Very Odd HDMI or Projector to Receiver Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-04-2019, 07:37 PM - Thread Starter
coderguy's Avatar
Quoted: 2349 Post(s)
Liked: 1271
Edit - Now (mostly) Resolved
My issue was self-resolved, I will leave this here in case anyone else comes across this. Very important to check your receiver video settings when setting up a new projector, because it may be adding CA looking halos around HTPC text due to Chroma conversion issues (and my Denon avr-x3400h doesn't seem to take any setting correctly - whether RGB, YcBcRc422, or 444 color). It looks similar to a CA or convergence error even when it is NOT actually that issue. I fixed the problem by turning Video processing OFF and setting the receiver to game mode to minimize lag and reduce processing. The side effect is that I lost my volume osd.
Resolved Issue
My Denon receiver was adding a 'CA LIKE' effect to text on my HTPC. Taking the receiver out of the equation 100% eliminates the issue. Pictures are below. Receiver is a Denon avr-x3400h. I added this receiver just a few months ago, but I guess I hadn't used my HTPC that much until lately so I didn't really notice it.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #2 of 9 Old 06-04-2019, 08:07 PM - Thread Starter
coderguy's Avatar
Liked: 1271
Images of the Chroma Issue below...
Denon Receiver adding outline around Small HTPC Text
(the blue & yellow looks like a camera error, but it's not)
Without Receiver (Direct Nvidia to Projector)
Both images are exaggerated as is usual with a cheap camera, but it makes the point.
I can see the error from seating distance, text looks perfectly sharp when removing the Denon.
coderguy is offline
post #3 of 9 Old 06-04-2019, 10:58 PM - Thread Starter
coderguy's Avatar
Liked: 1271
Well I did fix the issue by turning the video conversion off, but the side effect is that I will no longer get the VOLUME OSD when I change the volume. The menus still work as far as osd since it re-handshakes and now only applies processing while you are in the menu.
That's very weird that anytime I enable the volume osd I get the halo around HTPC text. Wow, I'm at a loss of words unless my receiver is 'mildly defective'. However, even if it is, I'm not sending it back for that, I'll just live without the volume osd rather than live with a halo.
My Onkyo nr-676 doesn't have that issue, maybe should have stuck with the Onkyo despite the slightly harsher trebles and vocals.
coderguy is offline
post #4 of 9 Old 06-05-2019, 03:40 AM
markmon1's Avatar
Quoted: 4418 Post(s)
Liked: 2768
Is there a network API you can use? Then perhaps you can control receiver volume and display it in your own HUD inside windows. This is the approach I'd be taking at least. I suspect you may be capable of it as well.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #5 of 9 Old 06-05-2019, 03:54 AM - Thread Starter
coderguy's Avatar
Liked: 1271
There are options, but all I have to do is turn my head to the right to see the volume on the receiver, but I am pretty lazy.
However, I still watch movies mostly on Bluray and Roku and not on MadVR.
So we'll see...
coderguy is offline
post #6 of 9 Old 06-06-2019, 08:31 AM
Craig Peer's Avatar
Quoted: 6557 Post(s)
Liked: 7581
So we'll see...
I decided to run video directly to my RS4500 from my Lumagen and bypass my Denon entirely. So that's what I do - just turn around and set the volume at the beginning of the movie. Easy enough. I moved my X8500 to eye level. No question now whether the receiver is affecting the picture.
Craig Peer is online now
post #7 of 9 Old 06-07-2019, 12:25 AM - Thread Starter
coderguy's Avatar
Liked: 1271
The problem is a Chroma error but this just shouldn't be happening with a Vanilla 1080p NVIDIA > Receiver > Projector setup. The receiver is trying to force convert the Chroma regardless of whether I send it RGB, 422, or 444 color from the NVIDIA Card.
I mean this issue makes zero sense overall, this is something that should have been resolved by 2010, not on a 2018 Denon receiver.
coderguy is offline
post #8 of 9 Old 06-07-2019, 03:38 AM
talon95's Avatar
Quoted: 332 Post(s)
Liked: 184
I have it off on my older Denon too (x2200 I think). For 4k HDR, I could never get anything but a pink colored image. Kinda annoying.
talon95 is offline
post #9 of 9 Old 06-07-2019, 04:28 AM
Archibald1's Avatar
Quoted: 1808 Post(s)
Liked: 1004
When you think about what HDMI was supposed to be, a convenient and high bandwidth combined AV interface designed to reduce the number of cables required, then it makes it laughable that there are so many issues with it and that so many choose (or have) to do separate connections to avoid any video issues.
HDCP is the spawn of the devil as well....
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
