Upgrade for JVC RS4810 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-24-2020, 12:46 AM - Thread Starter
Jackson.'s Avatar
Liked: 3
I have gotten the urge to upgrade. But reading through the forums is making me second guess everything.
I currently have a completly light controlled room throwing a 110" image from 13 feet away using a white on black spandex screen.
My plan was to upgrade to a JVC X550R for the improvement in E-shift and ability for HDR. With my RS4810 being calibrated by Chad B and having a greater native contrast than the X550R will I even notice a difference?
Marantz SR6013 DIYSG 1099s Volt 6s Dayton PA-460s Inuke 3000 MiniDSP 2x4
Jackson. is offline
post #2 of 8 Old 01-24-2020, 12:55 AM - Thread Starter
Jackson.'s Avatar
Liked: 3
If the X550R isn't an upgrade I'd be interested in a new projector for around the $1200 mark in the classifieds
Jackson. is offline
post #3 of 8 Old 01-24-2020, 01:48 AM
markmon1's Avatar
Quoted: 5859 Post(s)
Liked: 3933
Originally Posted by Jackson. View Post
Currently selling my JVC RS4810 in classifieds as I have gotten the urge to upgrade. But reading through the forums is making me second guess everything.
The x550R will be a decent upgrade in terms of brightness for sure. But contrast it may not be. If you're going used, I'd look for an RS500 / X750R, RS520 / x790R, RS540 / x790R or better. These are all going here on this site for under $2000 used I believe. The step up from the RS4810 to the RS500 is really dramatic in my opinion as it both majorly increases contrast and at the same time increases brightness.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is online now
post #4 of 8 Old 01-24-2020, 02:14 AM - Thread Starter
Jackson.'s Avatar
Liked: 3
Though I would love to get an RS500 it is definitely out of my budget. Should I simply keep the RS4810 and upgrade to the X700 series later down the line?
Jackson. is offline
post #5 of 8 Old 01-24-2020, 07:16 AM
markmon1's Avatar
Liked: 3933
Not X700, X750. I think if you are patient you can find an X750 / RS500 used around $1500. Is that out of your budget? Did you include the resale of your RS4810 as part of our budget?
post #6 of 8 Old 01-24-2020, 07:29 AM - Thread Starter
Jackson.'s Avatar
Liked: 3
Resale value was included with the budget. So the X750 is out of the budget.
Jackson. is offline
post #7 of 8 Old 01-24-2020, 07:59 AM - Thread Starter
Jackson.'s Avatar
Liked: 3
Would it be an upgrade to a higher end projector in the E-shift 3 lineup be worth it? Say X700 or X900? That way I am getting the increase in native contrast at least and E-shift.
Jackson. is offline
post #8 of 8 Old 01-24-2020, 08:36 AM
DavidHir's Avatar
Quoted: 2643 Post(s)
Liked: 2352
I owned an RS4810 for almost three years. Later moved to an RS4910, RS500, and RS440.
If you own the RS4810, I don't think it's worth going to the RS4910 or a 2014 year model. Go to an RS4XX or RS5XX.
DavidHir is offline
