Will the new JVC LX-NZ3 be native 4K? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 145Likes
post #361 of 385 Old 01-28-2020, 11:46 AM
Craig Peer's Avatar
Quoted: 7602 Post(s)
Liked: 9380
Brighter movies like this do look good.
ID:	2677278   Click image for larger version
ID:	2677280   Click image for larger version
ID:	2677282   Click image for larger version
jsgrise, cardoski and DunMunro like this.
Craig Peer is online now
post #362 of 385 Old 01-28-2020, 12:38 PM
Mike Garrett's Avatar
Quoted: 13163 Post(s)
Liked: 10796
That is what I found. Bright movies and content like sports looked great.
Mike Garrett is online now
post #363 of 385 Old 01-28-2020, 12:55 PM
Liked: 6
This projector is about as bright in lower laser as my RS4500 is in mid laser. HDR certainly looks bright enough on my screen.
Consider that "variable low" is like Normal with dynamic laser dimming. Echo is different.
Giuseppe D'Agata is offline
post #364 of 385 Old 01-28-2020, 12:56 PM
Craig Peer's Avatar
Liked: 9380
Originally Posted by Giuseppe D'Agata View Post
Except for Laser, those looks like default setting. What do you have in advanced menu?
This is all I've got setting wise.
ID:	2677324   Click image for larger version
ID:	2677326   Click image for larger version
post #365 of 385 Old 01-28-2020, 02:30 PM
Liked: 6
Thanks! I prefer gamma 2.4 by the way, open up some more details in the dark areas.
post #366 of 385 Old 01-28-2020, 03:48 PM
Craig Peer's Avatar
Liked: 9380
I may have changed the gamma just to see what effect that had. If I were keeping it, I'd do more tinkering. But I need to send it back next week.
post #367 of 385 Old 01-30-2020, 06:00 PM
Schurter's Avatar
Quoted: 56 Post(s)
Schurter is offline
post #368 of 385 Old 01-31-2020, 02:11 PM
Liked: 6
Originally Posted by Schurter View Post
Another unfair video. My NZ3 looks marvelous.
Craig Peer likes this.
post #369 of 385 Old 01-31-2020, 04:34 PM
sunol's Avatar
This looks like it is becoming the 'official' JVC LX-NZ3 thread. Anyone know how to make it so?
sunol is offline
post #370 of 385 Old 02-02-2020, 10:26 AM
Quoted: 21 Post(s)
So in the video review the dark scenes from guirdians if the Galaxy looked pretty flat/poor.
Is it really that bad or just just his setup (wash out + who knows what hdr stack).
kemannthey is offline
post #371 of 385 Old 02-03-2020, 01:24 PM
Liked: 6
I don't have guardians of the Galaxy to make a direct comparision but I can tell you that its not that bad at all. Its not a perfet projectr and contrast its not its best quality but I'm globally satisfied.
This is my initial impression after about 50 hour.
What I like:
- Brightness is impressive, even in echo mode. A TV like experience
- Colors are intense, deep and natural
- Resolution is beyond my expectation, e-shift works very well and without artifact or any added noise.
- Noise in echo mode, the projector is not udible
- Ranbow in 50/60 Hertz is almost absent
- Lens shift and throwing distance is perfect for my room
- I can leave it on without worrying about the lamp duration. With two kids who use it insted of TV is not trivial
What I don't like (but I can live with)
- Lens quality is poor, lot of cromatic aberrations and halo on menu text (which is not so evident on screen)
- Noise in Standard and variable high/low mode is udible
- Noise in variable high/low (80% of light) is equal to noise in Standard mode(100% light). For reference echo is 70% of light and its dead silent. Hope a firmware upgrade can fix this.
- Native contrast can be better
- Rainbow in 24P mode is clearly visible to my eyes (i'm very sensitive), but I have accepted it.
- Focus has slight shift when projecter is cold/hot, again the lens is poor.
- The menu has a good style if we had been twenty years ago
- Lens shift do not have a zero position, so you don't know if you have it enabled or not and how much. Its a minor issue, but I don't like it.
- HDMI synch is slow and may happen frequently when the Apple TV output format is different than the content you are watching.
Craig Peer and jsgrise like this.
post #372 of 385 Old 02-04-2020, 09:25 AM
sunol's Avatar
Thanks Giuseppe - as Craig knows, I am strongly considering this for my 135" screen in a non-dedicated workshop/mancave. Projector will be ~17ft from screen, ceiling mounted at 9ft and use will be divided between daytime/sports and movie viewing. Here is my thought process -
- full power when watching sports during the day. Usually with people over. Fan noise not likely an issue.
