Next Projector Advice - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Mike Garrett
post #1 of 8 Old 07-20-2019, 08:04 AM - Thread Starter
LCC
LCC's Avatar
Quoted: 14 Post(s)
I know everyone hates these threads, but am in bit of a pickle. I thought I would get the NX5 or Nx7. I have been in the thread reading and am seeing a lot about the 17:9 vs 16:9 aspect ratio and also some of the current issues. Admittedly I don't know enough about it to really understand if this is a big deal. So let me throw out what I have, and ask for opinions. The projector is the last piece I am upgrading.
I have a dedicated bat cave. All walls and ceilings and floor are black/very dark. I have a 16:9 120" dragonfly 4k Ultra White screen. Seating distance is 11 feet. The theater is used for sports and movies. I currently have a Sony vpl-hw40es. Have an Oppo 203 and Apple 4K TV as sources. I get killer deals on JVCs. Wondering if The extra money for the NX5 or NX7 is worth it over something like the LX-UH1. Or any other eshift model out there given current set up and uses. Downsides to 17:9 NXs given I have a 16:9 screen?
Thanks for indulging.
LCC is offline
post #2 of 8 Old 07-20-2019, 08:43 PM
Mike Garrett's Avatar
Quoted: 12540 Post(s)
Liked: 10154
No question, the RS1000/NX5 and RS2000/NX7 are worth it over the UH1 for movies. With your screen size, you will be able to use the DCI P3 filter in the NX7, so if you have the budget, that would be my first recommendation.
Mike Garrett is online now
post #3 of 8 Old 08-06-2019, 07:59 AM - Thread Starter
LCC
LCC's Avatar
Quoted: 14 Post(s)
Dealer is holding an NX5 and NX7 for me. Trying to pick up this afternoon. Is the DCI P3 filter really worth the price difference? Any other glaring advantages to the NX7?
LCC is offline
post #4 of 8 Old 08-06-2019, 08:07 AM
Liked: 10154
The NX7 has higher native contrast and the DCI P3 color filter. Most on AVSF felt the NX7 was worth the difference, but if your screen is large and low gain, you may not want to lose the 10% of light output to use the filter.
post #5 of 8 Old 08-06-2019, 08:17 AM - Thread Starter
LCC
LCC's Avatar
Quoted: 14 Post(s)
Great. Thanks. It's a 120" Dragonfly 16:9 4K Ultrawhite in a completely light controlled room. Great screen, just not a ton out there about them. Got it through a dealer.
LCC is offline
post #6 of 8 Old 08-06-2019, 08:24 AM
Liked: 10154
You should be able to use the filter with that screen, at least for a while.
post #7 of 8 Old 08-06-2019, 08:27 AM - Thread Starter
LCC
LCC's Avatar
Quoted: 14 Post(s)
OK. I'm curious. What does for a while mean with a smiley face ha ha???
LCC is offline
post #8 of 8 Old 08-06-2019, 08:37 AM
Liked: 10154
Nobody can use the filter for the full life of a lamp. At some point, the image gets too dim.
Jive Turkey likes this.
