Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread - Page 949 - AVS Forum | Home Theater Discussions And Reviews
 25230Likes
post #28441 of 28719 Old 06-28-2020, 12:45 AM
Jim Cutter's Avatar
Quoted: 205 Post(s)
Liked: 213
So I've had my RS2000 for a year now and absolutely love it. I finally decided to take the plunge and get a Panamorph DCR lens. All I can say is.......WOW!!!! I can't wait to get it calibrated in the near future. Thanks, Mike!!!!
ID:	2750052   Click image for larger version
ID:	2750054   Click image for larger version
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #28442 of 28719 Old 06-28-2020, 02:28 AM
alebonau's Avatar
Quoted: 2066 Post(s)
Liked: 1428
Originally Posted by haulin oats View Post
What are you guys using to play Netflix hdr content on your nx7? I use an Apple TV 4K. It used to show up as hdr (non Dolby vision). But recently on the Netflix screen it just says ultra HD 4K. No longer listing content as hdr.
atv 4k no problems here. 🙂
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #28443 of 28719 Old 06-28-2020, 03:28 AM
markmon1's Avatar
Quoted: 6815 Post(s)
Liked: 4938
Originally Posted by Dominic Chan View Post
I agree that in most cases using DHCP is easier. However, one can also manually assigning IP addresses, as long as you restrict the DHCP server to a specific address range to avoid potential conflicts.
Yes, it can be done, but realistically, this should never be done in a network. As the network grows, you risk having conflicts in IP addresses. The proper way to set a manual IP is to enable DHCP and then configure a static IP address in the router. The effect is the same, but the benefit is you have all your IP addresses in one location and should not get any devices assigned to the same IP that way. There have been multiple times in this thread alone where a person has had IP control issues and had static IP set with a conflicting IP address on his network.
rwestley, Franin, Manni01 and 1 others like this.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is online now
post #28444 of 28719 Old 06-28-2020, 05:45 AM
Frank Derks's Avatar
Quoted: 613 Post(s)
Liked: 462
I'm running a network analyzer on an iPad it is very useful to sniff out ip addresses and connected devices in the local network.
I use it to ping the projector if for some reason JVC Autocal fails to connect to the projector. After a ping the connection check returns connection ok and there is no need to power cycle the projector.
Stereo is simply Multichannel light.
Frank Derks is online now
post #28445 of 28719 Old 06-28-2020, 05:52 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
I utilize 4K ATV for most of my movies, unless playing on the Oppo w/ disc. However, I find Netflix is better, IMHO, played on my XboneX, sounds better (Atmos) and movies that are 4K are actually 4K when played, unlike ATV, which I believe throttles bandwidth during peak viewing times.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is offline
post #28446 of 28719 Old 06-28-2020, 06:08 AM
BondDonBond's Avatar
Quoted: 789 Post(s)
Liked: 757
Yup it is awesome....Next get a Lumagen and see how you never need to touch the projector controls with aspect ratios etc and has good DTM. Not quite as good as MadVR PC version but close enough.
Enjoy.....
skylarlove1999 likes this.
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #28447 of 28719 Old 06-28-2020, 06:18 AM
Quoted: 789 Post(s)
Liked: 757
Originally Posted by nafzal View Post
Hello Fellow JVC NX7 / RS2000 Owners,
I installed my JVC NX7 a few days ago. I installed the 3.1 firmware and am loving the frame adapt HDR.
My HT processor is the Marantz 8802A, I have it hooked up to a ATV 4k. I have all the correct wiring, everything is running as it's supposed to. Amazing, just wow.
What are the optimal settings for this projector (menu options and settings etc), anything I need to set on the Marantz processor?
I know this has been discussed but I am struggling to find it in this forum. Appreciate the help fellow NX7 owners!
Let you projector break in and get some hours on it before calibrating.
Make sure you are just passing through the Marantz for video.
You primarily going to use native and Frame Adapt for the video. Every room is different so don't just plug in some numbers from someone else. Mine will be different than yours.
Play a little with the Manual Iris in Native mode for contrast and see where you like it for a balance of light output to contrast.
