New HT build Projector help - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Mike Garrett
post #1 of 9 Old 01-07-2020, 07:04 AM - Thread Starter
thisismyname123's Avatar
Quoted: 146 Post(s)
Liked: 56
In the process of framing out my basement for a dedicated theater.
Room will be about 23'L x 12.5'W x 7.5'H
I am thinking a 120" width AT screen or thereabouts. 2 rows of seating, front row about 8 feet viewing distance.
I've never had a projector before.
Talked with 2 local HT companies and they both are recommending the Sony VPL-VW295ES 4K HDR projector.
I don't really have a huge issue with the $$ of that unit but do I need to jump right in with that? Are there projectors on par or pretty close in most specs for half the price or so?
thisismyname123 is offline
post #2 of 9 Old 01-07-2020, 07:20 AM
Mike Garrett's Avatar
Quoted: 12996 Post(s)
Liked: 10632
Need to be talking more than just projector. With 8' viewing distance, not many AT screens I would consider, due to seeing the weave from that distance. I would look at DreamScreen V6, Seymour AV UF and Screen Excellence NEO. As for projector, I would look at Sony VW295, Epson 6050 and JVC RS1000.
Mike Garrett is offline
post #3 of 9 Old 01-07-2020, 07:22 AM - Thread Starter
Quoted: 146 Post(s)
Liked: 56
Oh really? I didn't know that would be an issue to see the weave. Thanks I'll check into that.
Sent from my Pixel 4 using Tapatalk
post #4 of 9 Old 01-07-2020, 08:16 AM
Run&Gun's Avatar
Quoted: 27 Post(s)
That is roughly the size of my den, 20’x12’x8’, but your seating distance will be approximately half what mine currently is(~16’-17’) and I have a 120” screen, so I think you’ll be really happy with that at that distance.
Run&Gun is offline
post #5 of 9 Old 01-07-2020, 10:10 AM - Thread Starter
Quoted: 146 Post(s)
Liked: 56
My 2nd row will be about 17'
post #6 of 9 Old 01-09-2020, 03:55 PM - Thread Starter
Quoted: 146 Post(s)
Liked: 56
Anyone know anything about Echo & Optics?
Looks like they sell through Newegg.com
The Sony VPLVW295ES is over $1k less than list price....is this a legit place?
https://www.newegg.com/p/26X-000C-00...E&gclsrc=aw.ds
post #7 of 9 Old 01-09-2020, 05:50 PM
Run&Gun's Avatar
Quoted: 27 Post(s)
Just measured mine off today. ~16.5' from the screen. Your second row will be fine and your first will be great.
Run&Gun is offline
post #8 of 9 Old 01-09-2020, 05:50 PM
Liked: 10632
I can tell you that they are not an authorized Sony or JVC dealer.
thisismyname123 likes this.
post #9 of 9 Old Yesterday, 02:22 AM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 4005 Post(s)
Liked: 1884
At a 8' viewing distance the smoothest AT Material you can find that is not overly expensive is Milliskin Spandex.
Consider the new LVC DLP Laser. It has the lumen to drive into a 0.7 gain surface and do a great job of it.
MississippiMan is offline
