madMeasureHDR4iso - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By xxxx5
post #1 of 14 Old 03-27-2019, 11:18 PM - Thread Starter
Quoted: 27 Post(s)
madMeasureHDR4iso
the goal is to use madMeasureHDR with iso files
drop the zip in a folder
edit the madMeasureHDR4iso.ini to match your configuration
run madMeasureHDR4iso.exe to see the syntax
for testing,
i modify the search function with 2 popups and copy of the message in the clipboard
1) one to display which is use to execute madMeasureHDR4iso.exe,
2) the other to verify which is use with mpc-be64.exe
(clic ok to continue)
if using mpc without saving mpc-be64.ini ( save having r/w problem if mpc in program files) make sur mpc is configured with "full path" in "tittle bar"
@Manni01 : delete the empty file "mpc-be64.ini" you create for testing
@Manni01 : at home madMeasureHDR4iso.exe /s works with network mapped drive
if you use .bat , don't forget to modify path inside .bat
my results :
<C:\util\autoit\sources\pack_for_avs\madMeasureHDR 4iso.ini>
<c:\util\mpc-be64\><mpc-be64.exe>
D:\isofolder\BDMV\PLAYLIST\00089.mpls
Manni01 likes this.
xxxx5 is online now
post #2 of 14 Old 03-29-2019, 08:28 AM - Thread Starter
Quoted: 27 Post(s)
some improvments (i hope)
xxxx5 is online now
post #3 of 14 Old 03-30-2019, 04:15 PM
3ll3d00d's Avatar
Quoted: 2250 Post(s)
Liked: 2280
I thought I'd post in this thread rather than the HDR one since you commented on this little exe earlier
https://github.com/3ll3d00d/madmeasu...ases/tag/0.3.0 is a build which should search for iso's when used with the -i flag & which has (I think) improved the title detection (and also allows for a choice between the behaviour seen in LAVFilters BDDemuxer via the --use-lav switch and that found in libbluray, this is the default). It also has a -s flag for just dumping the main playlist out and nothing else.
for example, searching for ISOs on a particular drive (with or without silent)
Code:
C:\Users\Matt\Downloads>madmeasurer.exe -i -d0  w: 2>NUL
w:/test.iso,00800.mpls
C:\Users\Matt\Downloads>madmeasurer.exe -i -d0  -s w: 2>NUL
00800.mpls
so you could probably use this as a simpler/faster way to get the playlist (than launching MPC-BE)...
if it gets the right title that is, for me it still isn't exactly the same as the way jriver behaves (which seems to be more like libbluray but not exactly the same). If you remove the 2>NUL and use -vvv then it will dump debug info about why it picked that title.
3ll3d00d is online now
post #4 of 14 Old 03-30-2019, 04:33 PM
Javs's Avatar
Quoted: 6771 Post(s)
Liked: 6388
this thread should be moved to a more appropriate forum.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #5 of 14 Old 03-30-2019, 10:35 PM - Thread Starter
Quoted: 27 Post(s)
Code:
00800.mpls
Perfect !!! but as for you it doesn't give the same mpls as mpc-be (2/14 differents)
(with --use-lav it's 5/14 differents)
xxxx5 is online now
post #6 of 14 Old 03-31-2019, 12:40 AM - Thread Starter
Quoted: 27 Post(s)
i like to call your tool (as an option instead of mpc) with mine but i don't know how to launch it only for one iso file
c:\util\madvr\madmesureanalyser\madmeasurer.exe -i -d0 --use-lav d:\video_d\bluray4k\BT2020\file.iso 1>xxx 2>nul
it's seem to work only with folder
c:\util\madvr\madmesureanalyser\madmeasurer.exe -i -d0 --use-lav d:\video_d\bluray4k\BT2020\ 1>xxx 2>nul
xxxx5 is online now
post #7 of 14 Old 03-31-2019, 01:03 AM
3ll3d00d's Avatar
Liked: 2280
try this one https://github.com/3ll3d00d/madmeasu...ases/tag/0.4.0
Code:
madmeasurer.exe -is w:\test.iso 2>NUL
00800.mpls
I found the mpc-be code that does this job so I'll compare their implementation to see what the difference is (I must say I didn't expect working out how to guess the main title to be such a mission!)
post #8 of 14 Old 03-31-2019, 01:24 AM - Thread Starter
Quoted: 27 Post(s)
Great !
i 'll try to put this option in my tool
i can't use directly yours because for iso file , i create a measurements file with a name like :
"d:\video_d\madvr_mesures\save\Mission Impossible Rogue Nation (2015).iso[!BDMV!PLAYLIST!00800.mpls].measurements"
xxxx5 is online now
post #9 of 14 Old 03-31-2019, 10:05 AM - Thread Starter
Quoted: 27 Post(s)
add an option to use madMeasureDynamicClipping.exe to a folder of measurements files :/t mesurementsfolder
don't forget to edit the ini file to match your configuration
xxxx5 is online now
post #10 of 14 Old 04-02-2019, 02:45 PM
3ll3d00d's Avatar
Liked: 2280
@xxxx5 am I right in thinking you mount the iso as a drive and then measure the index.bdmv found on that drive? If so, where does the resulting measurement file end up?
post #11 of 14 Old 04-02-2019, 10:15 PM - Thread Starter
Quoted: 27 Post(s)
mpc-be mount a drive for me so i don't close it until the end of measurement with madmeasure.
The result was put in the path define in madvr
My script take it , rename it ( file.iso[name_of_mpls].measurements or file.iso[index!bdmv].measurements ) and put it in the path define in my .ini ( path_madmesure_save="d:\video_d\madvr_mesures\save \" )
At last , I close mpc-be
( for playing a file , my script do the reverse option activate /a : rename, put in madvr path then play )
in a first version, (without using mpc) i mounted the drive with virtualclone drive but i don't think it works anymore now
new version : global options /i /[ps]99999 works with folder full of iso
xxxx5 is online now
post #12 of 14 Old 04-03-2019, 09:15 AM
3ll3d00d's Avatar
Liked: 2280
I gave this a quick try in my script and found that if I mounted the ISO and measured then it wrote the measurements file into the iso (i.e. the measurements file survives though a dismount/mount cycle). If this is the case then why do you need a special file name for an iso as opposed to simply mount the iso and play it as if it is any other BDMV folder?
post #13 of 14 Old 04-03-2019, 03:09 PM - Thread Starter
Quoted: 27 Post(s)
With virtualclone drive or mpc-be, the mount bd is read only. (and with a real bd also) so i prefer save measuments file in another folder with a special name.
xxxx5 is online now
post #14 of 14 Old 05-16-2019, 04:55 AM - Thread Starter
Quoted: 27 Post(s)
no need to fill the path_madmesure_use et madvr_ignore_measurement_file variable.
madMeasureHDR4iso.exe read registry madvr to know the values.
xxxx5 is online now
