Anyone have their ceiling mounted projectors plugged into a UPS? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mattztt
post #1 of 10 Old 05-23-2019, 02:41 PM - Thread Starter
Fox
Fox's Avatar
My outlet is in the ceiling right behind my mount at the moment I just have a small surge protector (single outlet) , the last several days we've gotten several < 1 s brownouts which is frustrating. (not even all devices lose power, but some do). I was looking at UPS (uninterruptible power supply) surge protectors with the battery backups, I'd need 2-3 to cover all my devices/locations but I'm not sure what to do about the projector the ones I find all seem to be too large to put up there I was curious if something exists that would be useful?
Fox is offline
post #2 of 10 Old 05-23-2019, 03:06 PM
mattztt's Avatar
Quoted: 355 Post(s)
Liked: 352
My UPS is in my rack and I run a short extension cord from it to an "inlet" (opposite of an outlet - see below) in the wall next to it. That is connected with a run of 12/2 Romex in my wall to the outlet in the attic where my projector is plugged in.
Craig Peer likes this.
mattztt is offline
post #3 of 10 Old 05-23-2019, 03:16 PM - Thread Starter
Fox
Fox's Avatar
I was considering something like that I need to get a 4k cable installed maybe I'll have them pull an extension cord through with it.
Fox is offline
post #4 of 10 Old 05-23-2019, 03:24 PM
mattztt's Avatar
Quoted: 355 Post(s)
Liked: 352
Be aware that it's against code to run low voltage and high voltage in the same conduit and additionally if you run a signal cable parallel to a power cable you can get RF interference in the signal. A fiber optic HDMI cable may protect against this if you don't have any choice.
Additionally, some electricians as well as some inspectors are skeptical of the power inlet. It's an unusual fixtures and there's disagreement about whether it's use is is consistent with the NEC. I ran the wire myself and just covered the box with a blank plate for inspection and then installed my inlet afterwards.
Running a plain extension cord through the wall would definitely be against code as most extension cords are not rated for in-wall use.
mattztt is offline
post #5 of 10 Old 05-23-2019, 03:33 PM
dbpaddler's Avatar
Quoted: 134 Post(s)
Liked: 74
As an outlet it's fine according to a custom cable company I talked to. Try to get a double male cable and it's against whatever safety standard they go by. If you could do a double male power cable then you could just use a standard female socket. They charge a hefty premium for that male outlet over a female one.
Sent from my SM-N960U1 using Tapatalk
dbpaddler is offline
post #6 of 10 Old 05-23-2019, 03:39 PM
Craig Peer's Avatar
Quoted: 6560 Post(s)
Liked: 7588
I too use an extension cord from my Panamax M1500-UPS-PFP through a port in the wall into my projector closet. For in wall / ceiling, one could just use Romex and put a plug on the UPS end to plug into the power conditioner, and an outlet on the projector end. Or a box with a extension cord " pigtail " on the UPS end. That should satisfy code.
Craig Peer is online now
post #7 of 10 Old 05-23-2019, 08:42 PM
airscapes's Avatar
Quoted: 489 Post(s)
Liked: 403
no. but my cabinet sitting projector is plugged into a UPS as is the DVR, Receiver and all goodies.. UPS = no missed anything :-)
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 120"
http://www.airscapesart.com
airscapes is offline
post #8 of 10 Old 05-24-2019, 04:03 AM
Mocs123's Avatar
Quoted: 100 Post(s)
Liked: 27
Is there such a thing as a power cord or extension cord that is rated for in wall use?
7.1.4 Theater Room (In Progress): JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, NXG-NX BAS 500 (for now)
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is online now
post #9 of 10 Old 05-25-2019, 07:39 PM
bud16415's Avatar
Quoted: 1987 Post(s)
Liked: 1003
There is no cord that is allowed by code to even be passed thru a hole in a wall (room to room) let alone run inside a wall.
The proper way is to use an inlet in the equipment area where many things will be plugged into the battery backup power conditioner and an outlet on the end closest to the projector. These two things will be wired together with romex in compliance with code. A short pig tail is then used to plug into the conditioned power and the inlet.
If you want to run an extension cord it would be allowed in a wire raceway that is 100% accessible for the whole length. This is what I did for my projector power. I built an open wire raceway from my equipment to my projector and it holds my extension from the power conditioner and also my communication cables for the signals to the projector.
Bud
bud16415 is offline
post #10 of 10 Old 05-26-2019, 01:53 AM
Spizz's Avatar
Quoted: 448 Post(s)
Liked: 289
I am using a Furman F1500 UPS with my projector
Spizz is offline
