JVC DLA - dim picture - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By markmon1
  • 1 Post By Craig Peer
post #1 of 27 Old 03-01-2019, 11:34 AM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Hi all!
I have a JVC DLA RS-67 with about 1800 hours on the original lamp, always on low other than the handful of 3D movies I have watched. Lately I feel like the image is noticeably dimmer than I think it should be. I tried setting the lamp to High but that didn't help much.
In your experience, is this just a case of the bulb wearing out? JVC claims 4500 hours and 1800 seems awfully short of that. How often do you replace JVC bulbs?
How often (if ever) do you clean the lens?
schwaggs is offline
post #2 of 27 Old 03-01-2019, 12:10 PM
Mike Garrett's Avatar
Quoted: 12564 Post(s)
Liked: 10174
Originally Posted by schwaggs View Post
Hi all!
The RS67 lamp was rated for 3,000 in high and 4,000 in low. That is to half life. What size is your screen, aspect ratio and gain? Number of lamp strikes can make a difference also. What I mean, turn on projector and run it one hour, turn off and then turn on for another hour, turn off and then turn on for another hour. That would be three hours of use, but it puts more wear on the lamp than turning the projector on for three hours.
Mike Garrett is online now
post #3 of 27 Old 03-01-2019, 01:05 PM
Jeff60's Avatar
Quoted: 23 Post(s)
JVC rep told me they had one customer burn out 3 bulbs in 6 months. JVC sent someone to his house to look at the unit as they thought it may be defective. Turned out the customer was turning the unit off every time anyone left the room to "save the bulb time". The constant on/off killed the bulb in a couple of months.
Jeff60 is offline
post #4 of 27 Old 03-01-2019, 02:45 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Thanks Mike! Its a light controlled, darkly decorated, dedicated theater. 120" unity gain screen.
The lamp strikes is something I didn't consider. I would say that on average, I watch for 3-4 hours per session. Some longer, some shorter but I would say 3 on average. Its almost exclusivly movie watching.
3 hours average would be 600 lamp strikes making my total hours 1800 + 600 = 2400 hours on low.
So 4000 hours to half life means what? Lamp burns out or brightness is reduced to XX% of original brightness?
Is the light path sealed on the JVC PJ? Is there a possibility of airborne particles dirtying up the internal optics?
schwaggs is offline
post #5 of 27 Old 03-01-2019, 02:50 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Wow. That sounds painful considering the time it takes the PJ to turn off and on!
schwaggs is offline
post #6 of 27 Old 03-01-2019, 03:35 PM
descalabro's Avatar
Quoted: 435 Post(s)
Liked: 165
This webpage shows how much dust can get inside the light path:
https://www.avforums.com/threads/jvc...block.2126897/
I don't think the design has changed much on your model, but other people here probably know better.
descalabro is online now
post #7 of 27 Old 03-01-2019, 06:00 PM
Liked: 10174
If you are at the short end of the throw, you would get around 900 lumens (high lamp iris fully open) out of the RS67. At half live we would be looking at around 450 lumens. That would give you 10.5FL. I did not ask your throw distance, if it is longer than minimum, then you will have even less brightness. So I could see where at 1,800 lumens, you could be on the dim side.
post #8 of 27 Old 03-01-2019, 06:09 PM
markmon1's Avatar
Quoted: 5250 Post(s)
Liked: 3418
Hi all!
You'll never get 4500 hours. I remember my x500r (same basic series as your RS6710), bulbs would get put on high at 1000 hours and replaced around 1500 hours. New bulb brightens it back to where it was. You should just get a new bulb and see.
The newer series starting with RS500 seemed to about double the usable life of the bulb. I hit 3200 hours on my last RS500 bulb before even having to go to high.
Slonopot likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #9 of 27 Old 03-01-2019, 08:37 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Thanks agian Mike,
My throw is around 14 feet, if I remember correctly. I've never used the dynamic or static iris.
Regardless of how bright it could be, my question is around the fact that I thought the brightness was good when I first setup the PJ 30 months ago and today it looks noticeably dimmer with crushed blacks at less than 1/2 the advertised bulb life.
