Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 465 - AVS Forum | Home Theater Discussions And Reviews
 13941Likes
post #13921 of 14939 Old 07-14-2019, 05:29 PM
FenceMan's Avatar
Quoted: 90 Post(s)
Liked: 37
Just got my NX7 (to replace faulty NX5), gotta say big step up in PQ...
One question, can someone explain how the color filter works? What exactly is happening inside the projector when the filter engages and how does it expand the color gamut?
FenceMan is online now
post #13922 of 14939 Old 07-14-2019, 09:03 PM
DVD MAN's Avatar
Quoted: 231 Post(s)
Liked: 113
When you select BT.2020 as your color profile the filter will engage in the projector allowing the higher color gamut.
This is preferable if your screen size is not that large. When the filter is engaged there is a loss of output.
You should experiment between the HDR color profile and the BT.2020 and see which one you prefer.
Home Theater: Stewart -100” 4 Way Sreenwall Electric Masking, JVC-DLA-NX9 Tivo Vox, Oppo-UDP-205, Roku 4K Ultra, Apple TV 4K, Panasonic UB9000 , Marantz AV8802A-7.1 SSP, Ayre K5 MP Stereo Pre Amp, Clearaudio Concept Turntable, Schitt Audio Phono Pre Amp, Rotel RB-1070, Rotel RMB-1095, Rotel RB-933, Ayre-V5xe,Vandersteen-3A Signature-Front LR, Vandersteen-VCC-5-Center, Vandersteen-VSM-Surrounds and Atmos, Dual SVS PB16 Ultras Subwoofers.
DVD MAN is online now
post #13923 of 14939 Old 07-14-2019, 09:40 PM
elvinps2626's Avatar
Quoted: 49 Post(s)
Liked: 24
Originally Posted by den110 View Post
I have the Seymour UF on a DIY screen - 140in diag cinema scope with the RS2000(NX7) and it looks great! 1st row of seats about 10 feet from screen.
That is awesome to hear i was worried that i would lose light output for HDR content cause of the AT screen but you have a bigger screen than me. I wish i could go bigger but my room width and speaker doesn't let me. I will have 2 big L/R Speaker beside the screen and the center channel behind the screen. Thank you so much for the reply.
elvinps2626 is offline
post #13924 of 14939 Old 07-14-2019, 10:24 PM
bathes2051's Avatar
Quoted: 56 Post(s)
Liked: 30
I left CMD on, and sure enough, under 10h this “bait” worked.
Time to contact JVC, now that I have pics.
I have a May 2019 build, supposedly from the serial number.
ID:	2590868Click image for larger version
bathes2051 is offline
post #13925 of 14939 Old 07-15-2019, 03:41 AM
FenceMan's Avatar
Quoted: 90 Post(s)
Liked: 37
I understand that, I am just curious about what is happening, how does the color filter change things? This is all kind of strange to me, Rec709 was such a constant calibration with everything known and now with UHD / HDR there seems to be a lot of preference and "what looks good to you" going on?
Jacob92175 likes this.
post #13926 of 14939 Old 07-15-2019, 05:38 AM
Mike Garrett's Avatar
Quoted: 11991 Post(s)
Liked: 9502
Attachment 2590868Attachment 2590870
Are you running 2.07 firmware? If not, update to 2.07 and see what happens.
Mike Garrett is offline
post #13927 of 14939 Old 07-15-2019, 06:10 AM
jj-34's Avatar
Quoted: 154 Post(s)
Liked: 52
I cannot understand how that can be a hardware fault, such a regular pattern with no vertical color change and no input ?
Is there some hardware component that could induce such a pattern ?,
jj-34 is offline
post #13928 of 14939 Old 07-15-2019, 06:34 AM
Quoted: 118 Post(s)
Liked: 174
Mike, his first picture shows he’s at v2.07. JVC needs to figure this out!
Karl Maga is offline
post #13929 of 14939 Old 07-15-2019, 07:39 AM
jeahrens's Avatar
Quoted: 1886 Post(s)
Liked: 1189
Originally Posted by Des511 View Post
So with JVCs internal scaling not been regarded as the best and talk of using the full 17.9 panel then surely there will be a drop in quality of the picture?
