Need help with finding a 4k projector for my 2.39 CIH screen - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #31 of 116 Old 01-08-2020, 08:15 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@coderguy - OK, cheers, mate! EDIT: Whoops, would be 8" down. So 4 on the sides?
K, I still have yet to dive into reviews, and the AVS thread too.
EDIT - Deleted price discussion. Did not know it was not allowed....
I can buy this from AVS, no?
HudsonK is offline
post #32 of 116 Old 01-08-2020, 08:19 PM
Quoted: 952 Post(s)
Liked: 270
Originally Posted by HudsonK View Post
@coderguy - Ok. I will see what it comes down to with the current screen. How wide is the tape? I will be losing 6 inches diagonal according to Noob. Not sure yet what than means on W & H.
The Carada has a really nice 3.5" to 4" frame with excellent black-out material. Nothing shows on it.
I could sell the screen, yes. Even give my current setup to a friend if someone has the room...
The height of the 144" screen is 55.6" and 132.8" width.
The height of the 139.7" screen is 53.2" and 127.2" width.
The difference is 2.4" (total) vertical and 5.6" horizontal.
Keep in mind that this may not be accurate to the mm and there may be some variance as coderguy mentioned.
If you want to do the math yourself use this site: http://screen-size.info/
Just input 2.39 and 1 in the Aspect Ratio boxes and only one value in any of boxes below, and the rest will auto populate.
Velvet tapes are dark and can absorb light, but if that is not enough panels can be made with even darker velvet.
I'm not too familiar with these tapes but I do know that Carl's (screen manufacturer) makes velvet tapes:
https://www.carlofet.com/shop/black-felt-tape
The thread where this is being discussed was posted above, but here it is again, linked to a few types of velvet:
https://www.avsforum.com/forum/24-di...l#post58225900
Gluing velvet directly to the screen might not be the best idea.
noob00224 is offline
post #33 of 116 Old 01-08-2020, 08:20 PM
coderguy's Avatar
Quoted: 2884 Post(s)
Liked: 1510
@HudsonK
We are not allowed to discuss pricing in here, you can create a thread in the Great Found Deals section, though not many people will discuss JVC pricing in general. Those are going to be from unauthorized dealers most likely. Yes, I would probably from AVS.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #34 of 116 Old 01-08-2020, 08:21 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@noob00224 - Gotcha. Yeah I was thinking of being safe and going to a 136" 2.39-1. Thanks, Noob!!
HudsonK is offline
post #35 of 116 Old 01-08-2020, 08:23 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@coderguy - Oh, I did not know. Apologies. Ok, I will look into AVS then. I want to make sure I have proper support and warranty for sure....
HudsonK is offline
post #36 of 116 Old 01-08-2020, 08:23 PM
blee0120's Avatar
Quoted: 976 Post(s)
Liked: 699
@blee0120 - Very cool! Hope you love your new screen. Yeah I love the impact of the 144". It's great. If I slip to 136 I will still be happy. Especially since I've gone 8 years without an upgrade. It sounds like this will be a big step...
I'm still debating a scope screen vs a 16:9 screen. The documentary discs are absolutely amazing. Seven Wonders of the World, Turtle Oddessy, and Planet Earth are just amazing but do not know how the experience will be. It's tough.
blee0120 is offline
post #37 of 116 Old 01-08-2020, 08:24 PM
coderguy's Avatar
Liked: 1510
It's not me that cares, it's the mods, I'm just noting that when they see pricing stuff sometimes they move the thread or delete the post. You might want to edit it out.
coderguy is offline
post #38 of 116 Old 01-08-2020, 08:26 PM
coderguy's Avatar
Liked: 1510
Do the motorized masking, that's the end-all-be-all. You can do it like Markmon1 did it if you want 16:9, you can even do 4-way motorized masking.
However, a scope screen is definitely easier to do motorized masking than a 16:9, as the horizontal movement is simpler for actuators.
HudsonK likes this.
coderguy is offline
post #39 of 116 Old 01-08-2020, 08:35 PM
Mike Garrett's Avatar
Quoted: 13007 Post(s)
Liked: 10648
I would get the projector and see how much of the screen you can fill. be sure and use zoom on the RS2000. Then you can decide if you want to mask off the screen or look for ways to extend the throw. If you just need two or three inches, you could do a cutout in the wall. I did this for my JVC RS4500.
Mike Garrett is online now
post #40 of 116 Old 01-08-2020, 08:40 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@Mike Garrett - Thank you, Mike! I sent a message from the contact page on AVS regarding the PJ and a couple of questions. Is it appropriate to speak with you about purchasing this model? I see your email, and mine is [email protected].
skylarlove1999 likes this.
HudsonK is offline
post #41 of 116 Old 01-08-2020, 08:41 PM
blee0120's Avatar
Quoted: 976 Post(s)
Liked: 699
I might consider that. Thanks
blee0120 is offline
post #42 of 116 Old 01-08-2020, 08:43 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@blee0120 Good luck, Blee!
HudsonK is offline
post #43 of 116 Old 01-09-2020, 07:38 AM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
Woohoo! I just ordered the JVC RS2000 from Mike at AVS! Soooo pumped.
Need a little advice for a 4k blu ray player. I stumbled upon people raving about the Panasonic UB820 and UB9000 player for projectors with its great processing and HDR support. Am I a go on that? Or would you guys recommend anything else?
Mike said I can pick up the UB9000 through them.
Cheers!
HudsonK is offline
post #44 of 116 Old 01-09-2020, 07:48 AM
skylarlove1999's Avatar
Quoted: 1316 Post(s)
Liked: 964
Woohoo! I just ordered the JVC NX7 from Mike at AVS! Soooo pumped.
