Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 500 - AVS Forum | Home Theater Discussions And Reviews
 15442Likes
post #14971 of 16562 Old 08-19-2019, 09:39 AM
Mike Garrett's Avatar
Quoted: 12317 Post(s)
Liked: 9934
Originally Posted by jj-34 View Post
I could get the fabric as a 2 x 3 m (78" x 118") fabric only that would suit my current DIY motorized screen including the tension tabs, but it costs 1149 €uros ( ~ $1025) including shipping from Norway, a bit expensive just now, reason why I seek opinions.
And by the way is it actually suited as a tensioned motorized fabric, have not seen any mention of it on their web site.
DreamScreen, just has not designed an electric screen, but no reason you could not do so with this fabric.
Mike Garrett is online now
post #14972 of 16562 Old 08-19-2019, 09:42 AM
Liked: 9934
Originally Posted by reechings View Post
Considering the NX-5 and just wondering about any known issues/limitations. I do like the idea of a native 4K projector compared to Pixel shifters but a little apprehensive because this model is the entry level one. Planning to use a 135" 16:9 screen in a light controlled environment (darkish walls but not velvet at this point) sitting about 11-12 ft away. Would like to be able to have a little bit of light in the room when watching sports and do like a fairly bright picture if possible but hoping I wouldn't have to be running in high lamp mode all the time. Thanks!
Sent from my Pixel 2 XL using Tapatalk
I assume you are talking solid, not AT screen? If so, I would recommend 1.3 gain, then you would have good brightness.
post #14973 of 16562 Old 08-19-2019, 09:54 AM
asharma's Avatar
Quoted: 1816 Post(s)
Liked: 565
Originally Posted by jeahrens View Post
Yes but when you change to zoom are you going into the lens setup and changing the zoom/focus to compensate for the wider image? Shrinking the overall image to fit the now wider picture into the existing width should have a discernible bump.
Ahhhhhh, got it!!! I'll need to try that!!!! Thanks to everyone above also who tried to straighten me out...I get it now...
Charlie_L likes this.
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820
Triple black velvet batcave
asharma is online now
post #14974 of 16562 Old 08-19-2019, 10:54 AM
Pultzar's Avatar
Quoted: 220 Post(s)
Liked: 125
Originally Posted by dlinsley View Post
With the gear adjustment version, I'm having no issues. It hasn't moved since I re-hung my RS3000+DCR back in May, including across that small earthquake we had in early July.
I believe I have the gear adjustment version. It tilted down while I was messing with the DCR. Maybe I just need to get the screws tighter
Pultzar is online now
post #14975 of 16562 Old 08-19-2019, 11:31 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6589 Post(s)
Liked: 6587
Originally Posted by Josh Z View Post
I moved my NX7 off the shelf mount and up to the ceiling mount this weekend. I guess that means it's a keeper.
As of today, for the same pricing, I do not think you would find something better......
That is probably the case then, or that screw could be stripped.
Cleveland Plasma is online now
post #14976 of 16562 Old 08-19-2019, 12:51 PM
majicx's Avatar
Quoted: 33 Post(s)
Liked: 25
I came from a 3-1/2 year old RS400 (has eshift) on a 137 in 16:9 screen. Received my NX5 about 2 months ago and I am blown away by the difference. My friends and family agree.
majicx is offline
post #14977 of 16562 Old 08-19-2019, 01:10 PM
reechings's Avatar
Quoted: 87 Post(s)
Mostly in regards to sharpness? My understanding is that as far as light output and contrast your old projector and the NX-5 should be comparable?
reechings is offline
post #14978 of 16562 Old 08-19-2019, 01:27 PM
Craig Peer's Avatar
Quoted: 6866 Post(s)
Liked: 8097
Sharpness, processing, HDR - the RS1000 JVC brought over to demo in my theater looked sharper and cleaner picture wise than my previous RS600. It looked similar in many ways to my RS4500. But not that close - I'll be keeping my RS4500 thank you !
Manni01 likes this.
Craig Peer is offline
post #14979 of 16562 Old 08-19-2019, 02:03 PM
Quoted: 55 Post(s)
Liked: 2
Hi guys,
Quick probably stupid question. After doing a whole pixel adjust on rs2000, do you have to leave the adjust setting to on for adjustments to be used or can the adjust setting be turned to off and whatever adjustments were made while adjust was on are used. Thanks
Ron
Ikemi is offline
post #14980 of 16562 Old 08-19-2019, 02:05 PM
majicx's Avatar
Quoted: 33 Post(s)
Liked: 25
My RS400 was calibrated by CHADB so I feel he had it set to its limitations. I think the NX5 is brighter, sharper and has more contrast. I am on his schedule to this one done. Still out of the box this one is a BIG difference.
reechings likes this.
majicx is offline
post #14981 of 16562 Old 08-19-2019, 02:20 PM
majicx's Avatar
Quoted: 33 Post(s)
Liked: 25
I forgot to add I sold my OPPO 203 and replaced it with the PANNY UB9000. I set them up with instructions from VALUE ELECTRONICS. WHich I would recommend.
