Optoma P1 4k Laser UST @ CES - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 614Likes
post #721 of 1446 Old 09-17-2019, 07:41 PM
TimHuey's Avatar
Quoted: 133 Post(s)
Liked: 46
Anyone know what happens to the image other than it expanding obviously when you slide the projector away from the screen perpendicularly. Does the image stay centered and just get bigger or does it also transit vertically?
HTPC. Onkyo 636, Polk audio speakers and Klipsch sub. KHO-7 Outdoor speakers. Homeseer homecontrol over Z-wave.
TimHuey is offline
post #722 of 1446 Old 09-17-2019, 09:40 PM
g4s
g4s's Avatar
Quoted: 39 Post(s)
Liked: 34
I think it does rise vertically. I read somewhere you take the screen height x .24 to get the distance from the P1's stand height to the bottom of the screen. You can round it down to the nearest inch because of the adjustable feet.
g4s is online now
post #723 of 1446 Old 09-17-2019, 10:00 PM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
No it doesn't stay centered, bottom of the image only moves vertically a few inches while the rest of it expands or gets smaller
Xiaomi Mija Mi Laser UST 1080P (International), Sharp 4k 65", LG 4k 43", Nvidia Shield
klas is offline
post #724 of 1446 Old 09-18-2019, 01:32 AM
Liked: 0
Pricing on the LS 500
Originally Posted by colinmatheny11 View Post
My needle to moving towards the newly announced Epson LS 500. Similar price (2,999) point without all the extras such as built in apps, soundbar etc.
Hopefully the contrast is better than the LS100.
Sent from my LM-V350 using Tapatalk
Pricing on the LS 500 - the 100-inch projector and screen combo will cost $4,999, while the 120-inch combo will be $5,999, and both include a pair of 10-watt front-facing speakers. I'm not sure about the pricing without the screen.
Adarsh Shah is offline
post #725 of 1446 Old 09-18-2019, 09:03 AM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
Pricing with screen is ok, but they killed their product by not making it a real UST
klas is offline
post #726 of 1446 Old 09-18-2019, 09:42 AM
Koeikan's Avatar
Two different types of contrast. Check out a video on ANSI CONTRAST AND FULL ON OFF CONTRAST.
Okay, thanks, makes sense... seems like the ANSI contrast rating is generally much harder to find than it is for lumens w/r/t projectors .
Anyway, if this UST projector from Optoma has a native ANSI contrast of 500:1... which happens to be the same as my dated HT1085ST DLP projector, should I expect similar contrast between the two?
If so, that would be majorly disappointing.
How big a factor does dynamic dimming make and is it safe to assume that isn't factored in to the ANSI contrast (alternatively, how much of a difference would the perceived contrast differ between two projectors with the same native contrast but much different dynamic contrast ratings)? I see that native contrast is definitely more important, but still not clear how to compare and contrast (...) the ratings.
I guess the crux of what I'm asking is "has contrast performance generally stalled for projectors in the last 5 years or has it improved significantly despite the same native contrast ratings"? Trying to decide if I can make the plunge now w/ the P1 or wait another year for affordable 0.66" DMD ST/UST offerings to start showing up.
Koeikan is offline
post #727 of 1446 Old 09-18-2019, 10:16 AM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
In my experience contrast numbers are meaningless in specs, wait until reviews come out and do a real measurement.
Frank714 likes this.
klas is offline
post #728 of 1446 Old 09-18-2019, 10:35 AM
TimHuey's Avatar
Quoted: 133 Post(s)
Liked: 46
Yep from a reliable 3 party also. Not the dealer lol. Not that the review from the dealer isnt welcomed it's just unusable for evaluation and purchase.
TimHuey is offline
post #729 of 1446 Old 09-18-2019, 11:19 AM
Koeikan's Avatar
Okay, specific projector contrast ratings aside, can I be a bit more general and just ask how the perceived contrast on mid-range laser projectors of today (IE: UST options that have been released like the WEMAX/VAVA/etc) compare to older budget DLP bulb projectors 5 years ago (IE: BenQ/Optoma) given the same native contrast.
