JVC NX5 Settings Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #31 of 67 Old 11-14-2019, 05:57 PM
Liked: 0
XBOX One X and NX5
I can’t seem to get my x box to recognize my NX5. Can anyone help me with the settings to get my 4K working?
Bearakuda is offline
post #32 of 67 Old 12-18-2019, 02:19 PM
Quoted: 156 Post(s)
Liked: 94
I just got an NX5. Any recommended settings for a batcave, 120" screen since the new update? Primarily for UHD and SD content.
Dirk504 is offline
post #33 of 67 Old 12-18-2019, 07:31 PM
Quoted: 44 Post(s)
Liked: 24
Awesome! There are some moments when I am looking at the image this projector puts out and I am blown away. Enjoy! Go back to page 1 of this thread. There are some settings there to play with. After the upgrade to DTM, I have left my settings at the default and use the Frame by Frame setting for DTM for HDR content and have been happy. The next step is to see what happens to the image when I use the JVC calibration software for the projector.
Dirk504 likes this.
Projector: JVC RS1000/NX5 || Screen: 135" SilverTicket 16:9 || Fronts: Martin Logan Impression 11A || Center: Martin Logan 50xt || Sub: 2x Polk PSW 505 || Surrounds: Martin Logan EM IW || Atmos: 4x Martin Logan EM IC || AVR: Marantz 8012 LCR AMPs: Parasound JC 1s || Consoles: Xbox One S, PS4 ||HT Enhancements: Seats from 4seating.com w/Sound Shakers and risers.
Dferguso is offline
post #34 of 67 Old 12-20-2019, 07:52 AM
Quoted: 156 Post(s)
Liked: 94
Thanks for your input! I used the settings on the first page, along with the update and now I'm blown away lol. This pj has exceeded my expectations, which were already really high.
Dferguso likes this.
Dirk504 is offline
post #35 of 67 Old 12-31-2019, 09:23 AM
ysati's Avatar
Quoted: 27 Post(s)
Jvc n5 hdr
Your recommendations are very interesting.
I have a Radiance Pro 4442 and an OPPO UDP 203 reader.
I tried live Oppo JVC in HDR with Mad Max. Using your settings is not bad but remains problems of brightness and contrast not obvious.
On the other hand with the Radiance in HDR and the JVC in HDR everything is well managed, Brightness, color contrast.
Even without calibration, which remains difficult in HDR, I find the image fantastic.
Here are the pictures of my settings:
ID:	2661856   Click image for larger version
ID:	2661858   Click image for larger version
ID:	2661860   Click image for larger version
ID:	2661862   Click image for larger version
ysati is offline
post #36 of 67 Old 01-31-2020, 05:05 PM
bmx269's Avatar
Just got my NX5, in a light controlled room.
Calibration will come soon, I am glad to see an NX5 specific thread.
bmx269 is offline
post #37 of 67 Old 01-31-2020, 05:14 PM
Azekecse's Avatar
Quoted: 247 Post(s)
Liked: 239
Me 2, also in a light controlled room, welcome bmx269...Interested in your calibration settings.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is online now
post #38 of 67 Old 02-06-2020, 05:00 AM
Azekecse's Avatar
Quoted: 247 Post(s)
Liked: 239
I brought this up in another thread, discovered accidentally, JVC's Screen Adjustment Mode. I didn't see any major differences with it on or off. Anyone else using this on their NX5?
Azeke
post #39 of 67 Old 02-07-2020, 08:18 AM
SirMaster's Avatar
Quoted: 1223 Post(s)
Liked: 847
Well, most screens don't affect the color very much, hence the screen correction modes don't affect the color much either.
If your screen is in JVC's database then I would use the correct screen correction mode unless your projector has been calibrated by measuring its color off the screen.
In that case your screen's color shift will already be accounted for in the overall projector's calibration.
SirMaster is offline
post #40 of 67 Old 02-08-2020, 11:14 PM
Quoted: 50 Post(s)
Hey all. I have a question maybe someone can help with. So I have the nx5 and on the lastest firmware. I have lamp set to low. Basically all settings factory. Using frame adapt for hdr.
So on some content I have noticed some bright areas on peoples faces getting completely blown out a bright white. Not sure why or if anyone else is having this. I could try to take a pic to show want I have noticed. Its very rare but on some movies I have noticed it.
Also does anyone have the best settings to try if I was to mess with settings. I don't have experience with this or any tools to calibrate. Overall I am extremely happy with the nx5. Thanks. Any tips welcomed!
Huntmx24 is offline
post #41 of 67 Old 02-17-2020, 08:21 AM
Imatk's Avatar
Quoted: 42 Post(s)
I just setup my NX5 this weekend. Coming from an RS20 it's pretty spectacular... WAAAY brighter too.
I keep reading about "Dynamic Tone Mapping" is that enabled automatically... and also how do you know if you need a firmware update... and does it do it wirelessly or do you need to connect it to an Ethernet cable?
Also my NX5 is very slow with HDMI switching... up to 20 seconds sometimes. Are you guys noticing the same with yours?
Thanks for any info.
Imatk is offline
post #42 of 67 Old 02-17-2020, 08:47 AM
rwestley's Avatar
Quoted: 676 Post(s)
Liked: 422
1. You must have firmware 3.10 for Dynamic Tone Mapping. See information below from JVC or search thread.
2. Try a different HDMI cable to see if switching speed increases. A good fiber optic such as one by Ruipro is recommended.