You really should not mess with the color controls without some calibration equipment to know where you are with it.
Just write down where everything is before you mess with it and you should be fine.
Just have fun and be amazed!
rwestley and skylarlove1999 like this.
post #28448 of 28719 Old 06-28-2020, 06:46 AM
rwestley's Avatar
Quoted: 743 Post(s)
Liked: 472
The problem with using pass through with a Marantz/Dennon receiver is that you can't access the reciver setup to make any changes. I would be sure that you turn upscailing off on the receiver and not limit HDMI output resolution. If you set it that way you can access the other receiver controls.
MentatYP likes this.
rwestley is online now
post #28449 of 28719 Old 06-29-2020, 07:14 AM
Quoted: 92 Post(s)
Liked: 50
Originally Posted by alebonau View Post
I dont have a dedicated room and can tell you I easily have seen the benefits of going from epson 9000 series (same basis same dark chip fuji optics etc as current series), to jvc x35 to x7000 to now n7... it will hit you in the face ! I kid you not
That's fairly emphatic and I have the Epson 3700. So, safe to say that I'll see some significant difference in PQ:-).
as long as room is sealed and can eliminate like leakage you will see the benefits ... in my mind with my own experience there is no question of this.
I may have overstated the "sealed" wrt my room. 2 bedroom doors and a door to a kitchen can be closed, but unfortunately it's not a tight seal. So, there's some light leakage.
Would that change your (or anyone else's) answer?
ps as a clarification...i have actually helped two folk into epson ... it has its place if budget is limited ...but if wanting to bathe in the pure picture quality jvc provide id go n5/n7... n7 if budget will allow its worth it....
Fair enough. Don't think I can justify the NX7 in my room at 50% extra cost (locally. There are other options I'm considering where the difference is not as big). I'd rather put that towards the MadVR Envy when it becomes available.
liverpool_for_life is offline
post #28450 of 28719 Old 06-29-2020, 07:22 AM
SirMaster's Avatar
Quoted: 1373 Post(s)
Liked: 1032
You can still access setup through mobile app or web interface though.
SirMaster is offline
post #28451 of 28719 Old 06-29-2020, 08:20 AM
rwestley's Avatar
Quoted: 743 Post(s)
Liked: 472
That is true but is there any reason to use pass through since you can turn off upscaling and adjust other settings without using passthrough.
post #28452 of 28719 Old 06-29-2020, 10:12 AM
Cleveland Plasma's Avatar
Quoted: 7646 Post(s)
Liked: 7709
Originally Posted by Craig Peer View Post
You do need a show to see new projectors in person however. Or wait until you can get a demo unit in person - which can take a while.
Problem is everything at the show is "prototypes", not production units, so one would have to wait anyway.
Cleveland Plasma is offline
post #28453 of 28719 Old 06-29-2020, 06:41 PM
alebonau's Avatar
Liked: 1428
Be mad in my opinion to spend on madvr at expense of projector. It won’t make an epson into a jvc ! The dynamic tone mapping is that good on jvc n5/n7 for most folks I’d save the cash. For me hasn’t put foot wrong. Set forget and chucked wide variety of material of various sources.
Re light control it will impact ALL projectors. If not directly on screen unlikely to impact severely. We have doors to our room we close off. Picture doesn’t go to ***** just because someone turns light on in adjoining room 🙂
alebonau is offline
post #28454 of 28719 Old 06-29-2020, 06:44 PM
alebonau's Avatar
Liked: 1428
My marantz av8802a is working just fine in the path to n7 I’ve not touched any video settings they are as factory preset. See no reason to 🙂
alebonau is offline
post #28455 of 28719 Old 06-29-2020, 06:52 PM
Ediddy's Avatar
Quoted: 190 Post(s)
Liked: 175
How long does the free lamp with a purchase of a NX7 last?
