BenQ HT9060 / x12000h Owners Thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 350Likes
post #691 of 710 Old 05-26-2020, 05:56 AM
Liked: 1
Originally Posted by DoctorCyclops View Post
Got it.
Perhaps some sort of lift that you could wheel into place might work if you can’t find the right table.
Extreme Max 5001.5083 Hydraulic Motorcycle Lift Table – 300 lb.
Doc, if I may be informal, fascinating idea. I will look into this. Thanks for the link.
DoctorCyclops likes this.
one_audioman is offline
post #692 of 710 Old 06-13-2020, 06:04 PM
bobpaule's Avatar
Quoted: 80 Post(s)
Liked: 114
Is HDR usable or does it render the image dim like on many other projectors?
Furman IT-Reference 20i(amps/sub) & Elite-20PFi(low current) > Harmony-659 > Marantz-UD9004(bal.2+RCA7.1), Sony UBP-X800 & S5500RF(PAL), Apple-64GB, Dell Latitude 5490 w. W15 dock > Marantz-AV8805 & Classé-CP700(bypass) > Epson-LS10500/Carada1.4, Samsung QN32Q50RAFXZA secondary monitor > Classé CA-2200 & CA-5200, two Zamp v.3 > Paradigm S8v.2, C5, ADP3, S2, Servo15v2, CI Pro P-80A 7.4.1
bobpaule is offline
post #693 of 710 Old 06-13-2020, 11:14 PM
DoctorCyclops's Avatar
Quoted: 71 Post(s)
Liked: 68
It’s bright enough for HDR & 3D on screens up to 160” w 1.0 gain. For best 3D you will need to run it in anamorphic mode and use an A lens.
DoctorCyclops is online now
post #694 of 710 Old 06-14-2020, 04:43 AM
bobpaule's Avatar
Quoted: 80 Post(s)
Liked: 114
Great to know, I have made myself a promise to resist upgraditis until affordable native 4K, but now...
bobpaule is offline
post #695 of 710 Old 06-16-2020, 12:56 AM
Liked: 0
Hi,
I am a bit confused. As other users I would like to use my HT9060 with a HTPC in combination with MadVR. For that I understand easiest would be Vivid mode with 3D LUT (measurement gear is ready). With my Firmware 9.0.1 in Vivid mode BT.709 is selected and I cannot change it (option is greyed out). Only in HDR mode the color space can be changed to bt2020/dci-p3. That does not help me as I need the PCI-P3 in one of the SDR modes to use with MadVR.
Could you please check your firmware version or give me a hint what I might do wrong?
Ron
Ron Sebastian is offline
post #696 of 710 Old 06-16-2020, 03:33 AM
MDesigns's Avatar
Quoted: 296 Post(s)
Liked: 149
Originally Posted by Ron Sebastian View Post
Hi,
Ron
Have you measured the gamut with Vivid selected? The issue with 9060 is that you cant change the colorspace in SDR, but the Vivid should be wide.
JVC DLA-RS500
MDesigns is offline
post #697 of 710 Old 06-16-2020, 06:27 AM
SirMaster's Avatar
Quoted: 1384 Post(s)
Liked: 1036
Hi,
Ron
It doesn’t matter what the color gamut mode on the projector says.
Vivid mode should be a wide gamut meaning the primary color coordinates should be way out near the DCI-P3 reference points.
In Vivid, all the saturation tracking in the middle will be off from any reference color gamut like rec709 and DCI-P3 but this is what the 3DLUT is for.
A 3DLUT can only shrink the primary color points inward and move points within that triangle around.
Last time I measured the primary color coordinates on a HT9060 in Vivid, I noticed that they were very near DCI-P3 coordinates and was giving me slightly over 100% DCI-P3 coverage.
3DLUTs are capable of converting between color spaces entirely which is essentially what you will be doing here.
SirMaster is online now
post #698 of 710 Old 06-16-2020, 12:34 PM
Liked: 0
Hi!
well THAT explains it then! However, the gamut setting is quite pointless then....
I never even tried to measure it in vivid since I did not expect this. Will do now. Easy solution :-)
Before you apply the LUT measurement: do you still calibrate RGB levels for white and some grey steps before? Or just let the LUT do everything?
Ron
post #699 of 710 Old 06-16-2020, 12:43 PM
SirMaster's Avatar
Liked: 1036
Hi!
Ron
I would just let the 3DLUT do everything.
Since you are essentially converting colorspaces make sure you do enough patches, at least a couple thousand for best results.
But you could try a smaller 3DLUT first if you are unsure of your settings to see that the result is what you are expecting without wasting so much time.
Your 3DLUT will be converting from some random non-standard color gamut that the HT9060 calls Vivid mode, into proper DCI-P3. And then installing that 3DLUT into madVR will tell madVR that the display is now calibrated for DCI-P3, so it will map all the content that it's processing including BT.2020 and rec709 into the DCI-P3.
SOWK and DoctorCyclops like this.
post #700 of 710 Old 06-17-2020, 03:05 AM
Liked: 0
Hi SirMaster,
ok will do so. Just curious if I can also then just do the same for the Windows color profile Manager. Make a profile in BT.709 for this should then give my Desktop and Netflix Streaming normal Colors back. Doing so I could Always remain in vivid mode. MadVR will switch for itself then when playing and disable the windows desktop profile Manager.
