Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 495 - AVS Forum | Home Theater Discussions And Reviews
 16682Likes
post #14821 of 18041 Old 08-14-2019, 09:52 AM
alexr214's Avatar
Quoted: 16 Post(s)
Originally Posted by majicx View Post
I also have have Carada screen I was adding backlighting to the back of the frame at night and my flashlight hit the screen and it was amazing how much light went thru it. I added blackout material to the back of the screen and it really made a difference how my NX5 looked. Just a thought before you buy a new screen.
Thanks for the feedback. I painted the wall behind my screen in a matte black but never really tested for light passthrough. I may try some material on the back to see if it further improves upon things. My real reason for the change though was considering the switch from 16:9 to 2:35 AR. I have a short throw though ~13.3Ft and have seen some posts with regard to the right size you could fill at that throw so need to test that out because I would not want to go below a 125" diagonal 2:35 screen. If it can't fill that, then I will go for a 120" 16:9 which I am sure I could fill at my throw.
alexr214 is offline
post #14822 of 18041 Old 08-14-2019, 10:31 AM
den110's Avatar
Quoted: 61 Post(s)
Liked: 38
Any word yet on SpyderX support for the AutoCal Software?
Dedicated HT Equipment: Klipsch RF82BK L+R Speakers|Klipsch RC62BK CC Speaker|Definitive Technology B92X Surrounds|NHT Super One Rear Surrounds|4 Polk MC80 Ceiling Atmos|Velodyne VLF 1012 and Definitive Technology PF1500TL+ SWs|Marantz SR7012 Receiver|Yamaha RXV1800 Receiver for Atmos|JVC RS2000 Projector|Seymour Center Stage UF AT 140" diag 2:35 Screen on DIY frame and false front wall
den110 is offline
post #14823 of 18041 Old 08-14-2019, 11:00 AM
Mike Garrett's Avatar
Quoted: 12542 Post(s)
Liked: 10154
Nothing yet.
Mike Garrett is offline
post #14824 of 18041 Old 08-14-2019, 11:47 AM
jeahrens's Avatar
Quoted: 2073 Post(s)
Liked: 1381
Looks like using the zoom mode to scale to the full 17:9 panel it would work. Looking at this:
http://pro.jvc.com/pro/lens_calc/HTML/jvc_REF.html
If you put in a 2.35:1 125" screen you get 115x49" screen with a minimum throw of 164.96" or 13.75'. Which is just a bit more than you have. Since there is no indication whether it is using zoom to fill the 17:9 panel I switched the screen option to 17:9 and put in the 115" width (130" diagonal 17:9 screen). The minimum throw is now 154.33" or 12.86', which means that using panel zoom you should be able to fill the 125" scope screen.
Whether you want to use panel zoom or not is up to you. There seems to be some concerns over the mild scaling it uses. I use it on wider ARs and can detect no issues, just more light output. Personally I would use the panel zoom and get the 125" scope screen.
jeahrens is offline
post #14825 of 18041 Old 08-14-2019, 12:06 PM
alexr214's Avatar
Quoted: 16 Post(s)
Wow. Thanks for the link and the feedback. I am going to test the 17:9 and zoom on my current screen to see if I notice any issues. I highly doubt I will notice enough of an image issue that would sway me from the larger scope screen. At this point the image is so good, depending on the content, that we are just floored with the quality and color this puts out. I am anxious to at least do a gamma calibration for now since I love the image, but know we can tweak that contract to get it even better.
alexr214 is offline
post #14826 of 18041 Old 08-14-2019, 12:38 PM
aka jfinnie
Quoted: 2645 Post(s)
Liked: 1744
I would be nervous about using all your throw margin on assuming you will use the full width mode. If you only have 13ft and the calc says ~12'10" then you only have 2" spare. JVC have said in various places that these numbers are a guide only, and even had written on one of the N5/N7 brochures recently that the guides for throw were +/- 5%. -5% would see you unable to fill the screen and you wouldn't have zoom mode to fall back on (as you've already used that also).
If you do go for it, I'd suggest telling the supplying dealer your throw requirements and making them stand behind the JVC numbers as being good to go. Then you are fully covered if you can't fill your screen.
bobof is online now
post #14827 of 18041 Old 08-14-2019, 12:53 PM
Quoted: 58 Post(s)
Liked: 2
Hi guys,
On my rs2000 I’m getting three or so defined white lines curved not quite semi circular that stand out on white backgrounds like clouds. Don’t see it on black background or when pic has color. Any ideas what this might be and is it something I need to be concerned about. Thanks!