I'm trying to get a sense of if this is something that has been getting significantly better using other methods of implementation or if it's mostly been stagnant and the contrast on those older bulb projectors are more or less in line with newer laser projectors.
Koeikan is offline
post #730 of 1446 Old 09-18-2019, 01:37 PM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
I can tell you that I owned this one https://www.projectorcentral.com/Acer-H6510BD.htm before I got Xiaomi and spec numbers aside perceived contrast as well as blacks and color is much better with laser UST. Also both projectors are native 1080p, but 4k looks so much better with Xiaomi. I would expect that Optoma won't let us down with P1 and it will be as good or better.
Btw where did you see native contrast 500:1 for P1?
Koeikan likes this.
klas is offline
post #731 of 1446 Old 09-18-2019, 01:59 PM
Koeikan's Avatar
Appears to be determined by the DMD it's using.
Originally Posted by Frank714 View Post
As this is DLP technology there is no contrast regression over time (this phenomenon has been observed with Sony projectors using SXRD technology). The problem remains that the native contrast of the 0.47" Digital Micromirror Device (DMD) is around 500:1 which is a far cry from the native contrast / black levels you get from an OLED Screen or JVC front projector (several thousands: 1).
The larger 0.66" DMD has provided a native contrast of 1,000:1 and Vivitek will be using that DMD in its UST projector expected later this year (probably showcased at CES in January).
^ although I think I had read one of the Xiaomi projectors was able to get over 1000:1 with the .47 somehow.
Koeikan is offline
post #732 of 1446 Old 09-18-2019, 09:49 PM
Quoted: 27 Post(s)
Liked: 3
Originally Posted by Casey_Bryson View Post
Originally Posted by Kdub69 View Post
Any chance you have the dimensions for this so I can build one like it? Looks good! Thanks
I've attached my hand written notes. It's best to use it as a guide. The Only thing I would change is the depth of the Center Speaker base/platform from 15 inches to 12 inches to account for cables sticking out and other variances. I'll be cutting 3 inches into mine where the projector sits. I didn't have the screen up when I made the measurments. Rookie mistake ;-)
Awesome thanks!!! What size is your screen right now
120inch?
Kdub69 is offline
post #733 of 1446 Old 09-19-2019, 04:07 AM
Frank714's Avatar
Quoted: 969 Post(s)
Liked: 429
Over 2,000:1 actually according to the French review: https://www.passionhomecinema.fr/blo...is-de-gregory/ (English translation further down). But since it should be impossible to get a native contrast significantly ecxeeding 500:1 with the 0.47" DMD, it has been speculated that the Xiaomi already uses dynamic laser dimming in the standard operation mode without having announced that.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #734 of 1446 Old 09-19-2019, 08:20 AM
maverick87r's Avatar
Quoted: 12 Post(s)
Liked: 1
Originally Posted by ProjectionHead View Post
PLEASE don't shoot the messenger.... P1 expected ship date is now pushed back to 9/24.
I was just told this by my Optoma rep a couple of minutes ago.
My belief if that they want to make sure they all updated with most current firmware and ready to be released as "bulletproof" considering that they have a big campaign out there to compensate people to leave reviews for the projector online.
It is possible that the date could change again, but this is where we are at as of today.
Any updates on ship date? I noticed that projector screen.com says 9/30.
maverick87r is online now
post #735 of 1446 Old 09-19-2019, 08:21 AM
Casey_Bryson's Avatar
Quoted: 21 Post(s)
120inch?
NP! Yes 120 inch. It's the biggest size you can currently get with PET CLR.
Casey_Bryson is online now
post #736 of 1446 Old 09-19-2019, 08:31 AM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
and they claimed 3000:1 native contrast which again shows how these numbers in specs don't mean anything along with a lumen rating.
klas is offline
post #737 of 1446 Old 09-19-2019, 08:37 AM
Quoted: 18 Post(s)
Liked: 7
Eastporters in Canada has a package with the cinemax pi and Aurora 8k ust alr screen 120 inch for $5400. Looks like an amazing deal for the screen. Does anyone know if the quality of the screen is similar to xy pet crystal? The frame and material look the same, both are.8 gain.