(2) GoldenEar References, GoldenEar SuperCenter XXL, (4) GoldenEar HTR 7000 (atmos), (2) GoldenEar SuperSat 50’s, (2) GoldenEar Triton 7 (rears), Dual Seaton Sumbersive HP (Master / Slave), JVC NX5, Dalite 119 inch UTC, Panasonic BP - UB 820, Marantz 8805, Emotiva XPR 2, Emotiva XPA 9 (gen 3) Panamax 5102, Harmony Elite, 4K Apple TV
Ediddy is offline
post #28456 of 28719 Old 06-29-2020, 07:01 PM
Mike Garrett's Avatar
Quoted: 14043 Post(s)
Liked: 11708
Deal ended a month ago.
Mike Garrett is offline
post #28457 of 28719 Old 06-29-2020, 07:05 PM
Quoted: 92 Post(s)
Liked: 50
Think something got lost in communication there. The NX7 is 50% more than the NX5 for me where I live. Given my room, I suspect I might not really see the difference in contrast between the 2 units and may as well save the cash with an eye towards the Envy.
Which is why I'm leaning towards the JVC, TBH. Even if not the levels of a dedicated video processor, DTM seems to be good enough to watch HDR content. I do value the convenience of set and forget for all input/material sources.
Fair. Should be able to avoid light directly on screen.
alebonau likes this.
post #28458 of 28719 Old 06-29-2020, 10:50 PM
alebonau's Avatar
Liked: 1428
this is the problem with perceptions though, people say wont not the difference but as i mentioned in my non dedicated room, i have noticed every single projector upgrade done so far for the better
its a truly amazing projector !
this is top gun on uhd ...though a movie from vhs era ... just a hand held screen shot. camera doesnt even capture the detail abound and can see with own eyes but yeah this is possible even in a non dedicated room !
truly mind boggling what these jvc capable off !
alebonau is offline
post #28459 of 28719 Old 06-30-2020, 12:54 AM
Quoted: 92 Post(s)
Liked: 50
Not denying that. The point of diminishing returns is different for different folks, though. And without the possibility of a demo, some amount of guesswork based on other people's experiences is all I have to fall back upon.
Which is why I lust after one, eh? If you don't mind, what's your screen size (and type), throw and viewing distance?
post #28460 of 28719 Old 06-30-2020, 01:30 AM
alebonau's Avatar
Liked: 1428
yes definitely we all ha e to decide whats best for ourselves, . all projectors talking about are quite popular for their own reasons ...
re my screen its an australian brand screen technics. 1.1 gain. i'm one of those running a relatively small screen ... 92" 16:9 but am viewing at bang on THX spec (2.8m) for this screen size for immersion. so am well and truly resolving 2k and also getting some benefits of 4k the good thing with the smaller size as well is that i can happily run on low lamp an still easily achieve the 100 nits needed to do HDR justice
alebonau is offline
post #28461 of 28719 Old 06-30-2020, 05:17 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
Well, here's my $0.02 again. The NX-5 (returned due to Blue lines) is no slouch, however, the NX-7 (upgrade from NX-5) is next level up, DTM is a champion. I run the projector on low lamp (w/ DCR), based on my short throw of 1.4.1, which works out well for me. I got a great deal because of the NX-5 return and the inconvenience, on the NX-7/DCR lens. This was one of the best combos in my ~25 yr history with HT. Did I want to spend that much $$$? No sir, but I have no regrets, as sometimes I may, because of financial compromise.
Next, the Stewart 130 G4 2:40, but I need to complete a Home project, therefore, I may have to delay this purchase, unfortunately. If you can afford the JVC NX-7, go for it, IMHO, the diminishing returns are with the JVC NX-9, which is twice the cost of the NX-7. Don't get it twisted, if I could have afforded the NX-9, I probably would have done it, but I've heard that upgrade is incremental. Hope this helps someone in their quest.
Azeke
Azekecse is offline
post #28462 of 28719 Old 06-30-2020, 05:21 AM
Franin's Avatar
Quoted: 3680 Post(s)
Liked: 2608
Originally Posted by Azekecse View Post
Well, here's my $0.02 again. The NX-5 (returned due to Blue lines) is no slouch, however, the NX-7 (upgrade from NX-5) is next level up, DTM is a champion. I run the projector on low lamp (w/ DCR), based on my short throw of 1.4.1, which works out well for me. I got a great deal because of the NX-5 return and the inconvenience, on the NX-7/DCR lens. This was one of the best combos in my ~25 yr history with HT. Did I want to spend that much $$$? No, but I have no regrets, as sometimes I may, because of financial compromise.