Ron
Ikemi is offline
post #14828 of 18041 Old 08-14-2019, 01:08 PM
alexr214's Avatar
Quoted: 16 Post(s)
Well I am going to go ahead and test the right size by trying the suggestions on my setup currently before I make any purchase. Granted I currently have a 110" 16:9 AR screen but I should be able to zoom on and test what size I get zoomed in using the 16:9, and 17:9 panel on 2:35 content to see where I land in terms of size. I can easily see the image on my walls if I throw up a solid white or colored image, and even just using the gridlines so I will test it out first for sure before I make any purchase. I can likely also get a sense of any scaling degradation to the image, at least for the portion thatch showing up on my current screen, to test out whether I like the zoom option. I appreciate the advice though on dealer requirements.
rjmcinnis likes this.
alexr214 is offline
post #14829 of 18041 Old 08-14-2019, 01:18 PM
jeahrens's Avatar
Liked: 1381
Bobof makes a very good point, however I think it was missed that you have 13.3' to work with. So that gives you a 4-6" margin to work with. Still close enough that putting the image up on the wall and actually measuring is definitely a good step.
jeahrens is offline
post #14830 of 18041 Old 08-14-2019, 01:37 PM
aka jfinnie
Liked: 1744
Whenever I see ~ i disregard a bit. You can't include that measurement uncertainty in the JVC margin! (eg screen surface held away from wall, wall not straight, etc)
I think certainly if you can get the PJ first then just work out how the throw of the actual unit works (and still consider to allow for if your unit has to be exchanged and you get one which is still in spec but has less throw).
bobof is online now
post #14831 of 18041 Old 08-14-2019, 01:43 PM
jeahrens's Avatar
Liked: 1381
No that's true and mixing percentages/decimals with ft. doesn't end up all that accurate in a lot of cases. Just trying to be optimistic. Actually measuring is going to be the best method here. Just hope it works out.
bobof likes this.
jeahrens is offline
post #14832 of 18041 Old 08-14-2019, 01:52 PM
SirMaster's Avatar
Quoted: 680 Post(s)
Liked: 410
I had this dilemma with my NX5 (achieveing the largest screen possible with my limited throw). I decided to leave about 5 inches of wiggle room. In the end, the NX5 was within an inch of what the online calculators said FWIW. I installed the projector, zoomed the image as large as possible from my mounting position (then made it perfectly rectangular), then shrunk the image by about 1" diagonally (for future wiggle room) and then built my custom screen to fit that size perfectly.
But I am certainly using the 17:9 zoom mode to get another 4-5 inches of width out of my screen which is nice.
SirMaster is online now
post #14833 of 18041 Old 08-14-2019, 02:13 PM
aka jfinnie
Liked: 1744
It's one of those situations I don't think optimism has much place - but then my screen was significantly more money than my X7900 new, so there was no 2nd chance option.
bobof is online now
post #14834 of 18041 Old 08-14-2019, 02:38 PM
wwtech's Avatar
Quoted: 36 Post(s)
Liked: 35
Originally Posted by asharma View Post
Thanks, r u able to tell me specifically what pattern that is? (name and under what section) I looked last night but couldn't find it...Thanks again...
oops... I still use the White Clipping Pattern from the HD set, not the UHD set.
The similar pattern is in:
01 Basic Setup Patterns
05 White Clipping
03 White Clipping 80-100%
It has what you need, unless you want to check light fall off at the 4 corners.
wwtech is offline
post #14835 of 18041 Old 08-14-2019, 02:52 PM
asharma's Avatar
Quoted: 1841 Post(s)
Liked: 579
05 White Clipping
Thanks, found it...getting about 100 nits...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is online now
post #14836 of 18041 Old 08-14-2019, 02:54 PM
asharma's Avatar
Liked: 579
Panny 820 Dynamic Range slider
Hi folks
For anyone using an N5/7/9 and a Panny 820/9000 with HD Optimizer ON, what r u finding u can move the dynamic range adjuster to before raising black floor? +2, +3? Thanks folks
post #14837 of 18041 Old 08-14-2019, 06:44 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6679 Post(s)
Liked: 6675
Originally Posted by Ikemi View Post
Hi guys,
Ron
Well your bringing it to our attention so I would say its concerning you and that is all that matters. I am assuming that is in all content? The bottom line is you are still within the warranty I would guess so if you want to use your unit and see what happens you have plenty of time. If you want to call JVC about it, you can, which might lead to an exchange if you are in the USA. Uniformity issues are present in all display devises, it can be worse, could be better. Its a roll of the dice and that's the scary part.
Cleveland Plasma is offline
post #14838 of 18041 Old 08-14-2019, 07:07 PM
TL5
TL5's Avatar
Quoted: 121 Post(s)
Liked: 52
I’m thinking of buying an NX7, but read a review that mentioned its upscaling left a bit to be desired. I watch a fair bit of sports and TV shows on the xfinity X1 platform on my Sony HW55es. Will the NX7 not perform well in this situation?
TL5 is online now
post #14839 of 18041 Old 08-14-2019, 07:23 PM
RickAVManiac's Avatar
Quoted: 354 Post(s)
Liked: 454
Originally Posted by TL5 View Post
I’️m thinking of buying an NX7, but read a review that mentioned its upscaling left a bit to be desired. I watch a fair bit of sports and TV shows on the xfinity X1 platform on my Sony HW55es. Will the NX7 not perform well in this situation?