3 If you need to update your firmware instructions are at the link below.
https://www3.jvckenwood.com/english/...00_dla-rs1000/
rwestley is online now
post #43 of 67 Old 02-17-2020, 09:30 AM
Imatk's Avatar
Quoted: 42 Post(s)
Thank you!
So when/if I update then the tone mapping will be automatic or do I need to enable it?
Imatk is offline
post #44 of 67 Old 02-17-2020, 11:18 AM
rwestley's Avatar
Quoted: 676 Post(s)
Liked: 422
Thank you!
It will be automatic. The default for HDR is Frame Adapt.
post #45 of 67 Old 02-17-2020, 01:01 PM
Imatk's Avatar
Quoted: 42 Post(s)
Awesome thanks!
Imatk is offline
post #46 of 67 Old 02-17-2020, 02:14 PM
archipaolo's Avatar
Liked: 3
I also have a n5 jvc for two weeks.
It is already updated to the latest software 3.10
It is connected to denon amplifier with a rui pro optical cable and the hdmi switching is quite fast, it takes 7-8 sec
rwestley likes this.
JVC DLA NX5 - JVC DLA RS25
archipaolo is offline
post #47 of 67 Old 02-17-2020, 03:48 PM
Imatk's Avatar
Quoted: 42 Post(s)
So I did the firmware update, set the picture to Frame Adapt and the frame mode to "Frame by Frame"
And the colors look SUPER red.
Looks really bad.
Looks much better on just "Cinema" mode.
What am I missing here?
Imatk is offline
post #48 of 67 Old 02-17-2020, 04:11 PM
jbn008's Avatar
Quoted: 303 Post(s)
Liked: 163
Question, I can't find the "Low Lamp Mode" in the menu.
Looked at all the menu categories. I'm assuming it's in a hidden submenu somewhere.
Anyone care to share?
select the picture mode (natural, cinema, etc.) and it'll take you to a sub menu. it'll be in there with the manual and auto iris.
jbn008 is offline
post #49 of 67 Old 02-17-2020, 04:51 PM
Imatk's Avatar
Quoted: 42 Post(s)
Yeah finally found it, but after the firmware update and the new fancy frame mapping it looks pretty terrible with the frame mapping on.
Imatk is offline
post #50 of 67 Old 02-18-2020, 07:50 AM
Imatk's Avatar
Quoted: 42 Post(s)
You may just need a different cable. I had to swap cables to get my Roku to recognize the NX5 as having 4k @ 60fps.
After the update it wouldn't recognize it even with my new cable though.
Not sure what firmware you're on, but if it's the latest one I might be in the same boat with you.
Still trying to figure out how a firmware update disabled 4k on my Roku.
Imatk is offline
post #51 of 67 Old 02-18-2020, 09:20 AM
Azekecse's Avatar
Quoted: 247 Post(s)
Liked: 239
Just a quick thought, try changing the settings on your Roku to 4K @ 25f/s or 30f/s and see if that works, then you may be able to switch it back to 60f/s. I leave my Video settings in Auto mode. Hope this helps.
Azeke
post #52 of 67 Old 02-18-2020, 09:57 AM
Imatk's Avatar
Quoted: 42 Post(s)
Azeke
I can force it to output [email protected] but if I set it to auto, or if I try to set it to [email protected] without forcing it it reverts back to 30 after not passing the test.
Imatk is offline
post #53 of 67 Old 02-18-2020, 11:31 AM
mactoast's Avatar
Quoted: 57 Post(s)
Liked: 46
Sounds like you are using the HDR frame adapt mode with standard SDR (bluray) video. That will give you the awful red picture you describe. Only use "frame adapt" mode with HDR source material. Use natural or cinema for all other content. Also the projector "should" automatically switch modes when it detects the different source material but they don't always do that. I always manually verify the correct mode.
mactoast is offline
post #54 of 67 Old 02-18-2020, 12:53 PM
Imatk's Avatar
Quoted: 42 Post(s)
Ok, how do I set it up to use HDR for one and Cinema for the other?
Imatk is offline
post #55 of 67 Old 02-19-2020, 09:06 AM
mactoast's Avatar
Quoted: 57 Post(s)
Liked: 46
It should switch automatically but as I said they don't always behave properly. I always verify the setting manually, just takes a second. Start the movie and then press the picture mode button on the remote. Select frame adapt for 4k discs or when streaming HDR content. Natural or cinema for everything else.
mactoast is offline
post #56 of 67 Old 02-19-2020, 09:17 AM
Imatk's Avatar
Quoted: 42 Post(s)
So I set it on this first tab and it looked red. That's the tab I set back to "Cinema"
There is another setting I think on the third tab that has settings as well.
Is the first tab the one that it should be set on?
Imatk is offline
post #57 of 67 Old 02-19-2020, 10:31 AM
mactoast's Avatar
Quoted: 57 Post(s)
Liked: 46
The first tab on the left, select picture mode and set appropriately to the content you are viewing. Picture mode button on your remote is just a short cut to get to that setting.
mactoast is offline
post #58 of 67 Old 02-19-2020, 11:31 AM
Imatk's Avatar
Quoted: 42 Post(s)
So if I set it to "Cinema" it will automatically switch on that first tab when it detects an HDR source?
Imatk is offline
post #59 of 67 Old 03-31-2020, 08:57 AM
kemannthey's Avatar
Quoted: 76 Post(s)
Liked: 35
Did you ever figure this out? I saw this in one scene this weekend on 4k udh Pacific Rim.
kemannthey is offline
post #60 of 67 Old 03-31-2020, 09:25 AM
Quoted: 50 Post(s)
No I didn't
Huntmx24 is offline
