Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 441 - AVS Forum | Home Theater Discussions And Reviews
 16432Likes
post #13201 of 17813 Old 06-26-2019, 03:03 PM
tommarra's Avatar
Quoted: 627 Post(s)
Liked: 373
Originally Posted by jabz View Post
Hi on the N7/RS2000 is it possible to NOT engage the filter in HDR viewing mode? If not then it might be better to get the N5/RS1000 due to more brightness for HDR viewing?
Just use the HDR profile and not BT.2020
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #13202 of 17813 Old 06-26-2019, 03:07 PM
tommarra's Avatar
Quoted: 627 Post(s)
Liked: 373
Originally Posted by markmon1 View Post
There's nothing to be careful about. You can't damage anything with convergence adjustments, its very easy and pretty much common sense, and there's a reset to get back to where you start anyway. Feel free to play around with it carefree all you want.
Okay if you are wearing glasses - get someone who does not wear glasses to help you. I found that there is a bit of color refraction if I am not looking straight through the middle. So depending on how you look at the pattern you might find some issue where there is none!
post #13203 of 17813 Old 06-26-2019, 03:11 PM
tommarra's Avatar
Quoted: 627 Post(s)
Liked: 373
Originally Posted by GPBURNS View Post
Ya Captain Marvel as bad as Infinty Wars in 4K HDR - agreed on takes very aggressive settings to get looking half decent -
MadVR to the rescue :-)
Willie likes this.
post #13204 of 17813 Old 06-26-2019, 03:30 PM
Quoted: 4876 Post(s)
Liked: 1840
Originally Posted by 04rex View Post
Thank you very much. From the brief amount I read, it doesn't look promising.
The issue was mainly with custom curves (or lack thereof), which were crucial for the e-shift models. It’s less important for the native 4K models with auto tone mapping.
Dominic Chan is online now
post #13205 of 17813 Old 06-26-2019, 04:17 PM
Quoted: 55 Post(s)
Liked: 2
There's nothing to be careful about. You can't damage anything with convergence adjustments, its very easy and pretty much common sense, and there's a reset to get back to where you start anyway. Feel free to play around with it carefree all you want. No harm.
I think its a bit less than that. The lumens at the edge of your screen are probably lower than at the center anyway.
Most likely madVR is superior. MadVR has had a ton more work in dynamic tone mapping development, madVR has the best upscaling in the world tune by a massive A/I network, and madVR requires more hardware power than available in a lumagen. The Lumagen wins in area of flexibility (not being limited to playing on a PC).
Hi
My original question that prompted the response “to be careful” didn’t really answer my question either. I know how to adjust convergence—— my problem is I’m not sure how to check if convergence needs fixing. Is there some test pattern or disc I need to use to check convergence or can it be done directly from the projector? I’m a newbie on this stuff so please be gentle lol. Thanks
Ikemi is offline
post #13206 of 17813 Old 06-26-2019, 04:23 PM
jh901's Avatar
Quoted: 739 Post(s)
Liked: 288
Originally Posted by Craig Peer View Post
All I watch is on disc - either Blu-ray or UHD Blu-ray. The dynamic tone mapping on my Lumagen is just flat out amazing. 4K Blu-rays have never looked better.
Is your Lumagen able to accept Dolby Vision and ready it to be sent to your projector? Unfortunately, I get the feeling that the standard HDR10 will sometimes fall short to a significant degree. The one example I'm aware of is Saving Private Ryan where the HDR10 simply isn't right. I understand that the DV layer is completely different (as in, not messed up).
