Red splotch on Sony VPL-VW295ES - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Ryan Tremblay
  • 1 Post By descalabro
post #1 of 5 Old 07-08-2019, 09:02 PM - Thread Starter
Liked: 1
I just bought a Sony VPL-VW295ES from ProjectorPeople.com and right out of the box with no input source, it's displaying a big red splotch in the upper center of the screen (see attached photo). I'm not finding anything in the manual or in online searches that help diagnose the problem, so I'm assuming at this point that I got a bad unit. Has anyone seen anything like this before?
Ryan Tremblay is offline
post #2 of 5 Old 07-08-2019, 09:29 PM
descalabro's Avatar
Quoted: 403 Post(s)
Liked: 152
Hi,
I am almost sure there is some kind of particle (dust, textile, plastic) on the surface of one of the 3 image panels. If you turn the focus ring on the lens and the red splotch becomes sharper, then it means it's a particle. If it doesn't get sharper, then the issue is likely the panel itself.
Anyway, return this projector if you can.
descalabro is offline
post #3 of 5 Old 07-09-2019, 07:54 AM
Mike Garrett's Avatar
Quoted: 11825 Post(s)
Liked: 9357
You need to exchange.
Mike Garrett is offline
post #4 of 5 Old 07-10-2019, 10:21 PM - Thread Starter
Liked: 1
Thanks all. I checked and the splotch did change when adjusting focus. I told their tech support this and they agreed it must be something on the lcd panel and also agreed to swap out the projector for a new one. Hopefully this is a one time thing...
Archibald1 likes this.
post #5 of 5 Old 07-11-2019, 09:28 AM
descalabro's Avatar
Quoted: 403 Post(s)
Liked: 152
From what I’ve seen on this forum, I don’t think it’s common on Sony projectors. Don’t worry.
