Originally Posted by
Ron Sebastian
Hi all,
just registered here since I own a X12000h (=HT9060) since a while. I would like to ask if anyone else has a non-uniform sharpness across the screen? E.g. if I set left lower corner sharp the right upper corner text is not even readable (which is without problems in the left lower corner of course). Also sharpness changes a bit over time (heating up of the projector). I now contacted BenQ and started a RMA. However: anyone else experienced that?
Another Question: the smart Eco Mode seems to check always for the brightest pixel in the image. So if there is e.g. a dark scene with a fire the fires is priority and all dark environment is no longer black but grey due to high lamp power. Any idea how to tweak this? I use JRiver with MadVR and FFDshow but found nothing to Limit Peak brightness in dependence on image average brightness or similar. Or Maybe newer Firmware may help?
Ron
The blurry corner is a property of the lens (usually). Not all of them are perfect, although these projectors generally have very good lenses. I'd let the projector warm up at least 45 minutes before adjusting the focus and see if you can dial it in then. These lenses are so large that the uniformity does change as the room and projector hit operating temp. If at that time you still cannot get good enough focus to say read text in all areas of the screen, you should consider RMA.
The smart eco mode is just a limitation in the way the firmware is implemented I think.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
