Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 478 - AVS Forum | Home Theater Discussions And Reviews
 15133Likes
post #14311 of 16193 Old 07-27-2019, 12:00 PM
flyguyjake's Avatar
Quoted: 221 Post(s)
Liked: 73
Could someone buy (2) RS2000 and stack them for increased light output & greater HDR impact? Is it possible to align them 100%?
flyguyjake is offline
post #14312 of 16193 Old 07-27-2019, 12:06 PM
Craig Peer's Avatar
Quoted: 6820 Post(s)
Liked: 8020
Just buy an RS4500 - less hassle!
OzHDHT and catav like this.
Craig Peer is offline
post #14313 of 16193 Old 07-27-2019, 12:41 PM
flyguyjake's Avatar
Quoted: 221 Post(s)
Liked: 73
Doesn't it lose 40% light in BT.2020 mode with laser on high? Also this projector is double the cost of my proposition.
post #14314 of 16193 Old 07-27-2019, 01:37 PM
COACH2369's Avatar
Quoted: 1189 Post(s)
Liked: 988
I was curious if anyone had a link they could send me in regards to figuring out how much vertical lens shift is needed for my setup.
Right now I am looking at jumping into the RS2000, currently have a RS500 and want to see if I will have to lower my projector at all. Or if I can simply swap the two out and not make any adjustments to the mount.
Seems like some folks are having to do this and others haven't.
COACH2369 is offline
post #14315 of 16193 Old 07-27-2019, 01:58 PM
Mike Garrett's Avatar
Quoted: 12259 Post(s)
Liked: 9857
Where is the info?
Screen size?
Ceiling height where projector is mounted?
Vertical distance from ceiling (where projector is mounted) to top of image?
Throw distance?
Mike Garrett is offline
post #14316 of 16193 Old 07-27-2019, 01:58 PM
asharma's Avatar
Quoted: 1803 Post(s)
Liked: 562
Try this Sir...according to this, I end up with a different vertical lens shift than my rs600...
http://www.reviewtranslations.com/pr...ulator_en.html
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, triple black velvet batcave
Screen:120” 2.35 Elunevision Tab tensioned motorized drop down screen;
asharma is online now
post #14317 of 16193 Old 07-27-2019, 02:16 PM
COACH2369's Avatar
Liked: 988
Originally Posted by Mike Garrett View Post
Where is the info?
Screen size?
Throw distance?
Sorry. I didn't include that info since I was just looking for a link to the info.
Screen size = 115" wide, 2:35 ratio.
Ceiling Height = 8 feet tall
*Projector is mounted as flush as it can be to the ceiling, 3" to the top of the lens.
Vertical distance = screen is 22" from the ceiling(screen itself, not the frame)
Throw distance = 14.7 feet.
post #14318 of 16193 Old 07-27-2019, 02:32 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6568 Post(s)
Liked: 6567
Originally Posted by Treshnell View Post
What's the recommended ceiling (drop ceiling if that matters) mount for the NX5? All the mounts I've seen do like 30lbs max..
RPA + SLB281 combo
RPMA + SLM281 combo >>> This has gear adjustment.
You might be able to build a box and never buy a mount ever again. <<< Click Here >>> to be linked to pics and details.....
You will definitely be able to make it work, only one way to know for 100% sure is to buy one. If you have to get a shorter or longer pipe it will be worth the effort
Cleveland Plasma is offline
post #14319 of 16193 Old 07-27-2019, 02:40 PM
COACH2369's Avatar
Liked: 988
Originally Posted by Cleveland Plasma View Post
RPA + SLB281 combo
If I can determine before I order one, then I can plan accordingly and not have to wait until after it gets here.
post #14320 of 16193 Old 07-27-2019, 02:58 PM
Quoted: 169 Post(s)
Liked: 95
I’ve been watching Stranger Things on my NX7.
The picture is often incredible, so many breathtaking/like looking out a window moments. Recommend it.
I read a lot of 4K content isn’t filmed in 4K, but Netflix new stuff is. Maybe that’s the reason.
