Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 579 - AVS Forum | Home Theater Discussions And Reviews
 16735Likes
post #17341 of 18088 Old 10-10-2019, 06:24 AM
Mike Garrett's Avatar
Quoted: 12543 Post(s)
Liked: 10160
Originally Posted by Tom899 View Post
Just wondering?
I updated my RS1000 to 3.1 from 2.08. I thought with v2.08 and below the green LED in the front stayed on in normal viewing mode. With v3.1, the green LED comes on during start-up, and then is off during normal viewing.
Am I imagining it was on during normal viewing with the older firmware's?
No, green LED has always turned off, once projector is started. So red in standby. Green when power button is pushed and goes to off, once started.
seanbryan likes this.
Mike Garrett is offline
post #17342 of 18088 Old 10-10-2019, 06:26 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6684 Post(s)
Liked: 6681
Originally Posted by rwestley View Post
Panasonic should also include source direct as an option. I wonder if Panasonic was caught by surprise by the JVC firmware. This can't make them happy as there is no need for the Panasonic at this point.
If you have an Oppo 203 or other source direct unit it might be a better option at this point.
I was thinking the same thing, is the Panasonic player even worth buying at this point. I would think the cash could be put to better use else where......
Cleveland Plasma is offline
post #17343 of 18088 Old 10-10-2019, 06:28 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Is there no way to have two different Rec2020 color profiles to use the color filter? I have my Rec2020 setup for MadVR and I was going to try the new DTM settings which I assume uses the default Rec2020 with filter color profile when you set it to "wide color space" , but there doesn't seem to be a way to make a custom color profile that has the filter engaged to keep separate for other profiles?
grendelrt is offline
post #17344 of 18088 Old 10-10-2019, 06:28 AM
Quoted: 4884 Post(s)
Liked: 1849
All the recent JVC projectors behave the same way. You do not want the green LED to stay on during viewing, as the light can “pollute” the picture.
seanbryan and Manni01 like this.
Dominic Chan is online now
post #17345 of 18088 Old 10-10-2019, 06:29 AM
Killroy's Avatar
Quoted: 539 Post(s)
Liked: 437
Originally Posted by Dominic Chan View Post
Unless the lamp or filter settings are different between User 1 and User 2, you cannot have independent gamma calibrations on the two.
Then why does the software have this specific option in Gamma calibration? Am I mis-understanding the purpose of it?
EDIT - OK, I see the caveat. Interesting. I will have to test further to see how I can detect a difference.
Killroy is offline
post #17346 of 18088 Old 10-10-2019, 06:35 AM
Tom899's Avatar
Quoted: 175 Post(s)
Liked: 81
Just wondering?
Thanks everyone, my mistake thinking it was on
Pioneer UDP-LX500 | Denon AVR-X4400H | Emotiva A-300 2ch amp | Emotiva PA-1 monoblock | JVC DLA-RS1000 Projector | Mini DSP 4x2 | Dune HD Smart D1 | ZIDOO Z9S | Buttkicker system | HSU VTF-3 MK4 subs(2) | HSU MBM-12 MK2 Mid bass module | Klipsch RP-8000F(2) | Klipsch RP-504C | Klipsch RS-62 II(2) | Polk RC80i Ceiling(4) | Carada 134” screen | unRAID 40TB
Tom899 is offline
post #17347 of 18088 Old 10-10-2019, 06:37 AM
Liked: 1849
If you read the note that you just posted, under Individual it clearly says
However, even another Picture Mode has been selected, the calibration result is reflected if the setting values of Lamp Power and Filter are the same.
The Reflect to All option is used when you want the same gamma calibration to apply regardless of Lamp Power and Filter settings.
Manni01 likes this.
post #17348 of 18088 Old 10-10-2019, 06:41 AM
Liked: 1849
Not sure what I missed. Why can’t you have a custom profile that has the filters engaged?
post #17349 of 18088 Old 10-10-2019, 06:46 AM
rramacha's Avatar
Quoted: 157 Post(s)
Liked: 46
Hello All
I was wondering if any one had a solution for this.
I am not sure where to post this. If this is not the right place, please let me know.
I have JVC NX7 connected to AV 8805 feeding Strato. When ever I select a scene to play (HDR or not), there is a black screen for like almost 30 seconds before it shows me the content. Audio starts to play from the start. Is there any thing I am doing wrong from settings perspective.