Best regards
Ron
post #701 of 710 Old 06-17-2020, 06:52 AM
SirMaster's Avatar
Liked: 1036
Hi SirMaster,
Best regards
Ron
You cannot do this.
A Windows color profile only applies the 3DLUT color calibration part of the profile to color managed applications such as Adobe or similar content creation software. It does not apply the 3DLUT to the desktop or web browser or Netflix app or anything like that.
All that gets applied to non-color managed apps like your desktop, web browser, Netflix, etc is a 1DLUT which gets loaded into the vgct (video card gamma table), so it applies to all output. A 1DLUT is only capable of performing greyscale and gamma calibration. So it will get your greyscale range to 6500K temp and your gamma flat at 2.2 or whatever you like, but it's not capable of converting color spaces, so your color on desktop, web browser, Netflix app, etc will be way over-saturated in Vivid still.
What I would recommend is create your 3DLUT for madVR in Vivid like you were going to.
But then after that, set the mode to whatever color mode is closest to rec709 (I don't know what it's called, but you can measure to see which is most accurate). And create a Windows color profile for that mode, so at least you get accurate color temperature greyscale and accurate gamma.
Then I would actually use this remote control program I made which would let you easily switch between profile modes on your BenQ between Vivid and whatever. You could make a button on your phone/tablet or even just an icon on your desktop that switches when you click it. You could even set up madVR to automatically switch your BenQ to Vivid when it starts playing and back to the standard color mode when it's done playing.
https://www.avsforum.com/forum/26-ho...htpc-home.html
I wont get into the specifics too much here, but just to give you can idea:
I tested my program with the BenQ LK970, but it should work with the HT9060 too.
You can see BenQ IP commands here:
https://github.com/nicko88/HTPCRemot...BenQ_LK970.pdf
Vivid mode for example is: "appmod=vivid" which you would send from my program.
You can post in the other thread if you need help understanding how to get this all working.
post #702 of 710 Old 06-18-2020, 11:19 PM
Liked: 0
Hi SirMaster,
within several posts you already saved me hours of work! Great thanks!
I will have a look in the IP commands and how I could use that with madVR. If too tricky also switch by remote will be ok....
Ron
post #703 of 710 Old 06-23-2020, 10:43 AM
Quoted: 71 Post(s)
Liked: 68
Just saw this, it’s from February. https://www.projectorreviews.com/ben...ter-projector/
post #704 of 710 Old 06-23-2020, 11:51 AM
Quoted: 51 Post(s)
I might move to another house and might need to get a new projector. Coming from a Sony 285es, I'm looking for a solid state PJ (for longevity, no lamp to replace etc.) Source is going to be 99% from htpc with madvr calibrated with 3D-luts. Any thoughts from the owners, are you still satisfied with the unit?
entropy02 is offline
post #705 of 710 Old 06-23-2020, 12:13 PM
Quoted: 71 Post(s)
Liked: 68
I'm very satisfied. This coming from a CRT/LCOS background and a 3chip Runco LS10, which was a light canon. Once you get used to a brilliantly even lit image, it's hard to go back.
For a best all around Projector, the 9060 still checks all my boxes.
If you're in search of ultimate blacks, look elsewhere.
Read the review from February I just posted.
One of the most evenhanded and fair assessments yet.
In the end, he compares the color and clarity to the 30k+ Sony projectors with ARC lenses.
Not bad company to be in.
post #706 of 710 Old 06-23-2020, 02:53 PM
Mike Garrett's Avatar
Quoted: 14048 Post(s)
Liked: 11723
And I look at missing powered lens features, no lens memory, no dynamic tone mapping and low contrast. Seems too much money for what you get, if looking at new.
Mike Garrett is offline
post #707 of 710 Old 06-23-2020, 04:18 PM
Quoted: 71 Post(s)
Liked: 68
YMMV.
That said: mine is a refurb, so the cost was substantially less.
I would add: the only way for the 3D to truly rock is to go into anamorphic mode and use an A lens.
post #708 of 710 Old 07-02-2020, 09:54 AM
Quoted: 71 Post(s)
Liked: 68
Does anyone know what design the HT9060 is based off? Which company? Thx.
post #709 of 710 Old 07-06-2020, 05:24 PM
dfarina's Avatar
Quoted: 36 Post(s)
Thanks for the link,I tried inputting the colour settings from the review in my HT9060 and found a nice improvement in SDR colours.Never had it calibrated,all colour settings were factory default beforehand.
Benq HT9060,Elunevision Reference Studio 135",Denon AVR-X3300W,Panasonic UB820, B&W DM S3
dfarina is offline
post #710 of 710 Old 07-07-2020, 08:18 AM
Quoted: 71 Post(s)
Liked: 68
Great! I did the same.
Looking forward to an actual, full calibration but want to find someone well versed w/ the HT 9060.
Just got the 4K Seven Worlds, One Planet. Highly recommended.
Aztar35 likes this.