Dandlj is offline
post #14321 of 16193 Old 07-27-2019, 03:07 PM
Liked: 9857
Need more info on how your projector is mounted to the ceiling?
post #14322 of 16193 Old 07-27-2019, 03:19 PM
Liked: 9857
If you remove the feet from the projector and place the projector against the ceiling, then the lens center is 4" from the ceiling. A 45" high image allows 13.5" of vertical lens shift, if no horizontal lens shift is used. That gives you 17.5" max + whatever your mounting system adds. So you will have to add a drop tube. What I do not understand is how your existing setup works. If it is 22" from the ceiling to the image and the lens is only 3" down from the ceiling, then the math says your existing setup will not work, so something is wrong with the info provided.
post #14323 of 16193 Old 07-27-2019, 06:08 PM
COACH2369's Avatar
Liked: 988
I have attached two pictures of how my projector is mounted.
It looks like the center of the lens is approximately 6" from ceiling.
After remeasuring the screen distance from the ceiling, it looks like the start of the screen material is 21" from the ceiling.
Now, I am not 100% if my current setup is "ideal" but it has looked great to me and Chad has never mentioned that I was at the threshold of the lens shift. Guess maybe I could improve upon my picture if I used less lens shift or had the projector closer to the screen.
Definitely appreciate the input.
ID:	2595424   Click image for larger version
post #14324 of 16193 Old 07-27-2019, 06:16 PM
markmon1's Avatar
Quoted: 4994 Post(s)
Liked: 3253
Dont use the filter? Looks great without the filter.
It's going to be impossible to align those two projectors at the 4K pixel resolution. I bet the optics move slightly after warming up also.
Craig Peer likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #14325 of 16193 Old 07-27-2019, 07:22 PM
Liked: 9857
You either have the projector angled down some your projector has slightly more lens shift than specced. You really should lower the projector a little bit. Per specs, you have a 49" high image (115" wide 2.35) 49" x 0.3 = 14.7". 14.7" + 6" = 20.7" and you said your image is 21" down. I would get a mount and 3" drop tube.
post #14326 of 16193 Old 07-27-2019, 09:48 PM
claw's Avatar
Quoted: 2300 Post(s)
Liked: 2139
Wow - that is some hot bass. I had to brace and vibration dampen my shelf prior to the RS4500, to keep things from moving under extreme LFE too. You don't really want the projector moving in relation to the screen during a movie anyway.
Now I can't wait to get my copy of Alita:Battle Angel and see how much LFE it cranks out !
The Alita UHD disc has some weird HDR metadata.
MaxDML (maximum display monitor luminance) is 1000 nits; nothing out of the ordinary there.
But MaxCLL and MaxFall are both 10,000 nits. That is going to give HDR displays fits if they emphasize either value in their tone mapping. Might be why some other threads are reporting disappointment with the HDR.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #14327 of 16193 Old 07-27-2019, 10:38 PM
Craig Peer's Avatar
Liked: 8020
I’ll have the new Lumagen tone mapping firmware installed before I get the disc, so we will see.
llang269 likes this.
post #14328 of 16193 Old 07-28-2019, 12:29 AM
woofer's Avatar
Quoted: 1405 Post(s)
Liked: 2167
Looks "Spectacular" using HTPC and MadVR on the Z1....
woofer is online now
post #14329 of 16193 Old 07-28-2019, 03:26 AM
asharma's Avatar
Liked: 562
Watched it on my 1000 nit Sony tv last night...definitely some dim scenes where I was questioning how it would look on a pj...
post #14330 of 16193 Old 07-28-2019, 03:32 AM
woofer's Avatar
Liked: 2167
Honestly...... it looked just fantastic....
catav likes this.
post #14331 of 16193 Old 07-28-2019, 03:38 AM
asharma's Avatar
Liked: 562
I have no doubt on a laser and MadVR that it would look fantastic...I have not graduated to that level yet...my comment was more focused on how it would look on my bare bones stock N7...
post #14332 of 16193 Old 07-28-2019, 05:03 AM
3ll3d00d's Avatar
Quoted: 2391 Post(s)
Liked: 2558
I needed a rest api so I could send commands to my n7 from my (javascript) remote control app so I wrote https://github.com/3ll3d00d/pyjvcpj (based on an existing python impl of most of the commands then updated for the specifics of the N5/7/9 range) . If it's useful to anyone then you can get a windows exe from https://github.com/3ll3d00d/pyjvcpj/releases (linux could be built easily enough).
