Are there many projectors that support Dolby Vision yet? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By m0j0
post #1 of 8 Old 12-18-2019, 04:53 PM - Thread Starter
Quoted: 275 Post(s)
Just wondering how many projectors out there support Dolby Vision?
sound2017 is offline
post #2 of 8 Old 12-18-2019, 05:15 PM
m0j0's Avatar
Quoted: 922 Post(s)
Liked: 1103
None that I know of, and probably not likely to be any in the near future either.
m0j0 is offline
post #3 of 8 Old 12-18-2019, 05:56 PM
Kris Deering's Avatar
Quoted: 4139 Post(s)
Liked: 7308
Probably never going to happen from what I’ve heard from insiders.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #4 of 8 Old 12-18-2019, 06:00 PM
Musty Hustla's Avatar
Quoted: 39 Post(s)
Is there a reason?
Denon x4400H, Klipsch RP-450C center, RP6000, Onkyo HTiB surrounds, SVS PB13 and PC2000
LG OLED65B7A
Musty Hustla is offline
post #5 of 8 Old 12-18-2019, 06:59 PM
m0j0's Avatar
Quoted: 922 Post(s)
Liked: 1103
Search the forums, it’s been discussed a few times. Some posts saying Dolby hasn’t gotten around to setting a standard for projectors, some saying they don’t have a good way to get screen data required like they do from flat panels, others said that by the time they would get around to it the technology will be obsoleted by micro led panels, etc. Don’t really know the answer, if there is one.
Mkwillia1 likes this.
m0j0 is offline
post #6 of 8 Old 12-18-2019, 08:17 PM - Thread Starter
Quoted: 275 Post(s)
Ok thanks guys!
post #7 of 8 Old 12-18-2019, 09:13 PM
Bytehoven's Avatar
Quoted: 1606 Post(s)
Liked: 1260
None with DV built in... but there is the DV LLDV hack, where a capable source device can be spoofed into processing a DV, HDR10 or SDR source with the Player LED Do;by Profile 5 Layer DV processing, which then outputs a HDR10 signal with a PQ curve to any HDR10 compliant display.
Using this DV LLDV process (ATV4K, Oppo 203 or Sony x800m2 --> Vertex2 -> x990) works very well for me DV and HDR10 content.
Follow the link in my sig for discussion on this hack.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - Vertex2 - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #8 of 8 Old 12-18-2019, 09:17 PM
Bytehoven's Avatar
Liked: 1260
Originally Posted by Musty Hustla View Post
Is there a reason?
Might be licensing snafu... would be doable, since Dolby and Sony worked out the Profile 5 Layer processing for any Sony display (A1 OLED) which lacks DV process all together.
Sony could certainly incorporate whatever they do on the A1 OLED into their projectors. Maybe some fine tuning for more limited nit range, but it definitely works.
