Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 488 - AVS Forum | Home Theater Discussions And Reviews
 18590Likes
post #14611 of 20435 Old 08-08-2019, 12:51 PM
aka jfinnie
Quoted: 2821 Post(s)
Liked: 1949
Originally Posted by Aztar35 View Post
How much does an OEM lamp cost these days?
UK price inc sales tax (unavoidable for consumers) for genuine JVC x7900 lamp in genuine housing £390 - currently $475. Very few places listing the new unit for the new PJs over here, I imagine it will be round about a similar level as it is the same bare bulb just a different housing.
bobof is online now
post #14612 of 20435 Old 08-08-2019, 01:57 PM
MMC57's Avatar
Quoted: 151 Post(s)
Originally Posted by Mike Garrett View Post
No, the black bar should be about 4" wide on each side. As long as your walls are not near white, you will not see the bar. You can use any 16:9 source. Bring a 16:9 movie with you.
I will check it out see what it looks like.
Perhaps I should cover the wall the the screen is on with the same Black Velvet that is on the Bezel.
Then over scan and black bars will not be an issue.
MMC57 is offline
post #14613 of 20435 Old 08-08-2019, 02:03 PM
Quoted: 5204 Post(s)
Liked: 2048
Originally Posted by MMC57 View Post
So in my case I would have 1/2" spillage onto the wall... hmmm... will have to see a demo and see what it looks like.
Thanks for the information about the 3.3% of screen width.
Is there a reference or website that shows this type of information?
It was calculated from the ratio of 4096 to 3840.
JVC DLA-NX7; Denon AVR-X3400H; HD Fury Vertex; ATV4K; Fire TV Cube
JVC Projector Bright Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #14614 of 20435 Old 08-08-2019, 02:45 PM
Mike Garrett's Avatar
Quoted: 12799 Post(s)
Liked: 10433
Yes cover the wall and you will never see the bars, but you do not have to overscan.
Mike Garrett is online now
post #14615 of 20435 Old 08-08-2019, 03:13 PM
asharma's Avatar
Quoted: 1930 Post(s)
Liked: 625
Where are you getting your throw distances? A 120" diagonal 2.35 is 110.42" wide, so round up to 111". Set Projector Central calculator to 16:9 and set width to 111" and it gives you 13'-3" of throw. 17:9 is 1.896. So if you set the aspect ratio to 1.9:1, you get 12'-5" of throw. JVC says 12'-5.2", so you can see the calculator is correct.
Hey Mike...I’m using the projector central site...when choosing 2.35 and and 120” diagonal screen with max zoom, the calculator tells me I need 12”5’ throw distance to fill the screen...I have 13 ft...What am I missing? Clearly I’m misinterpreting how this works and I’m just about ready to move the pj back 6 inches... Thanks...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual SVS SB3000, Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is online now
post #14616 of 20435 Old 08-08-2019, 03:27 PM
Liked: 10433
Put it to 16:9 and adjust image width until you get to 111" wide. You will see 13'-4". That is the required throw, if you want 1:1 pixel mapping. Selecting 2.35 you will use full 4096 panel width, gain some brightness, reduce throw to 12'-5", lose 1:1 pixel mapping and cut off a little bit of the image height.
asharma likes this.
post #14617 of 20435 Old 08-08-2019, 03:33 PM
asharma's Avatar
Liked: 625
DOH! Now how the hec was I to realize that setting to 2.35 was based on the full panel? Does it mention that? Probably does and my speed reading failed me! Thanks man, appreciate the info and quick response...
post #14618 of 20435 Old 08-08-2019, 05:00 PM
jj-34's Avatar
Quoted: 225 Post(s)
Liked: 69
Not completely sure about how image frames are handled with either the native or zoom modes, I figured a scaled autocad drawing could help comprehension :
just hope this is what happens really :
Name:	format compare.jpg
jj-34 is offline
post #14619 of 20435 Old 08-08-2019, 06:21 PM
asharma's Avatar
Liked: 625
Ok folks, I am now 13”7’ back...I Have aspect set to auto...on my 2.35 120” screen with max zoom, I can juuuuuust fill the sides (and overlap a wee bit) but the top and bottom fall a little short with a bow at the bottom Center of the screen...I can’t recall what the bow indicates is out of whack...any input appreciated...not sure why my sides are full but the top and bottom a little short with a bow...thanks folks...
Also when projector central says I need 13”4’ is that from the lens or from the front of the pj?
Also I know I can fill the screen with setting aspect to zoom, but that’s not my preferred method...
post #14620 of 20435 Old 08-08-2019, 06:52 PM
Craig Peer's Avatar
Quoted: 7207 Post(s)
Liked: 8605
A bow indicates you are pointed too high. Small corrections.