It lets you send lists of commands to execute (or define macros in the server) and read various values to show the current state of the PJ. It supports all the remote codes & the direct codes listed in the jvc docs. See https://github.com/3ll3d00d/pyjvcpj/...mmands.py#L591 for the command list. Some brief docs on how to use/configure it in the readme in the repo.
3ll3d00d is online now
post #14333 of 16193 Old 07-28-2019, 05:26 AM
COACH2369's Avatar
Liked: 988
I guess it is possible that the projector is angled down some, didn't think about that.
If the only thing I would need to do is add a 3"-6" pole, then that is much easier than having to remount the projector.
Any suggestions on where to pick up the poles for the Chief mounts?
post #14334 of 16193 Old 07-28-2019, 06:00 AM
Craig Peer's Avatar
Liked: 8020
If that’s all you need, just get a 3” or 6” long 1 1/2” pipe nipple from Home Depot for a couple of bucks. Paint it black if you want.
catav likes this.
post #14335 of 16193 Old 07-28-2019, 07:13 AM
Industry Insider
Liked: 6567
Stick a level on your projector and find out, well at least that would give you some type of clue anyway but your projector case may or may not be parallel with the lens assembly. You will not know for sure until you try different things once you get your new projector, we can give an educated guess all day, but you will not know for sure until you mount it.
post #14336 of 16193 Old 07-28-2019, 08:16 AM
jj-34's Avatar
Quoted: 167 Post(s)
Liked: 56
Especially that there is no flat place where to put a spirit level at least when it is upright on its feet, the top of the PJ is rounded all around.
Suggestion to JVC : why not put some form of electronic horizon relative to the lens asm, would not cost an arm and would be so handy to adjust it, even my Nikon camera has one that I can see thru the view finder, I never have another leaning picture.
jj-34 is online now
post #14337 of 16193 Old 07-28-2019, 08:54 AM
COACH2369's Avatar
Liked: 988
That is a great idea! I guess what is sold online wouldn't be any different than what you are recommending, assuming they make one that has both sides threaded.
I'll check it out today or tomorrow.
Thank,
post #14338 of 16193 Old 07-28-2019, 09:20 AM
Quoted: 33 Post(s)
Finally received my NX7 today, having placed my order in January. Installed on a Chief mount. Firmware v2.08. Built July 2019. Perfect boxing. OOTB no strange colors, perfect pixel alignment cold and hot. Great picture. Another of the lucky ones, I guess.
Drem, rjmcinnis, coxy2416 and 3 others like this.
neb04 is offline
post #14339 of 16193 Old 07-28-2019, 10:08 AM
BondDonBond's Avatar
Quoted: 688 Post(s)
Liked: 624
Before I went the RS4500 route I would go (which I did) NX7 with a DCR lens and a VERY good screen and Panni 820. All reusable with whatever projector you have and will help all of them.
HDR and all looked great with that on mine. Then I went to MadVR and could not believe what an improvement that was for HDR. More work but honestly after I got it all set up with a HTPC and NAS, I buy the movie rip the movie for MadVR and also have the digital rights for other screens and Apple TV.
I have been thinking about this, where I actually think HTPC's may start coming back in fashion especially with us cord cutters. With Hulu, Disney's new service, HBO on and on the set top DVR may not have all the apps needed to do what you want let alone the video and audio capabilities. It will be interesting.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #14340 of 16193 Old 07-28-2019, 10:51 AM
Craig Peer's Avatar
Liked: 8020
Thank,
Yes - the pipe nipples are threaded on both ends. I have several here myself.
COACH2369 likes this.
Jvc , nx7 , nx9 , rs2000 , rs3000
