Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 415 - AVS Forum | Home Theater Discussions And Reviews
 18933Likes
post #12421 of 20864 Old 06-05-2019, 06:14 PM
roxiedog13's Avatar
Quoted: 2812 Post(s)
Liked: 1498
Originally Posted by microwiz View Post
"the DCR design allows the shortest throw which allows the maximum available light output."
I'm pretty sure an ISCOIII allows the shortest throw. My projector is 13ft from a 133 2:35 inch screen and I cannot even zoom out to fill that screen. Projected zoomed out image is about 4 inches from the border and i'm guessing in order for a DCR to work it needs to be far enough back so the image touches the border before it's compressed.
If that's the case I would need to move my projector back for a DCR lens.
I do think you'll need to move your projector back with either anamorphic lens. If your screen is 122" wide you'll need to be minimum 14ft for the Paladin DCR at 1.4 throw, with the ISCO if it is 1.6 throw then 16 feet is the minimum throw range. I have a 122" wide screen like yours, my projector with ISCO is mounted at 17ft, any closer I started to see distortion creep in. Anyway, I'm pretty sure the Paladin is 1.4X throw, one of the shortest there is in fact, at least compared to the common ones most are familiar with. The ISCO also shows softness and distortion towards the edges, just like the Paladin DCR, when you get close to the minimums you'll start seeing it as I did in my setup . Bottom line , either one will have to be mounted at the correct distance to avoid unwanted edge distortion. The ISCO has pin cushion distortion (wider on the ends, narrow in the middle) , the Paladin DCR being vertical compression has barrel distortion ( wider in the middle ). The DCR is best suited for a flat screen, whereas the ISCO best suited for a curved screen . The Paladin DCR will require 1.24X stretch to access the full 17:9 panel, the ISCO will require 1.33X stretch but will only utilize 16:9 portion of the panel, so you are cropping about 14% of light and detail . Lastly, Sony can stretch for 1.24X and 1.33X, JVC can only do 1.33X unless they have updated . So, unless you have an external scaler you are loosing the additional benefit the Paladin offers .
Dedicated Theater: Sony VPL VW5000 , Panamorph DCR & ISCO III L Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 134" diagonal curved , Denon AVR-X8500 , 9.2.6 Atmos, Panasonic UB900, Oppo 203, Lumagen Pro 4440 , (3) Paradigm CI Elite E7-L+C+R fronts, , (2) CI Pro P80-IW Rear, (2) Paradigm SA-ADP In-wall Surround, (6) SIG-1.5R-30 v.3 In-Ceiling, Subwoofers: (2) SVS SB-16 Ultra , (1) SVS PC13-Ultra .
roxiedog13 is offline
post #12422 of 20864 Old 06-05-2019, 08:09 PM
Mike Garrett's Avatar
Quoted: 12853 Post(s)
Liked: 10489
Originally Posted by dlinsley View Post
What is meant is that as it is a VC (Vertical Compression) lens it works at the shorter throw / max zoom and so with more light being input into the lens than an HE lens, for a given distance from the screen. For example, using the zoom method I measured a 7% increase in total light when zooming an RS600 (haven't checked my RS3000) to fill the scope screen compared to the total light at the unzoomed 16:9. So the DCR starts with 7% more light into it than if I had continued to use the UH480.
Except I have already pointed out, the above is not correct. The ISCO and the Prismasonic lens both work at shorter throws than the DCR lens. Both of these, go below 1.4 throw ratio.
Mike Garrett is online now
post #12423 of 20864 Old 06-05-2019, 08:17 PM
Killroy's Avatar
Quoted: 611 Post(s)
Liked: 491
The ISCO IIIL actually has, according to their own literature, an unlimited throw ratio capability depending on projector. The JVC falls under the "Unlimited" throw ratio range. You will need a curved screen on the lower end though. I tested it as low as 1.0 and it produced a perfectly sharp image...with a pincushion that would need an almost 90-degree screen though...lol
BTW, this is from the Schneider fact sheet but they are using the same ISCO fact sheet since the lenses are identical.
Name:	Screen Shot 2019-06-05 at 7.13.13 PM.png
Mike Garrett likes this.
Killroy is online now
post #12424 of 20864 Old 06-05-2019, 08:37 PM
slots1's Avatar
Quoted: 73 Post(s)
Liked: 25
Well, after saying my nx9 is perfect after over 100 hours.
This evening all of a sudden blue vertical bars and in the white area spots of yellow.
I turned it off for 10 minutes and back on and back to normal.
I am on version 2,04. I did down load 2.07 but have not installed it.
What solves this problem, other then a reboot.
slots1 is offline
post #12425 of 20864 Old 06-05-2019, 08:45 PM
Liked: 10489
2.07 I believe.
post #12426 of 20864 Old 06-05-2019, 08:45 PM
Davidian1's Avatar
Quoted: 24 Post(s)
Liked: 5
At any time and the last few hours did you switch your input signal to a different device that may be less stable with its video output
Davidian1 is offline
post #12427 of 20864 Old 06-05-2019, 09:03 PM
Roger Mathus's Avatar
Quoted: 97 Post(s)
Liked: 51
At 50 hours My NX9 has been perfect. It is on 2.04. Should I install the update? I downloaded it but did not install. I have watched Apolled 11 with no problems.