Cheers!
I own the 820. It is a great player. I would buy the 420 at this time. The 820 adds Dolby Vision. Not needed for a projector. The 9000 has the build quality of an Oppo with some upgrades for audiophiles. The 9000 also has the ability to set the nits for the player at 350. The lowest the 420 and 820 can be set is 500 nits. With the dynamic tone mapping of the JVC projector I don't believe the nits setting makes that much of a difference. With projectors that have just static tone mapping the nits setting can be a great HDR performance enhancer. I would save yourself the money and buy some more 4K discs. Just my opinion.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #45 of 116 Old 01-09-2020, 07:56 AM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@skylarlove1999 Ok, thanks man!
HudsonK is offline
post #46 of 116 Old 01-10-2020, 05:29 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
Hi guys,
I ordered 73 4k movies the past couple of nights. Woohoo!
I got a bunch today and realise I messed up! I accidentally bought two of The Martian, and two of The Revenant.
If any of you who helped here do not have these movies, or want one, give me a pm. I will send them off to you for free. I will also accept anyone else who reads this, but if I hear from helpers in here they will get first dibs. I wanted to do this before I go post in the video section, which is where it belongs. I am sure I will get takers there.
Cheers!
Hudson
HudsonK is offline
post #47 of 116 Old 01-10-2020, 07:45 PM
Liked: 964
Hi guys,
Cheers!
Hudson
Very kind and generous of you. I have both. Great HDR presentation on both . One for natural highlights like sun and snow and fire. The other for great man made highlights lighting lasers and computer screens.
post #48 of 116 Old 01-10-2020, 07:51 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
Well people in here like yourself really helped me a ton. Too bad you have both. Thanks for the quick info on them.
I am soooo glad I put off seeing the Revenant....
HudsonK is offline
post #49 of 116 Old 01-10-2020, 07:53 PM
Liked: 964
Honestly you will be blown away by both of them with your new setup. Blown away. Better than local multiplex. Way better.
post #50 of 116 Old 01-10-2020, 07:59 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@skylarlove1999 - I cannot tell you how excited I am. Stop making it worse, lol. I am still Blu Ray Shopping. My wife freaking hates me right now.
New to the thread? I have two good, new and free 4k movies to send to you - read up above!
HudsonK is offline
post #51 of 116 Old 01-10-2020, 08:02 PM
Liked: 964
New to the thread? Two free movies - read up above!
I know I am awful. LOL. I am living vicariously through you. I own the Epson 6050 but I really want to upgrade to the JVC NX7 but wife would probably divorce me. LOL . So I have to wait. I am really excited for you. Is that weird? LOL.
post #52 of 116 Old 01-10-2020, 08:12 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@skylarlove1999 No, it's not weird. I would feel the same in your shoes, hah. But man...my projector is so much worse than your current one. Start saving, man! In the mattress if you have to! LOL. I will definitely give you a message when I'm set up, and maybe a pic of my space.
HudsonK is offline
post #53 of 116 Old 01-13-2020, 02:23 PM
ScottAvery's Avatar
Quoted: 772 Post(s)
Liked: 223
Spend the money you would spend on the smaller screen to get a horizontal expansion anamorphic lens and then you do not need to change screen size.
Edit: I somehow missed a page of this thread. You made a good decision anyway!
ScottAvery is online now
post #54 of 116 Old 01-13-2020, 02:24 PM
Liked: 964
So did your new projector arrive today?
post #55 of 116 Old 01-13-2020, 02:29 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@skylarlove1999 - it did! It's sitting in the box. I had to run out. But I just got home a while ago. My UB9000 Panny arrived too. Time to carry downstairs and have a look. =)
I have to do a fair bit of work to set it up. A friend is going to help cut a hole in my back wall to mount the PJ on a shelf in my unfinished basement area behind my HT. I am very lucky I am able to do this and fill my screen. I also have a 2.35:1 screen, not 2.39:1...I misremembered that. So getting back further is even more important so 2.39's and 2.40's fit properly.
Mike Garrett and noob00224 like this.
HudsonK is offline
post #56 of 116 Old 01-13-2020, 02:32 PM
Liked: 964
I have to do a fair bit of work to set it up. A friend is going to help cut a hole in my back wall to mount the PJ on a shelf in my unfinished basement area behind my HT. I am very lucky I am able to do this and fill my screen. I also have a 2.35:1 screen, not 2.39:1...I misremembered that. So getting back further is even more important so 2.39's and 2/40's fit properly.
Can't wait to hear your impressions!!!
HudsonK likes this.
post #57 of 116 Old 01-13-2020, 02:33 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
OMG, you're telling me. I probably won't be all set up until the weekend. I will let you know!
HudsonK is offline
post #58 of 116 Old 01-13-2020, 03:08 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
BTW, another big thank you to @Mike Garrett . He was able to help with so many questions I had. And my 4k player and PJ came so fast, and the boxes in perfect condition. Buy from AVS, people.
Ok, unboxing time!
Mike Garrett likes this.
HudsonK is offline
post #59 of 116 Old 01-13-2020, 03:09 PM
Liked: 964
Ok, unboxing time!
Yes Mike is the man.
HudsonK likes this.
post #60 of 116 Old 01-13-2020, 03:10 PM - Thread Starter
HudsonK's Avatar
Quoted: 59 Post(s)
Liked: 35
@skylarlove1999 - And thank you for bringing him to my thread. I really appreciate it, man.
HudsonK is offline
