Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 788 - AVS Forum | Home Theater Discussions And Reviews
 25130Likes
post #23611 of 28583 Old 02-14-2020, 09:28 PM
SirMaster's Avatar
Quoted: 1353 Post(s)
Liked: 1008
Originally Posted by rowdyt View Post
i just recently got my RS2000 up and running. While playing HDR content I am seeing a weird issue where the edges of objects are bright white / bright yellow etc. and don’t match the rest of the picture at all. Something is clearly wrong and I am wondering if anyone here knows what it is.
When I pause playback it’s not there, but it’s there and very distracting while playing. I took a video of it with my phone and then took screenshots of the video... I then added arrows to call attention to what I’m talking about.
Anybody else experience this? Know what the fix is?
Yes, turn off Motion Enhance. It’s an artifact of the panels being overdriven by that.
SirMaster is online now
post #23612 of 28583 Old 02-14-2020, 09:31 PM
rowdyt's Avatar
I will try that, thanks!
Edit: That did the trick, thanks again. 👍
Todd G. and skylarlove1999 like this.
rowdyt is offline
post #23613 of 28583 Old 02-14-2020, 09:56 PM
tommarra's Avatar
Quoted: 1016 Post(s)
Liked: 597
Not sure if Arrow-AV still reads this thread but this issue and fix should be on the first page
skylarlove1999 likes this.
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 684S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Arcam AV40 + Monoprice Monolith 7x200 + Outlaw 7000x | Projector: JVC NX7 | Screen: 126 inch 16:9 Stewart Studiotek 130 G4 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #23614 of 28583 Old 02-15-2020, 02:46 AM
asharma's Avatar
Quoted: 2354 Post(s)
Liked: 867
Originally Posted by Aztar35 View Post
You have that St100, a cool cat screen. ..just curious?
Yes I do...LOVE it...it’s hard to describe...the complete lack of texture and phenomenal uniformity makes me perceive a sharper brighter punchier picture...
Video:JVC NX7, 125” 2.35 Stewart ST100 Electric, Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b, 25s, Dual SVS SB3000
Receiver/Amp: Anthem 1120, Emotiva XPA-11 Gen 3
Source: Panasonic UB820, Triple black velvet batcave
asharma is offline
post #23615 of 28583 Old 02-15-2020, 03:30 AM
Franin's Avatar
Quoted: 3675 Post(s)
Liked: 2607
Originally Posted by Craig Peer View Post
I have a ton of movie to catch up on - probably 20 at least. Hope the fires are under control now !
They seem to be under control from what I’ve heard.
God Bless!
A good way to test your Iris on your projector is on the Spears and Munsil disc. Go to Video processing then select Luminance Loading. Don't stare directly at the lens but on an angle and you can actually see the Iris at work.
Franin is offline
post #23616 of 28583 Old 02-15-2020, 04:06 AM
jj-34's Avatar
Quoted: 351 Post(s)
Liked: 113
Originally Posted by Cleveland Plasma View Post
You building a hush box?
No hush box, but I am fortunate to have a small attic ( or large cabinet ) behind the back wall, and I plan to move the projector into it and make a small hole thru the wall just big enough to accomodate a 5" PVC "lens tube"
2 reasons, one is to care for the high lamp noise and displace the PJ's hot air away from the main viewing area, second is to be able to lower the projector ( I can go as low as vertical lens shift 15 % and horizontal 0) and thus a better central zone of the front lens.
jj-34 is offline
post #23617 of 28583 Old 02-15-2020, 07:47 AM
Cleveland Plasma's Avatar
Quoted: 7622 Post(s)
Liked: 7694
Originally Posted by baronzemo78 View Post
We need more pictures of hush boxes. I'm planning on building one as well. I was going the route of Edmunds optical class in the front port and an AC Infinity T6 pulling air out the top front of the hush box and 6" duct going into the top back. Do you think that is enough ventilation or would another AC infinity S6 blowing air in the back be needed? I was thinking of internal box dimensions of 13.5" high by 30" long by 27" wide. Does that seem about right?
Most guys use computer fans, that seems like a wsy cheaper and more effective solution...