None that I've noticed. Folks using an anamorphic lens have no complaints about the scaling done there either.
jeahrens is offline
post #13930 of 14939 Old 07-15-2019, 07:49 AM
Liked: 9502
Just trying to help. I did not see it as my responsibility to go back through posts to try to determine what firmware he was using, so asked the question and told him if he was not on 2.07, that would be the first step. He already has 2.07, so no other option, other than get with JVC to resolve. Would also have been nice if he had listed what source he is using, when he got this, but again, I am not going to go back and read all his posts, trying to see if he previously mentioned.
Dandlj likes this.
post #13931 of 14939 Old 07-15-2019, 07:50 AM
SirMaster's Avatar
Quoted: 421 Post(s)
Liked: 432
Yeah and the zoom scaling is such a tiny rescale.
Just because the projector isn’t great upscaling 1080p to 4K doesn’t mean that the scaling from 3840 to 4096 will also not be great.
In fact the scale is doing very little so it maintains a lot of the original sharpness.
jeahrens likes this.
SirMaster is online now
post #13932 of 14939 Old 07-15-2019, 07:51 AM
jeahrens's Avatar
Liked: 1189
Originally Posted by jabz View Post
So I've decided and have a N7 on the way
I am a little confused whether I should continue to use my Prismasonic 1.33x Anamorphic Cylindrical lens, I didn't pay much attention to this with my Sony and just used the lens, however reading this thread and the talk of entire panel use, I'm questioning whether to continue to use it. I have a 130" (Diagonal) 2:35:1 screen and a 120" 16x9, most of my watching is on the 2:35:1 screen
With the lens it won't use the entire 4k panel, but increased light output using the full 3840 x 2160 resolution.
Without the lens I can use the entire panel with the correct projector setting, but zoomed? uses the full 4096 x 2160 panel, which yields slightly increased resolution and light, but more than using the A-lens?
As long as the lens is capable of resolving 4K, I'd use it. You'll get more overall light output. You may also consider removing it for non-scope content like 2.0:1 and 2.20:1 using an installation mode/lens memory to avoid cropping (and you could use the full panel here).
Dandlj likes this.
jeahrens is offline
post #13933 of 14939 Old 07-15-2019, 08:03 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6498 Post(s)
Liked: 6477
I had the NX7 for a short period of time but out of the box compared to the NX9 the immediate difference was how sharp the NX9 is. After a week of viewing the NX9, I feel the black level is on par with my RS500
even though the RS500 has a better contrast ratio. Th NX9 has a much higher price tag then the NX7 but the difference that I saw makes it worth it to me but probably not to most. If you are considering one over the other you should view them both before making that decision.
That is the funny thing about contrast ratio....
On Wikipedia, "There is no official, standardized way to measure contrast ratio for a system or its parts, nor is there a standard for defining "Contrast Ratio" that is accepted by any standards organization so ratings provided by different manufacturers of display devices are not necessarily comparable to each other due to differences in method of measurement, operation, and unstated variables"
Each item would have to be texted exactly the same and in the exact same situation to compare any results......
DVD MAN and rjmcinnis like this.
Cleveland Plasma is offline
post #13934 of 14939 Old 07-15-2019, 08:42 AM
Quoted: 118 Post(s)
Liked: 174
I wasn't criticizing you Mike, you are consistently helpful in this thread! I agree, it would have been helpful for him to note his source, and his firmware.
Mike Garrett likes this.
post #13935 of 14939 Old 07-15-2019, 09:14 AM
Craig Peer's Avatar
Quoted: 6705 Post(s)
Liked: 7829
Did you notice an improvement using the NX9 over the NX7, blacks etc?
With the same lens as my RS4500, I'm not surprised you find the NX9 super sharp. I find the picture to still amaze me after nearly 2 1/2 years of ownership. A lot has to do with the lens for sure.
Spizz, DVD MAN, Dandlj and 1 others like this.
Craig Peer is offline
post #13936 of 14939 Old 07-15-2019, 10:21 AM
bathes2051's Avatar
Quoted: 56 Post(s)
Liked: 30
So far all my issues have been with a Panasonic UB820 and in HDR mode (with CMD on Low), but that's the bulk of my viewing.
