/side effects. AUTO works fine, too.
Great news if the colourspace error is fixed, I'll update later and confirm.
Did you check the power saving option after the update? It might have defaulted to the max power saving one, instead of the one with the network standby if you've done a reset to factory defaults. I'll take a look as well after the update.
jh901 likes this.
JVC Autocal Software V11 Calibration for 2019 Models (Google)
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is offline
post #12096 of 16192 Old 05-30-2019, 06:48 AM
gravi's Avatar
Quoted: 364 Post(s)
Liked: 191
Video:
Just a quick basic question. When you say the DI closes, how do you determine that? Just by looking at how dark or bright a scene looks? I don't think I have seen such a problem but curious.
gravi is offline
post #12097 of 16192 Old 05-30-2019, 06:52 AM
Drem's Avatar
Quoted: 138 Post(s)
Liked: 116
In the video you see clearly how it closes and opens. The more in closes the lesser the light goes through and onto your screen.
Drem is offline
post #12098 of 16192 Old 05-30-2019, 07:40 AM
JaremyP's Avatar
Quoted: 768 Post(s)
Liked: 425
Would like to get more specific tweaking my NX7 for upcoming movie viewing. Don’t have a meter and not ready to get into more advanced calibration, but I’m seeing references here about using gammas of 2.4 and knocking brightness down to -1/-2.
I’m curious if there’s a published list of quick out of the box settings adjustments to make to optimize the picture?
I’m using sdr and hdr sources. Appletv and Kscape, but I may go back to an Oppo 203.
Sent from my iPhone using Tapatalk Pro
Video: JVC NX7, Stewart Cima Neve 135"
Audio: Marantz AV7704, Emotiva XPA-11 Gen 3
Speakers: Focal Electra 1038 Be x 2, Electra CC 1008 Be, Aria 906 x 8, REL S5 SHO x 2
Sources: Apple TV 4k, Kaleidescape Strato, Oppo 203, Xbox One X, Nintendo Switch
Xbox Live: TrackZ
JaremyP is offline
post #12099 of 16192 Old 05-30-2019, 08:13 AM
Mike Garrett's Avatar
Quoted: 12259 Post(s)
Liked: 9857
Yes, this is supposed to fix the color space issue that you reported.
desray2k, SOWK and Manni01 like this.
Mike Garrett is offline
post #12100 of 16192 Old 05-30-2019, 08:15 AM
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1461 Post(s)
Liked: 544
I can't update till later today... But 12bit 4:4:4 23.976Hz works now?
PLEASE SAY YES!!!!!!!!!!
Wisconsin Home Theater Enthusiasts Meet
SOWK Home Theater
SOWK is offline
post #12101 of 16192 Old 05-30-2019, 08:31 AM
Liked: 9857
My guess is RS4500 is:
- no *dynamic iris* (it has fantastically working laser dimming and doesn't need a DI).
- Will keep the lamp iris it has for manual settings.
- maybe 4000-5000 lumens
- New better contrast panel
- Probably 8K eshift
- Tone mapping of some sort perhaps an improved version of what is offered in NX series.
My guess is you will see $60-70k MSRP. Not really something someone that considered an RS4500 would consider.
And my guess is, the only laser projector JVC has at CEDIA is the 4500. Anybody taking bets?
post #12102 of 16192 Old 05-30-2019, 08:34 AM
Liked: 9857
Turn ECO mode off.
post #12103 of 16192 Old 05-30-2019, 09:51 AM
Manni01's Avatar
Liked: 5572
Unfortunately, as far as I can see, they haven't solved the problem, they have only disabled the colorspace setting when receiving 12bits, so that the symptoms are less visible.
YCC422 is still forced in 12bits even at 30p and lower, but in 12bits all the colorspace options in the JVC have the same effect, which is to select YCC422 internally.
So when you send RGB 444 12bits or YCC 444 12bits, you don't see that the wrong colorspace is applied if you don't select auto in the JVC, but there is still an unwanted chroma conversion happening behind the source's back that is detrimental to chroma resolution (in a minor way).