HT: Panasonic DP-UB820 | JVC RS600 | 106" x 45" Stewart ST 100 | Cary Audio Cinema 12 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut F5/B6; Focal CMS Sub
STEREO: [Shunyata Denali] Playback Designs MPS-5 (fully upgraded) | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 ES | Focal Diablo Utopia III DEN: 60" Panasonic VT60
jh901 is offline
post #13207 of 17813 Old 06-26-2019, 04:33 PM
markmon1's Avatar
Quoted: 5221 Post(s)
Liked: 3389
Originally Posted by Ikemi View Post
Hi
You go to installation menu, select pixel adjust, make sure that "Adjust Pattern" is "ON" then go to "Adjust Pixel" and it displays a grid of white lines. Here you can see if the lines are white or if say the red or blue is off. Now you can make adjustments and line them up. Be most concerned with the center of the image not the edges. I'd do this standing right in front of the screen. But to see if it matters you can leave the pattern up and go sit in your main seat and see if you can tell if it's off or not.
It won't matter. Dynamic tone mapping will fix this entirely. It doesn't need to accept dolby vision. It ignores all that and actually measures the APL of each frame.
Craig Peer likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #13208 of 17813 Old 06-26-2019, 04:55 PM
docrog's Avatar
Quoted: 1156 Post(s)
Liked: 406
Is the dynamic tone mapping Lumagen that keeps being referred to on this thread the Radiance XS-3D or some other model?
JVC NX7, Yamaha RX-A3080 (2 discrete 7.2.4 speaker layouts: Dolby Atmos & DTS:X), Panasonic UB820, Panasonic UB420, Oppo 103D, ATV4K, Roku Ultra, TiVo Bolt Vox, Vandersteen Model 3 Signatures & VCC-1 Signature, Atlantic Technology (side, rear, front height & overhead) surrounds, SVS SB-2000 (2), Clark Synthesis Tactile Bass Transducers (2), Polk PSW-12
docrog is offline
post #13209 of 17813 Old 06-26-2019, 04:59 PM
Kris Deering's Avatar
Quoted: 3989 Post(s)
Liked: 6940
Radiance Pro models only for HDR.
Craig Peer and jh901 like this.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #13210 of 17813 Old 06-26-2019, 05:36 PM
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
The issue was mainly with custom curves (or lack thereof), which were crucial for the e-shift models. It’️s less important for the native 4K models with auto tone mapping.
I see. That still leaves the doubt though in my head lol. Has anybody used him since with the new 4K JVCs?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One X, Apple TV 4K, HTPC, JVC NX-5, 106" screen
04rex is offline
post #13211 of 17813 Old 06-26-2019, 05:52 PM
JaremyP's Avatar
Quoted: 772 Post(s)
Liked: 432
Originally Posted by Tom899 View Post
I got on his list a few days ago. I live just south of Detroit. So that's two of us in south east Michigan. I'm hoping he can come in August. I'm sure I'll be well over 100 hours by then.
I’m in Northville. I may consider this for my NX7. Feel free to PM with details we can talk offline.
Sent from my iPhone using Tapatalk Pro
Video: JVC NX7, Stewart Cima Neve 135"
Audio: Marantz AV7704, Emotiva XPA-11 Gen 3
Speakers: Focal Electra 1038 Be x 2, Electra CC 1008 Be, Aria 906 x 8, REL S5 SHO x 2
Sources: Apple TV 4k, Kaleidescape Strato, Oppo 203, Xbox One X, Nintendo Switch
Xbox Live: TrackZ
JaremyP is online now
post #13212 of 17813 Old 06-26-2019, 08:31 PM
Quoted: 129 Post(s)
Liked: 202
I’m 15 minutes north of the I-96 and US-23 interchange. I contacted him the beginning of this week to do my JVC RS500, though I may be into a RS2000 by the time he comes here. Anyway, the list is growing.
Karl Maga is offline
post #13213 of 17813 Old 06-26-2019, 09:50 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6668 Post(s)
Liked: 6656
Originally Posted by Soccerdude View Post
Any quick tips as soon as you open the JVC RS2000 box ?..
Take the unit out of the box, look it over for a visual damage, power the unit up whether you are installing that day or a later date so at face value you have seen it work.
Jive Turkey and Tom899 like this.