Roger Mathus is offline
post #12428 of 20864 Old 06-05-2019, 09:11 PM
Liked: 10489
If you have no issues, then no, I would not install.
post #12429 of 20864 Old 06-05-2019, 11:07 PM
Jim Parys's Avatar
Quoted: 92 Post(s)
Liked: 53
All received my replacement NX9 due to faulty input 1 - got the new one and it seems to function well other than the convergence was noticeably off. See pick. I was able to adjust it with on click on blue and two on red, but I have had a lot of JVC projectors including the NX9 its replacing and never had to use the convergence adjustment. Is this normal to be this far off out of the box even if its adjustable? is this a problem or acceptable tolerance?
also very sorry about the previous post. Not sure what all the characters are I think I tried to post the picture the wrong way. I have tried several times to delete it but I keep getting a db error so hopefully the moderator can delete it.
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is online now
post #12430 of 20864 Old 06-06-2019, 12:21 AM
Homer J Simpson's Avatar
Quoted: 35 Post(s)
Liked: 39
Let's concentrte on the Netflix APP built into the UB9000 under main menu " NETWORK SERVICE" . Now go to SETUP on your UB9000. The following is my settings.
PLAYER SETTINGS
Resolution - AUTO
4k/60 Output - 4k/60p 4-4-4
24p Output - AUTO
HDMI (Video) Output Mode - AUTO
HDR10+ Setting - ON
ADVANCED SETTINGS
Color Mode - YCbCr (AUTO)
Deep Color Output - AUTO (12 bit priority)
25p/50p Output - OFF
I suspect that your4k/60 Output is something different from mine???
Hi roger these are my settings, the only difference I notice is in the Color Mode - YCbCr (AUTO)...I will try later, every else seems the same.
Video Format: Automatic
4K(50p/60p) Output: 4K(50p/60p) 4:4:4
24p Output: Automatic
HDMI(VIDEO) Output Mode: Automatic
HDMI(AUDIO) Output Mode: Audio Only
Dolby Vision Setting: Off
HDR10+ Setting: On
Colour Mode: YcbCr (4:4:4)
Deep Colour Output: Auto(12bit Priority)
HDR/Colour Gamut Output: HDR/BT.2020 (Auto)
SDR/HDR Conv. (Network Service): Off
HLG / PQ Conversion: Off
HDR Display Type: Basic Luminance Projector
HDCP Output Setting: Automatic
Content Type Flag: Automatic
Audio Output: Off
7.1ch Audio Reformatting: Off
Homer J Simpson is offline
post #12431 of 20864 Old 06-06-2019, 12:23 AM
markmon1's Avatar
Quoted: 5494 Post(s)
Liked: 3587
Adjusting convergence is both fine and expected which is why the convergence adjustment exists in the first place. I bet you have to readjust it again after a couple days of acclimation.
Jive Turkey likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #12432 of 20864 Old 06-06-2019, 03:35 AM
Quoted: 137 Post(s)
Liked: 41
Kind request to delete that long post. Took me almost two days to scroll through that.
Tom Bley, jh901, dgrizzard and 1 others like this.
abinav555 is offline
post #12433 of 20864 Old 06-06-2019, 07:03 AM
slots1's Avatar
Quoted: 73 Post(s)
Liked: 25
No, i was watching a 3d movie on y oppo
slots1 is offline
post #12434 of 20864 Old 06-06-2019, 07:52 AM
Super Moderator
DrDon's Avatar
Quoted: 2341 Post(s)
Liked: 4467
It took three of us almost as long to get rid of it.
If it happens, again, use the Report Post function as we don't read every post in every thread. (Someone else DID use RP or we wouldn't have known).
wwtech, steelman1991 and abinav555 like this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #12435 of 20864 Old 06-06-2019, 07:57 AM
Liked: 10489
Received an RS1000 and Panasonic UB9000 to play with, but found out the 50' fiber optic HDMI that I installed ahead of time was defective. AVR started acting up at the same time, so was not sure what the problem was and took me a day to determine. A hard reset of the AVR solved that problem and new cable arrives today. Have had the projector hear for a week and have not been able to use it.
post #12436 of 20864 Old 06-06-2019, 08:05 AM
BondDonBond's Avatar
Quoted: 753 Post(s)
Liked: 695
In a few days correct and for mine you need to have it on 60-90 Minutes before you even look at it. 30 is not enough.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #12437 of 20864 Old 06-06-2019, 08:13 AM
DLCPhoto's Avatar
Quoted: 1699 Post(s)
Liked: 798
Bummer!
What brand cable? Was it just a defective sample? Ordering another of the same, or going to a different brand?
