Help me decide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-12-2019, 10:39 AM - Thread Starter
eyeage30's Avatar
Quoted: 14 Post(s)
Help me decide
Hi everyone,
Made my foray into projectors nearly a decade ago and have been without one for nearly two years. It's time to get back into it. I have the option between a 285ES with 3 year warranty (Demo) vs RS500U with 100 hours and has been calibrated for $2000 each. I'll likely build my screen unless there are good screens out there for ~$200. I would also be happy with less, to be honest, for instance I also have the option of a used 5020UB with 100 hours on lamp and extra lamp for $800. Or I can do a BenQ 2050 for $300 starting out and work my way up again. Just looking for some opinions on this. Just for reference, my previous projectors were: HD250 JVC and a Midrange sony. So my standards aren't as high as some. Just let me know what your thoughts are. Thanks
eyeage30 is offline
post #2 of 3 Old 08-12-2019, 11:01 AM
JSKMDWK's Avatar
Quoted: 65 Post(s)
Liked: 57
Sony 285 sounds like a good option. You could also find a newer used JVC for under $2k. Maybe a DLA X550 for example.
New theater build thread
Would I have stayed happy not knowing how good it could be? -- My first theater in print -- My first build- Mocha Theater Construction
JSKMDWK is offline
post #3 of 3 Old 08-12-2019, 08:10 PM - Thread Starter
eyeage30's Avatar
Quoted: 14 Post(s)
Thanks JS,
Would you put the x550 over the 285es?
eyeage30 is offline