It's not a big issue, but I would still recommend to use 4:4:4 8bits or 4:2:2 12bits, depending on the source. RGB 4:4:4 12bits and YCC 4:4:4 12bits are still not recommended.
I attach a screenshot showing that YCC422 is forced irrespective of the colorspace option selected, and a close up on the "fox" pattern to show the effect (look at the red and blue lines at the bottom, the chroma resolution is much better in 8bits than in 12bits).
This is more likely to be visible on games and desktop apps, and unlikely to be noticeable on video content, except in very unusual situations, and only if the film is very boring .
If your source does good dithering (such as madVR), especially if your source is a PC you're also using for desktop work or gaming, I highly recommend to keep using RGB 8bits until this is fixed (with madVR set to 8bits for native panel bit depth). This doesn't add any banding compared to 12bits. You'll get better results than with RGB 12bits and madVR set to 10bits native bit depth, due to this minor chroma issue, and you'll get better results in gaming/desktop apps too.
If you have a dedicated HTPC exclusively to video content and you feel better using RGB 12bits because it feels more "right", by all mean do so, I doubt it will harm the picture in any significant way.
What's important with HDR is to have 10bits in the content. Having madVR dithering from its internal 16bits to 10bits or 8bits makes very little difference to the final result, and certainly none that would be noticeable from sitting distance regarding banding or additional noise.
With a standalone player, I still recommend using YCC 422 12bits. It will work at all frame rates up to 60p and should give you excellent results. If, for any reason, you need/prefer to use RGB or YCC444 12bits, again I doubt it will produce any significant/visible degradation with video content.
Mike, please forward to JVC and ask them if the new f/w is supposed to actually fix the problem, or if this is as far as they can go due to hardware limitations. V2.07 makes the issue less obvious when a "wrong" colorspace is selected manually, but from a PQ point of view there is zero difference as far as I can see.
I tested with nVidia drivers V385.28. I'll try with 430.86 later if I have the time, but I don't expect the results to be any different. [EDIT: tested with 430.86, same results].
Name:	4K23p RGB 444 8bits.jpg
ID:	2573484   Click image for larger version
Name:	4K23p RGB 444 12bits.jpg
ID:	2573486   Click image for larger version
ID:	2573532   Click image for larger version
ID:	2573534   Click image for larger version
Manni01 is offline
post #12104 of 16192 Old 05-30-2019, 10:05 AM
SOWK's Avatar
Liked: 544
You answered my question Manni. Thank you.
8 bit I stay.
RapalloAV likes this.
SOWK Home Theater
SOWK is offline
post #12105 of 16192 Old 05-30-2019, 11:44 AM
jmonier's Avatar
Quoted: 203 Post(s)
Liked: 113
I'm sorry to report that the 2.07 update does NOT fix the vertical bars problem. Note that the problem normally might not show up for quite a while so it might appear to be fixed when it is not. In my case it had not shown up for several days, but as soon as I tried a file that had caused it in the past, it came right up. I power cycled it and got the problem again.
jmonier is offline
post #12106 of 16192 Old 05-30-2019, 11:46 AM
jbn008's Avatar
Quoted: 258 Post(s)
Liked: 124
blue bars?
jbn008 is offline
post #12107 of 16192 Old 05-30-2019, 11:57 AM
jmonier's Avatar
Quoted: 203 Post(s)
Liked: 113
Originally Posted by jbn008 View Post
blue bars?
I've always had blue, green and occasionally purple. In this case I got green once and blue once with the same file.
jmonier is offline
post #12108 of 16192 Old 05-30-2019, 12:07 PM
jbn008's Avatar
Quoted: 258 Post(s)
Liked: 124
10-4. tks
jbn008 is offline
post #12109 of 16192 Old 05-30-2019, 12:17 PM
Killroy's Avatar
Quoted: 475 Post(s)
Liked: 388
Which file?
Killroy is offline
post #12110 of 16192 Old 05-30-2019, 12:20 PM
Liked: 9857
Have already sent to JVC.
post #12111 of 16192 Old 05-30-2019, 12:24 PM
Liked: 9857
Exactly what are you doing?