This never happened with Epson 9700UB.
Cheers
Raj
rramacha is offline
post #17350 of 18088 Old 10-10-2019, 06:48 AM
Killroy's Avatar
Quoted: 539 Post(s)
Liked: 437
HA! My Type A OCD has finally paid off!!! I had done screen captures of my meter readings when I did both readings. The first reading is from the V11 reading from about 2 weeks ago with Spyder5. The second one is from the V12 with SpyderX. The only thing that has changed between the two is the software and the meter (and how the meter was placed, the Spyder5 facing projector while the SpyderX is facing screen from 12").
Spyder5
SpyderX
David Mathews likes this.
Killroy is offline
post #17351 of 18088 Old 10-10-2019, 06:49 AM
riddle's Avatar
Quoted: 156 Post(s)
Liked: 69
I did a gamma cal on V12 with Spyder X (color with i1Pro2) for User 1 and still have my V11 gamma/color with Spyder5 (i1Pro2 color) on user 2 and the brightness is absolutely the same. Used a Lumu Pro light meter to test the output on 100% white.
Make sure your SpyderX is about 12" from screen and set on the lower end so you can point it slightly up to keep the shadow out of the way (too close to center and the shadow is in the angle of the lens view).
The only difference I found was that the SpyderX is incredibly faster than the Spyder5. So much faster that I thought it had done something wrong. BTW, color cal also seems faster on the i1Pro2 but I did not time it so I may be wrong.
2nd BTW...JVC AutoCal is amazing.
Can you make some photos how you with placement SpyderX?
riddle is offline
post #17352 of 18088 Old 10-10-2019, 06:53 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
I am probably just missing something easy here, but the BT2020 profile has the filter by default (which is set up for MADVR for me), but when I go to pick a profile that I want to build with the filter that isnt that one, I would need to use Custom. When you pick custom, there isn't an option inside the menu to pick BT2020 as the space or to engage the filter that I can see. (Pics attached)
ID:	2626160   Click image for larger version
post #17353 of 18088 Old 10-10-2019, 07:01 AM
Liked: 1849
You need to first create the custom profile and specify Wide at creation time. You cannot turn the filter on/off when using it.
The filter on/off has nothing to do with CMS on/off.
post #17354 of 18088 Old 10-10-2019, 07:03 AM
Killroy's Avatar
Quoted: 539 Post(s)
Liked: 437
Like I said, my Type A OCD knows no bounds and I document almost everything via pictures....lol
Both are 12" from screen but the angle of picture is different to show the magic arm. The SpyderX is pointed slightly up to make sure that pesky shadow is out of the angle of the lens. Not sure how wide the lens is so I did not want to take chances. The i1Pro2 is very narrow so I just kept it at the same angle as the SpyderX but that may change later if I find that my readings change with different angles.
ID:	2626166   Click image for larger version
riddle likes this.
Killroy is offline
post #17355 of 18088 Old 10-10-2019, 07:07 AM
Clark Burk's Avatar
Quoted: 712 Post(s)
Liked: 661
Originally Posted by Kris Deering View Post
I said it before, I would NOT use Auto. In my testing it would not give nearly as good of a result. Now the choice to use Low, Med, High probably comes down to your screen size, light output and what you are watching. In MY setup, I found HIGH gave the best image in most cases, but Med was better with REALLY high level content (like The Meg). But my screen is on the larger side so my peak white is in the mid-20's. Those with really bright setups may find med or low to be better. Unfortunately there is nothing in this picture mode that gives you the opportunity to inform the JVC how much brightness you are using.
Kris, I noted in the new firmware manual that the Auto setting uses MaxCLL/FALL to determine the HDR setting. Would this possibly work well with the Panasonic players Optimizer since that would send a tone mapped signal with a new lower MaxCLL/FALL setting allowing the JVC to dynamically tone map a smaller range? I know you had said you thought double tone mapping using both the Optimizer and the JVC DTM was not a good idea but I was wondering if you tried it with the Auto setting? I can see where using it with L,M,or H might lead to issues.
Edit: Disregard. I looked back over this quickly moving thread and found my probable answer. Auto is still using DTM just selecting one of the three options based on the dics data. No optimizer and L,M,or H is the preferred way to go.....
