JVC RS620 question.....pics included - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-15-2019, 02:53 PM - Thread Starter
Quoted: 29 Post(s)
Projector has 160 hrs on it. The picture is AMAZING....I wouldn't have even seen this had I not been shifting the image a bit. Is this anything to worry about?
On the one photo its hard to see but there is a faint diagonal line. The other photo is self explanatory.
ID:	2628150   Click image for larger version
16x22 dedicated home theater
JVC DLA RS620
Pioneer Elite SC LX801/UDP LX500/Outlaw5000
B&W CM9 S2s, CM2 S2 center, DS6 surrounds
DIY 2.35:1 screen (127 inch)
maybelooking1 is offline
post #2 of 7 Old 10-16-2019, 09:15 AM
Mike Garrett's Avatar
Quoted: 12854 Post(s)
Liked: 10490
I don't recall ever seeing anything like that before. Do you only see this on the test pattern? Actual video content does not show any problem? I would still contact JVC.
Mike Garrett is offline
post #3 of 7 Old 10-16-2019, 11:29 AM - Thread Starter
Quoted: 29 Post(s)
only on the test pattern.
Actual video content looks perfect. No issues at all.
ohh and one other thing.....I checked today, it doesn't show up in the test pattern if the projector is in 16x9 mode. If it is adjusted for my 2.40:1 setting then it shows up.
JVC DLA RS620
post #4 of 7 Old 10-16-2019, 11:56 AM
Liked: 10490
The test pattern is meant to be viewed in 16:9 mode. What do you mean by adjusted?
post #5 of 7 Old 10-16-2019, 12:05 PM - Thread Starter
Quoted: 29 Post(s)
I have a lense memory for 2.40:1 where I have zoomed the lens and saved the position.
JVC DLA RS620
post #6 of 7 Old 10-16-2019, 01:04 PM
Liked: 10490
That should not make a difference with the test pattern.
post #7 of 7 Old 10-19-2019, 06:40 AM - Thread Starter
Quoted: 29 Post(s)
I figured it out. It wasn't a projector issue at all.
My screen (Sintra) was built in front of two windows. Well some light from the sun was reflecting off at shade behind the screen causing it. Checked it again last night and nothing there.
I figured the Sintra was thick enough sunlight wouldn't be an issue but the sun comes up on that side of the house and is really bright during the day.
JVC DLA RS620
