Bes screen for JVC 4910 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-30-2019, 11:21 AM - Thread Starter
Liked: 0
I will be using a jvc 4910 in my living room with white walls, although I plan on painting the wall that the projector is projecting onto into a darker color. I will use it in the evening with all the lights off and very little ambient light.
Which screen would be the best for this setting? Best value? I heard that JVCs can be a little dim, I might purchase a new lamp even though its got fairly low hours on it. Thanks
Hunic Srdan is offline
post #2 of 2 Old 08-31-2019, 04:35 PM - Thread Starter
Liked: 0
Bump
