Need help with finding a 4k projector for my 2.39 CIH screen - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #61 of 101 Old 01-14-2020, 05:10 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Oh. My. God.
Here's a pic of the new RS2000 and the Panny UB9000 (hard to see) from AVS in my basement HT/entertainment room. The JVC is just massive. Controller for scale. I won't be set up until Saturday. Gotta cut out a hole the back wall and mount the PJ on a shelf in my unfinished basement area to the right of what you see. The old Panny AE8000u is small and saddened...
I. CAN'T. WAIT.
Craig Peer and Mike Garrett like this.
HudsonK is online now
post #62 of 101 Old 01-14-2020, 05:38 AM
coderguy's Avatar
Quoted: 2828 Post(s)
Liked: 1499
Pretty good room, not bad at all. JVC should look great in that room.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is online now
post #63 of 101 Old 01-14-2020, 01:58 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Thanks coderguy! I will try to take a better picture later.
post #64 of 101 Old 01-14-2020, 02:51 PM
skylarlove1999's Avatar
Quoted: 1288 Post(s)
Liked: 941
Originally Posted by HudsonK View Post
Oh. My. God.
I. CAN'T. WAIT.
Very nice looking theater room. Did you take off from work on Friday? LOL.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #65 of 101 Old 01-14-2020, 03:13 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
@skylarlove1999 I....I think I feel something coming on.....
post #66 of 101 Old 01-15-2020, 09:11 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
IT'S HAPPENING!
And yes, I just vacuumed the cobwebs. Lol. Damned basements....
ID:	2670276   Click image for larger version
post #67 of 101 Old 01-15-2020, 09:14 AM
Liked: 941
IT'S HAPPENING!
I think you should be feeling better shortly. LOL. Can't wait to see it.
HudsonK likes this.
post #68 of 101 Old 01-15-2020, 10:23 AM
Mike Garrett's Avatar
Quoted: 12996 Post(s)
Liked: 10632
IT'S HAPPENING!
I am not sure that shelf bracket will be beefy enough. It looks like it could only support a few hundred pounds each.
rossandwendy likes this.
Mike Garrett is offline
post #69 of 101 Old 01-15-2020, 10:28 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Originally Posted by Mike Garrett View Post
I am not sure that shelf bracket will be beefy enough. It looks like it could only support a few hundred pounds each. [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
Haha. It is incredibly strong. I bought a $55 8x4 sheet of incredibly hard and smooth plywood. I am taking no chances!! I am sure I could sit on it!
post #70 of 101 Old 01-15-2020, 10:32 AM
Liked: 10632
[QUOTE=HudsonK;59103258]Haha. It is incredibly strong. I bought a $55 8x4 sheet of incredibly hard and smooth plywood. I am taking no chances!! I am sure I could sit on it![/QUOTE]
Yep. I do overkill also. And why not, it hardly costs anymore to make it extra sturdy.
Craig Peer likes this.
post #71 of 101 Old 01-15-2020, 10:37 AM
Craig Peer's Avatar
Quoted: 7430 Post(s)
Liked: 8987
IT'S HAPPENING!
Nice ! More throw distance and the projector noise in another room ( assuming there will be a front closure panel ).
Craig Peer is offline
post #72 of 101 Old 01-15-2020, 10:37 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Yeah. It is an absolute no-brainer when you"ve just spend so many thousands of dollars...
post #73 of 101 Old 01-15-2020, 10:40 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Originally Posted by Craig Peer View Post
Nice ! More throw distance and the projector noise in another room ( assuming there will be a front closure panel ). [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Yes! I truly needed this extra 20 inches or so. I am going to be golden...
post #74 of 101 Old 01-15-2020, 11:15 AM
Craig Peer's Avatar
Liked: 8987
And your setup is easier to work on than having a projector in a " hush box ". You have a similar arrangement to my projector closet. Well done !
post #75 of 101 Old 01-15-2020, 12:23 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Ah cool. How did it work going through a closet?