Cleveland Plasma is offline
post #13214 of 17813 Old 06-27-2019, 04:37 AM
FenceMan's Avatar
Quoted: 91 Post(s)
Liked: 37
Man this thread is crazy, I don't want to start a new post but not sure anyone is seeing my question -
So I have Oppo UDP-203 (HDR set to "Auto") hooked to new DLA-NX5 and I am only getting metadata for auto tone mapping on some discs, is this normal?
Examples -
Halloween (new) - metadata
Jurassic Park - metadata
Most any Marvel movie - no metadata
Grease - metadata in the menus and splash screens but nothing for the film
Is this normal or is something going on with my setup?
Also it almost seems (and I have to do more testing) that setting the Oppo to HDR off but keeping the 2020 colorspace looks better than HDR on in most cases? The contrast is way better this way and picture pops huge. I still need to test and calibrate but I wonder if this is still a limitation of HDR on projectors as a whole?
FenceMan is offline
post #13215 of 17813 Old 06-27-2019, 05:11 AM
asharma's Avatar
Quoted: 1839 Post(s)
Liked: 576
Purchase opinions required, please and thank you
Hi Folks...
I have the opportunity to purchase an N7 at a good price...I sold my JVC x950 (Rs600) about a year ago...I purchased a 1000 nit Sony 85” tv in the interim...The Sony tv is set it and forget it and all HDR and DV looks stunning! No messing around with any settings! The compromise is on size...I also have the Panny 820 but don’t use any TMapping on the Panny...I’m thinking this time I would shrink my screen to 110” 2.35 with a 13 foot throw...
I’ve skimmed this thread and have a few questions on the N7...
1) my x950 produced a stunning picture with Arve custom curves...from reading this thread it appears there are still issues with brightness etc with dark scenes on this new generation of pj’s...has it improved or does this inherent pj brightness issue still exist? Could the Panny 820 help? I have a black velvet bat cave...
2) my understanding is the N7 reads the discs metadata and then tone maps accordingly...what does the N7 do when the metadata on the disc is messed up?
I think the essence of my questions is coming from my desire for a set it and forget it with the N7...Am I dreaming?
Thanks folks...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is online now
post #13216 of 17813 Old 06-27-2019, 05:36 AM
markmon1's Avatar
Liked: 3389
Originally Posted by asharma View Post
Hi Folks...
Thanks folks...
The tone mapping works great on new projectors, but some disks have no meta so whats it suppose to do then?
markmon1 is offline
post #13217 of 17813 Old 06-27-2019, 05:39 AM
asharma's Avatar
Liked: 576
Thanks, yup, that’s my question too...hopefully someone can chime in...
post #13218 of 17813 Old 06-27-2019, 06:08 AM
Mike Garrett's Avatar
Quoted: 12502 Post(s)
Liked: 10127
You can set up projector with settings for discs that do not have metadata. Then the next time you play a disc the projector will use the settings you input for discs without data.
Mike Garrett is offline
post #13219 of 17813 Old 06-27-2019, 06:11 AM
asharma's Avatar
Liked: 576
Thanks Mike, is the N7 a UGGGGGE leap over the RS600 with custom curves in regards to set it and for get it and picture quality or is there still tweaking required per disc?
post #13220 of 17813 Old 06-27-2019, 06:27 AM
Liked: 10127
The auto tone mapping is a very nice improvement. You also get a sharper image, due to the lens and native 4K. The image on the new models is also a little cleaner. If you have a scope screen, the lens memory is more accurate. JVC beefed up the lens supports, that is why lens memory is better now. CMD is slightly improved also.
asharma likes this.
post #13221 of 17813 Old 06-27-2019, 06:30 AM
Th601's Avatar
Quoted: 105 Post(s)
Liked: 31
What about disks that have meta data? Does the projector apply what you’ve inputted to that disk or does it just ignore it and auto detects the meta data? Haven’t had a chance to even look at this feature yet.
Th601 is online now
post #13222 of 17813 Old 06-27-2019, 06:32 AM
Liked: 10127
The projector will use the metadata, if you have it set up to do auto tone mapping, when metadata is available and will use your manual settings, when the disc does not have metadata.