Clark
Clark Burk is offline
post #17356 of 18088 Old 10-10-2019, 07:14 AM
gravi's Avatar
Quoted: 380 Post(s)
Liked: 202
Originally Posted by rramacha View Post
Hello All
Cheers
Raj
The handshake delay over HDMI is well known but it should not be 30 seconds, that is excessive.
rramacha likes this.
gravi is offline
post #17357 of 18088 Old 10-10-2019, 07:16 AM
gravi's Avatar
Quoted: 380 Post(s)
Liked: 202
I thought it was determined that, at least for UHD sources, turning off HDR optimizer and zeroing out all picture controls will pass 4K HDR signal as is, so no need for a source direct mode.
Agree that a cheaper player can do the same job if you are not tone mapping.
gravi is offline
post #17358 of 18088 Old 10-10-2019, 07:18 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Are you referring to creating something in autocal? Or the normal built in menus? Sorry my first JVC,still learning where everything is stored. If it is in autocal can you create that without running a color calibration?
post #17359 of 18088 Old 10-10-2019, 07:18 AM
gravi's Avatar
Quoted: 380 Post(s)
Liked: 202
Originally Posted by neb04 View Post
A newbie question - Looking at the Picture Mode menu, I see HDR10 mode is still present. Doesn't the new Frame Adapt HDR mode make HDR10 mode superfluous, or is there still a use for it with certain sources? TIA.
You still have the option to use static tone mapping using the HDR10 mode if one wants to. No harm, it is still an option.
gravi is offline
post #17360 of 18088 Old 10-10-2019, 07:24 AM
BondDonBond's Avatar
Quoted: 736 Post(s)
Liked: 663
Originally Posted by Cleveland Plasma View Post
Absolutely
Still feel you need the Panasonic Player?
No,because basically sending raw video to it. As long as it is a good player I can't see spending the extra on a 9000 or 203.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #17361 of 18088 Old 10-10-2019, 07:32 AM
Liked: 1849
You create custom profiles using Autocal. No actual calibrations are required.
Why do you want to have a custom colour profile in the first place?
post #17362 of 18088 Old 10-10-2019, 07:34 AM
Quoted: 736 Post(s)
Liked: 663
NX7/NX9 people have you switched the new firmware to Wide vs normal?
I did an for my setup the brightness did not change but the colors had additional pop.
post #17363 of 18088 Old 10-10-2019, 07:42 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 308
Thanks , that's very helpful. I went to calibrate the new dtm mode using the hdr profile that Kris suggested but it was tracking slightly different than the rec2020 setting I had in madvr , I just wanted to make a second profile to play in without having to mess with my current profile and to use for comparison.
post #17364 of 18088 Old 10-10-2019, 07:55 AM
rwestley's Avatar
Quoted: 460 Post(s)
Liked: 300
It could be a cable issue that is causing the delay.
rwestley is offline
post #17365 of 18088 Old 10-10-2019, 07:55 AM
ScottieBoysName's Avatar
Quoted: 1284 Post(s)
Liked: 431
There is still a possibility that the Panasonic will be updated they FW and ad some new options for JVC DTM, what i hear Panasonic work with JVC on this inovation....
So, right now when using the JVC DTM, I should disable the Panny Optimizer. Correct?
ScottieBoysName is offline
post #17366 of 18088 Old 10-10-2019, 07:58 AM
Frohlich's Avatar
Quoted: 2059 Post(s)
Liked: 2270
Correct.
Frohlich is offline
post #17367 of 18088 Old 10-10-2019, 07:58 AM
Liked: 431
I think most people still agree that the Panny is the best at upconverting 1080P BRs still - correct? Maybe not worth $500 for that though.
post #17368 of 18088 Old 10-10-2019, 08:00 AM
Liked: 431
Originally Posted by Frohlich View Post
Correct.
Allllrighty then. I’ll report back.
post #17369 of 18088 Old 10-10-2019, 08:00 AM
Liked: 10160
Wide will be with the color filter in place. Small drop in brightness..
post #17370 of 18088 Old 10-10-2019, 08:03 AM
David Mathews's Avatar
Quoted: 423 Post(s)
Liked: 423
good usage of OCD!
Hopefully others can duplicate your results, nice work :-)
not sure if it matters, but
what type screen material and gain?
from pic looks like angle of incidence reflected off screen ends up below projector? or did it end up being at lens?
does V12 have similar sensor box for meter placement and at 12 inches it was close to maxed out?
Dave
David Mathews is offline
Jvc , nx7 , nx9 , rs2000 , rs3000
