Projector Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-09-2019, 11:49 AM - Thread Starter
acho7's Avatar
Projector Upgrade
I am looking to upgrade my 10 year old Epson 8500UB. 4K not a must but desirable. Any suggestions welcome.
A7
acho7 is offline
post #2 of 14 Old 11-09-2019, 12:06 PM
skylarlove1999's Avatar
Quoted: 1031 Post(s)
Liked: 718
A7
Epson 5050
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #3 of 14 Old 11-09-2019, 02:29 PM
hd0823's Avatar
Quoted: 858 Post(s)
Liked: 1618
All depends on the budget also. I would look into the jvc nx5 or nx7
Sent from my SM-N950U using Tapatalk
hd0823 is offline
post #4 of 14 Old 11-09-2019, 09:38 PM
Mike Garrett's Avatar
Quoted: 12682 Post(s)
Liked: 10315
A7
What is your budget?
What size and aspect screen?
What fabric in your screen?
What is your room like?
Mike Garrett is offline
post #5 of 14 Old 11-10-2019, 05:42 AM - Thread Starter
acho7's Avatar
Projjector Upgrade
What is your budget? <3K
What size and aspect screen? 108"
What fabric in your screen? Goo paint
What is your room like? 12' X 23' - 8' ceiling
A7
acho7 is offline
post #6 of 14 Old 11-10-2019, 05:52 AM
lizrussspike's Avatar
Quoted: 1265 Post(s)
Liked: 1894
@acho7 , I have my rom close to yours. I started with a Optoma, which was decent(RBE, could not take it). The n went to Sony 40 ES, great in that space for 1080P. I then went to JVC RS420, and once I got it calibrated, and darkened the room, the picture got that much better. I would work with @Mike Garrett , as he can work with you to give you great advise, and maybe score a deal too. If you think that you may do more 4K viewing, then there are plenty of options, if 1080P, then you could score a great projector well below $1K!
lizrussspike is offline
post #7 of 14 Old 11-10-2019, 05:57 AM
markmon1's Avatar
Quoted: 5346 Post(s)
Liked: 3472
A7
Aren't you in the wrong forum then? Should be posting in the $3000 or under forum I'd think. It's a different crowd. Sorry, not trying to be a jerk. This was a serious comment. I only opened this thread cause I saws you were in the 3000+ forum so figured I'd chime in but when I saw your budget realized this was not a thread for me to participate etc.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #8 of 14 Old 11-10-2019, 06:19 AM - Thread Starter
acho7's Avatar
Good point. As it turns out, I could be either side of 3K. Sorry for my miscommunication.
A7
acho7 is offline
post #9 of 14 Old 11-10-2019, 06:20 AM - Thread Starter
acho7's Avatar
Thanks for the input. I'll try and connect with Mike.
A7
acho7 is offline
post #10 of 14 Old 11-10-2019, 07:51 AM
Liked: 10315
A7
I meant is your room light controlled, dark surfaces or did you have lots of ambient light. Anyway, for less than 3k, I would look at the Epson 5050 or a B-stock Sony/JVC. If you want new, the Epson 5050 would be your best choice. Nice performing projector for the money.
post #11 of 14 Old 11-10-2019, 01:19 PM - Thread Starter
acho7's Avatar
Projector Upgrade
OK, I'm sold on the Epson 5050UB. What ceiling mount to use?
acho7 is offline
post #12 of 14 Old 11-10-2019, 01:26 PM
Liked: 10315
My first choice would be the Chief RPM with Epson custom plate.
post #13 of 14 Old 11-11-2019, 07:29 AM - Thread Starter
acho7's Avatar
Thanks for all the help on this. One last item: My old 8500UB has component video cable inputs. The 5050UB does not accept these. Can I use a converter to HDMI with my current cables or do I need to run a new HDMI cable between my receiver and the new projector?
acho7 is offline
post #14 of 14 Old 11-11-2019, 07:39 AM
Liked: 718
The Epson is capable of accepting a 4K/60FPS signal. You will need a new 4K/60FPS capable HDMI cable. If your cable length needs to be over 25 ft I would suggest a Fiber Optic HDMI cable. Most cables of that length are directional so they will be labeled source and display.