Craig Peer is online now
post #14621 of 20435 Old 08-08-2019, 07:07 PM
Liked: 10433
keep in mind there is a variance, so not guaranteed to hit that size at 13'-4"
asharma likes this.
post #14622 of 20435 Old 08-08-2019, 07:45 PM
asharma's Avatar
Liked: 625
Thanks, so I did lower the pj but still bow...I put a level on the pj and it appears to be level...the other issue could be that I read is it bows when the Center of the screen is closer than the edges...I wonder if this is inherent in tab tensioned drop down design?
post #14623 of 20435 Old 08-08-2019, 07:46 PM
asharma's Avatar
Liked: 625
Thanks...but since the sides overlap, doesn’t it indicate some small tweak is needed somewhere in regards to pj and screen alignment?
post #14624 of 20435 Old 08-08-2019, 09:03 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6848 Post(s)
Liked: 6844
How big is this bow?
Cleveland Plasma is online now
post #14625 of 20435 Old 08-08-2019, 09:06 PM
asharma's Avatar
Liked: 625
Hmmm, I didn’t measure but I’m thinking an inch or so...I have a new tab tensioned screen...when I push the bottom Center of the screen in, where the apex of the bow is, it minimizes the bow...
post #14626 of 20435 Old 08-09-2019, 12:24 AM
SoonerDoc's Avatar
Quoted: 72 Post(s)
Liked: 25
Originally Posted by Josh Z View Post
You're really overthinking this.
- Your screen is 16:9.
- The projector's panel is natively 17:9, with 4096x2160 pixels.
- The projector's default mode is to only use 3840x2160 pixels in a 16:9 shape. This leaves thin black bars of unused pixels on the sides.
- When you align the projector onto the screen, the 16:9 portion of the panel should perfectly fill the 16:9 screen. The black bars on the sides should spill off onto your screen border. Because JVC projectors have good black levels, there is very little likelhood that you will ever notice them
As I mentioned earlier this is not what I am seeing. When throwing the 16:9 image onto my 16:9 screen, once the top and bottom of the image fill the screen, I STILL have black bars in the sides. So to use the lens zoom to make the side bars spill onto my frame, I lose a littlle of the image on the top and bottom.
As Mike said, I assume either my screen isn’t 16:9 or the image isn’t 16:9.
SoonerDoc is offline
post #14627 of 20435 Old 08-09-2019, 02:15 AM
Drem's Avatar
Quoted: 152 Post(s)
Liked: 128
Finally picked up the new N7. However weather is amazing so I will not test it until tonight,
Skickat från min SM-G973F via Tapatalk
Craig Peer likes this.
Drem is offline
post #14628 of 20435 Old 08-09-2019, 02:38 AM
markmon1's Avatar
Quoted: 5450 Post(s)
Liked: 3563
Originally Posted by SirMaster View Post
For IP control there are 2 different off commands. One of them needs to be used twice and the other only once.
Not sure if you can program in custom IP control commands with your remote, but if you can then it can be turned off with 1 command.
I believe the IP Commands also require dual send for off.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #14629 of 20435 Old 08-09-2019, 02:49 AM
markmon1's Avatar
Liked: 3563
Originally Posted by Dominic Chan View Post
Keep in mind that you get extra brightness if you use the full panel width (zoom aspect ratio).
It's really not significant. It's maybe 75 lumens on low maybe 100 lumens on high by math. But is actually less because lumens measured at center of screen are brighter than at edges. Since this masks off the very edges, you probably lose about 50 lumens. It's not going to be noticeable at all.
markmon1 is offline
post #14630 of 20435 Old 08-09-2019, 02:54 AM
markmon1's Avatar
Liked: 3563
My screen is 16 x 9... 137.7 Diagonal.... 120 width.... 67 high.
the Bezel is 1.5 inches.... Black Velvet.
Will the 1.5 inch bezel eat up the the black bars?
Walls and ceiling are going to be repainted with the renovation so hopefully any spillage beyond the 1.5 inch Bezel will not be noticeable if I go that route with the JVC.
My friend has an AV store with a NX5 on display so I will call him to see if he has cable or sat so we can feed
16 x 9 content.
If I am satisfied with the aspect ratio concern then my last issue will be about motion handling with fast moving sports.
Cable or satellite will never feed 17:9 to the projector. They'll be either sending 1920x1080 or 1280x720 both are 16:9 ratios and both will result in looking just like any other 16:9 projector. In fact, I have a 16x9 screen and just set the projector up as a 16x9 projector. If I watch 17:9 content, I don't worry about any zooming I simply have small black bars on top and bottom just like any other 16x9 display. You're worrying about something that's a non-issue.
Jacob92175 and Renerator like this.
markmon1 is offline
post #14631 of 20435 Old 08-09-2019, 04:29 AM
Quoted: 693 Post(s)
Liked: 372
I remain completely confused as so the aspect ratio the JVC NX7 will project on a 16 x 9 screen when 16 x 9 content for example NFL football is sent to the projector.
Since sports is the main use for my projector I do not want any black bars on the image... I only want perfect 16 x 9 geometry to fill the screen the full 16 x 9 image without any further manipulation.