What pieces of equipment in system is being used, when experiencing problem?
What are you using for HDMI and length?
What file?
Added
If you will shoot that info to me in an email, along with a picture and the serial number of your unit, I will get this info to JVC engineering.
desray2k likes this.
post #12112 of 16192 Old 05-30-2019, 12:26 PM
Tom Bley's Avatar
Quoted: 912 Post(s)
Liked: 873
File? It would be helpful if people would list what their source is and if they are going through an AVR etc. I have not had any issue playing UHD 4k Blu-Rays and standard Blu-Ray discs with an Oppo 203. When you say file, are you streaming a movie?
Tom Bley is offline
post #12113 of 16192 Old 05-30-2019, 12:28 PM
Killroy's Avatar
Quoted: 475 Post(s)
Liked: 388
I'm sensing a pattern in the questions....
Killroy is offline
post #12114 of 16192 Old 05-30-2019, 12:30 PM
tommarra's Avatar
Quoted: 579 Post(s)
Liked: 348
Same here without the source, settings and equipment hard to try and replicate the problem.
Tom Bley likes this.
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
post #12115 of 16192 Old 05-30-2019, 02:57 PM
jmonier's Avatar
Quoted: 203 Post(s)
Liked: 113
What file?
I have one of the first RS-3000s (received it the day after the first shipment was released by JVC USA QC). When the problem first occurred back in February, I went through the entire chain and swapped out equipment, cables, bypassed AVR, etc. etc. until I was sure that none of that was influencing the problem.
Most of my viewing is done with an HTPC although I've seen the problem streaming from a Roku and playing back from from a Tivo. (I have an Oppo 203 but use it very seldom.) I have also tried Latency and CMD settings and can report that they do not affect anything.
After 3 months with the problem, I can guarantee that the only thing that causes the problem is the video material. When it occurs, it seems to always be on a frame with large black areas and with a somewhat complex image (like a logo) that occupies 10-30% of the screen area. (But many images that seem to fit that description never cause the problem.)
The file that I mentioned is a 6 sec test clip of the old Amazon instant video logo. It often shows the problem the first time but may may need to be played 5-10 times until it shows up.
Among others, the problem shows up on Murder in the Orient Express (4K) and especially the Apollo 11 Blu-ray documentary. This last is a special problem because it has many scenes with black space as a background.
On the other hand, I've played many, many movies and videos over the last 3 months without seeing a problem. Because of this experience, I would not consider the problem fixed until I'd gone at least 2 weeks without seeing the problem. My usage is about 5 hours a day. I may not see it for several days or I may see it 2 or 3 times in a single day. People that have much lower usage and/or different movies/videos could conceivably never see it.
MIKE: Craig already has the info and has passed it on to JVC.
Tom Bley and desray2k like this.
jmonier is offline
post #12116 of 16192 Old 05-30-2019, 03:00 PM
Liked: 9857
I guess you did not see what i added to my post? "If you will shoot that info to me in an email, along with a picture and the serial number of your unit, I will get this info to JVC engineering."
post #12117 of 16192 Old 05-30-2019, 03:04 PM
jmonier's Avatar
Quoted: 203 Post(s)
Liked: 113
Sorry, I did see that and edited my post to say that Craig has the info.
jmonier is offline
post #12118 of 16192 Old 05-30-2019, 03:06 PM
Liked: 9857
Okay, was just offering to help. Did not know where you bought your projector.
post #12119 of 16192 Old 05-30-2019, 03:26 PM
locutus2k's Avatar
Quoted: 245 Post(s)
Liked: 83
2.07 ... so far so good. Just one thing: i can't find no more the special Panasonic profiles. I never use them even if i have a Pana 9000 i prefer a custom cal but i was wondering if they have been removed or if i messed up something playin' around.
locutus2k is offline
post #12120 of 16192 Old 05-30-2019, 03:40 PM
Craig Peer's Avatar
Quoted: 6820 Post(s)
Liked: 8020
What file?
Added
Working on it with Mr. D. !
Mike Garrett likes this.
Craig Peer is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