Clark Burk and Craig Peer like this.
majicx is offline
post #14982 of 16562 Old 08-19-2019, 02:30 PM
reechings's Avatar
Quoted: 87 Post(s)
Yeah my main worry is brightness since I do want the HDR to pop and maybe have lights on a little bit for sports etc. I would prefer not to run high lamp all the time unless it isn't too loud. I'm guessing contrast is still going to kick butt on Epson 6050.
post #14983 of 16562 Old 08-19-2019, 02:33 PM
reechings's Avatar
Quoted: 87 Post(s)
Also I was planning to get an Elunevision reference 4k screen slim but it is only 1.0 gain and it sounds like getting a custom order for 1.3 will add quite a bit of cost.
post #14984 of 16562 Old 08-19-2019, 02:41 PM
Quoted: 4778 Post(s)
Liked: 1789
Originally Posted by Ikemi View Post
Hi guys,
Quick probably stupid question. After doing a whole pixel adjust on rs2000, do you have to leave the adjust setting to on for adjustments to be used or can the adjust setting be turned to off and whantever adjustments were made while adjust was on are used. Thanks
Ron
If the setting is off then the adjustments are not used.
Dominic Chan is online now
post #14985 of 16562 Old 08-19-2019, 03:23 PM
reechings's Avatar
Quoted: 87 Post(s)
Yeah solid screen. Any recommendations for 135" 1.3 gain screen for Canada? Thanks
post #14986 of 16562 Old 08-19-2019, 03:24 PM
Quoted: 55 Post(s)
Liked: 2
Hi guys,
Have another newbie question. I want to try the zoom function in installation modes to use full panel while watching wider aspect ratios (ie. My screen is 16:9). How exactly do I do this to get increased light. Do I just turn aspect ratio from native to zoom or is there something else I need to do in addition to that. Thanks
Ron
Ikemi is offline
post #14987 of 16562 Old 08-19-2019, 03:25 PM
Quoted: 55 Post(s)
Liked: 2
Thanks for that Dominic—-that’s what I thought but just wanted to make sure.
Rob
Ikemi is offline
post #14988 of 16562 Old 08-19-2019, 03:48 PM
asharma's Avatar
Liked: 565
Originally Posted by markmon1 View Post
You shouldnt need to physically unplug cables. Both displays should be unplugged and the anthem off to start. Power on only one display leaving the other unplugged. Then power on anthem. It should show video on the one display. To switch displays, power off the active one, power off the socket, power on the new display socket, power on the display, then perhaps power cycle anthem. This is how I managed my 2 projectors last year with the anthem.
No dice...3 smart plugs, tv, pj, anthem...both monitor outs connected, all plugs off...switch pj plug on, switch anthem plug on, play hdr movie on pj...all good...power down pj, switch off pj plug, power down anthem, switch anthem plug off...switch anthem plug on (enables tv pass thru when in standby) switch tv plug on, turn tv on, no video to tv...
Edit: switched monitor outs (1 to 2 and 2 to 1) still no dice...Pj will fire up fine with both monitor outs connected, but tv will not with both monitor outs connected, have to physically unplug the pj monitor out to get tv to fire up...
post #14989 of 16562 Old 08-19-2019, 03:59 PM
jj-34's Avatar
Quoted: 177 Post(s)
Liked: 58
I received a reply from them (Jon) and no, it is not suitable for tensioned electric screens as it requires too much side tension only possible with fixed frames.
jj-34 is online now
post #14990 of 16562 Old 08-19-2019, 04:44 PM
Jmouse007's Avatar
Quoted: 229 Post(s)
Liked: 191
I tried that with my Onkyo 1100. I was using Rupro 40' fiber optic to RS1000 and 12' premium certified HDMI to TCL TV. Would work intermittently. Also tried RS640 and same results. If I used 6' premium certified cables to the TV and the projector, they worked every time. I ended up replacing the rupro cable with Atlona HD Base T system.
Question: I currently have an ONKYO RZ5100 A/V Preamp, which is ONKYO's present flagship preprocessor. The HDMI run to our 1080p projector is approximately 25 feet. We have never had any connectivity issues from the preamp.
Based on your experience and information, when switching to a JVC 4K projector, will my ONKYO Preprocessor be able to handle this run using a Rupio optical HDMI cable or am I going to have "connectivity issues" and have to go another route to make it work?
Jmouse007 is offline
post #14991 of 16562 Old 08-19-2019, 05:17 PM
Liked: 1
Originally Posted by asharma View Post
You are 100 percent correct, the output is just split...I have a wall switch which totally kills power and therefore standby mode to the pj...Still can't get vid on tv without physically unplugging an hdmi monitor out...Also the 50 ft hdmi run to the pj is active BUT I think ive tried both active and inactive...Any other thoughts or things I could try? Thanks again
Hey, I have the exact same issue with my setup on the RS1000 and my Sony 65" 900e.