I have no problem trying a new bulb, I'm just wondering if less than 1/2 the advertised life is normal. After all, nobody ever gets the EPA estimated mileage out of a new car!
schwaggs is offline
post #10 of 27 Old 03-01-2019, 08:44 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Thanks @markmon1 ! This is the feedback I was looking for. I received an extra bulb with the JVC when I bought it so I can easily give that a try. I didn't want to try the new bulb if I was way out of range of normal life of a bulb.
BTW - You wouldn't happen to have pinball machines at your place, would you?
schwaggs is offline
post #11 of 27 Old 03-01-2019, 09:12 PM
markmon1's Avatar
Liked: 3418
Yes, a bunch, lol Why?
markmon1 is offline
post #12 of 27 Old 03-01-2019, 09:41 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
I recognized your name from Pinside. Small world.
schwaggs is offline
post #13 of 27 Old 09-19-2019, 09:25 PM - Thread Starter
schwaggs's Avatar
Quoted: 298 Post(s)
Liked: 414
Update: I didn't get a chance to replace the bulb before it exploded in July at 1950 hours. Popped the new bulb in and it is like a new projector! It was the bulb after all.
Thanks for the advice and help guys.
schwaggs is offline
post #14 of 27 Old 09-19-2019, 09:31 PM
Craig Peer's Avatar
Quoted: 7001 Post(s)
Liked: 8295
Hi all!
1800 hours in my book is pretty good ! 4000 hours is a probably an engineer's pipe dream in Heaven.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #15 of 27 Old 09-19-2019, 09:47 PM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 195
Hi all!
It can be one of three things from most to least likely
- the panel gamma has shifted .. this can be fixed buy doing a gamma only auto-calibration. ou can adjust gamma settings in the menu as well to approximate a fix.
- the bulb actually has actually dimmed to the point of it being noticeable. the larger your screen the sooner you would notice. ie if you needed the extra brightness to begin with. 1800 hours is not all that bad.
- there is dirt build up on a mirror or lens surface inside the projector
Edit: oh sorry, saw you replaced the bulb and all is good
Purple X is online now
post #16 of 27 Old 09-20-2019, 05:05 AM
Quoted: 61 Post(s)
4000 hours life is not unattainable for a modern projector bulb.
Of course, that would depends on the actual type (model) of the bulb and also the power supply board that monitors/powers it.
I've had a bulb once popping, before it even reaching 3500 hours.
But I also had bulbs (same model of bulb on the same projector unit), that exceeded the 4000 hours mark and were still going (albeit with markedly reduced brightness output).
So, I suppose a few bulbs are coming out the factory that aren't that great(?).
evonimos is online now
post #17 of 27 Old 09-20-2019, 07:07 AM
Craig Peer's Avatar
Liked: 8295
For my purposes, a lamp needs to be changed when it is too dim for my tastes. That was usually around 1000 - 1200 hours - 2 - 2/12 years of use for me.
post #18 of 27 Old 09-20-2019, 10:02 AM
Quoted: 61 Post(s)
That's great.
But unfortunately it wouldn't be practical in my case.
A change every 1000 hours would translate to bulb changes roughly every 3 months.
And to be honest, I rarely notice any significant drop in brightness before 2000 hours.
I keep the bulb in 'Economy' mode as long as I can and when I start to see a drop in lumens, I usually just switch to 'Bright' mode.
This commonly happens at the last 1000 hours of the bulb.
However, my experience is limited only to single-chip DLP units.
I've never had a JVC like the one being discussed here.
post #19 of 27 Old 09-20-2019, 10:46 AM
Craig Peer's Avatar
Liked: 8295
That's great.
However, my experience is limited to only single-chip DLP units.
Sounds like you watch yours for longer stretches of time = less lamp strikes. That will give you a longer lamp life. I had to change lamps every 1000 hours or so with my 3 chip DLP - the Sim Lumis.
bdht likes this.
post #20 of 27 Old 09-20-2019, 11:24 AM
Quoted: 61 Post(s)
That's an interesting point you make, but I'm not sure I actually get away with it.