- eco at night should be plenty
- I don't see DLP rainbows
Pros:
No bulb dimming. Never have to change a bulb.
Cheaper than NX5 or Optoma laser dlp
Much brighter than NX5
Cons:
Contrast/blacks (but that will be hurt anyway by my space, grey/green walls, etc)
Fan noise (but ceiling mounted in eco mode should be ok, not an issue when watching sports)
Manual lens adjustments (but how often am I really going to mess with it? Not using panamorph, etc)
From the YouTube videos and pro-reviews out there, you'd think this was the worse projector ever. And I get it. If I had a dedicated space, this would be a non-starter. I would be looking at an NX5 or even an NX7 because the space could justify it. Or for the same price, something quieter/dimmer/higher contrast like an Epson for my quiet black room. However, for a non-dedicated space with ambient light (and ambient people), this seems like a great option.
sunol is offline
post #373 of 385 Old 02-04-2020, 09:39 AM
Craig Peer's Avatar
Liked: 9380
Pros:
Cons:
If I was still in my old house with the projector in an open beam ceiling family room ( with zero light control ), this projector would be just the ticket. Or, as a 2nd projector for watching sports and HDTV with some lights on, it would be perfect.
post #374 of 385 Old 02-04-2020, 10:06 AM
Liked: 0
Pros:
Cons:
What screen choice are you going to pair with that ambient light setup?
Ben M is offline
post #375 of 385 Old 02-04-2020, 10:16 AM
sunol's Avatar
Stewart Cima Neve (1.1 gain)
sunol is offline
post #376 of 385 Old 02-04-2020, 10:21 AM
Schurter's Avatar
Quoted: 56 Post(s)
Pros:
Cons:
After watching the reviews.
Reading.
The uhz65 I feel is a better projector.
I have read the thread 3 times now.
The adjust thats available for picture is outstanding.
I really want to see a side by side on these 2.
My goal is 150 inch screen.
So I need the output.
Only other projector I am looking at is the 6050
Schurter is offline
post #377 of 385 Old 02-04-2020, 10:24 AM
Liked: 10796
In order of preference, I would use a HALR, FireHawk or SI Slate.
post #378 of 385 Old 02-04-2020, 10:39 AM
sunol's Avatar
Makes sense. For me, I already have the Cima.
sunol is offline
post #379 of 385 Old 02-04-2020, 11:39 AM
sunol's Avatar
The uhz65 I feel is a better projector...
Agree. Would also like to see them side by side.
The uhz65 is two years old, but has the .66 chip. Maybe better lens?
The JVC has auto-tone mapping, more lens shift (if needed) and is ~$1k cheaper
uhz65 is probably quieter.
sunol is offline
post #380 of 385 Old 02-04-2020, 01:04 PM
Liked: 0
Does anyone have a "in-depth" Calibration for this projector? (JVC LX-NZ3)
I have this unit, and will be doing a comparison on using Seymour AV Glacier White screen vs. Carl's Place Ultra Gray Screen material.
Trying to help those black levels a tad. Any calibrations would be great to see and try!!!
Kellen Fleener is offline
post #381 of 385 Old 02-10-2020, 06:25 PM
Quoted: 1018 Post(s)
Liked: 496
LX-NZ3 head to head with the 6050UB:
kemannthey and Kellen Fleener like this.
DunMunro is offline
post #382 of 385 Old 02-10-2020, 06:47 PM
Craig Peer's Avatar
Liked: 9380
These two projectors are really for two different uses. The JVC - watch like a TV in a less than ideal room. The Epson - works better in a dedicated space as a home theater projector. A closer match up would be a JVC RS540 and the 6050UB. Same price more or less too.
post #383 of 385 Old 02-11-2020, 08:16 AM
Liked: 0
[quote=DunMunro;59227874]LX-NZ3 head to head with the 6050UB:
post #384 of 385 Old 02-14-2020, 04:42 PM
antneed's Avatar
I am also torn between the Optoma UHZ65 and the NZ3...
wish there were some direct comparisons...
what do the pros on this thread recommend between these two projectors?
antneed is offline
post #385 of 385 Old 02-14-2020, 05:30 PM
Liked: 496
@antneed You might want to also consider the ZK507:
https://www.projectorcentral.com/Opt...tor-Review.htm
DunMunro is offline