See a copy of the email I received from Eastporters
Here is a link to the screen: https://www.eastporters.com/product/110-elunevision-reference-8k-short-throw-alr-projection-screen-2/ We currently do not have a package price up on our website! Yes that price is for a 120" fixed frame. The screen gain is .08 gain. If you have any questions please let us know!
Floorit72 is offline
post #738 of 1446 Old 09-19-2019, 03:19 PM
Quoted: 85 Post(s)
Liked: 65
This thread is becoming stagnant...the lack of P1 content is triggering just parallel conversations, not fun :/
J Bone, drdoom2k and copperfield74 like this.
Gae80uk is offline
post #739 of 1446 Old 09-19-2019, 03:26 PM
klas's Avatar
Quoted: 254 Post(s)
Liked: 83
We waited that long what's two more weeks and things will pick up...
g4s likes this.
klas is offline
post #740 of 1446 Old 09-20-2019, 01:36 AM
Quoted: 51 Post(s)
For those in Europe interested by the European model (UHZ65UST). I've just chat with optoma France and they told me the UHZ65UST and P1 are different model, the UHZ65UST have 3500 lumens and 2 500 000:1 contrast ratio ( the P1 one have 3000 lumens and 1 500 000:1), they finally set an MSRP price of 3.299 € for France (It certainly should be the same elsewhere in europe)
solal- is offline
post #741 of 1446 Old 09-20-2019, 01:59 AM
Liked: 0
any expected release date in europe? maybe October too?
Enviado desde mi POCOPHONE F1 mediante Tapatalk
f.c.g. is offline
post #742 of 1446 Old 09-20-2019, 02:00 AM
Quoted: 20 Post(s)
I'm curious if this is true. Here in Germany they advertise it with 3200 Lumens and 3995Euro (including VAT)
copperfield74 is offline
post #743 of 1446 Old 09-20-2019, 02:04 AM
Quoted: 51 Post(s)
They told me they just changed the price to 3299 Euros MSRP who was before announced at 3999 Euros MSRP. For the lumens I found that strange too, you can see their reply on twitter ( https://twitter.com/OptomaFrance/sta...59606365208576 ), they announced it for October but nothing precise yet.
solal- is offline
post #744 of 1446 Old 09-20-2019, 02:26 AM
Quoted: 85 Post(s)
Liked: 65
This is a bit confusing but certainly good news if happening
Gae80uk is offline
post #745 of 1446 Old 09-20-2019, 02:28 AM
Quoted: 20 Post(s)
Thumbs up
That would be great news if the decide to lower the price and raise the lumens! I'm really looking forward to the release.
Thanks for the information.
Maybe I should follow the french Optoma page instead of the german.
post #746 of 1446 Old 09-20-2019, 02:59 AM
Quoted: 85 Post(s)
Liked: 65
Just seen that confirmed on Optoma FR FB page! €3.299 release in Oct...woop woop! Check that out
drdoom2k likes this.
Gae80uk is offline
post #747 of 1446 Old 09-20-2019, 03:02 AM
Quoted: 85 Post(s)
Liked: 65
https://www.facebook.com/389223354478942/posts/2499654666769123/
Gae80uk is offline
post #748 of 1446 Old 09-20-2019, 04:01 AM
Liked: 9
Good idea . "Heimkinoraum" in Germany is still stuck on 3.999 EUR and I already left a comment on their board about the announcement of their French colleagues. Lets see what happens...
kalle4242 is offline
post #749 of 1446 Old 09-20-2019, 05:10 AM
tambur123's Avatar
Quoted: 37 Post(s)
Liked: 5
Ohh wow! This is great 😀
tambur123 is online now
post #750 of 1446 Old 09-20-2019, 05:37 AM
ProjectionHead's Avatar
Quoted: 152 Post(s)
Liked: 213
Expected to ship out next week; it depends what time they arrive on Thursday or Friday to then be shipped out to customers.
Eagle13, Bytehoven, TTBear and 1 others like this.
ProjectionHead is offline