Next, I would like the Stewart 130 G4 2:40, but I needed to complete a Home project, therefore, I may need to delay this purchase, unfortunately. If you can afford the JVC NX-7, go for it. IMHO, the diminishing returns are with the JVC NX-9, which is twice the cost of the NX-7. Don't get it twisted, if I could have afforded the NX-9, I probably would have done it, but I've heard that upgrade is incremental. Hope this helps someone in their quest.
Azeke
So when you did side by side testing with the NX7 and the Nx9 you found it the same ?
God Bless!. A good way to test your Iris on your projector is on the Spears and Munsil disc. Go to Video processing then select Luminance Loading. Don't stare directly at the lens but on an angle and you can actually see the Iris at work
My Recently Updated Small Home Theatre Room :https://www.avsforum.com/forum/29-what-s-your-system-configuration/1162038-franin-ht-42.html#post16806495l
Franin is online now
post #28463 of 28719 Old 06-30-2020, 05:34 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
No Franin, I didn't test NX7 and NX9, only the NX5 and NX7 and that is based on a visual comparison experience, in my HT room (light controlled). The NX9 is a personal opinion/evaluation, based on my google/YouTube research, and a few viewings at Magnolia, which happen to be on display. I felt that the DCR lens and NX7 was better bang for my buck, because I couldn't really afford the NX9 and the DCR lens combo (~50% cost increase), I wish I could .
Azeke
alebonau and skylarlove1999 like this.
Azekecse is offline
post #28464 of 28719 Old 06-30-2020, 06:19 AM
Franin's Avatar
Liked: 2608
Azeke
Okay
post #28465 of 28719 Old 06-30-2020, 06:22 AM
alebonau's Avatar
Liked: 1428
main thing with the nx9 is those grand optics isnt it and the up in contrast ? gotta pay for it though... nothing in life is free
alebonau is offline
post #28466 of 28719 Old 06-30-2020, 07:20 AM
rwestley's Avatar
Quoted: 743 Post(s)
Liked: 472
i may be wrong but I would think that one could see a bigger difference between the NX7 & NX9 on a larger screen. The NX5/NX7 lens is still quite good but as we all know good lenses are expensive. That being said there are some great lower cost lenses and All JVC projector lenses are made out of glass.
post #28467 of 28719 Old 06-30-2020, 08:29 AM
Craig Peer's Avatar
Quoted: 8056 Post(s)
Liked: 10640
If you buy an NX9 / RS3000, you get a free spare lamp right now.
tigerhonaker likes this.
Craig Peer is offline
post #28468 of 28719 Old 06-30-2020, 09:15 AM
Liked: 11708
But today is the last day JVC is offering the free lamp, unless they decide to carry over to next month.
Added
Free lamp on RS3000 does carry through for July.
post #28469 of 28719 Old 06-30-2020, 09:20 AM
asharma's Avatar
Quoted: 2354 Post(s)
Liked: 868
Azeke
The Stewart screen will take your HT to the next level! I know it did for me!!
mikela, DavidHir, alebonau and 3 others like this.
Video:JVC NX7, 125” 2.35 Stewart ST100 Electric, Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b, 25s, Dual SVS SB3000
Receiver/Amp: Anthem 1120, Emotiva XPA-11 Gen 3
Source: Panasonic UB820, Triple black velvet batcave
asharma is offline
post #28470 of 28719 Old 06-30-2020, 10:08 AM
Azekecse's Avatar
Quoted: 287 Post(s)
Liked: 304
Yes sir, I know .
Azeke
asharma and skylarlove1999 like this.
Azekecse is offline
drift , Jvc , nx5 , nx7 , nx9 , pixel alignment , rs1000 , rs2000 , rs3000