First I've personally heard of a fiber optic cable failing the test.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #12438 of 20864 Old 06-06-2019, 08:21 AM
GPBURNS's Avatar
Quoted: 453 Post(s)
Liked: 846
Guess what I'm viewing shortly today - lower right
Pooch15 likes this.
15400 Watts of Atmos Seaton Power -Quad SubMersived - JVC N7
GPBURNS is offline
post #12439 of 20864 Old 06-06-2019, 08:24 AM
Liked: 10489
Originally Posted by DLCPhoto View Post
Bummer!
Have read and spoken to several people that have had bad fiber optic HDMI cables. I tried this one, because it looked like it was protected pretty good. Updated fiber with braided jacket.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
DLCPhoto likes this.
post #12440 of 20864 Old 06-06-2019, 09:10 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6870 Post(s)
Liked: 6869
I am sure you have an easy pull or conduit.
Glad to see your new one is a OK.
Cleveland Plasma is offline
post #12441 of 20864 Old 06-06-2019, 10:18 AM
Todd G.'s Avatar
Quoted: 167 Post(s)
Liked: 380
Originally Posted by panman40 View Post
I have no issues pouring wine wearing 3D glasses in the pitch dark, neither does my wife who normally tops our glasses
Drinking from the bottle is always an option...use brown paper bag at your discretion.
panman40 likes this.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #12442 of 20864 Old 06-06-2019, 10:26 AM
Craig Peer's Avatar
Quoted: 7260 Post(s)
Liked: 8699
I just don't like 3D. I don't watch it at home or at a commercial theater. I've tried watching it a couple of times when someone brings a disc and glasses over. My feeling is " meh ". 4K is where it's at for me. I own zero 3D content and that's they way it's going to stay. I do have quite a few new 4K discs on the radar though.
Craig Peer is online now
post #12443 of 20864 Old 06-06-2019, 11:06 AM
jeahrens's Avatar
Quoted: 2261 Post(s)
Liked: 1541
Right there with ya. I don't begrudge anyone liking it, but the few theatrical outings and experiences with it in other's home theaters left me underwhelmed. Still I'm glad that for those that enjoy it the projector manufacturers keep supporting it.
Avatar was probably the best that format looked, though I'm not a fan of the film.
bwillcox and Craig Peer like this.
jeahrens is online now
post #12444 of 20864 Old 06-06-2019, 11:41 AM
Wookii's Avatar
Quoted: 3024 Post(s)
Liked: 2233
Like a lot of things in HT I think it’s very much a personal thing. I do find 3D a little bit fake (it’s more like layers of 2D than actual 3D), but I do like the effect sometimes, it does create a little more immersion on occasion. What I don’t like is my eyes feeling like I’ve been awake for three weeks straight, after watching a 3D movie!
Craig Peer and Dandlj like this.
Wookii is offline
post #12445 of 20864 Old 06-06-2019, 12:50 PM
Liked: 10489
Yes, have a chase, but does have a right angle turn, so had to be gentle. Cable delivered and installed. So will be viewing tonight.
post #12446 of 20864 Old 06-06-2019, 01:13 PM
Quoted: 97 Post(s)
Liked: 51
Change this to YcbCr (AUTO) and you will see HDR on Nefflix movies. I tried your setting and did not get HDR. You need the auto setting. It will work.
post #12447 of 20864 Old 06-06-2019, 03:11 PM
Quoted: 35 Post(s)
Liked: 39
PLAYER SETTINGS
Resolution - AUTO
24p Output - AUTO
HDR10+ Setting - ON
ADVANCED SETTINGS
My setup is NX9 fed by the UB9000 via Marantz 8805 Pre-Pro
Hi Roger, you are the man!!! The problem was the color mode that needed to be set in AUTO....thanks !!!
rjmcinnis likes this.
post #12448 of 20864 Old 06-06-2019, 04:51 PM
colleycol's Avatar
Quoted: 36 Post(s)
Mount?
Everyone,
My RS2000 arrives Monday but looking to see what mount/plates i should get? I will be dropping the projector down with an extension pole.
Eventually I will add a Panamorph DCR if that is a factor as well.
Cory
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #12449 of 20864 Old 06-06-2019, 06:15 PM
dlinsley's Avatar
Quoted: 573 Post(s)
Liked: 447
The Chief RPM(A/B/C)-281 (RPM Elite mount with the SLM281 bracket) is usually recommended, and is what I use with the RS3000. The DCR then comes with its own XM2 mount that connects directly to mounting holes on the projector itself.
Congratulations!
dlinsley is offline
post #12450 of 20864 Old 06-06-2019, 07:08 PM
KanosWRX's Avatar
Quoted: 202 Post(s)
Liked: 79
Well at 82 hours, my NX7 just did the blue vertical line error. Haven't had an issue at all with the projector until now. A reboot fixed it, but thought I escaped it. Looks like it's time to upgrade to 2.07. was on 2.04, that's what came with mine fyi.
KanosWRX is offline
Jvc , nx5 , nx7 , nx9 , rs1000 , rs2000 , rs3000
