$1000 for ceiling mount or $2000 for NX7 instead of NX5? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By blee0120
  • 1 Post By RaceCarDriver
post #1 of 11 Old 09-29-2019, 09:39 PM - Thread Starter
jsenger's Avatar
Quoted: 12 Post(s)
Liked: 0
My theater room was built for mounting an NX5 behind the back wall 21 feet from a 135” 16:9 screen with 1.1 gain in a black room. Helpful commenters suggested I explore a ceiling mount closer to the screen for more brightness. I just learned that would cost $1000. Would I be better off upgrading to an NX7 for $2000 instead?
jsenger is offline
post #2 of 11 Old 09-29-2019, 09:42 PM
blee0120's Avatar
Quoted: 995 Post(s)
Liked: 723
I would choose the RS2000/N7 over a RS1000/NX5 every day of the week. If it cost $1000 to reconfigure and move the mount, I personally would just leave it. Probably would not notice too much of a difference moving it forward unless it's an easy fix.
blee0120 is online now
post #3 of 11 Old 09-30-2019, 01:56 AM
markmon1's Avatar
Quoted: 5922 Post(s)
Liked: 3996
I'd buy the NX7 also but then mount it in the correct spot, about 14 feet from your screen. Why is this costing $1000? No one is spending that kind of money on a mount. Why not get a local handy man to build you a mount shelf? I think I paid a guy around $150 for this.
I'll never have to buy a mount again. I can just slide any projector up here.
ID:	2621686   Click image for larger version
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is online now
post #4 of 11 Old 09-30-2019, 07:55 AM
Mike Garrett's Avatar
Quoted: 13206 Post(s)
Liked: 10831
What all has to be done, to move the projector closer?
Mike Garrett is online now
post #5 of 11 Old 09-30-2019, 08:08 AM - Thread Starter
jsenger's Avatar
Quoted: 12 Post(s)
Liked: 0
He says "We'd have to retrofit a few wires for power, HDMI video, and control to the ceiling location where we'd have the projector location. That will run about an additional $600, plus the ceiling mount for those are around $400."
jsenger is offline
post #6 of 11 Old 09-30-2019, 08:28 AM
Liked: 10831
Ceiling plate, drop tube and mount should be less than $250 to purchase. If you have access above the ceiling, it is not that difficult to relocate the wires there, but if I was an electrician coming out to do the work, I could see charging $400 to do this.
post #7 of 11 Old 09-30-2019, 02:22 PM
jmeitz's Avatar
Quoted: 67 Post(s)
Liked: 34
I would just stick with the nx5 if you have a dedicated room. I was in the same boat as a dealer and spoke with one of the top calibrators in the country and he said based on his experience there wasn’t enough of a reason to pay the extra money for the nx7. More than happy with my nx5 after being calibrated.
Yamaha Aventage 3070 * Emotiva xpa5
Polk LSIM 707, 706, 703, 702, Rci85 and 65
Stereo Integrity HT18 (2) * Inuke 6000dsp
Panasonic UB820 * JVC NX5 * Silver Ticket 120” thin bezel
jmeitz is offline
post #8 of 11 Old 09-30-2019, 02:43 PM
blee0120's Avatar
Quoted: 995 Post(s)
Liked: 723
If you have a dedicated room, that is more of a reason to upgrade from the RS1000/NX5 to the RS2000/N7. It's not as dramatic pricewise as going up to the RS3000/NX9, which is double the cost of the RS2000/N7.
markmon1 likes this.
post #9 of 11 Old 09-30-2019, 07:56 PM
Quoted: 244 Post(s)
Liked: 227
I am throwing 24’ with my NX5 on a 133” 2.40. Panamorph paladin lens and SI screen. I’m not sure a few feet forward will be terribly beneficial let alone a more expensive JVC as far as brightness is concerned.
Bytehoven likes this.
RaceCarDriver is offline
post #10 of 11 Old 10-01-2019, 03:09 AM
markmon1's Avatar
Liked: 3996
If you have a dedicated room that's totally black anyway, you can just run that cabling along the ceiling coming out of where it's at now 6 feet forward to where the projector is at and hide it with a painted black channel. You'd probably never see it. My room is a pitch black cave and I have cables hidden along the sides of the walls. No one can even see them. Plus this is not a permanent install you could undo it at anytime if you hated it.
I ran a black CAT5 cable along the baseboard, up the black wall, and up to the projector for IP control no one can see that either. I'm sure you'll benefit more from the increased lumens of moving forward vs the occasional seeing the black cover of cables when the lights are on and the projector is off. Of course if this is a living room, forget what I said. The cosmetics will matter a lot.
post #11 of 11 Old 10-05-2019, 04:43 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7159 Post(s)
Liked: 7198
That's a great point! Can always get a longer power cord, just make sure its the proper gauge wire.......
Cleveland Plasma is offline
brightness , nx5 , nx7
