HELP JVC RS 440U Will not play standard DVD Movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-12-2019, 01:26 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 1
Just installed my New Rs440 3 weeks ago and last Friday for the first time I played a standard DVD and no picture . It will play Blu-ray and 4K. I called JVC and they have been no help at all. I Have played again with it for the last 2 hours changing Cables and inputs but still NO pictures . I can not believe this is not backwards compatible . I am Using a OPPO 205 player and I have even set up my old OPPO 83 and I did get a picture but the colors where only red and bluein HDMI 1. I have set the OPPO 205 to my 4k TV and it works perfect.
Thanks for any help.
glucas168 is offline
post #2 of 8 Old 06-12-2019, 01:29 PM
Buddylee123's Avatar
Quoted: 867 Post(s)
Liked: 614
Set your player to output at 1080p or 4K. The JVC projectors don't support DVD resolution, crazy I know.
Edit: It should be under custom resolution on the OPPO
Buddylee123 is online now
post #3 of 8 Old 06-12-2019, 02:49 PM
Craig Peer's Avatar
Quoted: 6557 Post(s)
Liked: 7581
Upscaling it should work. I'm able to watch my one remaining DVD on my RS4500 - " Team America : World Police - Unrated Version " ( F ya ! ).
Craig Peer is online now
post #4 of 8 Old 06-12-2019, 05:37 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 1
I was set at 1080p Auto. Should I take off Auto put it on 24Hz or 50Hz or 60Hz , There are the same choices for the UH [4K]?
Thanks for your help.
post #5 of 8 Old 06-12-2019, 07:54 PM
Quoted: 867 Post(s)
Liked: 614
I just had to set mine to custom resolution and 1080p. My frame rate is set to the factory settings and I think that was auto.
post #6 of 8 Old 06-12-2019, 08:04 PM
Javs's Avatar
Quoted: 6777 Post(s)
Liked: 6393
Try 'EDID 2' in the JVC Menu.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #7 of 8 Old 06-12-2019, 08:05 PM
DavidHir's Avatar
Quoted: 2520 Post(s)
Liked: 2196
I was just going to say, don't you have the Blu-ray - but then I just looked at mine and it's the R rated version.
DavidHir is offline
post #8 of 8 Old 06-13-2019, 07:29 AM
Craig Peer's Avatar
Liked: 7581
I have both. Can't bare to part with the unrated version !