Would a projector with native 3840 x 2160 chip be better for me considering that 16 x 9 sports is the top priority?
Right now the two projectors I would consider are the JVC NX7 or the BenQ HT9060.
I am starting to think that the JVC NX7 is better suited for movies and that the BenQ HT9060 is better suited for sports.
I need a demo of the JVC NX7 with either cable or sat input showing HD content to see how it fills the screen.
Get yourself a jvc.. your not going to see the bars but there is a learning curve setting these things up but once set, you'll be happy for years to come.. Trust me I've had projectors for 16 years now I owned 2 Optoma for a total of 12 or 13 years.. when I bought my first jvc 3 years back I upgraded every year all the way up to the 640, I was hooked like a drug addict, obsessed.. I even put a pre-ordered for the n7 back on Sept or Oct but ended up canceling after it got delayed..
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #14632 of 20435 Old 08-09-2019, 07:31 AM
SirMaster's Avatar
Quoted: 840 Post(s)
Liked: 525
Well in this case it doesn't.
Sending (0x21, 0x89, 0x01, 0x50, 0x57, 0x30, 0x0A) which sets the power state to off turns the JVC off in a single command, or at least it does for me.
It's not always simply the center that is brighter. It depends where you lens is compared to the screen. On my screen, the top center edge is about 0.5 fc brighter than the center of my screen because my projector is ceiling mounted with the lens in line with the top of my screen. So the lens is physically closer to the top of my screen than to the center.
Yes it's about 75 and 100 lumens in normal and high bulb (more if you have screen gain), but I don't know what you mean by masking off the edges. I'm not masking off any of my projector's panel area and my brightness does increase a little using the zoom mode. Plus I get a bigger image than I could if I didn't use it.
SirMaster is online now
post #14633 of 20435 Old 08-09-2019, 08:02 AM
Josh Z's Avatar
Quoted: 4456 Post(s)
Liked: 3383
Your projector may not be aligned properly for accurate picture geometry. These things are easy to check. Grab a tape measure and measure the width and height of the screen, then divide to get the aspect ratio. Do the same for your projected image. If your screen is 1.78:1 but your projected image is not, adjust the position and angle of the projector until you get it right.
Josh Z
Television and Home Theater Writer/Editor, Primetimer.com
My opinions are my own and do not necessarily reflect those of my employers, whoever they may be.
Josh Z is online now
post #14634 of 20435 Old 08-09-2019, 09:26 AM
cemo62's Avatar
Quoted: 181 Post(s)
Liked: 49
how this is possible? thank you
cemo62 is offline
post #14635 of 20435 Old 08-09-2019, 10:27 AM
Quoted: 693 Post(s)
Liked: 372
it's explained above about 5 to 10 post above..
post #14636 of 20435 Old 08-09-2019, 10:53 AM
asharma's Avatar
Liked: 625
Double Tone mapping with Panny 820
Hi folks...I’m ok with the TMapping settings on my N7...On the Panny side under advanced settings do u chose basic luminance pj and then simply turn Optimizer on? Are those the settings on the Panny to achieve double TMapping?
post #14637 of 20435 Old 08-09-2019, 01:13 PM
asharma's Avatar
Liked: 625
Hey folks any other ideas? I’m trying to have my picture fill my 2.35 120” screen...I’m on max zoom and the top is aligned, both sides are aligned, the bottom right is aligned but from bottom right to left bows up and misses the left bottom by an inch...thanks...
Edit: using a tab tensioned screen, if that makes any difference
post #14638 of 20435 Old 08-09-2019, 01:28 PM
GlenC's Avatar
Location: So. Cal - Downey, CA / Rancho Santa Margarita
Quoted: 33 Post(s)
Liked: 39
Turn projector a bit to left until L & R are even then shift image to right...
Sent from my SM-G965U1 using Tapatalk
asharma likes this.
Glen Carter
Home Theater Calibration
CalMAN, CS1000, K10-A, Spyder5, Six-G, QD780
JVC RS3000, RS2000, RS600
GlenC is online now
post #14639 of 20435 Old 08-09-2019, 01:36 PM
Josh Z's Avatar
Liked: 3383
Adjust your pitch, adjust your roll, adjust your yaw, adjust your lens shift. Compare results of how changing one of these things affects the others. This is just geometry. Keep adjusting until you get it right. It's going to be trial-and-error until it lines up the way you expect it to.
asharma and jorgebetancourt like this.
Josh Z
post #14640 of 20435 Old 08-09-2019, 01:38 PM
asharma's Avatar
Liked: 625
Thanks, so r u suggesting my mount is not perpendicular to the screen...? I can’t turn the pj when it’s in the mount...I can adjust yaw and pitch but can’t physically turn the pj when using the Peerless mount...given that r u suggesting to unbolt the mount and realign the mount?
Jvc , nx5 , nx7 , nx9 , rs1000 , rs2000 , rs3000