Cleveland Plasma is offline
post #23618 of 28583 Old 02-15-2020, 09:00 AM
Quoted: 13 Post(s)
Liked: 0
which colour profile are you guys using on your rs-1000?
bt.709 for sdr is a no brainer i guess
but hdr or dci for hdr content?
what option are you using on your madvr display calibration setting (bt.2020 or dci) when viewing hdr?
thanks a lot!
malicedr is offline
post #23619 of 28583 Old 02-15-2020, 10:03 AM
kemannthey's Avatar
Quoted: 78 Post(s)
Liked: 38
Looking into JVC nx5/7 A bit. I keep reading to get max contrast you close an iris?
How many lummens are there at max contrast?
This manual iris is the same as using a nutrual density filter to achieve a given foot lamberts or something else?
Also in a batcave theater that you can't see your hand in when the lights are out does the nx5 or nx7 support a fade to back effect where you eyes have to adjust on all black scenes?
kemannthey is offline
post #23620 of 28583 Old 02-15-2020, 10:15 AM
rads03's Avatar
Quoted: 80 Post(s)
Liked: 40
im trying to decide between nx5 and nx7 to upgrade current 57u. is anyone using either for gaming (pc) and if so, is one of the two projectors significant better for that?
Pray for all of our healthcare providers who are doing their best at great risk to help us survive the current Covid-19 virus crisis.
rads03 is offline
post #23621 of 28583 Old 02-15-2020, 10:31 AM
Mike Garrett's Avatar
Quoted: 14011 Post(s)
Liked: 11684
Computer fans, cheaper yes, but not even close in which system is more effective. With the AC Infinity S6, I would not be worried about airflow. With computer fans, I would be very concerned with airflow/box temperature.
Mike Garrett is online now
post #23622 of 28583 Old 02-15-2020, 10:35 AM
Liked: 11684
thanks a lot!
You only use DCI if you are feeding the projector DCI content. HDR content is not DCI content. Use HDR mode.
post #23623 of 28583 Old 02-15-2020, 10:36 AM
skylarlove1999's Avatar
Quoted: 2276 Post(s)
Liked: 2431
Thanks Mike. Appreciate the clarification. What would be an example of DCI content, if you don't mind.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #23624 of 28583 Old 02-15-2020, 11:02 AM
Liked: 11684
Hollywood screening rooms, showing commercial canned movies. The stuff in commercial theaters is DCI.
post #23625 of 28583 Old 02-15-2020, 11:18 AM
Liked: 2431
Ah I see. Thanks again.
post #23626 of 28583 Old 02-15-2020, 01:12 PM
Liked: 7694
I was pointing out the hush boxes I have seen, I have not seen a hush box with the S6.
Any pics of that setup?
@blake , we will be waiting for those pics
post #23627 of 28583 Old 02-15-2020, 01:24 PM
rwestley's Avatar
Quoted: 741 Post(s)
Liked: 472
I was pointing out the hush boxes I have seen, I have not seen a hush box with the S6. They do work well as I have one on top of my AVR-X8500H......
I think you are referring to the Aircom S6 not the Cloudline s6 They are different. How could you put the Cloudline S6 on the AVR x8500
https://www.amazon.com/AC-Infinity-C...20468220&psc=1
https://www.acinfinity.com/component...ar-exhaust-12/
rwestley is online now
post #23628 of 28583 Old 02-15-2020, 04:43 PM
Craig Peer's Avatar
Quoted: 8051 Post(s)
Liked: 10622
A person I know decided to take my recommendation and try an RS2000, since they needed a new projector. Their reaction -
" Hi Craig,
I watched 2001 4K HDR last night and the space scenes were Astonishing!!
This is the image I have been searching for since I started this hobby over 20 years ago, always pursuing the best black level with brightest highlights. The stars in space and the light reflected off of the ships and objects were really incredible.
Very happy with the upgrade. ".
These are just really great projectors for the money !
Craig Peer is online now
post #23629 of 28583 Old 02-15-2020, 04:49 PM
Liked: 2431
" Hi Craig,
Craig thank you for sharing.
post #23630 of 28583 Old 02-15-2020, 06:50 PM
DAtherton's Avatar
Quoted: 22 Post(s)
Firmware update problem
Latest units I have seen still did not have 3.1 firmware.