I am sooo lucky to have unfinished space behind my basement HT....
post #76 of 101 Old 01-15-2020, 12:40 PM
Craig Peer's Avatar
Liked: 8987
Check my photos ( in my signature ). Yes - you lucked out. It's always great when things just work out !
HudsonK likes this.
post #77 of 101 Old 01-15-2020, 01:49 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
I just went through your entire thread. Magnificent theater and work. I just ordered my first acoustic panels myself. Very much looking forward to implementing them....
Well done!
Hey btw, I was skimming a bit. Do you have powered curtains over your screen? Any recommendation there? I'd love it for the look and for masking my CIH 2.35...
H
post #78 of 101 Old 01-15-2020, 02:50 PM
Craig Peer's Avatar
Liked: 8987
Well done!
H
No need for powered curtains since they are both electric screens. If I want just curtains, I just roll the screens up. But the theater has morphed into a dedicated theater, so one or the other of the screens usually stay down.
post #79 of 101 Old 01-15-2020, 06:08 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Well, dangit. I am stuck in 1080p. My RX-a2020 does not pass 4k. Gotta wait until Friday for the 3080 to come in.
Hard to give a first impression so far. I've not turned off the lights. I have been going through all the menus. Been really struggling to get a square image. The bottom left was stepping out when everything else was square. I shifted the position of the PJ, played with the feet, digitally shifted, and had to compromise with a -2 keystone so far (no trapezoid adjustments that I found.
Anyway. Quite a bit of punch in low eco mode here. I can't wait to hit 4k and HDR on Friday. Till then, I'll work on the physical stuff that I can in the HT. Atmos speakers are late and come tomorrow. Plenty to do.
post #80 of 101 Old 01-15-2020, 09:10 PM
coderguy's Avatar
Liked: 1499
H
He has dual screens so he does not use direct masking. I doubt most curtains would be firm enough to keep a perfect edge for masking. You could put flocked velvet (it's pretty thick) on a motorized curtain setup, but motorized curtain setups are bulky and hard to know what you're buying, and they can be lacking in perfect positioning. The default easy way for SCOPE MASKING is to buy a dual linear actuator motor (already synchronized) and one that comes with a remote. Almost all the remotes are RF though, so you'll have to initially use their remote unless you convert the signal. A stepper motor is smaller and probably more accurate, there are numerous youtube videos of people that made pulley systems (some disadvantages to that though).
For scope screens to a masked 16:9 & 2:1, you can also just make manual masking panels tall enough to just lean them against the screen.
See this thread for some ideas...
https://www.avsforum.com/forum/24-di...l#post59075462
post #81 of 101 Old 01-15-2020, 09:14 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
@coderguy Thanks man! Yeah I planed on static panels with magnets when I can get to it. But my projector screen is recessed, so I could track curtains really tight to the screen. Though I would look at what's out there...
post #82 of 101 Old 01-15-2020, 09:18 PM
coderguy's Avatar
Liked: 1499
Magnets are not really necessary for Scope screens, easier to just lean the panels against the screen. You can use magnets if you want it perfectly flush, but it will not look any different from seating position with or without magnets for us scope owners. The great thing about panels is you just set them to the side and they completely blend in with a TBV wall, you don't even know they are there.
It's possible to use curtains, but there is just no way to know if whatever you bought would work.
post #83 of 101 Old 01-16-2020, 07:42 AM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
@coderguy - ok thanks!
Ok, guys. Had the new PJ fired up last night.
I had to bypass the old RX-a2020 and plug directly from the UB9000 to the RS2000 in order to get 4k. And send optical audio to the a2020 from the UB9000.
I threw in Apollo 13 UHD BR. I have seen this a lot, and didn't want to ruin a different movie with a partial test viewing. And the contrast, colours, and black level were glorious. Utterly smashes my AE8000u. Space looks like space finally, and it must take a massive cost upgrade to get better than this.
