Wasted money? I1 display Pro to calibrate projecotr? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tnaik4
post #1 of 7 Old 11-12-2019, 06:21 PM - Thread Starter
TimHuey's Avatar
Quoted: 217 Post(s)
Liked: 57
I just ordered a I1 display Pro to calibrate a future projector probably a Epson 6050. However as I considered my purchase I can't figure out how it could possibly be any use in calibrating a projector on a grey screen. If its sensor is grabbing the light from the projector and not the altered reflected light from the grey colored screen how can you calibrate the projector for your particular screen.
The calibration section mostly talks about emmisive display devices not projected ones. Is there a way to use i1 display pro to adjust the projector to project onto a grey screen accurately?
HTPC. Onkyo 636, Polk audio speakers and Klipsch sub. KHO-7 Outdoor speakers. Homeseer homecontrol over Z-wave.
TimHuey is offline
post #2 of 7 Old 11-12-2019, 06:35 PM
Quoted: 497 Post(s)
Liked: 287
Originally Posted by TimHuey View Post
I just ordered a I1 display Pro to calibrate a future projector probably a Epson 6050. However as I considered my purchase I can't figure out how it could possibly be any use in calibrating a projector on a grey screen. If it sensor is grabbing the light from the projector and not the altered reflected light from the grey colored screen how can you calibrate the projector for your particular screen.
maybe i m missing something , but why cant you calibrate the image of the screen, that is how i do it with my C6 HDR 2000 meter .
Brian Hampton likes this.
JVC DLA X590/RS440
BenQ LK970
tnaik4 is offline
post #3 of 7 Old 11-12-2019, 06:41 PM - Thread Starter
TimHuey's Avatar
Quoted: 217 Post(s)
Liked: 57
If the sensor is between the projector and screen, resting on the screen, how does the light reflect into the sensor from the screen?
TimHuey is offline
post #4 of 7 Old 11-12-2019, 08:53 PM
mpyw's Avatar
Quoted: 103 Post(s)
Liked: 32
You need to place the sensor like 1-2 feet off the screen and just careful of not reading the meter's shadow
To be or NOT to be......YOU are WHO you ARE
mpyw is offline
post #5 of 7 Old 11-12-2019, 09:04 PM
blee0120's Avatar
Quoted: 934 Post(s)
Liked: 649
I sent you a PM to help you
blee0120 is online now
post #6 of 7 Old 11-12-2019, 09:32 PM - Thread Starter
TimHuey's Avatar
Quoted: 217 Post(s)
Liked: 57
Yeah I just saw a video on YouTube. They placed the sensor on a tripod pointing not at the projector but at the screen. Now it makes sense. I didn't know it could read from a distance.
TimHuey is offline
post #7 of 7 Old 11-13-2019, 03:02 AM
Quoted: 497 Post(s)
Liked: 287
yes u dont rest it on the screen, put the meter facing the screen 2feet away and tilt it upwards a little so u dont hit the meter shadow.
JVC DLA X590/RS440
BenQ LK970
tnaik4 is offline