My newly purchased NX5 came with firmware 2.09 which I don't see listed on the JVC page - 2.08 & 2.10, but not 2.09.
I downloaded 3.10 and have followed the JVC instructions to the letter to create a flash drive formatted with FAT32 in order to update to 3.10. Didn't work. So I created another flash drive - ditto. I receive the error message onscreen: The USB flash drive is not inserted or cannot be recognized
Any ideas, please, on how to make the update happen. (I'm surprised that JVC don't allow Ethernet downloads; clearly they want to avoid the support costs.)
Not sure how to proceed. HELP, please.
DAtherton is offline
post #23631 of 28583 Old 02-15-2020, 08:40 PM
Liked: 11684
Configured FAT32.
Use older small USB stick.
Use PC, not mac.
If you are doing the above, try a different USB stick.
post #23632 of 28583 Old 02-15-2020, 11:26 PM
Scurly's Avatar
Quoted: 77 Post(s)
Liked: 27
Originally Posted by Bob Barrett View Post
Seems turnaround time on receiving the new bulb is fast. I got mine one week after dropping the form in the mail. I live just a 1/2 hour south of Long Beach where it was shipped from.
I am approaching 2 weeks now and no replacement bulb. Will wait a little longer before calling someone. Says 6-8 weeks for processing and every case is different but it starts making you wonder....
Scurly is offline
post #23633 of 28583 Old 02-16-2020, 12:22 AM
Fredstwofeet's Avatar
Quoted: 41 Post(s)
Send a message via AIM to Fredstwofeet
You must use a flash drive that is less than 64 GB.
Fredstwofeet is offline
post #23634 of 28583 Old 02-16-2020, 02:25 AM
Semi-Advanced Member
ht guy's Avatar
Quoted: 292 Post(s)
Liked: 304
Configured FAT32.
Use PC, not mac.
fwiw, we've only got macs here and no problems doing the FW updates.
ht guy is offline
post #23635 of 28583 Old 02-16-2020, 04:51 AM
rwestley's Avatar
Quoted: 741 Post(s)
Liked: 472
As others have said find a old usb drive and clear everything off it. Be sure to only include the unzipped root file on the clear drive and try it.
I have done many firmware updates on various types of equipment and have found that some drives just don't seem to work. I have several old Lexar 4 and 8gb drives that I always use with no issues.
post #23636 of 28583 Old 02-16-2020, 06:04 AM
Todd G.'s Avatar
Quoted: 228 Post(s)
Liked: 534
Mine took every bit of five weeks.
Basement bat cave: JVC RS2000 (calibrated), 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #23637 of 28583 Old 02-16-2020, 07:08 AM
Liked: 11684
Give it the 6 to 8 weeks. If you have not received by then, shoot me an email and I will get it taken care of.
post #23638 of 28583 Old 02-16-2020, 08:40 AM
DAtherton's Avatar
Quoted: 22 Post(s)
Thank you all for your helpful tips.
I have done as you all suggest and have tried it on three different flash drives, 32gb, 16gb, 4gb. I've used a Windows machine twice and a Mac. I've placed the USB stick in the projector BEFORE switching it on. Same result. I've tried re-setting the projector's data to the factory settings. Same result.
As I mentioned earlier, my software is version 2.09 which is not listed on JVC's current site. Could this have anything to do with it?
post #23639 of 28583 Old 02-16-2020, 08:50 AM
Quoted: 6281 Post(s)
Liked: 2640
Did you unzip the files prior to copying on to the USB?
rwestley likes this.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #23640 of 28583 Old 02-16-2020, 09:26 AM
rwestley's Avatar
Quoted: 741 Post(s)
Liked: 472
I was thinking the same thing. You must unzip the files and put the root directory on the USB drive for it to work.
1. Download the Firmware to a folder on your computer.
2. Make sure noting else is on your usb drive.
3. Unzip the file to the blank usb drive.
4. Try again. Good luck. (I suggest using the 4gb drive)
The problem has nothing to do with the firmware you now have installed.
drift , Jvc , nx5 , nx7 , nx9 , pixel alignment , rs1000 , rs2000 , rs3000