In fact, I have the PJ connected to an HTPC with the screen adjusted to turn off after 10 mins.
The projector follows with settings at 5mins turn off without signal.
I have done that in order to save up on bulb hours, since in the past I ended up forgetting the unit turned on, while I was busy doing something else, or when I doze off in front of the screen late at night.
The result is several turn on/off cycles during each day.
I'd say at least 3 in most days.
But I believe it is better to be like that, than to forget the unit on for no reason or during the night.
post #21 of 27 Old 09-20-2019, 11:28 AM
dkersten's Avatar
Quoted: 703 Post(s)
Liked: 1229
That's great.
Holy Cow, 1000 hours every three months means 4000 hours per year, or 11 hours of watching PER DAY EVERY DAY OF THE YEAR!
Even counting weekends and 6 hours of sleep per night, I don't even have 4000 hours of free time per year, and my kids are grown up so I have a lot of free time...
dkersten is offline
post #22 of 27 Old 09-20-2019, 11:31 AM
Quoted: 61 Post(s)
Yeah, I know.
I'm probably towards the "heavy-duty use" side of things.
I actually made a post on here a couple of days ago, documenting the 21747 total hours on my BenQ W1110 projector.
It's quite a feat for that particular machine, with only regular maintainance and bulb changes.
All other previous units (not from Benq) gave up the ghost well before that mark.
I actually wonder sometimes with the way the projector counts the total hours of use.
Are they true hours of use or they are calculated using a formula?
post #23 of 27 Old 09-20-2019, 11:46 AM
bdht's Avatar
Quoted: 278 Post(s)
Liked: 108
This is not good for the projector or the bulb(though I did read your last post and you hit 20000 hours so apparently its ok xD. Electronics do their best when they maintain a constant temperature. Power cycling frequently throughout the day puts wear on the power supply, regulators, capacitors, and most importantly, as Craig stated, striking the bulb repeatedly reduces its life.
Think of it this way. You spend the same amount of bulb life if you strike it once per day whether its on for 2 hours or 12 hours. I get 7-8000 hours on my W1070 since the projector is on 12-14 hours a day.
bdht is online now
post #24 of 27 Old 09-20-2019, 12:05 PM
Quoted: 61 Post(s)
Yeah I know.
That makes sense.
But It seems that this particular unit has a somewhat more sophisticated lamp power board and monitoring system, that manages to go through the cycles without much damage(?).
In fact, I changed bulb a few days ago and remember that it had reached above 4000 "true" hours and was still going.
Albeit at reduced brightness.
I suppose, what's actually doing far more damage to the bulb and surrounding electronics is continuous stress due to excessive heat.
From my experience, a unit with proper heat dissipation will last longer than one without.
post #25 of 27 Old 09-20-2019, 12:08 PM
bdht's Avatar
Quoted: 278 Post(s)
Liked: 108
They may be used for in a home office, in commercial settings, parents home with children(just like a tv on all day), or by disabled/elderly persons.
bdht is online now
post #26 of 27 Old 09-20-2019, 02:48 PM
dkersten's Avatar
Quoted: 703 Post(s)
Liked: 1229
Sure, but this is the high end projectors forum, these aren't commercial projectors we're talking about, and I'm not letting a day care in my theater.. The thought of dirty kids hands touching my $3500 screen makes me shiver... lol!
dkersten is offline
post #27 of 27 Old 09-21-2019, 06:05 PM
Jon S's Avatar
Quoted: 1124 Post(s)
Liked: 408
My JVC RS-600U has about 1200 hours since I bought it... It is actually too bright for my taste so i have to close down the aperture almost all the way to get the brightness levels right on my 108" Stewart Studiotek 1.1 gain screen.
Previously, I owned a RS-57U and that projector was actually too dim... Even having the aperture opened all the way, the picture seemed dark.
If it's not a BIG screen, it's not a theater...
Jon S is offline
