Difference vw295es vw270es - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-22-2019, 09:29 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
In Europe we seem to have the Sony 4K projector ‘vw270es’ currently, which is the successor of the ‘vw260es’. In the us it seems it went from vw285es to vw295es. Are these the same projectors for different regions? If so, why would they have different numbers? Can’t seem to find much info on this as depending on a site’s location they only feature one or the other.
ijansch is offline
post #2 of 5 Old 09-23-2019, 05:26 AM
Archibald1's Avatar
Quoted: 2036 Post(s)
Liked: 1104
Yes.
No-one but Sony knows this.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #3 of 5 Old 09-23-2019, 08:33 AM
Mike Garrett's Avatar
Quoted: 12534 Post(s)
Liked: 10148
Same projectors. All manufacturers do this. That way if they are sold in different regions (VW270ES shows up in the US), the manufacturer knows that somebody is breaking dealer agreements importing projectors from another country.
Mike Garrett is offline
post #4 of 5 Old 09-25-2019, 04:08 PM - Thread Starter
Quoted: 31 Post(s)
Liked: 2
Ok so it’s safe to use US reviews and configuration tips but still buy the EU version. Thanks!
ijansch is offline
post #5 of 5 Old 09-25-2019, 05:56 PM
Liked: 10148
Yes, most of the time. Every now and then, there is a difference. But 95% of the time they are exact same projectors.
