Would the NX5 be too bright for my room? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Todd G.
post #1 of 5 Old 05-05-2019, 06:05 AM - Thread Starter
lbstoller's Avatar
Hi all. I am upgrading from an old Sony VPL-HW10, and I was planning on getting an NX5, but I have seen some posts that make it sound like it would be too bright in my room.
My setup is a fully light controlled room, with dark dark red walls and ceiling, but a not very dark carpet. I have a 100in diagonal Da-Lite Cinema screen, 1.3 gain. Projecting from a ceiling mount from about 14 feet, we sit at about 12 feet from the screen.
So what do people think, will I be able to lower the light output enough and still have a great image?
lbstoller is offline
post #2 of 5 Old 05-05-2019, 06:14 AM
markmon1's Avatar
Quoted: 4657 Post(s)
Liked: 2951
Yes, I wouldn't be worried about this at all. Also, that 1.3 gain screen is probably really only about 1.1 gain, if that. But its sort of sparkly right?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 5 Old 05-05-2019, 06:30 AM - Thread Starter
lbstoller's Avatar
Yes, it is a bit sparkly. I am not adverse to changing the screen, but probably not for a while.
post #4 of 5 Old 05-05-2019, 06:38 AM
Todd G.'s Avatar
Quoted: 159 Post(s)
Liked: 373
Good morning!
I’m using the RS2000 (NX7) sitting 10.5’ back from a Stewart StudioTek 130 (1.3 gain) screen and throwing 15’ in a very dark room. The projector is calibrated now, but I didn’t think it was overly bright before that and I didn’t have any artifacts/sparkles/hot spots. The NX5 will be a little less bright than the NX7 and I think its light output would suit your configuration well.
Best of luck with your decision.
JohnnyWilkinson likes this.
Basement bat cave: JVC RS2000, 100" 16:9 Stewart StudioTek 130, Denon AVR-X4400H, Oppo UDP-203, Polk RTi A7 towers/CSi A6 center/65RT in-wall side surrounds (2)/70RT in-ceiling Atmos (4), dual PSA V1811 subwoofers
Todd G. is offline
post #5 of 5 Old 05-05-2019, 10:44 AM
tommarra's Avatar
Quoted: 572 Post(s)
Liked: 340
With low lamp you should be fine I think
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is offline