I have the NX7 and beside movies, the only tv I watch is sport. I can confirm that the NX7 have no problem at all with tv upscaling. Something better do exist I agree, but the upscaling on the JVC is not weak in any way,
Before the JVC I was using a Sony 885. Sony is supposed to have one of the best scaling and the difference between the Sony and JVC for sport viewing are very minor. A poor signal is a poor signal even the best scaler cannot do miracle.
Until TV signal get better we would have to live with that, but for your movies watching you will be in heaven because the JVC NX7 perform really well.
Dandlj likes this.
RickAVManiac is offline
post #14840 of 18041 Old 08-15-2019, 04:46 AM
Quoted: 58 Post(s)
Liked: 2
Thanks Cleveland for the thoughts. The thing is though, as I understand it, I don’t think it’s a uniformity problem——it’s actually three distinct clear white lines that show up (wish it were clearer in my pic, sorry) almost as though something in light path causes that pattern just on that one small part of screen. Otherwise I think my white and color field uniformity is pretty good. My dealer is coming to finish off a bit of work on my installation so I guess I will show him and go from there. Thanks again for your opinion on this.
Ron
Ikemi is offline
post #14841 of 18041 Old 08-15-2019, 05:39 AM
markmon1's Avatar
Quoted: 5231 Post(s)
Liked: 3400
Hi guys,
Quick question—- on my rs2000 I’m getting three or so defined white lines curved not quite semi circular that stand out on white backgrounds like clouds. Don’t see it on black background or when pic has color. Sorry don’t have pics of it right now. Any ideas what this could be and should I worry about it i.e. ask dealer for replacement projector——everything else seems to be working fine so far. Thanks.
Ron
Show a photo?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #14842 of 18041 Old 08-15-2019, 05:43 AM
markmon1's Avatar
Liked: 3400
Hi guys,
Ron
I see like 4 or 5 lines in your photo. Its almost like some lens reflection (the lens is round). Is that centered on where your lens hits the screen? Is your lens dirty at all?
markmon1 is offline
post #14843 of 18041 Old 08-15-2019, 05:48 AM
markmon1's Avatar
Liked: 3400
NVC's upscaler isn't terrible. It's just standard. That content will look "fine". It won't look 4K. I didn't think Sony's upscaler was any good either. I liked its reality creation processing but never thought it upscaled 1080p content to take on any aspects of 4K. A good upscaler can make 1080p content look a lot like 4K. So far, the only "good" upscaler I've ever seen is madVR's A/I Neural network trained upscaler.
markmon1 is offline
post #14844 of 18041 Old 08-15-2019, 06:11 AM
asharma's Avatar
Liked: 579
Hi folks
Any input would be appreciated folks...Thanks kindly
post #14845 of 18041 Old 08-15-2019, 09:26 AM
Quoted: 4884 Post(s)
Liked: 1848
The Dynamic Range Adjustment control does not touch the black level at all. See the measurements from Stacey Spears:
https://www.avsforum.com/forum/139-d...l#post58417332
Dominic Chan is online now
post #14846 of 18041 Old 08-15-2019, 10:04 AM
Quoted: 50 Post(s)
Hi all, whar is the input lag on n7/nx7 with cmd?? I hve tried to search the thread without luck.
Jonathan Schwabe is offline
post #14847 of 18041 Old 08-15-2019, 10:23 AM
asharma's Avatar
Liked: 579
Thanks buddy...wholly crap...tooooo technical for me...what I found was as I adjusted the Dynamic range slider on the Panny 820, the black level rose around 3 or 4 as bar 68 became more visible...I have my JVC brightness set to -2 and contrast set to 7 (clips at 1000 nits according to R.Masciola patterns)...
Does any of this “sound” right?
post #14848 of 18041 Old 08-15-2019, 11:11 AM
Quoted: 58 Post(s)
Liked: 2
Hi markmon
I too thought it looked like a lens reflection. Can’t tell just looking at the outer lens if it’s dirty or not. Everyone says to avoid cleaning outer lens if at all possible so I have avoided that so far. Do you think it would be worth giving the lens a cleaning and how would you suggest doing that safely. Thanks!
Ron
Ikemi is offline
post #14849 of 18041 Old 08-15-2019, 11:28 AM
seanbryan's Avatar
Quoted: 283 Post(s)
Liked: 175
Hi markmon
Ron
Did you confirm that it isn’t your screen? You probably did, but if you haven’t I’d recommend confirming that first before additional troubleshooting.
If you can pause an image that shows the issue, try flipping and/or inverting the image. That might help clarify if it is something in the lens (which shouldn’t change) or something in the image itself.
seanbryan is offline
post #14850 of 18041 Old 08-15-2019, 11:32 AM
Liked: 1848
Level 68 becoming more visible is not unexpected when you increase D.R.A. I was replying to your original question, i.e., D.R.A. should not “raise black floor” which is level 64.
Jvc , nx7 , nx9 , rs2000 , rs3000