Th601 likes this.
post #13223 of 17813 Old 06-27-2019, 06:34 AM
Soccerdude's Avatar
Quoted: 375 Post(s)
Liked: 130
Since RS 2000 / NX7 reads the discs metadata and then tone maps accordingly, would this applies to HDR 4k stuff from AppleTV 4k
LG OLED C8 65 2018 BR . HT: JVC RS2000, S Studio Tek 130 1.3 Gain screen, Apple TV4k, Def Tech 9080/C 9080/9040 Dolby Atmos Speakers, Denon X6500H , Panasonic UB820 and a nagging wife.
Soccerdude is offline
post #13224 of 17813 Old 06-27-2019, 06:56 AM
Th601's Avatar
Quoted: 105 Post(s)
Liked: 31
That is a pretty awesome and convenient feature. Thanks so much.
Th601 is online now
post #13225 of 17813 Old 06-27-2019, 07:12 AM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 200
Hi Folks...
Thanks folks...
I believe if there is no metadata a default 1000 nits peak is used. But that may be for the Panasonic player, I don't remember exactly. Many here use the Panasonic tone mapping in conjunction with the JVC and like it.
asharma likes this.
gravi is offline
post #13226 of 17813 Old 06-27-2019, 07:14 AM
claw's Avatar
Quoted: 2315 Post(s)
Liked: 2170
Originally Posted by FenceMan View Post
Got my NX5 hooked up, first question is sometimes I don't seem to be getting the info for tone mapping to kick in. For example Halloween (new) gives me the data and tone mapping pops on but Guardians of the Galaxy 2 does not? I am using Oppo UDP-203 with HDR set to Auto.
The Guardians of the Galaxy 2 disc has zero metadata values for MaxCLL and MaxFALL.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #13227 of 17813 Old 06-27-2019, 07:18 AM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 200
Examples -
Yes, some studios do not include metadata, it is well known. Disney/Marvel is one of them. You will have to manually tweak the tone mapping settings in the JVC using the controls to adjust - essentially raise the overall level and correspondingly reduce brightness.
You can use HDR off 2020 on the Oppo. In that case you are using the Oppo's tone mapping. It is quite good and was the best thing since sliced bread at one time. Until someone figured out that the 2020 colorspace it outputs is really only REC 709 in reality. That is a known bug but you personally may not notice it. Other than that the Oppo does a fine job with tone mapping.
gravi is offline
post #13228 of 17813 Old 06-27-2019, 07:20 AM
FenceMan's Avatar
Quoted: 91 Post(s)
Liked: 37
You can use HDR off 2020 on the Oppo. In that case you are using the Oppo's tone mapping. It is quite good and was the best thing since sliced bread at one time. Until someone figured out that the 2020 colorspace it outputs is really only REC 709 in reality. That is true but you personally may not notice it. Other than that the Oppo does a fine job with tone mapping.
So if I shut off HDR on the Oppo then it is doing the tone mapping? I did not realize that, it looks absolutely amazing if I do that (I thought I was just shutting off HDR alltogether).... Any point in investing in a Panasonic player?
FenceMan is offline
post #13229 of 17813 Old 06-27-2019, 07:20 AM
Yoxxy's Avatar
Quoted: 41 Post(s)
Liked: 38
AFAIK no Disney disks have MaxCLL and MaxFALL. Planet Earth 2 doesn't either which was a bummer when I got the projector.
Yoxxy is offline
post #13230 of 17813 Old 06-27-2019, 07:26 AM
gravi's Avatar
Quoted: 379 Post(s)
Liked: 200
So if I shut off HDR on the Oppo then it is doing the tone mapping? I did not realize that, it looks absolutely amazing if I do that.... Any point in investing in a Panasonic player?
Correct. Oppo was one of the pioneers in tone mapping. Other than the aforementioned colorspace bug it is really good with its razor sharp image and upscaling capabilities. Not to mention the other features that makes Oppo a great player. I have both the Oppo and the Panasonic and now use the Panasonic exclusively because of its ability to tweak the picture.
gravi is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