I upgraded from 2.06 to 2.07 on Day 1, but I haven't done a factory reset. I could try that.
post #13937 of 14939 Old 07-15-2019, 10:44 AM
nanoodhaliwal's Avatar
Quoted: 54 Post(s)
will the 115" wide AT screen (soundmax 4K, 1.1 gain) be bright enough for NX5 ? in light controlled with dark walls and not bat cave ?
nanoodhaliwal is offline
post #13938 of 14939 Old 07-15-2019, 10:48 AM
Liked: 9502
You definitely need to be talking to JVC, because you are not doing anything out of the ordinary.
post #13939 of 14939 Old 07-15-2019, 10:50 AM
Liked: 9502
Yes, if you are at the short end of the throw, but that 1.1 gain number is BS. Probably closer to 0.9, though I have never seen the material. But I have seen a lot of woven AT screens and I am yet to see one above 1.0.
post #13940 of 14939 Old 07-15-2019, 11:08 AM
DVD MAN's Avatar
Quoted: 231 Post(s)
Liked: 113
Hey Guys,
Are there any members that are using the Panasonic PQ-BL color profile on the NX series with the Panasonic UB9000. If so what are your thoughts?
post #13941 of 14939 Old 07-15-2019, 11:43 AM
Quoted: 290 Post(s)
Liked: 174
The RS2000 is up and running finally. FW 2.06. I'm staying on 2.06 to see if I get the green lines issue; 2.07 doesn't fix it anyway from what I've read. I haven't seen yellowing issues no matter what color profile I use. I keep trying to find them during films and I just don't see it.
I had to make some minor adjustments to the color alignment, but not a lot. I wish the uniformity of the color alignment was better. It's good, but around the edges of the screen I see a little bit of misalignment. I can fix that with zonal correction so it's not a big deal.
The projector is more than bright enough for my 135" Silver Ticket White 1.1 screen. However, I'm not happy with the auto-tone mapping feature. When I use MadVR I can adjust the HDR dynamic mapping to retain the benefits of HDR without graying/washing out everything; and to handle multiple films without adjusting for each one. If I'm watching Netflix from my PC, however, it sends the metadata (directly from Netflix; not the Win10 default metadata) but even with the mapping level maxed the image is not vibrant or bright enough. I've decided that for each Netflix film I start out letting the projector auto-tone map to start out and then turn that off to bump up the image tone manually a couple notches. It's not even a projector brightness issue because I can zoom the lens down to a tiny 77" size and it's still not bright enough. SDR content is bright enough no problem. It's really the metadata and auto-tone mapping not being able to compensate for it enough. I wish the mapping level went from 0 to 10 rather than 0 to 5. I don't care if there is some clipping. That's to be expected. I'll decide how much I want. I might need to do some custom gamma curves to get what I want on non-madVR content.
As I said before, however, MadVR content is beautiful. I'm running the new dynamic HDR builds and they do great. Set it and forget it for all of the movies I've tried so far. I wish the projector would accept my 12-bit RGB 24p signal and not lie to me while forcing it to 4:2:2 (as pointed out by Manni), but otherwise my UHD HDR Blu Ray experience is pretty great. Maybe JVC will fix that issue in the next firmware (it's not actually fixed, just hidden in 2.07 so I hear). It's really easy to tell when the projector is forcing 4:2:2 because you can set the chroma on the projector to RGB and the colors go wack. When running 8-bit RGB, forcing the projector to use RGB works fine.
The fan on high is a touch too loud, but it doesn't bother me. Maybe I'll put some diverters on the front vents. The lens shift is very grindy. Zoom is smooth and quiet and horizontal lens shift is fine, but vertical sounds like a 1980s printer. Not sure why. As long as it doesn't break I'm fine.
Another complaint... the pixels are not tack sharp. I'm not expecting a Christie level chess-board-quality layout, but even with better color alignment in the center and close adjustment of the focus, it really isn't super sharp. I would like to see the QuickBrownFox pattern on another projector to compare (not just screenshots). Maybe that's just how these new 4k projectors are. It still looks great, but not as great as I would like.
Definitely I am happy that I put black velvet all over my room for this projector. I actually would go as far as to say that without the velvet you should probably get a different projector with a lot more brightness that sacrifices on black levels. Don't even waste your time with JVC or Sony unless you are doing a dedicated blacked out home theater. I'm sure many will disagree. That's fine.