The picture did look soft, though. And very grainy. If you guys can feed back on this title, that would be great. I think it was largely the source, especially the grain. Because on pause, going to the animated Universal screen, it looked quite sharp and clean, and of course, with excellent contrast and blacks. Really punchy.
But I did have trouble on the test screen with lines, getting a sharpness with focus. It looked soft, and also showed misconvergence on both sides of the white lines. The misconvergence was a couple of mm on either side of those white guidelines (145" 2.35:1 screen at 12 feet viewing, 16 feet from the PJ). But I think I read somewhere that convergence improves with projector break-in? Is that right?
Anyway, really happy so far. And Mike Garret was again, helping me late into the night with my trouble updating the PJ firmware. Ended up being an issue with the USB stick I was using. It updated perfectly with a new stick, which I think required less power. The first stick was puking on data transfer even from my laptop.
Anyhow, look forward to feedback on the above images.
Cheers!
Hudson
post #84 of 101 Old 01-16-2020, 09:11 AM
Liked: 10632
Remove the keystone.
With left bottom corner outside the screen you need to do the following.
1. Reduce picture size so that everything is inside the frame.
2. raise left side of projector until error is equal at top and bottom left corner. This will give you a sloped top and sloped bottom line of the image. Slopes should be about the same.
3. Physically rotate projector toward the right corner, until the top and bottom lines are parallel with the screen.
4. Horizontal lens shift the image back onto the screen.
5. zoom the image to fit the screen.
post #85 of 101 Old 01-16-2020, 02:23 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
@Mike Garrett
Hi Mike, I have not gotten to this yet. Don't you mean to raise the right side of the projector? Would that not tuck in the bottom left corner toward center? I picture that if I raise the left side, that it will exacerbate the bottom left corner being wider.
post #86 of 101 Old 01-16-2020, 02:38 PM
Craig Peer's Avatar
Liked: 8987
hi there is a lot of film frame in that movie, a great film but not the best UHD out there.
If you want to see a reference UHD pick up Mortal Engines. this was filmed in 8K with Red cameras and has a 4K DI. It's a visually spectacular film and a good title to demonstrate what the projector is capable of.
https://www.amazon.com/Mortal-Engine.../dp/6317640173
I've picked that up but haven't watched it yet. Other good 4K demo discs -
Alita Battle Angel
Logan Lucky
Deadpool 2
Hacksaw Ridge
Baby Driver
Get Out
post #87 of 101 Old 01-16-2020, 02:42 PM
Liked: 941
Alita Battle Angel
Logan Lucky
Deadpool 2
Hacksaw Ridge
Baby Driver
Get Out
Logan is pretty pristine video as well in 4K HDR.
post #88 of 101 Old 01-16-2020, 03:24 PM
zombie10k's Avatar
Quoted: 5490 Post(s)
Liked: 5919
Alita Battle Angel
Logan Lucky
Deadpool 2
Hacksaw Ridge
Baby Driver
Get Out
This is worth an import from Amazon UK if you get a chance, it's one of the best i've seen yet from this series. not avail in the US until mid-march
https://www.amazon.co.uk/Seven-World.../dp/B07W4D6TRZ
zombie10k is offline
post #89 of 101 Old 01-16-2020, 08:06 PM - Thread Starter
HudsonK's Avatar
Quoted: 52 Post(s)
Liked: 31
Thanks guys. I have these from that list:
Alita
Logan
DP 1&2
Hacksaw Ridge
My Yammy 3080 came today. Doesn't fit in my damned AV rack (open shelf). The second shelf is just too short, and I gotta keep the 2020 which doesn't fit there either. You guys have any recommendations for racks with good shelf height that are open?
post #90 of 101 Old 01-16-2020, 08:15 PM
Liked: 941
Alita
Logan
DP 1&2
Hacksaw Ridge
I have used these in the past. Modular and versatile. Only comes with two shelves but you can order more. There are also taller ones for more components. That is the 1620 model.
https://www.crutchfield.com/S-LPBUIw...hoC1w8QAvD_BwE
HudsonK likes this.