-My Problem-
My Denon 4500H on 'auto' screen select can't work out what to output, If I have the Apple TV on and the Sony TV on and I want to switch to the PJ, I turn off the TV which also then turns off the Apple TV, and the PJ says no input. If I turn the apple TV back on, it turns the PJ off and turns the TV on. From time to time it will display the Apple TV on both the PJ and the Sony simultaneously - So turn off the TV, which turns off the Apple TV and we start the Cycle again and again.
I have been through the manual unplugging etc to try to isolate the culprit, disabled CEC on everything (btw Apple TV turns this back on by itself each update), changed from Optical HDMI cables to short normal cables, different ports.
-FIX-
The fix is easier than you think, and relatively painless.
Set the output manually on the amp, its the only way to effectively change without unplugging or de-powering anything.
For easier, buy a Logitech Harmony (~$30), and code the button combo on the amp into the remote as the Logitech can perform step changes. I have two programs, switch from TV -> PJ, and switch PJ -> TV. Only downside is you have to keep the harmony pointed at the receiver until it complete the steps.
For an even easier option without buying an additional remote is see if there is an app from an iOS or Android device and change it in the app - Denon AVR app on iOS can switch the output from TV to PJ.
I wish my Denon remote had was an output button, as my old Yamaha Aventage did.
Not an ideal fix (as I was blaming the Denon as my old Yamaha didn't do this), but I hope this helps.
Cheers,
Dave
dlambe is offline
post #14992 of 16562 Old 08-19-2019, 05:34 PM
asharma's Avatar
Liked: 565
-My Problem-
-FIX-
Cheers,
Dave
Thanks...on the Denon, can you choose what monitor out to use (1 or 2?)...i “don’t” think the Anthem has that capability...perhaps someone can correct me if I am wrong...
post #14993 of 16562 Old 08-19-2019, 06:19 PM
savefarris's Avatar
Quoted: 24 Post(s)
Liked: 41
I have an NX5, projecting onto a 110" from 14 feet. If you can see from the attachment, there is approximately 7 inches of clearance on each side of felt edges of the screen. I was thinking of moving up to a 120" screen, which would be a tight fit and only leave about 1-1.5" on each side beyond the felt borders of the screen. Is there any reason why I should not move up to a bigger screen, would the edges of the screen being too close to the side walls? Do i need to leave a set amount of clearance, or it is ok to go right up against the other walls?
savefarris is offline
post #14994 of 16562 Old 08-19-2019, 08:19 PM
Liked: 9934
The problem is not the JVC. The problem is the Onkyo, per my discussions with Onkyo. The Onkyo and I suspect the Anthem have a problem powering both outputs for long distance at 18Gbps. Like I said, I could connect the TV and the projector using 6' premium certified HDMI cables and completely issue free, but as soon as I use long cables (50' Rupro) and 12' premium certified to TV, issues galore. If all you are doing is connecting a 25' premium certified HDMI cable to the projector and not using the second HDMI output, you probably will not have any problems, though you would need to test to know for sure.
post #14995 of 16562 Old 08-19-2019, 10:08 PM
avsBuddy's Avatar
Quoted: 139 Post(s)
Liked: 86
Hi guys,
Ron
You leave adjustment setting on. What were you hoping to achieve by turning in off?
avsBuddy is offline
post #14996 of 16562 Old 08-19-2019, 10:39 PM
Jmouse007's Avatar
Quoted: 229 Post(s)
Liked: 191
Thank you for the answer. I will be using a single HDMI run to the projector when the time comes so hopefully it will work. We shall see.
By the way, what is a "Atlona HD Base T system"? Can you provide me with a link so that I, along with others can research it as an option if needed, thanks in advance.
post #14997 of 16562 Old 08-20-2019, 01:15 AM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 195
Just got an alert from JVC Japan; FW2.08 has been released and is now on the support site
Purple X is offline
post #14998 of 16562 Old 08-20-2019, 01:16 AM
markmon1's Avatar
Quoted: 5057 Post(s)
Liked: 3285
On a 135" 16x9 you will have plenty of light. This is the same screen I have. I've always run my JVC's always on low lamp and low lighting for sports is fine.
Edit: and you do not need a 1.3 gain screen for this size. 1.0 is just fine. I have a 1.0 gain screen and have always run low lamp on all my JVC machines in here. You get about 1250 lumens on low lamp on JVC which will be fine for you. For HDR you may want to kick into high but good tone mapping you can get away with running on low also. On all projectors, HDR is not going to pop like a TV. But really good tone mapping can make it look pretty good.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #14999 of 16562 Old 08-20-2019, 01:18 AM
markmon1's Avatar
Liked: 3285
-My Problem-
-FIX-
Cheers,
Dave
Anthem HDMI is a passthrough device. You cannot set the output in the amp.
markmon1 is offline
post #15000 of 16562 Old 08-20-2019, 01:28 AM
jj-34's Avatar
Quoted: 177 Post(s)
Liked: 58
One has to remember that even with fiber optic cables there are still a number of copper cables within those cables and that is not completely free as far as length is concerned, that may explain that.
jj-34 is online now
Jvc , nx7 , nx9 , rs2000 , rs3000