So... was it worth it? Yeah! I'm not aware of anything better anywhere near the same price point and I got a great deal on this thing. Maybe I got a bit of a lemon on sharpness and color alignment? Dunno. I guess we'll find out when I compare it. I might go for a nicer higher-gain screen next to help that image "pop" more with a bit more brightness. We'll see.
Glyssas likes this.
wombats is offline
post #13942 of 14939 Old 07-15-2019, 11:49 AM
asharma's Avatar
Quoted: 1729 Post(s)
Liked: 518
Mike, just considering the Cima Neve 115 or 125 2.35...stated 1.1 gain...I’ll have about a 14ft throw, batcave, N7...do U think the N7 can adequately light up a 125 2.35 Cima Neve for HDR or would u stick with the 115”?
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, triple black velvet batcave
Screen:120” 2.35 Elunevision Tab tensioned motorized drop down screen;
asharma is online now
post #13943 of 14939 Old 07-15-2019, 12:05 PM
Liked: 9502
The JVC at short end of throw range is bright enough for the 125, especially if using the UB9000. The 115 will give you longer lamp life.
asharma likes this.
post #13944 of 14939 Old 07-15-2019, 12:10 PM
asharma's Avatar
Liked: 518
Thanks man, i just don’t like non bright images...the drawback of going too big is “dullness” whereas I know I won’t have that issue with a 115” but I don’t want to regret buying too small! I’m using an 820 BTW...I need to see a dr I think! 🤪
Edit I’m not concerned about lamp life...for all the $$ I have into this hobby, what’s another $500 every year or 2...
Karl Maga likes this.
post #13945 of 14939 Old 07-15-2019, 01:10 PM
Industry Insider
Liked: 6477
<<< Click Here >>>
@Dominic Chan is selling loose bulbs and they're cheap.
post #13946 of 14939 Old 07-15-2019, 01:21 PM
asharma's Avatar
Liked: 518
Originally Posted by Cleveland Plasma View Post
<<< Click Here >>>
Gotta pay to play 😀
post #13947 of 14939 Old 07-15-2019, 02:34 PM
avsBuddy's Avatar
Quoted: 128 Post(s)
Liked: 73
Finally got my NX1000 from JVC, which is replacing unit that took forever to boot up. New projector boots up much faster and its lens appears to be more uniform!
Just as my wife predicted though, new unit isn't perfect
  1. I'm seeing "dancing" streaks on convergence adjustment menu as it appears in the bottom right corner. Regular projector menu on top left corner is fine though.
  2. When doing pixel convergence adjustment, i'm seeing a slight greenish tint above all horizontal lines on the conversion grid. I can't get it to go away by shifting Red or Blue pixels. Is this something that people experience often on these projectors?
avsBuddy is offline
post #13948 of 14939 Old 07-15-2019, 09:12 PM
Liked: 0
Hi guys, just un-boxed and fired up my new RS2000. Yay! Uh-oh
There is a blue banded tint on the bottom 6” of the image across the entire screen. Images below. Is there an adjustment or is the unit defective?
ID:	2591244   Click image for larger version
OnTheSnap is offline
post #13949 of 14939 Old 07-15-2019, 09:20 PM
dbochniak's Avatar
Quoted: 13 Post(s)
Liked: 34
Originally Posted by OnThe&#83;nap View Post
Hi guy&#115;, ju&#115;t un-boxed and fired up my new R&#83;2000. Yay! Uh-oh
There i&#115; a blue banded tint on the bottom 6” of the image acro&#115;&#115; the entire &#115;creen. Image&#115; below. I&#115; there an adju&#115;tment or i&#115; the unit defective?
&#83;adly, I think you need a replacement unit. Bummer to &#115;ee that out of the box!
dbochniak is offline
post #13950 of 14939 Old 07-15-2019, 10:12 PM
coderguy's Avatar
Quoted: 2436 Post(s)
Liked: 1319
Maybe it's just sample variance, you probably got an average sample, which isn't bad considering it could have gone either way.
Aztar35 likes this.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is online now
Jvc , nx7 , nx9 , rs2000 , rs3000
